74AHCU04-Q100
Hex unbuffered inverter
Rev. 2 — 7 December 2015
Product data sheet
1. General description
The 74AHCU04-Q100 is high-speed Si-gate CMOS device and is pin compatible with
low-power Schottky TTL (LSTTL). It is specified in compliance with JEDEC standard
No. 7A.
The 74AHCU04-Q100 is a general-purpose hex unbuffered inverter. Each of the six
inverters is a single stage.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Low power dissipation
Balanced propagation delays
Inputs accept voltages higher than VCC
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
Multiple package options
3. Ordering information
Table 1.
Type number
Package
Temperature
range
74AHCU04D-Q100
Name
40 C to +125 C SO14
74AHCU04PW-Q100 40 C to +125 C TSSOP14
Description
Version
plastic small outline package; 14 leads; body width
3.9 mm
SOT108-1
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74AHCU04BQ-Q100 40 C to +125 C DHVQFN14 plastic dual in-line compatible thermal enhanced very SOT762-1
thin quad flat package; no leads; 14 terminals;
body 2.5 3 0.85 mm
74AHCU04-Q100
Nexperia
4. Functional diagram
1
1
1A
1Y
2
3
2A
2Y
4
3
5
5
3A
3Y
6
9
4A
4Y
8
11
5A
5Y
10
13
6A
6Y
12
9
11
13
2
1
4
1
6
1
8
1
10
1
12
A
Y
mna045
mna343
mna342
Fig 1.
1
Logic symbol
Fig 2.
IEC logic symbol
Fig 3.
Logic diagram (one
inverter)
5. Pinning information
WHUPLQDO
LQGH[DUHD
$+&84
9&&
$+&84
9&&
*1'
*1'
*1'
DDD
7UDQVSDUHQWWRSYLHZ
DDD
(1) This is not a supply pin. The substrate is attached to this
pad using conductive die attach material. There is no
electrical or mechanical requirement to solder this pad.
However, if it is soldered, the solder land should remain
floating or be connected to GND.
Fig 4.
Pin configuration SO14 and TSSOP14
74AHCU04_Q100
Product data sheet
Fig 5.
Pin configuration DHVQFN14
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 15
74AHCU04-Q100
Nexperia
5.1 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1A, 2A, 3A, 4A, 5A, 6A
1, 3, 5, 9, 11, 13
data input
1Y, 2Y, 3Y, 4Y, 5Y, 6
2, 4, 6, 8, 10, 12
data output
GND
7
ground (0 V)
VCC
14
supply voltage
6. Functional description
Table 3.
Function table
H = HIGH voltage level; L = LOW voltage level
Input
Output
nA
nY
L
H
H
L
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VCC
supply voltage
Max
Unit
0.5
+7.0
V
mA
+7.0
V
VO < 0.5 V or VO > VCC + 0.5 V
mA
0.5 V < VO < VCC + 0.5 V
25
mA
supply current
75
mA
ground current
75
mA
65
+150
C
500
mW
input clamping current
input voltage
IOK
output clamping current
IO
output current
ICC
IGND
Tstg
storage temperature
total power dissipation
VI < 0.5 V
Min
0.5
IIK
VI
Ptot
Conditions
[1]
Tamb = 40 C to +125 C
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO14 packages: above 70 C the value of Ptot derates linearly with 8 mW/K.
For TSSOP14 packages: above 60 C the value of Ptot derates linearly with 5.5 mW/K.
For DHVQFN14 packages: above 60 C the value of Ptot derates linearly with 4.5 mW/K.
74AHCU04_Q100
Product data sheet
3 of 15
74AHCU04-Q100
Nexperia
8. Recommended operating conditions
Table 5.
Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VCC
supply voltage
2.0
5.0
5.5
V
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
40
+25
+125
C
t/V
input transition rise and fall rate
VCC = 3.3 V 0.3 V
100
ns/V
VCC = 5.0 V 0.5 V
ns/V
9. Static characteristics
Table 6.
Symbol
Parameter
25 C
Conditions
Min
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
Typ
40 C to +85 C
Max
Min
40 C to +125 C Unit
Max
Min
Max
VCC = 2.0 V
1.7
1.7
1.7
V
VCC = 3.0 V
2.4
2.4
2.4
V
VCC = 5.5 V
4.4
4.4
4.4
V
VCC = 2.0 V
0.3
0.3
0.3
V
VCC = 3.0 V
0.6
0.6
0.6
V
VCC = 5.5 V
1.1
1.1
1.1
V
HIGH-level
VI = VIH or VIL
output voltage
IO = 50 A; VCC = 2.0 V
1.8
2.0
1.8
1.8
V
IO = 50 A; VCC = 3.0 V
2.7
3.0
2.7
2.7
V
IO = 50 A; VCC = 4.5 V
4.0
4.5
4.0
4.0
V
IO = 4.0 mA; VCC = 3.0 V 2.58
2.48
2.4
V
IO = 8.0 mA; VCC = 4.5 V 3.94
3.8
3.7
V
LOW-level
VI = VIH or VIL
output voltage
0.2
0.2
V
0.3
0.3
V
0.5
0.5
V
0.36
0.44
0.55
V
0.36
0.44
0.55
V
0.1
1.0
2.0
A
II
input leakage
current
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
2.0
A
CI
input
capacitance
3
10
10
10
pF
74AHCU04_Q100
Product data sheet
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
4 of 15
74AHCU04-Q100
Nexperia
10. Dynamic characteristics
Table 7.
