74LVC1G123
Single retriggerable monostable multivibrator;
Schmitt trigger inputs
Rev. 6 — 2 November 2018
Product data sheet
1. General description
The 74LVC1G123 is a single retriggerable monostable multivibrator with Schmitt trigger inputs.
Output pulse width is controlled by three methods:
1. The basic pulse is programmed by selection of an external resistor (REXT) and capacitor (CEXT).
2. Once triggered, the basic output pulse width may be extended by retriggering the gated active
LOW-going edge input (A) or the active HIGH-going edge input (B). By repeating this process,
the output pulse period (Q = HIGH) can be made as long as desired. Alternatively an output
delay can be terminated at any time by a LOW-going edge on input CLR, which also inhibits the
triggering.
3. An internal connection from CLR to the input gates makes it possible to trigger the circuit by a
HIGH-going signal at input CLR.
Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of these devices
as translators in a mixed 3.3 V and 5 V environment. Schmitt trigger inputs, makes the circuit highly
tolerant to slower input rise and fall times.
This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry
disables the output, preventing the damaging backflow current through the device when it is
powered down.
2. Features and benefits
Wide supply voltage range from 1.65 V to 5.5 V
High noise immunity
±24 mA output drive (VCC = 3.0 V)
CMOS low power consumption
DC triggered from active HIGH or active LOW inputs
Retriggerable for very long pulses up to 100 % duty factor
Direct reset terminates output pulse
Schmitt trigger on all inputs
Complies with JEDEC standard:
• JESD8-7 (1.65 V to 1.95 V)
• JESD8-5 (2.3 V to 2.7 V)
• JESD8-B/JESD36 (2.7 V to 3.6 V)
Power-on-reset on outputs
Latch-up performance exceeds 100 mA
Direct interface with TTL levels
Inputs accept voltages up to 5.5 V
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V
• CDM JESD22-C101E exceeds 1000 V
Multiple package options
Specified from -40 °C to +85 °C and -40 °C to +125 °C
74LVC1G123
Nexperia
Single retriggerable monostable multivibrator; Schmitt trigger inputs
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range Name
Description
Version
74LVC1G123DP
-40 °C to +125 °C
TSSOP8
plastic thin shrink small outline package; 8 leads; SOT505-2
body width 3 mm; lead length 0.5 mm
74LVC1G123DC
-40 °C to +125 °C
VSSOP8
plastic very thin shrink small outline package;
8 leads; body width 2.3 mm
SOT765-1
74LVC1G123GT
-40 °C to +125 °C
XSON8
plastic extremely thin small outline package;
no leads; 8 terminals; body 1 x 1.95 x 0.5 mm
SOT833-1
74LVC1G123GF
-40 °C to +125 °C
XSON8
extremely thin small outline package; no leads;
8 terminals; body 1.35 x 1 x 0.5 mm
SOT1089
74LVC1G123GN
-40 °C to +125 °C
XSON8
8 terminals; body 1.2 x 1.0 x 0.35 mm
SOT1116
74LVC1G123GS
-40 °C to +125 °C
XSON8
8 terminals; body 1.35 x 1.0 x 0.35 mm
SOT1203
4. Marking
Table 2. Marking codes
Type number
Marking code[1]
74LVC1G123DP
Y3
74LVC1G123DC
Y3
74LVC1G123GT
Y3
74LVC1G123GF
Y3
74LVC1G123GN
Y3
74LVC1G123GS
Y3
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
CEXT
REXT/CEXT
1
3
7
A
Q
2
6
Q
5
B
CLR
R
aaa-001871
Fig. 1.
Logic symbol
74LVC1G123
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2018. All rights reserved
2 / 25
74LVC1G123
Nexperia
VCC
REXT/CEXT
CEXT
CLR
R
R
CL
VCC
Q
CL
R
VCC
CL
CL
A
CL
B
R
Fig. 2.
aaa-001872
Logic diagram
6. Pinning information
6.1. Pinning
74LVC1G123
74LVC1G123
A
1
8
VCC
B
2
7
REXT/CEXT
CLR
3
6
CEXT
GND
4
5
Q
A
1
8
VCC
B
2
7
REXT/CEXT
CLR
3
6
CEXT
GND
4
5
Q
aaa-001874
Transparent top view
aaa-001873
Fig. 3.
