74LV132-Q100
Quad 2-input NAND Schmitt trigger
Rev. 1 — 11 November 2013
Product data sheet
1. General description
The 74LV132-Q100 is a low-voltage Si-gate CMOS device that is pin and function
compatible with 74HC132-Q100 and 74HCT132-Q100.
The 74LV132-Q100 contains four 2-input NAND gates which accept standard input
signals. These gates are capable of transforming slowly changing input signals into
sharply defined, jitter-free output signals.
The gate switches at different points for positive and negative-going signals. The
difference between the positive voltage VT+ and the negative voltage VT is defined as the
input hysteresis voltage VH.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Wide operating voltage: 1.0 V to 5.5 V
Optimized for low voltage applications: 1.0 V to 3.6 V
Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V
Typical output ground bounce < 0.8 V at VCC = 3.3 V and Tamb = 25 C
Typical HIGH-level output voltage (VOH) undershoot: > 2 V at VCC = 3.3 V and
Tamb = 25 C
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
Multiple package options
3. Applications
Wave and pulse shapers for highly noisy environments
Astable multivibrators
Monostable multivibrators
74LV132-Q100
Nexperia
4. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
40 C to +125 C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
74LV132PW-Q100 40 C to +125 C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74LV132BQ-Q100 40 C to +125 C
DHVQFN14 plastic dual in-line compatible thermal enhanced very SOT762-1
thin quad flat package; no leads; 14 terminals;
body 2.5 3 0.85 mm
74LV132D-Q100
5. Functional diagram
1
1A
1Y
2
4
2A
2Y
5
3
1B
6
2B
1
4
9
3A
3
6
8
5
3Y
10
2
8
3B
9
10
12
4A
4Y
13
12
11
4B
74LV132_Q100
Product data sheet
11
Y
13
B
mna407
Fig 1. Logic symbol
A
mna409
mna408
Fig 2. IEC logic symbol
Fig 3. Logic diagram (one gate)
All information provided in this document is subject to legal disclaimers.
2 of 16
Nexperia B.V. 2017. All rights reserved
74LV132-Q100
Nexperia
6. Pinning information
6.1 Pinning
*1'
9&&
9&&
*1'
/94
WHUPLQDO
LQGH[DUHD
9&&
/94
DDD
7UDQVSDUHQWWRSYLHZ
(1) The die substrate is attached to the exposed die pad
using conductive die attach material. It cannot be
used as a supply pin or input.
DDD
Fig 4. Pin configuration SO14 and TSSOP14
Fig 5. Pin configuration DHVQFN14
6.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1A
1
data input
1B
2
data input
1Y
3
data output
2A
4
data input
2B
5
data input
2Y
6
data output
GND
7
ground (0 V)
3Y
8
data output
3A
9
data input
3B
10
data input
4Y
11
data output
4A
12
data input
4B
13
data input
VCC
14
supply voltage
74LV132_Q100
Product data sheet
3 of 16
74LV132-Q100
Nexperia
7. Functional description
Table 3.
Function table
H = HIGH voltage level; L = LOW voltage level.
Input
Output
nA
nB
nY
L
L
H
L
H
H
H
L
H
H
H
L
8. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
[1]
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
VO = 0.5 V to (VCC + 0.5 V)
ICC
IIK
Min
Max
Unit
0.5
+7.0
V
mA
50
mA
25
mA
supply current
50
mA
IGND
ground current
50
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
Tamb = 40 C to +125 C
SO14 package
[2]
500
mW
TSSOP14 package
[3]
500
mW
DHVQFN14 package
[4]
500
mW
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
Ptot derates linearly with 8 mW/K above 70 C.
[3]
Ptot derates linearly with 5.5 mW/K above 60 C.
[4]
Ptot derates linearly with 4.5 mW/K above 60 C.
74LV132_Q100
Product data sheet
4 of 16
74LV132-Q100
Nexperia
9. Recommended operating conditions
Table 5.
Symbol
Parameter
Conditions
Min
[1]
Typ
Max
Unit
VCC
supply voltage
1.0
3.3
5.5
V
VI
input voltage
VCC
V
VO
output voltage
VCC
V
Tamb
ambient temperature
40
+25
+125
C
[1]
The static characteristics are guaranteed from VCC = 1.2 V to VCC = 5.5 V. LV devices are guaranteed to function down to VCC = 1.0 V
(with input levels GND or VCC).
10. Static characteristics
Table 6.
