74LVC1G123GF,115
74LVC1G123GF,115
    NEXPERIA(安世)
    XSON8_1.35X1MM
    单重触发单稳多谐振荡器;施密特触发器的输入
74LVC1G123GF,115 数据手册
74LVC1G123 Single retriggerable monostable multivibrator; Schmitt trigger inputs Rev. 6 — 2 November 2018 Product data sheet 1. General description The 74LVC1G123 is a single retriggerable monostable multivibrator with Schmitt trigger inputs. Output pulse width is controlled by three methods: 1. The basic pulse is programmed by selection of an external resistor (REXT) and capacitor (CEXT). 2. Once triggered, the basic output pulse width may be extended by retriggering the gated active LOW-going edge input (A) or the active HIGH-going edge input (B). By repeating this process, the output pulse period (Q = HIGH) can be made as long as desired. Alternatively an output delay can be terminated at any time by a LOW-going edge on input CLR, which also inhibits the triggering. 3. An internal connection from CLR to the input gates makes it possible to trigger the circuit by a HIGH-going signal at input CLR. Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of these devices as translators in a mixed 3.3 V and 5 V environment. Schmitt trigger inputs, makes the circuit highly tolerant to slower input rise and fall times. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2. Features and benefits • • • • • • • • • • • • • • • • Wide supply voltage range from 1.65 V to 5.5 V High noise immunity ±24 mA output drive (VCC = 3.0 V) CMOS low power consumption DC triggered from active HIGH or active LOW inputs Retriggerable for very long pulses up to 100 % duty factor Direct reset terminates output pulse Schmitt trigger on all inputs Complies with JEDEC standard: • JESD8-7 (1.65 V to 1.95 V) • JESD8-5 (2.3 V to 2.7 V) • JESD8-B/JESD36 (2.7 V to 3.6 V) Power-on-reset on outputs Latch-up performance exceeds 100 mA Direct interface with TTL levels Inputs accept voltages up to 5.5 V ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V • CDM JESD22-C101E exceeds 1000 V Multiple package options Specified from -40 °C to +85 °C and -40 °C to +125 °C 74LVC1G123 Nexperia Single retriggerable monostable multivibrator; Schmitt trigger inputs 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC1G123DP -40 °C to +125 °C TSSOP8 plastic thin shrink small outline package; 8 leads; SOT505-2 body width 3 mm; lead length 0.5 mm 74LVC1G123DC -40 °C to +125 °C VSSOP8 plastic very thin shrink small outline package; 8 leads; body width 2.3 mm SOT765-1 74LVC1G123GT -40 °C to +125 °C XSON8 plastic extremely thin small outline package; no leads; 8 terminals; body 1 x 1.95 x 0.5 mm SOT833-1 74LVC1G123GF -40 °C to +125 °C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.35 x 1 x 0.5 mm SOT1089 74LVC1G123GN -40 °C to +125 °C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.2 x 1.0 x 0.35 mm SOT1116 74LVC1G123GS -40 °C to +125 °C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.35 x 1.0 x 0.35 mm SOT1203 4. Marking Table 2. Marking codes Type number Marking code[1] 74LVC1G123DP Y3 74LVC1G123DC Y3 74LVC1G123GT Y3 74LVC1G123GF Y3 74LVC1G123GN Y3 74LVC1G123GS Y3 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram CEXT REXT/CEXT 1 3 7 A Q 2 6 Q 5 B CLR R aaa-001871 Fig. 1. Logic symbol 74LVC1G123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 2 November 2018 © Nexperia B.V. 2018. All rights reserved 2 / 25 74LVC1G123 Nexperia Single retriggerable monostable multivibrator; Schmitt trigger inputs VCC