Pin configuration SOT505-2 (TSSOP8) and
SOT765-1 (VSSOP8)
74LVC1G123
Product data sheet
Fig. 4.
Pin configuration SOT833-1, SOT1089, SOT1116
and SOT1203 (XSON8)
3 / 25
74LVC1G123
Nexperia
6.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
A
1
negative-edge triggered input
B
2
positive-edge triggered input
CLR
3
direct reset LOW and positive-edge triggered input
GND
4
ground (0 V)
Q
5
active HIGH output
CEXT
6
external capacitor connection
REXT/CEXT
7
external resistor and capacitor connection
VCC
8
supply voltage
7. Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care; ↑ = LOW-to-HIGH transition; ↓ = HIGH-to-LOW transition;
= one HIGH level output pulse.
Output
Input
CLR
A
B
Q
L
X
X
L
X
H
X
L[1]
X
X
L
L[1]
H
L
H
H
L
H
[1]
If the monostable was triggered before this condition was established, the pulse continues as programmed.
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
Min
Max
Unit
VCC
supply voltage
-0.5
+6.5
V
VI
input voltage
[1]
-0.5
+6.5
V
VO
output voltage
[1]
-0.5
VCC + 0.5
V
IIK
input clamping current
VI < 0 V
[1][2]
-0.5
+6.5
V
-50
mA
IOK
output clamping current
VO < 0 V or VO > VCC
±50
mA
IO
output current
VO = 0 V to VCC
±50
mA
ICC
supply current
100
mA
IGND
ground current
-100
mA
Tstg
storage temperature
-65
+150
°C
Active mode
Power-down mode
74LVC1G123
Product data sheet
4 / 25
74LVC1G123
Nexperia
Symbol
Parameter
Conditions
Ptot
total power dissipation
Tamb = -40 °C to +125 °C
[1]
[2]
[3]
Min
Max
Unit
300
mW
[3]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation.
For TSSOP8 package: above 55 °C the value of Ptot derates linearly with 2.5 mW/K.
For VSSOP8 package: above 110 °C the value of Ptot derates linearly with 8 mW/K.
For XSON8 packages: above 118 °C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 6. Operating conditions
Symbol
Parameter
Conditions
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
Active mode
Power-down mode
VCC = 1.65 V to 5.5 V
Min
Max
Unit
1.65
5.5
V
V
VCC
V
V
-40
+125
°C
1
ms/V
10. Static characteristics
Table 7. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ[1]
Max
Unit
VCC - 0.1
V
IO = -4 mA; VCC = 1.65 V
1.2
V
IO = -8 mA; VCC = 2.3 V
1.9
V
IO = -12 mA; VCC = 2.7 V
2.2
V
IO = -24 mA; VCC = 3.0 V
2.4
V
IO = -32 mA; VCC = 4.5 V
3.8
V
IO = 100 μA; VCC = 1.65 V to 5.5 V
0.1
V
IO = 4 mA; VCC = 1.65 V
0.45
V
IO = 8 mA; VCC = 2.3 V
0.3
V
IO = 12 mA; VCC = 2.7 V
0.4
V
IO = 24 mA; VCC = 3.0 V
0.55
V
IO = 32 mA; VCC = 4.5 V
0.55
V
±2
μA
±2
μA
Tamb = -40 °C to +85 °C
VOH
VOL
HIGH-level
output voltage
LOW-level
output voltage
VI = VT+ or VTIO = -100 μA; VCC = 1.65 V to 5.5 V
VI = VT+ or VT-
II
input leakage
current
IOFF
power-off
VI or VO = 5.5 V; VCC = 0 V
leakage current
74LVC1G123
Product data sheet
VI = 5.5 V or GND; VCC = 0 V to 5.5 V
5 / 25
74LVC1G123
Nexperia
Symbol Parameter
Conditions
ICC
VI = 5.5 V or GND;
supply current
Min
Typ[1]
Max
0.1
10
μA
VCC = 1.65 V
80
μA
VCC = 2.3 V
130
μA
VCC = 3 V
240
μA
VCC = 4.5 V
400
μA
VCC = 5.5 V
650
μA
2.0
pF
Quiescent; VCC = 1.65 V to 5.5 V; IO = 0 A
Unit
Active state; REXT/CEXT = 0.5VCC
CI
input
capacitance
VOH
VOL
HIGH-level
output voltage
LOW-level
output voltage
VCC - 0.1
V
1.2
V
1.9
V
2.2
V
2.4
V
3.8
V
0.1
V
0.45
V
0.3
V
0.4
V
0.55
V
0.55
V
±10
μA
±10
μA
μA
VCC = 1.65 V
80
μA
VCC = 2.3 V
130
μA
VCC = 3 V
240
μA
VCC = 4.5 V
400
μA
VCC = 5.5 V
650
μA
VI = VT+ or VT-
II
input leakage
current
IOFF
power-off
leakage current
ICC
supply current
VI = 5.5 V or GND;
[1]
All typical values are measured at Tamb = 25 °C.
