74HC3GU04-Q100
Triple unbuffered inverter
Rev. 2 — 29 January 2019
Product data sheet
1. General description
The 74HC3GU04-Q100 is a triple unbuffered inverter. Inputs include clamp diodes. This enables
the use of current limiting resistors to interface inputs to voltages in excess of VCC.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
Wide supply voltage range from 2.0 V to 6.0 V
Symmetrical output impedance
High noise immunity
Low-power dissipation
Balanced propagation delays
Multiple package options
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω)
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
Name
Description
74HC3GU04DP-Q100
-40 °C to +125 °C
TSSOP8
plastic thin shrink small outline package;
SOT505-2
8 leads; body width 3 mm; lead length 0.5 mm
74HC3GU04DC-Q100
-40 °C to +125 °C
VSSOP8
plastic very thin shrink small outline package;
8 leads; body width 2.3 mm
4. Marking
Table 2. Marking
Type number
Marking code[1]
74HC3GU04DP-Q100
HU4
74HC3GU04DC-Q100
HU4
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
Version
SOT765-1
74HC3GU04-Q100
Nexperia
5. Functional diagram
1
1A
1Y
1
1
7
3
1
5
6
1
2
7
3
2A
2Y
5
6
3A
3Y
2
mna720
Fig. 1.
mna721
Logic symbol
Fig. 2.
IEC logic symbol
6. Pinning information
6.1. Pinning
74HC3GU04
1A
1
8
VCC
3Y
2
7
1Y
2A
3
6
3A
GND
4
5
2Y
001aak022
Fig. 3.
Pin configuration SOT505-2 (TSSOP8) and SOT765-1 (VSSOP8)
6.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
1A, 2A, 3A
1, 3, 6
data input
1Y, 2Y, 3Y
7, 5, 2
data output
GND
4
ground (0 V)
VCC
8
supply voltage
7. Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level.
Input
Output
nA
nY
L
H
H
L
74HC3GU04_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2019. All rights reserved
2 / 14
74HC3GU04-Q100
Nexperia
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Min
Max
Unit
VCC
supply voltage
-0.5
+7.0
V
IIK
input clamping current
VI < -0.5 V or VI > VCC + 0.5 V
[1]
±20
mA
IOK
output clamping current
IO
output current
VO < -0.5 V or VO > VCC + 0.5 V
[1]
±20
mA
VO = -0.5 V to (VCC + 0.5 V)
[1]
±25
mA
ICC
quiescent supply current
[1]
50
mA
IGND
ground current
[1]
-50
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
300
mW
Max
Unit
[1]
[2]
Conditions
Tamb = -40 °C to +125 °C
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For TSSOP8 package: above 55 °C the value of Ptot derates linearly with 2.5 mW/K.
For VSSOP8 package: above 110 °C the value of Ptot derates linearly with 8 mW/K.
9. Recommended operating conditions
Table 6. Recommended operating conditions
Symbol
Parameter
Conditions
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
Min
Typ
2.0
5.0
6.0
V
VCC
V
VCC
V
-40
+25
+125
°C
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
10. Static characteristics
Table 7. Static characteristics
Symbol
Parameter
Conditions
Min
Typ[1]
Max
Min
Max
VIH
HIGH-level input
voltage
VCC = 2.0 V
1.7
1.1
1.7
V
VCC = 4.5 V
3.6
2.4
3.6
V
VCC = 6.0 V
4.8
3.1
4.8
V
VCC = 2.0 V
0.9
0.3
0.3
V
VCC = 4.5 V
2.1
0.9
0.9
V
VCC = 6.0 V
2.9
1.2
1.2
V
VIL
LOW-level input
voltage
74HC3GU04_Q100
Product data sheet
-40 °C to +85 °C
-40 °C to +125 °C
Unit
3 / 14
74HC3GU04-Q100
Nexperia
Symbol
Parameter
VOH
Conditions
HIGH-level output
voltage
VOL
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Typ[1]
Max
Min
Max
IO = -20 μA; VCC = 2.0 V
1.9
2.0
1.9
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
4.4
V
IO = -20 μA; VCC = 6.0 V
5.9
6.0
5.9
V
IO = -4.0 mA; VCC = 4.5 V
4.13
4.32
3.7
V
IO = -5.2 mA; VCC = 6.0 V
5.63
5.81
5.2
V
IO = 20 μA; VCC = 2.0 V
0.1
V
IO = 20 μA; VCC = 4.5 V
0.1
V
IO = 20 μA; VCC = 6.0 V
0.1
V
IO = 4.0 mA; VCC = 4.5 V
0.15
0.33
0.4
V
IO = 5.2 mA; VCC = 6.0 V
VI = VIH or VIL
VI = VIH or VIL
LOW-level output
voltage
0.16
0.33
0.4
V
II
input leakage current
VI = VCC or GND; VCC = 6.0 V
±1.0
±1.0
μA
ICC
supply current
per input pin; VI = VCC or GND;
IO =0A; VCC = 6.0 V
10
μA
CI
input capacitance
3.0
pF
[1]
All typical values are measured at Tamb = 25 °C.