REXT/CEXT CEXT CLR R R CL VCC Q CL R VCC CL CL A CL B R Fig. 2. aaa-001872 Logic diagram 6. Pinning information 6.1. Pinning 74LVC1G123 74LVC1G123 A 1 8 VCC B 2 7 REXT/CEXT CLR 3 6 CEXT GND 4 5 Q A 1 8 VCC B 2 7 REXT/CEXT CLR 3 6 CEXT GND 4 5 Q aaa-001874 Transparent top view aaa-001873 Fig. 3. Pin configuration SOT505-2 (TSSOP8) and SOT765-1 (VSSOP8) 74LVC1G123 Product data sheet Fig. 4. Pin configuration SOT833-1, SOT1089, SOT1116 and SOT1203 (XSON8) All information provided in this document is subject to legal disclaimers. Rev. 6 — 2 November 2018 © Nexperia B.V. 2018. All rights reserved 3 / 25 74LVC1G123 Nexperia Single retriggerable monostable multivibrator; Schmitt trigger inputs 6.2. Pin description Table 3. Pin description Symbol Pin Description A 1 negative-edge triggered input B 2 positive-edge triggered input CLR 3 direct reset LOW and positive-edge triggered input GND 4 ground (0 V) Q 5 active HIGH output CEXT 6 external capacitor connection REXT/CEXT 7 external resistor and capacitor connection VCC 8 supply voltage 7. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; ↑ = LOW-to-HIGH transition; ↓ = HIGH-to-LOW transition; = one HIGH level output pulse. Output Input CLR A B Q L X X L X H X L[1] X X L L[1] H L ↑ H ↓ H ↑ L H [1] If the monostable was triggered before this condition was established, the pulse continues as programmed. 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit VCC supply voltage -0.5 +6.5 V VI input voltage [1] -0.5 +6.5 V VO output voltage [1] -0.5 VCC + 0.5 V IIK input clamping current VI < 0 V [1][2] -0.5 +6.5 V -50 - mA IOK output clamping current VO < 0 V or VO > VCC - ±50 mA IO output current VO = 0 V to VCC - ±50 mA ICC supply current - 100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Active mode Power-down mode 74LVC1G123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 2 November 2018 © Nexperia B.V. 2018. All rights reserved 4 / 25 74LVC1G123 Nexperia Single retriggerable monostable multivibrator; Schmitt trigger inputs Symbol Parameter Conditions Ptot total power dissipation Tamb = -40 °C to +125 °C [1] [2] [3] Min Max Unit - 300 mW [3] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation. For TSSOP8 package: above 55 °C the value of Ptot derates linearly with 2.5 mW/K. For VSSOP8 package: above 110 °C the value of Ptot derates linearly with 8 mW/K. For XSON8 packages: above 118 °C the value of Ptot derates linearly with 7.8 mW/K. 9. Recommended operating conditions Table 6. Operating conditions Symbol Parameter Conditions VCC supply voltage VI input voltage VO output voltage Tamb ambient temperature Δt/ΔV input transition rise and fall rate Active mode Power-down mode VCC = 1.65 V to 5.5 V Min Max Unit 1.65 5.5 V 0 5.5 V 0 VCC V 0 5.5 V -40 +125 °C - 1 ms/V 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ[1] Max Unit VCC - 0.1 - - V IO = -4 mA; VCC = 1.65 V 1.2 - - V IO = -8 mA; VCC = 2.3 V 1.9 - - V IO = -12 mA; VCC = 2.7 V 2.2 - - V IO = -24 mA; VCC = 3.0 V 2.4 - - V IO = -32 mA; VCC = 4.5 V 3.8 - - V IO = 100 μA; VCC = 1.65 V to 5.5 V - - 0.1 V IO = 4 mA; VCC = 1.65 V - - 0.45 V IO = 8 mA; VCC = 2.3 V - - 0.3 V IO = 12 mA; VCC = 2.7 V - - 0.4 V IO = 24 mA; VCC = 3.0 V - - 0.55 V IO = 32 mA; VCC = 4.5 V - - 0.55 V - - ±2 μA - - ±2 μA Tamb = -40 °C to +85 °C VOH VOL HIGH-level output voltage LOW-level output voltage VI = VT+ or VTIO = -100 μA; VCC = 1.65 V to 5.5 V VI = VT+ or VT- II input leakage current IOFF power-off