74LVC1G123
Product data sheet
6 / 25
74LVC1G123
Nexperia
Table 8. Transfer characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 17.
Symbol Parameter
Conditions
VT+
A, B and CLR input; see Fig. 5
positive-going
threshold voltage
VT-
negative-going
threshold voltage
-40 °C to +125 °C
Unit
Min
Typ[1]
Max
Min
Max
VCC = 1.65 V to 1.95 V
0.72
0.98
1.22
0.71
1.22
V
VCC = 2.3 V to 2.7 V
0.97
1.26
1.52
0.97
1.52
V
VCC = 3.0 V to 3.6 V
1.20
1.58
1.90
1.20
1.90
V
VCC = 4.5 V to 5.5 V
1.74
2.27
2.75
1.74
2.78
V
0.56
0.81
1.04
0.56
1.04
V
0.83
1.09
1.33
0.82
1.33
V
1.08
1.40
1.70
1.08
1.72
V
1.61
2.07
2.53
1.61
2.57
V
61
170
295
54
295
mV
41
174
304
41
304
mV
40
183
319
40
319
mV
32
199
363
26
363
mV
hysteresis voltage A, B and CLR input; (VT+ - VT-);
see Fig. 5
VH
[1]
-40 °C to +85 °C
Typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 3.3 V and 5.0 V respectively.
10.1. Waveform transfer characteristics
aaa-001877
4
lCC
(mA)
3
2
1
2
VI (V)
3
VCC = 3.0 V.
Fig. 5.
Typical transfer characteristics
74LVC1G123
Product data sheet
7 / 25
74LVC1G123
Nexperia
11. Dynamic characteristics
Table 9. Dynamic characteristics
Symbol Parameter
tpd
propagation
delay
Conditions
-40 °C to +85 °C
-40 °C to +125 °C Unit
Min
Typ[1]
Max
Min
Max
2.5
7.1
16.3
2.5
17.6
ns
1.9
10.3
1.9
11.2
ns
VCC = 2.7 V
1.9
8.5
1.9
9.3
ns
1.5
7.6
1.5
8.3
ns
1.2
5.3
1.2
5.8
ns
2.9
7.8
17.6
2.9
19.0
ns
2.2
11.3
2.2
12.3
ns
VCC = 2.7 V
2.7
10.5
2.7
11.4
ns
2.0
9.5
2.0
10.3
ns
1.5
6.7
1.5
7.2
ns
3.0
6.9
16.2
3.0
17.4
ns
2.2
9.6
2.2
10.5
ns
VCC = 2.7 V
2.2
8.2
2.2
8.9
ns
2.0
7.3
2.0
8.0
ns
1.5
5.1
1.5
5.5
ns
3.3
7.5
17.2
3.8
18.6
ns
2.5
10.3
2.0
11.2
ns
VCC = 2.7 V
2.8
9.3
2.8
10.2
ns
1.5
8.4
1.5
9.2
ns
1.5
6.0
1.5
6.6
ns
2.7
7.6
17.4
2.7
18.9
ns
2.1
11.0
2.1
12.0
ns
VCC = 2.7 V
2.1
9.2
2.1
10.0
ns
1.7
8.2
1.7
8.9
ns
1.4
5.9
1.4
6.4
ns
3.1
8.3
18.8
3.3
20.3
ns
2.5
12.0
2.5
13.1
ns
VCC = 2.7 V
2.8
11.1
2.8
12.1
ns
2.0
10.1
2.0
11.0
ns
1.5
7.1
1.5
7.7
ns
A, B to Q; see Fig. 6
[2]
CL = 15 pF;
CL = 30 pF or CL = 50 pF
CLR to Q; see Fig. 6
CL = 15 pF;
tpd
propagation
delay
CLR to Q (trigger); see Fig. 6
[2]
CL = 15 pF;
