HEF4077BT-Q100J
HEF4077BT-Q100J
    NEXPERIA(安世)
    SOIC14_150MIL
    IC GATE XNOR 4CH 2-INP 14SO
HEF4077BT-Q100J 数据手册
HEF4077B Quad 2-input EXCLUSIVE-NOR gate Rev. 6 — 14 March 2017 1 Product data sheet General description The HEF4077B is a quad 2-input EXCLUSIVE-NOR gate. The outputs are fully buffered for the highest noise immunity and pattern insensitivity to output impedance. The HEF4077B operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. 2 Features and benefits • • • • • 3 Fully static operation 5 V, 10 V, and 15 V parametric ratings Standardized symmetrical output characteristics Specified from -40 °C to +85 °C Complies with JEDEC standard JESD 13-B Ordering information Table 1. Ordering information Type number Package Temperature range Name Description HEF4077BT -40 °C to +85 °C SO14 4 Version plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 Functional diagram 1 2 1A 1B 1Y 3 5 6 2A 2B 2Y 4 8 9 3A 3B 3Y 10 12 13 4A 4B 4Y 11 aaa-012674 Figure 1. Functional diagram 1A 1B Figure 2. Logic diagram (one gate) 1Y aaa-012675 HEF4077B Nexperia Quad 2-input EXCLUSIVE-NOR gate 5 Pinning information 5.1 Pinning HEF4077B 1A 1 14 VDD 1B 2 13 4B 1Y 3 12 4A 2Y 4 11 4Y 2A 5 10 3Y 2B 6 9 3B VSS 7 8 3A aaa-012676 Figure 3. Pin configuration 5.2 Pin description Table 2. Pin description Symbol Pin Description 1A to 4A 1, 5, 8, 12 input 1B to 4B 2, 6, 9, 13 input 1Y to 4Y 3, 4, 10, 11 output VSS 7 ground (0 V) VDD 14 supply voltage 6 Functional description Table 3. Functional table [1] Output Input nA nB nY L L H L H L H L L H H H [1] H = HIGH voltage level; L = LOW voltage level HEF4077B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 14 March 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 11 HEF4077B Nexperia Quad 2-input EXCLUSIVE-NOR gate 7 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to VSS = 0 V (ground). Symbol Parameter Conditions Min Max Unit -0.5 +18 V - ±10 mA -0.5 VDD + 0.5 - ±10 mA VDD supply voltage IIK input clamping current VI input voltage IOK output clamping current II/O input/output current - ±10 mA IDD supply current - 50 mA Tstg storage temperature -65 +150 °C Tamb ambient temperature -40 +85 °C Ptot total power dissipation - 500 mW - 100 mW Min Max Unit VI < -0.5 V or VI > VDD + 0.5 V VO < -0.5 V or VO > VDD + 0.5 V Tamb = -40 °C to +85 °C SO14 package P [1] power dissipation V per output [1] For SO14 package: Ptot derates linearly with 8 mW/K above 70 °C. 8 Recommended operating conditions Table 5. Operating conditions Symbol Parameter Conditions VDD supply voltage 3 15 V VI input voltage 0 VDD V Tamb ambient temperature in free air -40 +85 °C Δt/ΔV input transition rise and fall rate VDD = 5 V - 3.75 μs/V VDD = 10 V - 0.5 μs/V VDD = 15 V - 0.08 μs/V HEF4077B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 14 March 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 11 HEF4077B Nexperia Quad 2-input EXCLUSIVE-NOR gate 9 Static characteristics Table 6. Static characteristics VSS = 0 V; VI = VSS or VDD unless otherwise specified. Symbol Parameter VIH VIL VOH VOL IOH IOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage HIGH-level output current LOW-level output current II input leakage current IDD supply current CI input capacitance HEF4077B Product data sheet Conditions Tamb = -40 °C Tamb = 25 °C Tamb = 85 °C Min Max Min Max Min Max 5V 3.5 - 3.5 - 3.5 - V 10 V 7.0 - 7.0 - 7.0 - V 15 V 11.0 - 11.0 - 11.0 - V 5V - 1.5 - 1.5 - 1.5 V 10 V - 3.0 - 3.0 - 3.0 V 15 V - 4.0 - 4.0 - 4.0 V 5V 4.95 - 4.95 - 4.95 - V 10 V 9.95 - 9.95 - 9.95 - V 15 V 14.95 - 14.95 - 14.95 - V 5V - 0.05 - 0.05 - 0.05 V 10 V - 0.05 - 0.05 - 0.05 V 15 V - 0.05 - 0.05 - 0.05 V VO = 2.5 V 5V - -1.7 - -1.4 - -1.1 mA VO = 4.6 V 5V - -0.52 - -0.44 - -0.36 mA VO = 9.5 V 10 V - -1.3 - -1.1 - -0.9 mA VO = 13.5 V 15 V - -3.6 - -3.0 - -2.4 mA VO = 0.4 V 5V 0.52 - 0.44 - 0.36 - mA VO = 0.5 V 10 V 1.3 - 1.1 - 0.9 - mA VO = 1.5 V 15 V 3.6 - 3.0 - 2.4 - mA 15 V - ±0.3 - ±0.3 - ±3.0 μA 5V - 1.0 - 1.0 - 7.5 μA 10 V - 2.0 - 2.0 - 15.0 μA 15 V - 4.0 - 4.0 - 30.0 μA - - - - 7.5 - - pF |IO| < 1 μA |IO| < 1 μA |IO| < 1 μA |IO| < 1 μA all valid input combinations; IO = 0 A VDD All information provided in this document is subject to legal disclaimers. Rev. 6 — 14 March 2017 Unit © Nexperia B.V. 2017. All rights reserved. 