74ABT125
Quad buffer; 3-state
Rev. 7 — 25 November 2015
Product data sheet
1. General description
The 74ABT125 high-performance BiCMOS device combines low static and dynamic
power dissipation with high speed and high output drive.
The 74ABT125 device is a quad buffer that is ideal for driving bus lines. The device
features four output enable inputs (1OE, 2OE, 3OE, 4OE), each controlling one of the
3-state outputs.
2. Features and benefits
Quad bus interface
3-state buffers
Live insertion and extraction permitted
Output capability: HIGH 32 mA; LOW +64 mA
Power-up 3-state
Inputs are disabled during 3-state mode
Latch-up protection exceeds 500 mA per JESD78 class II level A
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Multiple package options
Specified from 40 C to +85 C
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74ABT125D
40 C to +85 C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
74ABT125DB
40 C to +85 C
SSOP14
plastic shrink small outline package; 14 leads;
body width 5.3 mm
SOT337-1
74ABT125PW
40 C to +85 C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74ABT125BQ
40 C to +85 C
DHVQFN14
plastic dual in-line compatible thermal enhanced very
thin quad flat package; no leads; 14 terminals;
body 2.5 3 0.85 mm
SOT762-1
74ABT125
Nexperia
4. Functional diagram
2(
2(
(1
2(
Q<
Q$
2(
Q2(
PQD
Fig 1.
PQD
Logic symbol
Fig 2.
PQD
IEC logic symbol
Fig 3.
Logic diagram (one buffer)
5. Pinning information
5.1 Pinning
WHUPLQDO
LQGH[DUHD
$%7
9&&
2(
$%7
2(
2(
9&&
2(
2(
2(
2(
*1'
*1'
2(
*1'
DDL
7UDQVSDUHQWWRSYLHZ
DDL
(1) This is not a supply pin. The substrate is attached to this
pad using conductive die attach material. There is no
electrical or mechanical requirement to solder this pad.
However, if it is soldered, the solder land should remain
floating or be connected to GND.
Fig 4.
Pin configuration SO14 and (T)SSOP14
74ABT125
Product data sheet
Fig 5.
Pin configuration DHVQFN14
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 15
74ABT125
Nexperia
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1OE to 4OE
1, 4, 10, 13
output enable input (active LOW)
1A to 4A
2, 5, 9, 12
data input
1Y to 4Y
3, 6, 8, 11
data output
GND
7
ground (0 V)
VCC
14
supply voltage
6. Functional description
Table 3.
Function selection[1]
Inputs
Output
nOE
nA
L
L
L
L
H
H
H
X
Z
[1]
nY
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
7. Limiting values
Table 4.
Limiting values[1]
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VCC
supply voltage
0.5
+7.0
V
VI
input voltage
1.2
+7.0
V
VO
output voltage
output in OFF-state or HIGH-state
0.5
+5.5
V
IIK
input clamping current
VI < 0 V
18
IOK
output clamping current
VO < 0 V
50
mA
IO
output current
output in LOW-state
128
mA
Tj
junction temperature
150
C
Tstg
storage temperature
65
+150
C
500
mW
total power dissipation
Ptot
[2]
Tamb = 40 C to +85 C
[3]
mA
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction
temperatures which are detrimental to reliability.
[3]
SO14 packages: above 70 C Ptot derate linearly with 8 mW/K
SSOP14 and TSSOP14 packages: above 60 C Ptot derate linearly with 5.5 mW/K
DHVQFN14 packages: above 60 C Ptot derate linearly with 4.5 mW/K
74ABT125
Product data sheet
3 of 15
74ABT125
Nexperia
8. Recommended operating conditions
Table 5.
Operating conditions
Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
VCC
supply voltage
VI
input voltage
VIH
HIGH-level input voltage
VIL
LOW-level Input voltage
IOH
HIGH-level output current
Min
Max
Unit
4.5
5.5
V
VCC
V
2.0
V
0.8
V
32
mA
IOL
LOW-level output current
64
mA
t/V
input transition rise and fall rate
10
ns/V
Tamb
ambient temperature
40
+85
C
in free air
9. Static characteristics
Table 6.