74LVC1G123
Product data sheet
8 / 25
74LVC1G123
Nexperia
Symbol Parameter
tW
pulse width
Conditions
-40 °C to +85 °C
Min
Typ[1]
Max
Min
Max
8.0
8.0
ns
4.0
4.0
ns
VCC = 2.7 V
3.0
3.0
ns
3.0
3.0
ns
2.5
2.5
ns
8.0
8.0
ns
4.0
4.0
ns
VCC = 2.7 V
3.0
3.0
ns
3.0
3.0
ns
2.5
2.5
ns
1.4
2.2
2.2
μs
1.3
1.8
1.8
μs
VCC = 2.7 V
1.2
1.8
1.8
μs
1.2
1.8
1.8
μs
1.2
1.8
1.8
μs
100
110
110
μs
100
110
110
μs
VCC = 2.7 V
100
110
110
μs
100
110
110
μs
100
110
110
μs
1.0
1.05
1.05
ms
VCC = 2.7 V
1.0
1.05
1.05
ms
1.0
1.05
1.05
ms
1.0
1.05
1.05
ms
1.0
1.05
1.05
ms
input A LOW; B HIGH; see Fig. 6 and Fig. 7
input CLR LOW; see Fig. 6 and Fig. 8
tW
pulse width
output Q HIGH; see Fig. 6, Fig. 7 and Fig. 8; [3]
REXT = 10 kΩ
CEXT = 100 pF
CEXT = 0.01 μF
[3]
CEXT = 0.1 μF
74LVC1G123
Product data sheet
[3]
9 / 25
74LVC1G123
Nexperia
Symbol Parameter
Conditions
-40 °C to +85 °C
Min
Typ[1]
Max
Min
Max
174
ns
59
ns
32
ns
ns
14
ms
10
ms
10
ms
8
ms
VCC = 2.0 V
5
kΩ
VCC ≥ 3.0 V
1
kΩ
pF
VCC = 1.8 V
35
pF
VCC = 2.5 V
35
pF
VCC = 3.3 V
27
pF
VCC = 5.0 V
29
pF
retrigger time A, B; see Fig. 7
trtrig
CEXT = 100 pF; REXT = 5 kΩ
CEXT = 100 pF; REXT = 1 kΩ
CEXT = 100 μF; REXT = 5 kΩ
CEXT = 100 μF; REXT = 1 kΩ
Rext
external
resistance
see Fig. 11, Fig. 12 and Fig. 13
Cext
external
capacitance
VCC = 5.0 V; see Fig. 11, Fig. 12 and Fig. 13
CPD
power
dissipation
capacitance
VI = GND to VCC; CEXT = 0 pF;
REXT = 5 kΩ
REXT = 1 kΩ
[1]
[2]
[3]
tpd is the same as tPHL and tPLH
For other REXT and CEXT combinations see Fig. 11, Fig. 12 and Fig. 13. If CEXT > 10 nF, the next formula is valid.
tW = K x REXT x CEXT, where:
tW = typical output pulse width in ns;
REXT = external resistor in kΩ;
CEXT = external capacitor in pF;
K = constant = 1; see Fig. 14 for typical "K" factor as function of VCC.
74LVC1G123
Product data sheet
10 / 25
74LVC1G123
Nexperia
11.1. Waveforms, graphs and test circuit
VI
B input
GND
VM
tW
VI
A input
VM
GND
tW
VI
CLR input
GND
VM
tPLH
tPLH
VOH
Q output
VOL
tW
tPHL
(reset)
tPLH
VM
tW
tW
aaa-001878
Measurement points are given in Table 10.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig. 6.