4 / 11 HEF4077B Nexperia Quad 2-input EXCLUSIVE-NOR gate 10 Dynamic characteristics [1] Table 7. Dynamic characteristics Tamb = 25 °C; unless otherwise specified; for waveform see Figure 4; for test circuit see Figure 5. Symbol Parameter Conditions VDD Extrapolation formula tPHL nA or nB to nY 5V HIGH to LOW propagation delay tPLH LOW to HIGH propagation delay nA or nB to nY Min Typ Max Unit 48 ns + (0.55 ns/pF)CL - 75 150 ns 10 V 24 ns + (0.23 ns/pF)CL - 35 70 ns 15 V 22 ns + (0.16 ns/pF)CL - 30 55 ns 5V 43 ns + (0.55 ns/pF)CL - 70 145 ns 10 V 19 ns + (0.23 ns/pF)CL - 30 60 ns 17 ns + (0.16 ns/pF)CL - 25 50 ns 10 ns + (1.00 ns/pF)CL - 60 120 ns 10 V 9 ns + (0.42 ns/pF)CL - 30 60 ns 15 V 6 ns + (0.28 ns/pF)CL - 20 40 ns 15 V tt [1] [2] transition time 5V nY [2] The typical value of the propagation delay and output transition time can be calculated with the extrapolation formula (CL in pF). tt is the same as tTHL and tTLH. Table 8. Dynamic power dissipation VSS = 0 V; tr = tf ≤ 20 ns; Tamb = 25 °C. Symbol Parameter PD dynamic power dissipation VDD Typical formula 5V PD = 850 × fi + Σ(fo × CL) × where: 2 VDD (μW) fi = input frequency in MHz; 10 V PD = 4500 × fi + Σ(fo × CL) × (μW) fo = output frequency in MHz; CL = output load capacitance in pF; 2 15 V PD = 114700 × fi + Σ(fo × CL) × VDD Σ(fo × CL) = sum of the outputs; (μW) VDD = supply voltage in V. 2 VDD HEF4077B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 14 March 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 11 HEF4077B Nexperia Quad 2-input EXCLUSIVE-NOR gate 10.1 Waveform and test circuit tr VI tf 90 % VM nA, nB input 0V 10 % tPHL VOH tPLH 90 % VM nY output 10 % VOL tTHL tTLH aaa-009502 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Figure 4. Input to output propagation delay and output transition times Table 9. Measurement points Supply voltage Input Output VDD VM VM 5 V to 15 V 0.5VDD 0.5VDD VDD G VI VO DUT CL RT 001aag182 Test data is given in Table 10. Definitions for test circuit: CL = load capacitance including jig and probe capacitance. RT = termination resistance should be equal to the output impedance Zo of the pulse generator. Figure 5. Test circuit Table 10. Test data Supply voltage Input VDD VI tr, tf CL 5 V to 15 V VSS or VDD ≤ 20 ns 50 pF HEF4077B Product data sheet Load All information provided in this document is subject to legal disclaimers. Rev. 6 — 14 March 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 11 HEF4077B Nexperia Quad 2-input EXCLUSIVE-NOR gate 11 Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 A2 Q A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.05 0.01 0.01 0.004 0.028 0.012 0.244 0.039 0.028 0.041 0.228 0.016 0.024 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Figure 6. Package outline SOT108-1 (SO14) HEF4077B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 14 March 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 11 HEF4077B Nexperia Quad 2-input EXCLUSIVE-NOR gate 12 Abbreviations Table 11. Abbreviations Acronym Description DUT Device Under Test ESD ElectroStatic Discharge 13 Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes HEF4077B v.6 20170314 Product data sheet - HEF4077B v.5 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. HEF4077B v.5 20151210 Modifications: • Type number HEF4077BP (SOT27-1) removed. HEF4077B v.4 20140718 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • Legal texts have been adapted to the new company name where appropriate. • Data sheet is imported into latest template. HEF4077B_CNV_3 19950101 HEF4077B Product data sheet Product data sheet Product data sheet Product specification - - All information provided in this document is subject to legal disclaimers. Rev. 6 — 14 March 2017 HEF4077B v.4 HEF4077B_CNV_3 - © Nexperia B.V. 2017. All rights reserved. 8 / 11 HEF4077B Nexperia Quad 2-input EXCLUSIVE-NOR gate 14 Legal information 14.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical HEF4077B Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 6 — 14 March 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 11 HEF4077B Nexperia Quad 2-input EXCLUSIVE-NOR gate Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer HEF4077B Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 6 — 14 March 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 11 HEF4077B Nexperia Quad 2-input EXCLUSIVE-NOR gate Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 10.1 11 12 13 14 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 1 Functional diagram ............................................. 1 Pinning information ............................................ 2 Pinning ............................................................... 2 Pin description ................................................... 2 Functional description ........................................2 Limiting values .................................................... 3 Recommended operating conditions ................ 3 Static characteristics .......................................... 4 Dynamic characteristics .....................................5 Waveform and test circuit ..................................6 Package outline ...................................................7 Abbreviations ...................................................... 8 Revision history .................................................. 8 Legal information ................................................ 9 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 14 March 2017 Document identifier: HEF4077B Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: HEF4077BT,652 HEF4077BT,653
HEF4077BT-Q100J 价格&库存
很抱歉,暂时无法提供与“HEF4077BT-Q100J”相匹配的价格&库存,您可以联系我们找货