GND = 0 V; For test circuit see Figure 7.
Symbol
Parameter
25 C
Conditions
Min
propagation
delay
tpd
nA to nY; see Figure 6
[1]
VCC = 3.0 V to 3.6 V
[2]
CL = 15 pF
CL = 50 pF
CL = 15 pF
CL = 50 pF
power
dissipation
capacitance
[4]
CL = 50 pF; fi = 1 MHz;
VI = GND to VCC
[1]
tpd is the same as tPLH and tPHL.
[2]
Typical values are measured at VCC = 3.3 V.
Max
Min
Max
Min
Max
3.0
7.1
1.0
8.5
1.0
9.0
ns
3.4
10.6
1.0
12.0
1.0
13.5
ns
2.4
5.5
1.0
6.5
1.0
7.0
ns
3.5
7.0
1.0
8.0
1.0
9.0
ns
9.1
[3]
VCC = 4.5 V to 5.5 V
CPD
Typ
40 C to +85 C 40 C to +125 C Unit
[3]
Typical values are measured at VCC = 5.0 V.
[4]
CPD is used to determine the dynamic power dissipation (PD in W).
pF
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
11. Waveforms
VI
VM
nA input
VM
VCC
GND
t PHL
t PLH
PULSE
GENERATOR
VOH
VM
nY output
VOL
VI
VO
DUT
CL
50 pF
RT
VM
mna344
mna034
VM = 0.5 VCC; VI = GND to VCC.
Test data is given in Table 7.
Definitions for test circuit:
CL = Load capacitance including jig and probe
capacitance.
RT = Termination resistance should be equal to output
impedance Zo of the pulse generator.
Fig 6.
The input (nA) to output (nY) propagation
delay times
74AHCU04_Q100
Product data sheet
Fig 7.
Test circuit for measuring switching times
5 of 15
74AHCU04-Q100
Nexperia
12. Typical transfer characteristics
mna353
2
VO
VO
(V)
mna352
4
700
ICC
(μA)
6
VO
(V)
ICC
(mA)
VO
500
3
1
300
2
2
0.5
100
1
4
ICC
ICC
1
1.5 V (V)
i
2
−100
Tamb = 25 C.
Fig 8.
1
2
3
Vi (V)
−2
Tamb = 25 C.
VCC = 2.0 V; IO = 0 A
Fig 9.
VCC = 3.0 V; IO = 0 A
mna351
8
30
VO
(V)
ICC
(mA)
6
10
Rbias = 560 kΩ
VCC
ICC
2
0.47 μF
VO
Tamb = 25 C.
4
Vi (V)
6
−10
input
100 μF
output
VI
(f = 1 kHz)
A IO
GND
mna050
I O
g fs = --------V I
fi = 1 kHz at VO is constant
Fig 10. VCC = 5.5 V; IO = 0 A
74AHCU04_Q100
Product data sheet
Fig 11. Test set-up for measuring forward
transconductance
6 of 15
74AHCU04-Q100
Nexperia
mna355
40
g fs
(mA/V)
30
4
VCC (V)
6
Tamb = 25 C.
Fig 12. Typical forward transconductance as a function of the supply voltage
13. Application information
Some applications are:
• Linear amplifier (see Figure 13)
• Crystal oscillator design (see Figure 14)
Remark: All values given are typical unless otherwise specified.
R2
R1
VCC
1 μF
R2
R1
U04
U04
C1
ZL
C2
out
mna052
mna053
Maximum Vo(p-p) = VCC 1.5 V centered at 0.5 VCC.
C1 = 47 pF (typical)
G ol
G v = – --------------------------------------R1
1 + ------- 1 + G ol
R2
C2 = 33 pF (typical)
R1 = 1 M to 10 M (typical
R2 optimum value depends on the frequency and
required stability against changes in VCC or average
minimum ICC. ICC is typically 5 mA at VCC = 5 V and
fi = 10 MHz.