Symbol Parameter
VOH
LOW-level output voltage
VOL
Conditions
40 C to +85 C
40 C to +125 C Unit
Min
Typ[1]
Max
Min
Max
lO = 100 A; VCC = 1.2 V
1.2
V
lO = 100 A; VCC = 2.0 V
1.8
2.0
1.8
V
lO = 100 A; VCC = 2.7 V
2.5
2.7
2.5
V
lO = 100 A; VCC = 3.0 V
2.8
3.0
2.8
V
lO = 100 A; VCC = 4.5 V
4.3
4.5
4.3
V
lO = 6 mA; VCC = 3.0 V
2.4
2.82
2.2
V
lO = 12 mA; VCC = 4.5 V
3.6
4.2
3.5
V
IO = 100 A; VCC = 1.2 V
V
IO = 100 A; VCC = 2.0 V
0.2
V
IO = 100 A; VCC = 2.7 V
0.2
V
IO = 100 A; VCC = 3.0 V
0.2
V
IO = 100 A; VCC = 4.5 V
0.2
V
IO = 6 mA; VCC = 3.0 V
0.25
0.40
0.50
V
IO = 12 mA; VCC = 4.5 V
0.35
0.55
0.65
V
VI = VT+ or VT
VI = VT+ or VT
II
input leakage current
VI = VCC or GND;
VCC = 5.5 V
1.0
1.0
A
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
20.0
40
A
ICC
additional supply current
per input; VI = VCC 0.6 V;
VCC = 2.7 V to 3.6 V
500
850
A
CI
input capacitance
3.5
pF
[1]
Typical values are measured at Tamb = 25 C.
74LV132_Q100
Product data sheet
5 of 16
74LV132-Q100
Nexperia
11. Dynamic characteristics
Table 7.
GND = 0 V; for test circuit, see Figure 7.
Symbol Parameter
propagation delay
tpd
40 C to +85 C
Conditions
power dissipation
capacitance
Unit
Min
Max
Min
Max
VCC = 1.2 V
65
ns
VCC = 2.0 V
18
34
43
ns
[2]
nA, nB to nY; see Figure 6
VCC = 2.7 V
CPD
40 C to +125 C
Typ[1]
15
24
30
ns
VCC = 3.0 V to 3.6 V; CL = 15 pF
[3]
10
ns
[3]
12
ns
VCC = 4.5 V to 5.5 V
[3]
9.0
14
17
ns
CL = 50 pF; fi = 1 MHz;
VI = GND to VCC
[4]
24
pF
[1]
All typical values are measured at Tamb = 25 C.
[2]
tpd is the same as tPLH and tPHL.
[3]
Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V).
[4]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz, fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in V
N = number of inputs switching
(CL VCC2 fo) = sum of the outputs.
12. Waveforms
VI
VM
nA, nB input
GND
t PHL
t PLH
VOH
VM
nY output
VOL
001aaa662
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 6. The input (nA, nB) to output (nY) propagation delays
74LV132_Q100
Product data sheet
6 of 16
74LV132-Q100
Nexperia
Table 8.
Measurement points
Supply voltage
Input
Output
VCC
VM
VM
< 2.7 V
0.5VCC
0.5VCC
2.7 V to 3.6 V
1.5 V
1.5 V
4.5 V
0.5VCC
0.5VCC
VCC
PULSE
GENERATOR
VI
VO
DUT
CL
50 pF
RT
RL
1 kΩ
001aaa663
Test data is given in Table 9.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
Fig 7. Load circuit for switching times
Table 9.
Test data
Supply voltage
Input
VCC
VI
tr, tf
< 2.7 V
VCC
2.5 ns
2.7 V to 3.6 V
2.7 V
2.5 ns
4.5 V
VCC
2.5 ns
13. Transfer characteristics
Table 10. Transfer characteristics
Symbol Parameter
VT+
positive-going
threshold voltage
74LV132_Q100
Product data sheet
40 C to +85 C
Conditions
40 C to +125 C
Unit
Min
Typ[1]
Max
Min
Max
VCC = 1.2 V
0.70
V
see Figure 6
VCC = 2.0 V
0.8
1.10
1.4
0.8
1.4
V
VCC = 2.7 V
1.0
1.45
2.0
1.0
2.0
V
VCC = 3.0 V
1.2
1.60
2.2
1.2
2.2
V
VCC = 3.6 V
1.5
1.95
2.4
1.5
2.4
V
VCC = 4.5 V
1.7
2.50
3.2
1.7
3.2
V
VCC = 5.5 V
2.1
3.00
3.9
2.1
3.9
V
7 of 16
74LV132-Q100
Nexperia
Table 10. Transfer characteristics …continued
Symbol Parameter
VT
negative-going
threshold voltage
hysteresis voltage
VH
[1]
40 C to +85 C
Conditions
40 C to +125 C
Unit
Min
Typ[1]
Max
Min
Max
VCC = 1.2 V
0.34
V
VCC = 2.0 V
0.3
0.65
0.9
0.3
0.9
V
VCC = 2.7 V
0.4
0.90
1.4
0.4
1.4
V
VCC = 3.0 V
0.6
1.05
1.5
0.6
1.5
V
VCC = 3.6 V
0.8
1.30
1.8
0.8
1.8
V
VCC = 4.5 V
0.9
1.60
2.0
0.9
2.0
V
VCC = 5.5 V
1.2
2.00
2.6
1.2
2.6
V
VCC = 1.2 V
0.3
V
VCC = 2.0 V
0.2
0.55
0.8
0.2
0.8
V
VCC = 2.7 V
0.3
0.60
1.1
0.3
1.1
V
VCC = 3.0 V
0.4
0.65
1.2
0.4
1.2
V
VCC = 3.6 V
0.4
0.70
1.2
0.4
1.2
V
VCC = 4.5 V
0.4
0.80
1.4
0.4
1.4
V
VCC = 5.5 V
0.6
1.00
1.5
0.6
1.5
V
see Figure 6
(VT+ VT); see Figure 6
14. Waveforms transfer characteristics
VT+
VO
VI
VH
VT−
VO
VI
VH
VT−
VT+
Fig 8. Transfer characteristic
74LV132_Q100
Product data sheet
mna208
mna207
VT+ and VT limits at 70 % and 20 %.