Propagation delays from inputs (A, B, CLR) to output (Q)
Table 10. Measurement points
Supply voltage
Input
Output
VCC
VM
VM
1.65 V to 1.95 V
0.5VCC
0.5VCC
2.3 V to 2.7 V
0.5VCC
0.5VCC
2.7 V
1.5 V
1.5 V
3.0 V to 3.6 V
1.5 V
1.5 V
4.5 V to 5.5 V
0.5VCC
0.5VCC
74LVC1G123
Product data sheet
11 / 25
74LVC1G123
Nexperia
B input
tW
A input
trtrig
tW
Q output
tW
tW
tW
aaa-001879
CLR = HIGH
Fig. 7.
Output pulse control using retrigger pulse
B input
CLR input
tW
Q output
tW
tW
aaa-001880
A = LOW
Fig. 8.
Output pulse control using reset input CLR
trtrig
A input
B input
CLR input
REXT/CEXT
Q output
tW
tW
tW + trtrig
aaa-001881
Fig. 9.
Input and output timing
74LVC1G123
Product data sheet
12 / 25
74LVC1G123
Nexperia
VCC
REXT
CEXT
to CEXT
(pin 6)
to REXT/CEXT
(pin 7)
aaa-001882
Fig. 10. Timing component connections
tW
(ns)
aaa-000298
109
(1)
(2)
(3)
(4)
108
107
aaa-000299
109
(1)
(2)
(3)
(4)
(5)
108
107
106
106
105
105
104
104
103
103
102
102
10
tW
(ns)
10
1
10
102
103
104
105
106
CEXT (pF)
VCC = 1.8 V; Tamb = 25 °C.
(1) REXT = 200 kΩ
(2) REXT = 100 kΩ
(3) REXT = 10 kΩ
(4) REXT = 5 kΩ
Fig. 11. Typical output pulse width as a function of the
external capacitor value
74LVC1G123
Product data sheet
1
10
102
103
104
105
106
CEXT (pF)
VCC = 3.3 V; Tamb = 25 °C.
(1) REXT = 200 kΩ
(2) REXT = 100 kΩ
(3) REXT = 10 kΩ
(4) REXT = 5 kΩ
(5) REXT = 1 kΩ
Fig. 12. Typical output pulse width as a function of the
13 / 25
74LVC1G123
Nexperia
tW
(ns)
aaa-000300
109
(1)
(2)
(3)
(4)
(5)
108
107
aaa-000301
1.2
'K'
factor
106
1.1
105
(1)
104
(2)
1.0
103
(3)
102
10
0.9
1
10
102
103
104
105
106
CEXT (pF)
VCC = 5.0 V; Tamb = 25 °C.
(1) REXT = 200 kΩ
(2) REXT = 100 kΩ
(3) REXT = 10 kΩ
(4) REXT = 5 kΩ
(5) REXT = 1 kΩ
0.8
Fig. 13. Typical output pulse width as a function of the
4
VCC (V)
6
REXT = 10 kΩ; Tamb = 25 °C.
(1) CEXT = 1000 pF
(2) CEXT = 0.01 μF
(3) CEXT = 0.1 μF
Fig. 14. Typical ‘K’ factor as function of VCC
aaa-001943
10
trtrig
(µs)
(1)
1
(2)
10-1
(3)
(4)
10-2
10-3
1.5
2.5
3.5
4.5
VCC (V)
5.5
Tamb = 25 °C.