Symbol
Parameter
25 C
Conditions
40 C to +85 C Unit
Min
Typ
Max
Min
Max
0.9
1.2
1.2
V
VCC = 4.5 V; IOH = 3 mA
2.5
2.9
2.5
V
VCC = 5.0 V; IOH = 3 mA
3.0
3.4
3.0
V
VCC = 4.5 V; IOH = 32 mA
VIK
input clamping voltage VCC = 4.5 V; IIK = 18 mA
VOH
HIGH-level output
voltage
VI = VIL or VIH
2.0
2.4
2.0
V
VOL
LOW-level output
voltage
VCC = 4.5 V; IOL = 64 mA;
VI = VIL or VIH
0.35
0.55
0.55
V
II
input leakage current
VCC = 5.5 V; VI = GND or 5.5 V
0.01
1.0
1.0
A
IOFF
power-off leakage
current
VCC = 0.0 V; VI or VO 4.5 V
5.0
100
100
A
IO(pu/pd)
power-up/power-down VCC = 2.1 V; VO = 0.5 V;
output current
VI = GND or VCC; OE = don’t care
5.0
50
50
A
IOZ
OFF-state output
current
VO = 2.7 V
1.0
50
50
A
VO = 0.5 V
1.0
50
50
A
5.0
50
50
A
50
100
180
50
180
mA
65
250
250
A
[1]
VCC = 5.5 V; VI = VIL or VIH
ICEX
output high leakage
current
HIGH-state; VO = 5.5 V;
VCC = 5.5 V; VI = GND or VCC
IO
output current
VCC = 5.5 V; VO = 2.5 V
ICC
supply current
[2]
outputs HIGH-state
74ABT125
Product data sheet
outputs LOW-state
12
15
30
mA
outputs disabled
65
250
50
A
4 of 15
74ABT125
Nexperia
Table 6.
Static characteristics …continued
Symbol
Parameter
ICC
additional supply
current
25 C
Conditions
40 C to +85 C Unit
Min
Typ
Max
Min
Max
outputs enabled
0.5
1.5
1.5
mA
outputs disabled
50
250
250
mA
one enable input at 3.4 V and other
inputs at VCC or GND; outputs
disabled
0.5
1.5
1.5
mA
per control pin; VCC = 5.5 V;
one control input at 3.4 V, other
[3]
CI
input capacitance
VI = 0 V or VCC
4
pF
CO
output capacitance
outputs disabled; VO = 0 V or VCC
7
pF
[1]
This parameter is valid for any VCC between 0 V and 2.1 V, with a transition time of up to 10 ms. From VCC = 2.1 V to VCC = 5 V 10 %,
a transition time of up to 100 s is permitted.
[2]
Not more than one output should be tested at a time, and the duration of the test should not exceed one second.
[3]
This is the increase in supply current for each input at 3.4 V.
10. Dynamic characteristics
Table 7.
GND = 0 V. Test circuit is shown in Figure 8.
Symbol Parameter
25 C; VCC = 5.0 V
Conditions
40 C to +85 C; Unit
VCC = 5.0 V 0.5 V
Min
Typ
Max
Min
Max
tPLH
LOW to HIGH
propagation delay
nA to nY, see Figure 6
1.0
2.8
4.1
1.0
4.6
ns
tPHL
HIGH to LOW
propagation delay
nA to nY; see Figure 6
1.0
3.1
4.6
1.0
4.9
ns
tPZH
OFF-state to HIGH
propagation delay
nOE to nY; see Figure 7
1.0
3.2
5.0
1.0
5.9
ns
tPZL
OFF-state to LOW
propagation delay
1.0
4.2
6.2
1.0
6.8
ns
tPHZ
HIGH to OFF-state
propagation delay
1.0
4.1
5.4
1.0
6.2
ns
tPLZ
LOW to OFF-state
propagation delay
1.5
2.8
5.0
1.5
5.5
ns
74ABT125
Product data sheet
5 of 15
74ABT125
Nexperia
11. Waveforms
9,
90
Q$LQSXW
*1'
W3+/
W3/+
92+
90
Q
很抱歉,暂时无法提供与“74ABT125PW,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5000+1.69960
- 10000+1.67760
- 15000+1.65605
- 25000+1.63506
- 50000+1.59472
- 125000+1.55631
- 250000+1.51964