Fig 9.
Definition of VT+, VT and VH
8 of 16
74LV132-Q100
Nexperia
001aaa659
12
001aaa660
100
ICC
(μA)
ICC
(μA)
80
8
60
40
4
0.6
0.9
1.2
0.8
1.2
1.6
VI (V)
2
VI (V)
VCC = 1.2 V.
VCC = 2.0 V.
Fig 10. Typical 74LV132-Q100 transfer characteristics
Fig 11. Typical 74LV132-Q100 transfer characteristics
001aaa661
300
ICC
(μA)
200
100
1.2
1.8
2.4
3
VI (V)
VCC = 3.0 V.
Fig 12. Typical 74LV132-Q100 transfer characteristics
74LV132_Q100
Product data sheet
9 of 16
74LV132-Q100
Nexperia
15. Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.010 0.057
inches 0.069
0.004 0.049
0.05
0.244
0.039
0.041
0.228
0.016
0.028
0.024
0.01
0.01
0.028
0.004
0.012
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig 13. Package outline SOT108-1 (SO14)
74LV132_Q100
Product data sheet
10 of 16
74LV132-Q100
Nexperia
TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm
SOT402-1
E
D
A
X
c
y
HE
v M A
Z
8
14
Q
(A 3)
A2
A
A1
pin 1 index
θ
Lp
L
1
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.72
0.38
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT402-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig 14. Package outline SOT402-1 (TSSOP14)
74LV132_Q100
Product data sheet
11 of 16
74LV132-Q100
Nexperia
DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT762-1
14 terminals; body 2.5 x 3 x 0.85 mm
A
B
D
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
2
6
y
y1 C
v M C A B
w M C
b
L
1
7
Eh
e
14
8
13
9
Dh
X
5 mm
scale
UNIT
A(1)
max.
A1
b
c
D (1)
Dh
E (1)
Eh
e
e1
L
v
w
y
y1
mm
1
0.05
0.00
0.30
0.18
0.2
3.1
2.9
1.65
1.35
2.6
2.4
1.15
0.85
0.5
2
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT762-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig 15. Package outline SOT762-1 (DHVQFN14)
74LV132_Q100
Product data sheet
12 of 16
74LV132-Q100
Nexperia
16. Abbreviations
Table 11.
Abbreviations
Acronym
Description
CMOS
Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
17. Revision history
Table 12.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LV132_Q100 v.1
20131111
Product data sheet
74LV132_Q100
Product data sheet
13 of 16
74LV132-Q100
Nexperia
18. Legal information
18.1 Data sheet status
Document status[1][2]
Product status[3]
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
Definition
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
18.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
18.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74LV132_Q100
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
14 of 16
74LV132-Q100
Nexperia
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
18.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
19. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74LV132_Q100
Product data sheet
15 of 16
Nexperia
74LV132-Q100
20. Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
12
13
14
15
16
17
18
18.1
18.2
18.3
18.4
19
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 5
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Dynamic characteristics . . . . . . . . . . . . . . . . . . 6
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Transfer characteristics . . . . . . . . . . . . . . . . . . 7
Waveforms transfer characteristics. . . . . . . . . 8
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13
Legal information. . . . . . . . . . . . . . . . . . . . . . . 14
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Contact information. . . . . . . . . . . . . . . . . . . . . 15
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
11 November 2013
Date of release:
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74LV132D-Q100J 74LV132PW-Q100J 74LV132BQ-Q100X