(1) CEXT = 0.01 μF
(2) CEXT = 1000 pF
(3) CEXT = 100 pF
(4) CEXT = 10 pF
Fig. 15. Minimum retrigger time as function of the supply voltage
74LVC1G123
Product data sheet
14 / 25
74LVC1G123
Nexperia
aaa-000303
1.45
'K'
factor
1.35
(1)
(2)
1.25
(3)
(4)
1.15
1.05
0.95
102
103
104
105
106
CEXT (pF)
(1) VCC = 1.8 V
(2) VCC = 2.5 V
(3) VCC = 3.3 V
(4) VCC = 5.0 V
Fig. 16. Typical ‘K’ factor as function of CEXT
74LVC1G123
Product data sheet
15 / 25
74LVC1G123
Nexperia
VI
negative
pulse
tW
90 %
VM
0V
VI
tf
tr
tr
tf
90 %
positive
pulse
0V
VM
10 %
VM
VM
10 %
tW
VEXT
VCC
PULSE
GENERATOR
VI
RL
VO
DUT
RT
CL
RL
001aae235
Test data is given in Table 11.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = Test voltage for switching times.
Fig. 17. Test circuit for measuring switching times
Table 11. Test data
Supply voltage
Input
VEXT
Load
VCC
VI
tr, tf
CL
RL
tPLH, tPHL
1.65 V to 1.95 V
VCC
≤ 2.0 ns
15 pF
1 MΩ
open
2.3 V to 2.7 V
VCC
≤ 2.0 ns
15 pF
1 MΩ
open
2.7 V
2.7 V
≤ 2.5 ns
15 pF
1 MΩ
open
3.0 V to 3.6 V
2.7 V
≤ 2.5 ns
15 pF
1 MΩ
open
4.5 V to 5.5 V
VCC
≤ 2.5 ns
15 pF
1 MΩ
open
1.65 V to 1.95 V
VCC
≤ 2.0 ns
30 pF
1 kΩ
open
2.3 V to 2.7 V
VCC
≤ 2.0 ns
30 pF
500 Ω
open
2.7 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
3.0 V to 3.6 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
4.5 V to 5.5 V
VCC
≤ 2.5 ns
50 pF
500 Ω
open
74LVC1G123
Product data sheet
16 / 25
74LVC1G123
Nexperia
12. Package outline
TSSOP8: plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm
D
E
A
SOT505-2
X
c
HE
y
v M A
Z
5
8
A
A2
pin 1 index
(A3)
A1
θ
Lp
L
1
4
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.15
0.00
0.95
0.75
0.25
0.38
0.22
0.18
0.08
3.1
2.9
3.1
2.9
0.65
4.1
3.9
0.5
0.47
0.33
0.2
0.13
0.1
0.70
0.35
8°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT505-2
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-01-16
Fig. 18. Package outline SOT505-2 (TSSOP8)
74LVC1G123
Product data sheet
17 / 25
74LVC1G123
Nexperia
VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm
D
SOT765-1
E
A
X
c
y
HE
v
A
Z
5
8
Q
A
A2
A1
pin 1 index
(A3)
θ
Lp
1
detail X
4
e
L
w
bp
5 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
A
max.
max
nom
min
1
A1
A2
0.15 0.85
0.00 0.60
A3
0.12
D(1)
E(2)
0.27 0.23
2.1
2.4
0.17 0.08
1.9
2.2
bp
c
e
HE
0.5
3.2
3.0
L
0.4
Lp
Q
0.40 0.21
0.15 0.19
v
w
y
0.2
0.08
0.1
Z(1)
θ
0.4
8°
0.1
0°
Note
2. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
Outline
version
SOT765-1
References
IEC
JEDEC
JEITA
sot765-1_po
European
projection
Issue date
07-06-02
16-05-31
MO-187
Fig. 19. Package outline SOT765-1 (VSSOP8)
74LVC1G123
Product data sheet
18 / 25
74LVC1G123
Nexperia
XSON8: plastic extremely thin small outline package; no leads; 8 terminals; body 1 x 1.95 x 0.5 mm
1
2
SOT833-1
b
4
3
4×
(2)
L
L1
e
8
7
6
e1
5
e1
e1
8×
A
(2)
A1
D
E
terminal 1
index area
2 mm
scale
UNIT
A(1)