VI or VO = 5.5 V; VCC = 0 V leakage current 74LVC1G123 Product data sheet VI = 5.5 V or GND; VCC = 0 V to 5.5 V All information provided in this document is subject to legal disclaimers. Rev. 6 — 2 November 2018 © Nexperia B.V. 2018. All rights reserved 5 / 25 74LVC1G123 Nexperia Single retriggerable monostable multivibrator; Schmitt trigger inputs Symbol Parameter Conditions ICC VI = 5.5 V or GND; supply current Min Typ[1] Max - 0.1 10 μA VCC = 1.65 V - - 80 μA VCC = 2.3 V - - 130 μA VCC = 3 V - - 240 μA VCC = 4.5 V - - 400 μA VCC = 5.5 V - - 650 μA - 2.0 - pF Quiescent; VCC = 1.65 V to 5.5 V; IO = 0 A Unit Active state; REXT/CEXT = 0.5VCC CI input capacitance Tamb = -40 °C to +125 °C VOH VOL HIGH-level output voltage LOW-level output voltage VI = VT+ or VTIO = -100 μA; VCC = 1.65 V to 5.5 V VCC - 0.1 - - V IO = -4 mA; VCC = 1.65 V 1.2 - - V IO = -8 mA; VCC = 2.3 V 1.9 - - V IO = -12 mA; VCC = 2.7 V 2.2 - - V IO = -24 mA; VCC = 3.0 V 2.4 - - V IO = -32 mA; VCC = 4.5 V 3.8 - - V IO = 100 μA; VCC = 1.65 V to 5.5 V - - 0.1 V IO = 4 mA; VCC = 1.65 V - - 0.45 V IO = 8 mA; VCC = 2.3 V - - 0.3 V IO = 12 mA; VCC = 2.7 V - - 0.4 V IO = 24 mA; VCC = 3.0 V - - 0.55 V IO = 32 mA; VCC = 4.5 V - - 0.55 V - - ±10 μA - - ±10 μA - - 20 μA VCC = 1.65 V - - 80 μA VCC = 2.3 V - - 130 μA VCC = 3 V - - 240 μA VCC = 4.5 V - - 400 μA VCC = 5.5 V - - 650 μA VI = VT+ or VT- II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V IOFF power-off VI or VO = 5.5 V; VCC = 0 V leakage current ICC supply current VI = 5.5 V or GND; Quiescent; VCC = 1.65 V to 5.5 V; IO = 0 A Active state; REXT/CEXT = 0.5VCC [1] All typical values are measured at Tamb = 25 °C. 74LVC1G123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 2 November 2018 © Nexperia B.V. 2018. All rights reserved 6 / 25 74LVC1G123 Nexperia Single retriggerable monostable multivibrator; Schmitt trigger inputs Table 8. Transfer characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 17. Symbol Parameter Conditions VT+ A, B and CLR input; see Fig. 5 positive-going threshold voltage VT- negative-going threshold voltage -40 °C to +125 °C Unit Min Typ[1] Max Min Max VCC = 1.65 V to 1.95 V 0.72 0.98 1.22 0.71 1.22 V VCC = 2.3 V to 2.7 V 0.97 1.26 1.52 0.97 1.52 V VCC = 3.0 V to 3.6 V 1.20 1.58 1.90 1.20 1.90 V VCC = 4.5 V to 5.5 V 1.74 2.27 2.75 1.74 2.78 V VCC = 1.65 V to 1.95 V 0.56 0.81 1.04 0.56 1.04 V VCC = 2.3 V to 2.7 V 0.83 1.09 1.33 0.82 1.33 V VCC = 3.0 V to 3.6 V 1.08 1.40 1.70 1.08 1.72 V VCC = 4.5 V to 5.5 V 1.61 2.07 2.53 1.61 2.57 V VCC = 1.65 V to 1.95 V 61 170 295 54 295 mV VCC = 2.3 V to 2.7 V 41 174 304 41 304 mV VCC = 3.0 V to 3.6 V 40 183 319 40 319 mV VCC = 4.5 V to 5.5 V 32 199 363 26 363 mV A, B and CLR input; see Fig. 5 hysteresis voltage A, B and CLR input; (VT+ - VT-); see Fig. 5 VH [1] -40 °C to +85 °C Typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 3.3 V and 5.0 V respectively. 10.1. Waveform transfer characteristics aaa-001877 4 lCC (mA) 3 2 1 0 0 1 2 VI (V) 3 VCC = 3.0 V. Fig. 5. Typical transfer characteristics 74LVC1G123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 2 November 2018 © Nexperia B.V. 2018. All rights reserved 7 / 25 74LVC1G123 Nexperia Single retriggerable monostable multivibrator; Schmitt trigger inputs 11. Dynamic characteristics Table 9. