HEF4077B
Quad 2-input EXCLUSIVE-NOR gate
Rev. 6 — 14 March 2017
1
Product data sheet
General description
The HEF4077B is a quad 2-input EXCLUSIVE-NOR gate. The outputs are fully buffered
for the highest noise immunity and pattern insensitivity to output impedance.
The HEF4077B operates over a recommended VDD power supply range of 3 V to 15 V
referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or
another input.
2
Features and benefits
3
Fully static operation
5 V, 10 V, and 15 V parametric ratings
Standardized symmetrical output characteristics
Specified from -40 °C to +85 °C
Complies with JEDEC standard JESD 13-B
Ordering information
Table 1. Ordering information
Type
number
Package
Temperature range
Name Description
HEF4077BT
-40 °C to +85 °C
SO14
4
Version
plastic small outline package; 14 leads; body width 3.9 mm SOT108-1
Functional diagram
1
2
1A
1B
1Y
3
5
6
2A
2B
2Y
4
8
9
3A
3B
3Y
10
12
13
4A
4B
4Y
11
aaa-012674
Figure 1. Functional diagram
1A
1B
Figure 2. Logic diagram (one gate)
1Y
aaa-012675
HEF4077B
Nexperia
5
Pinning information
5.1 Pinning
HEF4077B
1A
1
14 VDD
1B
2
13 4B
1Y
3
12 4A
2Y
4
11 4Y
2A
5
10 3Y
2B
6
9
3B
VSS
7
8
3A
aaa-012676
Figure 3. Pin configuration
5.2 Pin description
Table 2. Pin description
Symbol
Pin
Description
1A to 4A
1, 5, 8, 12
input
1B to 4B
2, 6, 9, 13
input
1Y to 4Y
3, 4, 10, 11
output
VSS
7
ground (0 V)
VDD
14
supply voltage
6
Functional description
Table 3. Functional table
[1]
Output
Input
nA
nB
nY
L
L
H
L
H
L
H
L
L
H
H
H
[1]
H = HIGH voltage level;
L = LOW voltage level
HEF4077B
Product data sheet
All information provided in this document is subject to legal disclaimers.
© Nexperia B.V. 2017. All rights reserved.
2 / 11
HEF4077B
Nexperia
7
Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to VSS = 0 V (ground).
Symbol Parameter
Conditions
Min
Max
Unit
-0.5
+18
V
±10
mA
-0.5
VDD + 0.5
±10
mA
VDD
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
II/O
input/output current
±10
mA
IDD
supply current
50
mA
Tstg
storage temperature
-65
+150
°C
Tamb
ambient temperature
-40
+85
°C
Ptot
total power dissipation
500
mW
100
mW
Min
Max
Unit
VI < -0.5 V or VI > VDD + 0.5 V
VO < -0.5 V or VO > VDD + 0.5 V
Tamb = -40 °C to +85 °C
SO14 package
P
[1]
power dissipation
V
per output
[1]
For SO14 package: Ptot derates linearly with 8 mW/K above 70 °C.
8
Recommended operating conditions
Table 5. Operating conditions
Symbol Parameter
Conditions
VDD
supply voltage
3
15
V
VI
input voltage
VDD
V
Tamb
ambient temperature
in free air
-40
+85
°C
Δt/ΔV
input transition rise and fall
rate
VDD = 5 V
3.75
μs/V
VDD = 10 V
0.5
μs/V
VDD = 15 V
0.08
μs/V
HEF4077B
Product data sheet
3 / 11
HEF4077B
Nexperia
9
Static characteristics
Table 6. Static characteristics
VSS = 0 V; VI = VSS or VDD unless otherwise specified.
Symbol Parameter
VIH
VIL
VOH
VOL
IOH
IOL
HIGH-level
input voltage
LOW-level
input voltage
HIGH-level
output voltage
LOW-level
output voltage
HIGH-level
output current
LOW-level
output current
II
input leakage
current
IDD
supply current
CI
input capacitance
HEF4077B
Product data sheet
Conditions
Tamb = -40 °C
Tamb = 25 °C
Tamb = 85 °C
Min
Max
Min
Max
Min
Max
5V
3.5
3.5
3.5
V
10 V
7.0
7.0
7.0
V
15 V
11.0
11.0
11.0
V
5V
1.5
1.5
1.5
V
10 V
3.0
3.0
3.0
V
15 V
4.0
4.0
4.0
V
5V
4.95
4.95
4.95
V
10 V
9.95
9.95
9.95
V
15 V
14.95
14.95
14.95
V
5V
0.05
0.05
0.05
V
10 V
0.05
0.05
0.05
V
15 V
0.05
0.05
0.05
V
VO = 2.5 V
5V
-1.7
-1.4
-1.1
mA
VO = 4.6 V
5V
-0.52
-0.44
-0.36
mA
VO = 9.5 V
10 V
-1.3
-1.1
-0.9
mA
VO = 13.5 V
15 V
-3.6
-3.0
-2.4
mA
VO = 0.4 V
5V
0.52
0.44
0.36
mA
VO = 0.5 V
10 V
1.3
1.1
0.9
mA
VO = 1.5 V
15 V
3.6
3.0
2.4
mA
15 V
±0.3
±0.3
±3.0
μA
5V
1.0
1.0
7.5
μA
10 V
2.0
2.0
15.0
μA
15 V
4.0
4.0
30.0
μA
7.5
pF
|IO| < 1 μA
|IO| < 1 μA
|IO| < 1 μA
|IO| < 1 μA
all valid input
combinations;
IO = 0 A
VDD
Unit
4 / 11
HEF4077B
Nexperia
10 Dynamic characteristics
[1]
Table 7. Dynamic characteristics
Tamb = 25 °C; unless otherwise specified; for waveform see Figure 4; for test circuit see Figure 5.