max
A1
max
b
D
E
e
e1
L
L1
mm
0.5
0.04
0.25
0.17
2.0
1.9
1.05
0.95
0.6
0.5
0.35
0.27
0.40
0.32
Notes
1. Including plating thickness.
2. Can be visible in some manufacturing processes.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT833-1
MO-252
EUROPEAN
PROJECTION
ISSUE DATE
07-11-14
07-12-07
Fig. 20. Package outline SOT833-1 (XSON8)
74LVC1G123
Product data sheet
19 / 25
74LVC1G123
Nexperia
XSON8: extremely thin small outline package; no leads;
SOT1089
E
terminal 1
index area
D
A
A1
detail X
(4×)(2)
e
L
(8×)(2)
b 4
5
e1
1
terminal 1
index area
8
L1
X
scale
Dimensions
Unit
mm
max
nom
min
1 mm
A(1)
0.5
A1
b
D
E
e
e1
L
L1
0.04 0.20 1.40 1.05
0.35 0.40
0.15 1.35 1.00 0.55 0.35 0.30 0.35
0.12 1.30 0.95
0.27 0.32
Note
2. Visible depending upon used manufacturing technology.
Outline
version
SOT1089
sot1089_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-09
10-04-12
MO-252
Fig. 21. Package outline SOT1089 (XSON8)
74LVC1G123
Product data sheet
20 / 25
74LVC1G123
Nexperia
1
2
SOT1116
b
4
3
(4×)(2)
L
L1
e
8
7
6
e1
e1
5
e1
(8×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
e1
max 0.35 0.04 0.20 1.25 1.05
nom
0.15 1.20 1.00 0.55
min
0.12 1.15 0.95
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
0.3
Note
Outline
version
sot1116_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-07
SOT1116
Fig. 22. Package outline SOT1116 (XSON8)
74LVC1G123
Product data sheet
21 / 25
74LVC1G123
Nexperia
SOT1203
b
1
2
3
(4×)(2)
4
L
L1
e
8
7
6
e1
e1
5
e1
(8×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
e1
L
L1
max 0.35 0.04 0.20 1.40 1.05
0.35 0.40
nom
min
0.12 1.30 0.95
0.27 0.32
Note
Outline
version
sot1203_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-06
SOT1203
Fig. 23. Package outline SOT1203 (XSON8)
74LVC1G123
Product data sheet
22 / 25
74LVC1G123
Nexperia
13. Abbreviations
Table 12. Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 13. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LVC1G123 v.6
20181102
Product data sheet
74LVC1G123 v.5
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type numbers 74LVC1G123GD (SOT996-2/XSON8) removed.
74LVC1G123 v.5
20160614
Modifications:
74LVC1G123 v.4
20131127
Modifications:
74LVC1G123 v.3
20130329
Modifications:
74LVC1G123 v.2
20120801
Modifications:
74LVC1G123 v.1
20120123
74LVC1G123
Product data sheet
Product data sheet
74LVC1G123 v.4
Fig. 19, package outline drawing for SOT765-1 has changed
Product data sheet
74LVC1G123 v.3
74LVC1G123 v.2
74LVC1G123GM (XQFN8) removed.
Product data sheet
For type number 74LVC1G123GD XSON8U has changed to XSON8.
Product data sheet
74LVC1G123 v.1
VHYS conditions and limits corrected (errata).
Product data sheet
23 / 25
74LVC1G123
Nexperia
15. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74LVC1G123
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
24 / 25
74LVC1G123
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................2
4. Marking.......................................................................... 2
5. Functional diagram.......................................................2
6. Pinning information......................................................3
6.1. Pinning.........................................................................3
6.2. Pin description............................................................. 4
7. Functional description................................................. 4
8. Limiting values............................................................. 4
9. Recommended operating conditions..........................5
10. Static characteristics..................................................5
10.1. Waveform transfer characteristics............................. 7
11. Dynamic characteristics.............................................8
11.1. Waveforms, graphs and test circuit..........................11
12. Package outline........................................................ 17
13. Abbreviations............................................................ 23
14. Revision history........................................................23
15. Legal information......................................................24
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 2 November 2018
74LVC1G123
Product data sheet
25 / 25
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74LVC1G123GT,115 74LVC1G123DC-Q100H 74LVC1G123DP-Q100H 74LVC1G123GN,115 74LVC1G123GS,115
74LVC1G123GM,125 74LVC1G123DP,125 74LVC1G123GD,125 74LVC1G123DC,125 74LVC1G123GF,115