11. Dynamic characteristics
Table 8. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 5.
Symbol Parameter
tpd
tt
CPD
[1]
[2]
[3]
[4]
Conditions
-40 °C to +85 °C
Min
Typ[1]
Max
Min
Max
VCC = 2.0 V
13
75
90
ns
VCC = 4.5 V
6
15
18
ns
VCC = 6.0 V
5
13
15
ns
VCC = 2.0 V
18
95
125
ns
VCC = 4.5 V
6
19
25
ns
VCC = 6.0 V
5
16
ns
5
pF
propagation delay nA to nY; see Fig. 4
transition time
-40 °C to +125 °C Unit
[2]
nY; see Fig. 4
[3]
power dissipation VI = GND to VCC
capacitance
[4]
tpd is the same as tPLH and tPHL.
tt is the same as tTLH and tTHL.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL x VCC x fo) = sum of outputs.
74HC3GU04_Q100
Product data sheet
4 / 14
74HC3GU04-Q100
Nexperia
11.1. Waveforms and test circuit
VI
VM
nA input
VM
GND
t PHL
t PLH
VOH
90 %
VM
VM
nY output
10 %
VOL
t THL
t TLH
mna722
Measurement points are given in Table 9.
Fig. 4.
Propagation delay data input (nA) to data output (nY) and transition time output (nY)
Table 9. Measurement points
Type
74HC3GU04-Q100
VI
negative
pulse
Input
Output
VM
VM
0.5 × VCC
0.5 × VCC
tW
90 %
VM
VM
10 %
0V
tf
tr
VI
positive
pulse
0V
tr
tf
90 %
VM
VM
10 %
tW
VCC
VI
G
DUT
VCC
VO
RT
RL
S1
open
CL
001aad983
Test data is given in Table 10.
Definitions for test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
RL = Load resistance.
S1 = Test selection switch.
Fig. 5.
Test circuit for measuring switching times
Table 10. Test data
Type
Input
VI
74HC3GU04-Q100 GND to VCC
74HC3GU04_Q100
Product data sheet
S1 position
Load
tr, tf
CL
RL
tPHL, tPLH
≤ 6 ns
50 pF
1 kΩ
open
5 / 14
74HC3GU04-Q100
Nexperia
12. Additional characteristics
Rbias = 560 kΩ
VCC
0.47 µF
input
output
100 µF
VI
(f = 1 kHz)
A IO
GND
mna050
VO is constant.
Fig. 6.
Test set-up for measuring forward transconductance
mnb124
30
gfs
(mA/V)
4
6
VCC (V)
8
Tamb = 25 °C.
Fig. 7.
Typical forward transconductance as a function of supply voltage
74HC3GU04_Q100
Product data sheet
6 / 14
74HC3GU04-Q100
Nexperia
13. Typical transfer characteristics
mnb121
150
ICC
(µA)
VO
(V)
120
1.6
90
1.2
60
0.8
30
0.4
0.8
1.2
1.6
VI (V)
2
5
I CC
(mA)
VO
(V)
8
4
6
3
4
2
2
1
VCC = 2.0 V; IO = 0 A.
Fig. 8.
mnb122
10
2
2
3
4
VI (V)
5
VCC = 4.5 V; IO = 0 A.
Typical transfer characteristics VCC = 2.0 V
Fig. 9.
Typical transfer characteristics VCC = 4.5 V
mnb123
I CC
(mA)
6
VO
(V)
16
12
3
8
4
4
VI (V)
6
VCC = 6.0 V; IO = 0 A.
Fig. 10. Typical transfer characteristics VCC = 6.0 V
74HC3GU04_Q100
Product data sheet
7 / 14
74HC3GU04-Q100
Nexperia
14. Application information
Some applications for the 74HC3GU04-Q100 are:
Linear amplifier (see Fig. 11)
Crystal oscillator (see Fig. 13).
All values given are typical values unless otherwise specified.
R2
VCC
1 µF
R1
U04
ZL
mna052
ZL > 10 kΩ.
R1 ≥ 3 kΩ.
R2 ≤ 1 MΩ.
Open loop amplification: AOL = 20 (typical).
Voltage amplification:
Vo(p-p) = VCC - 1.5 V centered at 0.5 × VCC.
Unity gain bandwidth product is 5 MHz (typical).
Input capacitance see Fig. 12.
Fig. 11. Linear amplifier application
mna054
80
input
capacitance
(pF)
(1)
60
(2)
40
(3)
4
6
VI (V)
8
(1) VCC = 2.0 V.
(2) VCC = 4.5 V.
(3) VCC = 6.0 V.
Fig. 12. Typical input capacitance as a function of the input voltage
74HC3GU04_Q100
Product data sheet
8 / 14
74HC3GU04-Q100
Nexperia
R1
R2
U04
out
C1
C2
mna053
Test data is given in Table 11 and Table 12.