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 17. Symbol Parameter tpd propagation delay Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ[1] Max Min Max VCC = 1.65 V to 1.95 V 2.5 7.1 16.3 2.5 17.6 ns VCC = 2.3 V to 2.7 V 1.9 - 10.3 1.9 11.2 ns VCC = 2.7 V 1.9 - 8.5 1.9 9.3 ns VCC = 3.0 V to 3.6 V 1.5 - 7.6 1.5 8.3 ns VCC = 4.5 V to 5.5 V 1.2 - 5.3 1.2 5.8 ns VCC = 1.65 V to 1.95 V 2.9 7.8 17.6 2.9 19.0 ns VCC = 2.3 V to 2.7 V 2.2 - 11.3 2.2 12.3 ns VCC = 2.7 V 2.7 - 10.5 2.7 11.4 ns VCC = 3.0 V to 3.6 V 2.0 - 9.5 2.0 10.3 ns VCC = 4.5 V to 5.5 V 1.5 - 6.7 1.5 7.2 ns VCC = 1.65 V to 1.95 V 3.0 6.9 16.2 3.0 17.4 ns VCC = 2.3 V to 2.7 V 2.2 - 9.6 2.2 10.5 ns VCC = 2.7 V 2.2 - 8.2 2.2 8.9 ns VCC = 3.0 V to 3.6 V 2.0 - 7.3 2.0 8.0 ns VCC = 4.5 V to 5.5 V 1.5 - 5.1 1.5 5.5 ns VCC = 1.65 V to 1.95 V 3.3 7.5 17.2 3.8 18.6 ns VCC = 2.3 V to 2.7 V 2.5 - 10.3 2.0 11.2 ns VCC = 2.7 V 2.8 - 9.3 2.8 10.2 ns VCC = 3.0 V to 3.6 V 1.5 - 8.4 1.5 9.2 ns VCC = 4.5 V to 5.5 V 1.5 - 6.0 1.5 6.6 ns VCC = 1.65 V to 1.95 V 2.7 7.6 17.4 2.7 18.9 ns VCC = 2.3 V to 2.7 V 2.1 - 11.0 2.1 12.0 ns VCC = 2.7 V 2.1 - 9.2 2.1 10.0 ns VCC = 3.0 V to 3.6 V 1.7 - 8.2 1.7 8.9 ns VCC = 4.5 V to 5.5 V 1.4 - 5.9 1.4 6.4 ns VCC = 1.65 V to 1.95 V 3.1 8.3 18.8 3.3 20.3 ns VCC = 2.3 V to 2.7 V 2.5 - 12.0 2.5 13.1 ns VCC = 2.7 V 2.8 - 11.1 2.8 12.1 ns VCC = 3.0 V to 3.6 V 2.0 - 10.1 2.0 11.0 ns VCC = 4.5 V to 5.5 V 1.5 - 7.1 1.5 7.7 ns A, B to Q; see Fig. 6 [2] CL = 15 pF; CL = 30 pF or CL = 50 pF CLR to Q; see Fig. 6 CL = 15 pF; CL = 30 pF or CL = 50 pF tpd propagation delay CLR to Q (trigger); see Fig. 6 [2] CL = 15 pF; CL = 30 pF or CL = 50 pF 74LVC1G123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 2 November 2018 © Nexperia B.V. 2018. All rights reserved 8 / 25 74LVC1G123 Nexperia Single retriggerable monostable multivibrator; Schmitt trigger inputs Symbol Parameter tW pulse width Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ[1] Max Min Max VCC = 1.65 V to 1.95 V 8.0 - - 8.0 - ns VCC = 2.3 V to 2.7 V 4.0 - - 4.0 - ns VCC = 2.7 V 3.0 - - 3.0 - ns VCC = 3.0 V to 3.6 V 3.0 - - 3.0 - ns VCC = 4.5 V to 5.5 V 2.5 - - 2.5 - ns VCC = 1.65 V to 1.95 V 8.0 - - 8.0 - ns VCC = 2.3 V to 2.7 V 4.0 - - 4.0 - ns VCC = 2.7 V 3.0 - - 3.0 - ns VCC = 3.0 V to 3.6 V 3.0 - - 3.0 - ns VCC = 4.5 V to 5.5 V 2.5 - - 2.5 - ns VCC = 1.65 V to 1.95 V - 1.4 2.2 - 2.2 μs VCC = 2.3 V to 2.7 V - 1.3 1.8 - 1.8 μs VCC = 2.7 V - 1.2 1.8 - 1.8 μs VCC = 3.0 V to 3.6 V - 1.2 1.8 - 1.8 μs VCC = 4.5 V to 5.5 V - 1.2 1.8 - 1.8 μs VCC = 1.65 V to 1.95 V - 100 110 - 110 μs VCC = 2.3 V to 2.7 V - 100 110 - 110 μs VCC = 2.7 V - 100 110 - 110 μs VCC = 3.0 V to 3.6 V - 100 110 - 110 μs VCC = 4.5 V to 5.5 V - 100 110 - 110 μs VCC = 1.65 V to 1.95 V - 1.0 1.05 - 1.05 ms VCC = 2.7 V - 1.0 1.05 - 1.05 ms VCC = 3.0 V to 3.6 V - 1.0 1.05 - 1.05 ms VCC = 3.0 V to 3.6 V - 1.0 1.05 - 1.05 ms VCC = 4.5 V to 5.5 V - 1.0 1.05 - 1.05 ms input A LOW; B HIGH; see Fig. 6 and Fig. 7 input CLR LOW; see Fig. 6 and Fig. 8 tW pulse width output Q HIGH; see Fig. 6, Fig. 7 and Fig. 8; [3] REXT = 10 kΩ CEXT = 100 pF CEXT = 0.01 μF [3] CEXT = 0.1 μF 74LVC1G123 Product data sheet [3] All information provided in this document is subject to legal disclaimers. Rev. 6 — 2 November 2018 © Nexperia B.V. 2018. All rights reserved 9 / 25 74LVC1G123 Nexperia Single retriggerable monostable multivibrator; Schmitt trigger inputs Symbol Parameter Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ[1] Max Min Max VCC = 1.65 V to 1.95 V - 174 - - - ns VCC = 2.3 V to 2.7 V - 59 - - - ns VCC = 3.0 V to 3.6 V - 32 - - - ns VCC = 4.5 V to 5.5 V - 20 - - - ns VCC = 1.65 V to 1.95 V - 14 - - - ms VCC = 2.3 V to 2.7 V - 10 - - - ms VCC = 3.0 V to 3.6 V - 10 - - - ms VCC = 4.5 V to 5.5 V - 8 - - - ms VCC = 2.0 V 5 - - - - kΩ VCC ≥ 3.0 V 1 - - - - kΩ - - - - - pF VCC = 1.8 V - 35 - - - pF VCC = 2.5 V - 35 - - - pF VCC = 3.3 V - 27 - - - pF VCC = 5.0 V - 29 - - - pF retrigger time A, B; see Fig. 7 trtrig CEXT = 100 pF; REXT = 5 kΩ CEXT = 100 pF; REXT = 1 kΩ CEXT = 100 μF; REXT = 5 kΩ CEXT = 100 μF; REXT = 1 kΩ Rext external resistance see Fig. 11, Fig. 12 and Fig. 13 Cext external capacitance VCC = 5.0 V; see Fig. 11, Fig. 12 and Fig. 13 CPD power dissipation capacitance VI = GND to VCC; CEXT = 0 pF; REXT = 5 kΩ REXT = 1 kΩ [1] [2] [3] Typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 3.3 V and 5.0 V respectively. tpd is the same as tPHL and tPLH For other REXT and CEXT combinations see Fig. 11, Fig. 12 and Fig. 13. If CEXT > 10 nF, the next formula is valid. tW = K x REXT x CEXT, where: tW = typical output pulse width in ns; REXT = external resistor in kΩ; CEXT = external capacitor in pF; K = constant = 1; see Fig. 14 for typical "K" factor as function of VCC. 74LVC1G123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 2 November 2018 © Nexperia B.V. 2018. All rights reserved 10 / 25 74LVC1G123 Nexperia Single retriggerable monostable multivibrator; Schmitt trigger inputs 11.1. Waveforms, graphs and test circuit VI B input GND VM tW VI A input VM GND tW VI CLR input GND VM tPLH tPLH VOH Q output VOL tW tPHL (reset) tPLH VM tW tW aaa-001878 Measurement points are given in Table 10. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 6. Propagation delays from inputs (A, B, CLR) to output (Q) Table 10. Measurement points Supply voltage Input Output VCC VM VM 1.65 V to 1.95 V 0.5VCC 0.5VCC 2.3 V to 2.7 V 0.5VCC 0.5VCC 2.7 V 1.5 V 1.5 V 3.0 V to 3.6 V 1.5 V 1.5 V 4.5 V to 5.5 V 0.5VCC 0.5VCC 74LVC1G123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 2 November 2018 © Nexperia B.V. 2018. All rights reserved 11 / 25 74LVC1G123 Nexperia Single retriggerable monostable multivibrator; Schmitt trigger inputs B input tW A input trtrig tW Q output tW tW tW aaa-001879 CLR = HIGH Fig. 7. Output pulse control using retrigger pulse B input CLR input tW Q output tW tW aaa-001880 A = LOW Fig. 8. Output pulse control using reset input CLR trtrig A input B input CLR input REXT/CEXT Q output tW tW tW + trtrig aaa-001881 Fig. 9. Input and output timing 74LVC1G123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 2 November 2018 © Nexperia B.V. 2018. All rights reserved 12 / 25 74LVC1G123 Nexperia Single retriggerable monostable multivibrator; Schmitt trigger inputs VCC REXT CEXT to CEXT (pin 6) to REXT/CEXT (pin 7) aaa-001882 Fig. 10. Timing component connections tW (ns) aaa-000298 109 (1) (2) (3) (4) 108 107 aaa-000299 109 (1) (2) (3) (4) (5) 108 107 106 106 105 105 104 104 103 103 102 102 10 tW (ns) 10 1 10 102 103 104 105 106 CEXT (pF) VCC = 1.8 V; Tamb = 25 °C. (1) REXT = 200 kΩ (2) REXT = 100 kΩ (3) REXT = 10 kΩ (4) REXT = 5 kΩ Fig. 11. Typical output pulse width as a function of the external capacitor value 74LVC1G123 Product data sheet 1 10 102 103 104 105 106 CEXT (pF) VCC = 3.3 V; Tamb = 25 °C. (1) REXT = 200 kΩ (2) REXT = 100 kΩ (3) REXT = 10 kΩ (4) REXT = 5 kΩ (5) REXT = 1 kΩ Fig. 12. Typical output pulse width as a function of the external capacitor value All information provided in this document is subject to legal disclaimers. Rev. 