Symbol Parameter
Conditions
VDD
Extrapolation
formula
tPHL
nA or nB to nY
5V
HIGH to LOW
propagation delay
tPLH
LOW to HIGH
propagation delay
nA or nB to nY
Min
Typ
Max
Unit
48 ns + (0.55 ns/pF)CL
75
150
ns
10 V
24 ns + (0.23 ns/pF)CL
35
70
ns
15 V
22 ns + (0.16 ns/pF)CL
30
55
ns
5V
43 ns + (0.55 ns/pF)CL
70
145
ns
10 V
19 ns + (0.23 ns/pF)CL
30
60
ns
17 ns + (0.16 ns/pF)CL
25
50
ns
10 ns + (1.00 ns/pF)CL
60
120
ns
10 V
9 ns + (0.42 ns/pF)CL
30
60
ns
15 V
6 ns + (0.28 ns/pF)CL
ns
15 V
tt
[1]
[2]
transition time
5V
nY
[2]
The typical value of the propagation delay and output transition time can be calculated with the extrapolation formula (CL in pF).
tt is the same as tTHL and tTLH.
Table 8. Dynamic power dissipation
VSS = 0 V; tr = tf ≤ 20 ns; Tamb = 25 °C.
Symbol Parameter
PD
dynamic power dissipation
VDD Typical formula
5V
PD = 850 × fi + Σ(fo × CL) ×
where:
2
VDD
(μW)
fi = input frequency in MHz;
10 V PD = 4500 × fi + Σ(fo × CL) ×
(μW) fo = output frequency in MHz;
CL = output load capacitance in pF;
2
15 V PD = 114700 × fi + Σ(fo × CL) × VDD
Σ(fo × CL) = sum of the outputs;
(μW)
VDD = supply voltage in V.
2
VDD
HEF4077B
Product data sheet
5 / 11
HEF4077B
Nexperia
10.1 Waveform and test circuit
tr
VI
tf
90 %
VM
nA, nB input
0V
10 %
tPHL
VOH
tPLH
90 %
VM
nY output
10 %
VOL
tTHL
tTLH
aaa-009502
Measurement points are given in Table 9.
Logic levels: VOL and VOH are typical output voltage levels that occur with the output load.
Figure 4. Input to output propagation delay and output transition times
Table 9. Measurement points
Supply voltage
Input
Output
VDD
VM
VM
5 V to 15 V
0.5VDD
0.5VDD
VDD
G
VI
VO
DUT
CL
RT
001aag182
Test data is given in Table 10.
Definitions for test circuit:
CL = load capacitance including jig and probe capacitance.
RT = termination resistance should be equal to the output impedance Zo of the pulse generator.
Figure 5. Test circuit
Table 10. Test data
Supply voltage
Input
VDD
VI
tr, tf
CL
5 V to 15 V
VSS or VDD
≤ 20 ns
50 pF
HEF4077B
Product data sheet
Load
6 / 11
HEF4077B
Nexperia
11 Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
A2
Q
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.05
0.01
0.01
0.004
0.028
0.012
0.244
0.039 0.028
0.041
0.228
0.016 0.024
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Figure 6. Package outline SOT108-1 (SO14)
HEF4077B
Product data sheet
7 / 11
HEF4077B
Nexperia
12 Abbreviations
Table 11. Abbreviations
Acronym
Description
DUT
Device Under Test
ESD
ElectroStatic Discharge
13 Revision history
Table 12. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
HEF4077B v.6
20170314
Product data sheet
HEF4077B v.5
Modifications:
• The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
• Legal texts have been adapted to the new company name where appropriate.
HEF4077B v.5
20151210
Modifications:
• Type number HEF4077BP (SOT27-1) removed.
HEF4077B v.4
20140718
Modifications:
• The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
• Data sheet is imported into latest template.
HEF4077B_CNV_3
19950101
HEF4077B
Product data sheet
Product data sheet
Product data sheet
Product specification
HEF4077B v.4
HEF4077B_CNV_3
8 / 11
HEF4077B
Nexperia
14 Legal information
14.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
14.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
14.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
HEF4077B
Product data sheet
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
9 / 11
HEF4077B
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications. In the event that customer
uses the product for design-in and use in automotive applications to
automotive specifications and standards, customer (a) shall use the product
without Nexperia's warranty of the product for such automotive applications,
use and specifications, and (b) whenever customer uses the product for
automotive applications beyond Nexperia's specifications such use shall be
solely at customer’s own risk, and (c) customer fully indemnifies Nexperia
for any liability, damages or failed product claims resulting from customer
HEF4077B
Product data sheet
design and use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
14.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
10 / 11
HEF4077B
Nexperia
Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
10.1
11
12
13
14
General description ............................................ 1
Features and benefits .........................................1
Ordering information .......................................... 1
Functional diagram ............................................. 1
Pinning information ............................................ 2
Pinning ............................................................... 2
Pin description ................................................... 2
Functional description ........................................2
Limiting values .................................................... 3
Recommended operating conditions ................ 3
Static characteristics .......................................... 4
Dynamic characteristics .....................................5
Waveform and test circuit ..................................6
Package outline ...................................................7
Abbreviations ...................................................... 8
Revision history .................................................. 8
Legal information ................................................ 9
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 14 March 2017
Document identifier: HEF4077B
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
HEF4077BT,652 HEF4077BT,653