C1 = 47 pF (typical).
C2 = 22 pF (typical).
R1 = 1 MΩ to 10 MΩ (typical).
R2 optimum value depends on the frequency and required stability against changes in VCC or average
minimum ICC.
(ICC = 2 mA at VCC = 3.0 V and f = 1 MHz.)
Fig. 13. Crystal oscillator application
Table 11. External components for resonator (f < 1 MHz)
Frequency
R1
R2
C1
C2
10 kHz to 15.9 kHz
2.2 MΩ
220 kΩ
56 pF
20 pF
16 kHz to 24.9 kHz
2.2 MΩ
220 kΩ
56 pF
10 pF
25 kHz to 54.9 kHz
2.2 MΩ
100 kΩ
56 pF
10 pF
55 kHz to 129.9 kHz
2.2 MΩ
100 kΩ
47 pF
5 pF
130 kHz to 199.9 kHz
2.2 MΩ
47 kΩ
47 pF
5 pF
200 kHz to 349.9 kHz
2.2 MΩ
47 kΩ
47 pF
5 pF
350 kHz to 600 kHz
2.2 MΩ
47 kΩ
47 pF
5 pF
Table 12. Optimum value for R2
Frequency
R2
3 kHz
6 kHz
10 kHz
14 kHz
> 14 kHz
74HC3GU04_Q100
Product data sheet
Optimum
2.0 kΩ
minimum required ICC
8.0 kΩ
minimum influence due to change in VCC
1.0 kΩ
4.7 kΩ
minimum influence by VCC
0.5 kΩ
2.0 kΩ
0.5 kΩ
2.0 kΩ
replace R2 by C3 = 35 pF (typical)
9 / 14
74HC3GU04-Q100
Nexperia
15. Package outline
TSSOP8: plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm
D
E
A
SOT505-2
X
c
HE
y
v M A
Z
5
8
A
A2
pin 1 index
(A3)
A1
θ
Lp
L
1
4
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.15
0.00
0.95
0.75
0.25
0.38
0.22
0.18
0.08
3.1
2.9
3.1
2.9
0.65
4.1
3.9
0.5
0.47
0.33
0.2
0.13
0.1
0.70
0.35
8°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT505-2
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-01-16
Fig. 14. Package outline SOT505-2 (TSSOP8)
74HC3GU04_Q100
Product data sheet
10 / 14
74HC3GU04-Q100
Nexperia
VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm
D
SOT765-1
E
A
X
c
y
HE
v
A
Z
5
8
Q
A
A2
A1
pin 1 index
(A3)
θ
Lp
1
detail X
4
e
L
w
bp
5 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
A
max.
max
nom
min
1
A1
A2
0.15 0.85
0.00 0.60
A3
0.12
D(1)
E(2)
0.27 0.23
2.1
2.4
0.17 0.08
1.9
2.2
bp
c
e
HE
0.5
3.2
3.0
L
0.4
Lp
Q
0.40 0.21
0.15 0.19
v
w
y
0.2
0.08
0.1
Z(1)
θ
0.4
8°
0.1
0°
Note
2. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
Outline
version
SOT765-1
References
IEC
JEDEC
JEITA
sot765-1_po
European
projection
Issue date
07-06-02
16-05-31
MO-187
Fig. 15. Package outline SOT765-1 (VSSOP8)
74HC3GU04_Q100
Product data sheet
11 / 14
74HC3GU04-Q100
Nexperia
16. Abbreviations
Table 13. Abbreviations
Acronym
Description
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
17. Revision history
Table 14. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC3GU04_Q100 v.2
20190129
Product data sheet
74HC3GU04_Q100 v.1
Modifications:
74HC3GU04_Q100 v.1
74HC3GU04_Q100
Product data sheet
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
20131113
Product data sheet
12 / 14
74HC3GU04-Q100
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
18. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
74HC3GU04_Q100
Product data sheet
13 / 14
74HC3GU04-Q100
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Marking.......................................................................... 1
5. Functional diagram.......................................................2
6. Pinning information......................................................2
6.1. Pinning.........................................................................2
6.2. Pin description............................................................. 2
7. Functional description................................................. 2
8. Limiting values............................................................. 3
9. Recommended operating conditions..........................3
10. Static characteristics..................................................3
11. Dynamic characteristics.............................................4
11.1. Waveforms and test circuit........................................ 5
12. Additional characteristics.......................................... 6
13. Typical transfer characteristics................................. 7
14. Application information............................................. 8
15. Package outline........................................................ 10
16. Abbreviations............................................................ 12
17. Revision history........................................................12
18. Legal information......................................................13
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 29 January 2019
74HC3GU04_Q100
Product data sheet
14 / 14
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74HC3GU04DC-Q100H 74HC2GU04GV-Q100H 74HC2GU04GW-Q100H 74HC3GU04DP-Q100H