6 — 2 November 2018 © Nexperia B.V. 2018. All rights reserved 13 / 25 74LVC1G123 Nexperia Single retriggerable monostable multivibrator; Schmitt trigger inputs tW (ns) aaa-000300 109 (1) (2) (3) (4) (5) 108 107 aaa-000301 1.2 'K' factor 106 1.1 105 (1) 104 (2) 1.0 103 (3) 102 10 0.9 1 10 102 103 104 105 106 CEXT (pF) VCC = 5.0 V; Tamb = 25 °C. (1) REXT = 200 kΩ (2) REXT = 100 kΩ (3) REXT = 10 kΩ (4) REXT = 5 kΩ (5) REXT = 1 kΩ 0.8 Fig. 13. Typical output pulse width as a function of the external capacitor value 0 2 4 VCC (V) 6 REXT = 10 kΩ; Tamb = 25 °C. (1) CEXT = 1000 pF (2) CEXT = 0.01 μF (3) CEXT = 0.1 μF Fig. 14. Typical ‘K’ factor as function of VCC aaa-001943 10 trtrig (µs) (1) 1 (2) 10-1 (3) (4) 10-2 10-3 1.5 2.5 3.5 4.5 VCC (V) 5.5 Tamb = 25 °C. (1) CEXT = 0.01 μF (2) CEXT = 1000 pF (3) CEXT = 100 pF (4) CEXT = 10 pF Fig. 15. Minimum retrigger time as function of the supply voltage 74LVC1G123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 2 November 2018 © Nexperia B.V. 2018. All rights reserved 14 / 25 74LVC1G123 Nexperia Single retriggerable monostable multivibrator; Schmitt trigger inputs aaa-000303 1.45 'K' factor 1.35 (1) (2) 1.25 (3) (4) 1.15 1.05 0.95 102 103 104 105 106 CEXT (pF) REXT = 10 kΩ; Tamb = 25 °C. (1) VCC = 1.8 V (2) VCC = 2.5 V (3) VCC = 3.3 V (4) VCC = 5.0 V Fig. 16. Typical ‘K’ factor as function of CEXT 74LVC1G123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 2 November 2018 © Nexperia B.V. 2018. All rights reserved 15 / 25 74LVC1G123 Nexperia Single retriggerable monostable multivibrator; Schmitt trigger inputs VI negative pulse tW 90 % VM 0V VI tf tr tr tf 90 % positive pulse 0V VM 10 % VM VM 10 % tW VEXT VCC PULSE GENERATOR VI RL VO DUT RT CL RL 001aae235 Test data is given in Table 11. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = Test voltage for switching times. Fig. 17. Test circuit for measuring switching times Table 11. Test data Supply voltage Input VEXT Load VCC VI tr, tf CL RL tPLH, tPHL 1.65 V to 1.95 V VCC ≤ 2.0 ns 15 pF 1 MΩ open 2.3 V to 2.7 V VCC ≤ 2.0 ns 15 pF 1 MΩ open 2.7 V 2.7 V ≤ 2.5 ns 15 pF 1 MΩ open 3.0 V to 3.6 V 2.7 V ≤ 2.5 ns 15 pF 1 MΩ open 4.5 V to 5.5 V VCC ≤ 2.5 ns 15 pF 1 MΩ open 1.65 V to 1.95 V VCC ≤ 2.0 ns 30 pF 1 kΩ open 2.3 V to 2.7 V VCC ≤ 2.0 ns 30 pF 500 Ω open 2.7 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 3.0 V to 3.6 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 4.5 V to 5.5 V VCC ≤ 2.5 ns 50 pF 500 Ω open 74LVC1G123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 2 November 2018 © Nexperia B.V. 2018. All rights reserved 16 / 25 74LVC1G123 Nexperia Single retriggerable monostable multivibrator; Schmitt trigger inputs 12. Package outline TSSOP8: plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm D E A SOT505-2 X c HE y v M A Z 5 8 A A2 pin 1 index (A3) A1 θ Lp L 1 4 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D(1) E(1) e HE L Lp v w y Z(1) θ mm 1.1 0.15 0.00 0.95 0.75 0.25 0.38 0.22 0.18 0.08 3.1 2.9 3.1 2.9 0.65 4.1 3.9 0.5 0.47 0.33 0.2 0.13 0.1 0.70 0.35 8° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT505-2 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 02-01-16 --- Fig. 18. Package outline SOT505-2 (TSSOP8) 74LVC1G123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 2 November 2018 © Nexperia B.V. 2018. All rights reserved 17 / 25 74LVC1G123 Nexperia Single retriggerable monostable multivibrator; Schmitt trigger inputs VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm D SOT765-1 E A X c y HE v A Z 5 8 Q A A2 A1 pin 1 index (A3) θ Lp 1 detail X 4 e L w bp 0 5 mm scale Dimensions (mm are the original dimensions) Unit mm A max. max nom min 1 A1 A2 0.15 0.85 0.00 0.60 A3 0.12 D(1) E(2) 0.27 0.23 2.1 2.4 0.17 0.08 1.9 2.2 bp c e HE 0.5 3.2 3.0 L 0.4 Lp Q 0.40 0.21 0.15 0.19 v w y 0.2 0.08 0.1 Z(1) θ 0.4 8° 0.1 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic or metal protrusions of 0.25 mm maximum per side are not included. Outline version SOT765-1 References IEC JEDEC JEITA sot765-1_po European projection Issue date 07-06-02 16-05-31 MO-187 Fig. 19. Package outline SOT765-1 (VSSOP8) 74LVC1G123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 2 November 2018 © Nexperia B.V. 2018. All rights reserved 18 / 25 74LVC1G123 Nexperia Single retriggerable monostable multivibrator; Schmitt trigger inputs XSON8: plastic extremely thin small outline package; no leads; 8 terminals; body 1 x 1.95 x 0.5 mm 1 2 SOT833-1 b 4 3 4× (2) L L1 e 8 7 6 e1 5 e1 e1 8× A (2) A1 D E terminal 1 index area 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max A1 max b D E e e1 L L1 mm 0.5 0.04 0.25 0.17 2.0 1.9 1.05 0.95 0.6 0.5 0.35 0.27 0.40 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT833-1 --- MO-252 --- EUROPEAN PROJECTION ISSUE DATE 07-11-14 07-12-07 Fig. 20. Package outline SOT833-1 (XSON8) 74LVC1G123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 2 November 2018 © Nexperia B.V. 2018. All rights reserved 19 / 25 74LVC1G123 Nexperia Single retriggerable monostable multivibrator; Schmitt trigger inputs XSON8: extremely thin small outline package; no leads; 8 terminals; body 1.35 x 1 x 0.5 mm SOT1089 E terminal 1 index area D A A1 detail X (4×)(2) e L (8×)(2) b 4 5 e1 1 terminal 1 index area 8 L1 X 0 0.5 scale Dimensions Unit mm max nom min 1 mm A(1) 0.5 A1 b D E e e1 L L1 0.04 0.20 1.40 1.05 0.35 0.40 0.15 1.35 1.00 0.55 0.35 0.30 0.35 0.12 1.30 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version SOT1089 sot1089_po References IEC JEDEC JEITA European projection Issue date 10-04-09 10-04-12 MO-252 Fig. 21. Package outline SOT1089 (XSON8) 74LVC1G123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 2 November 2018 © Nexperia B.V. 2018. All rights reserved 20 / 25 74LVC1G123 Nexperia Single retriggerable monostable multivibrator; Schmitt trigger inputs XSON8: extremely thin small outline package; no leads; 8 terminals; body 1.2 x 1.0 x 0.35 mm 1 2 SOT1116 b 4 3 (4×)(2) L L1 e 8 7 6 e1 e1 5 e1 (8×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e e1 max 0.35 0.04 0.20 1.25 1.05 nom 0.15 1.20 1.00 0.55 min 0.12 1.15 0.95 L L1 0.35 0.40 0.30 0.35 0.27 0.32 0.3 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1116_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-07 SOT1116 Fig. 22. Package outline SOT1116 (XSON8) 74LVC1G123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 2 November 2018 © Nexperia B.V. 2018. All rights reserved 21 / 25 74LVC1G123 Nexperia Single retriggerable monostable multivibrator; Schmitt trigger inputs XSON8: extremely thin small outline package; no leads; 8 terminals; body 1.35 x 1.0 x 0.35 mm SOT1203 b 1 2 3 (4×)(2) 4 L L1 e 8 7 6 e1 e1 5 e1 (8×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e e1 L L1 max 0.35 0.04 0.20 1.40 1.05 0.35 0.40 nom 0.15 1.35 1.00 0.55 0.35 0.30 0.35 min 0.12 1.30 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1203_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-06 SOT1203 Fig. 23. Package outline SOT1203 (XSON8) 74LVC1G123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 2 November 2018 © Nexperia B.V. 2018. All rights reserved 22 / 25 74LVC1G123 Nexperia Single retriggerable monostable multivibrator; Schmitt trigger inputs 13. Abbreviations Table 12. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC1G123 v.6 20181102 Product data sheet - 74LVC1G123 v.5 Modifications: • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type numbers 74LVC1G123GD (SOT996-2/XSON8) removed. 74LVC1G123 v.5 20160614 Modifications: • 74LVC1G123 v.4 20131127 Modifications: • 74LVC1G123 v.3 20130329 Modifications: • 74LVC1G123 v.2 20120801 Modifications: • 74LVC1G123 v.1 20120123 74LVC1G123 Product data sheet Product data sheet - 74LVC1G123 v.4 Fig. 19, package outline drawing for SOT765-1 has changed Product data sheet - 74LVC1G123 v.3 - 74LVC1G123 v.2 74LVC1G123GM (XQFN8) removed. Product data sheet For type number 74LVC1G123GD XSON8U has changed to XSON8. Product data sheet - 74LVC1G123 v.1 VHYS conditions and limits corrected (errata). Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 6 — 2 November 2018 - © Nexperia B.V. 2018. All rights reserved 23 / 25 74LVC1G123 Nexperia Single retriggerable monostable multivibrator; Schmitt trigger inputs 15. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74LVC1G123 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 6 — 2 November 2018 © Nexperia B.V. 2018. All rights reserved 24 / 25 74LVC1G123 Nexperia Single retriggerable monostable multivibrator; Schmitt trigger inputs Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................2 4. Marking.......................................................................... 2 5. Functional diagram.......................................................2 6. Pinning information......................................................3 6.1. Pinning.........................................................................3 6.2. Pin description............................................................. 4 7. Functional description................................................. 4 8. Limiting values............................................................. 4 9. Recommended operating conditions..........................5 10. Static characteristics..................................................5 10.1. Waveform transfer characteristics............................. 7 11. Dynamic characteristics.............................................8 11.1. Waveforms, graphs and test circuit..........................11 12. Package outline........................................................ 17 13. Abbreviations............................................................ 23 14. Revision history........................................................23 15. Legal information......................................................24 © Nexperia B.V. 2018. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 2 November 2018 74LVC1G123 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 2 November 2018 © Nexperia B.V. 2018. All rights reserved 25 / 25 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74LVC1G123GT,115 74LVC1G123DC-Q100H 74LVC1G123DP-Q100H 74LVC1G123GN,115 74LVC1G123GS,115 74LVC1G123GM,125 74LVC1G123DP,125 74LVC1G123GD,125 74LVC1G123DC,125 74LVC1G123GF,115
74LVC1G123GF,115 价格&库存
很抱歉,暂时无法提供与“74LVC1G123GF,115”相匹配的价格&库存,您可以联系我们找货