Gol = open loop gain
Gv = voltage gain
R1 3 k, R2 1 M
ZL > 10 k; Gol = 12 (typical)
Typical unity gain bandwidth product is 5 MHz.
Fig 13. Used as a linear amplifier
74AHCU04_Q100
Product data sheet
Fig 14. Crystal oscillator configuration
7 of 15
74AHCU04-Q100
Nexperia
Table 8.
External components for resonator (f < 1 MHz)
All values given are typical and must be used as an initial set-up.
Frequency
R1
R2
C1
C2
10 kHz to 15.9 kHz
22 M
220 k
56 pF
20 pF
16 kHz to 24.9 kHz
22 M
220 k
56 pF
10 pF
25 kHz to 54.9 kHz
22 M
100 k
56 pF
10 pF
55 kHz to 129.9 kHz
22 M
100 k
47 pF
5 pF
130 kHz to 199.9 kHz
22 M
47 k
47 pF
5 pF
200 kHz to 349.9 kHz
10 M
47 k
47 pF
5 pF
350 kHz to 600 kHz
10 M
47 k
47 pF
5 pF
Table 9.
Optimum value for R2
Frequency
R2
Optimum for
3 kHz
2.0 k
minimum required ICC
8.0 k
minimum influence due to change in VCC
1.0 k
6 kHz
4.7 k
minimum influence by VCC
0.5 k
2.0 k
14 kHz
0.5 k
1.0 k
>14 kHz
replace R2 by C3 with a typical value of 35 pF
10 kHz
74AHCU04_Q100
Product data sheet
8 of 15
74AHCU04-Q100
Nexperia
14. Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.010 0.057
inches 0.069
0.004 0.049
0.05
0.244
0.039
0.041
0.228
0.016
0.028
0.024
0.01
0.01
0.028
0.004
0.012
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig 15. Package outline SOT108-1 (SO14)
74AHCU04_Q100
Product data sheet
9 of 15
74AHCU04-Q100
Nexperia
TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm
SOT402-1
E
D
A
X
c
y
HE
v M A
Z
8
14
Q
(A 3)
A2
A
A1
pin 1 index
θ
Lp
L
1
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.72
0.38
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT402-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig 16. Package outline SOT402-1 (TSSOP14)
74AHCU04_Q100
Product data sheet
10 of 15
74AHCU04-Q100
Nexperia
'+94)1SODVWLFGXDOLQOLQHFRPSDWLEOHWKHUPDOHQKDQFHGYHU\WKLQTXDGIODWSDFNDJHQROHDGV
WHUPLQDOVERG\[[PP
627
F
GHWDLO;
WHUPLQDO
LQGH[DUHD
WHUPLQDO
LQGH[DUHD
H
H
Y
Z
E
(K
H
N
'K
N
PP
VFDOH
'LPHQVLRQVPPDUHWKHRULJLQDOGLPHQVLRQV
8QLW
PP
PD[
QRP
PLQ
E
F
'K
(K
H
H
N
Y
Z
1RWH
3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
2XWOLQH
YHUVLRQ
627
5HIHUHQFHV
-(,7$
VRWBSR
(XURSHDQ
SURMHFWLRQ
,VVXHGDWH
02
Fig 17. Package outline SOT762-1 (DHVQFN14)
74AHCU04_Q100
Product data sheet
11 of 15
74AHCU04-Q100
Nexperia
15. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CMOS
Complementary Metal Oxide Semiconductor
LSTTL
Low-power Schottky Transistor-Transistor Logic
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
CDM
Charge Device Model
TTL
16. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AHCU04_Q100 v.2
20151207
Product data sheet
74AHCU04_Q100 v.1
Modifications:
74AHCU04_Q100 v.1
74AHCU04_Q100
Product data sheet
General description corrected (added “-Q100” to product types (errata)).
20130605
Product data sheet
12 of 15
74AHCU04-Q100
Nexperia
17. Legal information
17.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
17.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
17.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74AHCU04_Q100
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
13 of 15
74AHCU04-Q100
Nexperia
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
17.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
18. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74AHCU04_Q100
Product data sheet
14 of 15
Nexperia
74AHCU04-Q100
19. Contents
1
2
3
4
5
5.1
6
7
8
9
10
11
12
13
14
15
16
17
17.1
17.2
17.3
17.4
18
19
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 4
Dynamic characteristics . . . . . . . . . . . . . . . . . . 5
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5
Typical transfer characteristics . . . . . . . . . . . . 6
Application information. . . . . . . . . . . . . . . . . . . 7
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12
Legal information. . . . . . . . . . . . . . . . . . . . . . . 13
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Contact information. . . . . . . . . . . . . . . . . . . . . 14
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Date of release: 07 December 2015
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AHCU04D-Q100J 74AHCU04BQ-Q100X 74AHCU04PW-Q100J
