74ALVC125D-Q100J
74ALVC125D-Q100J
    NEXPERIA(安世)
    SOIC14_150MIL
    接口(驱动器/接收器/收发器) 1.65~3.6V 8.65 x 3.90mm 14Pins 24mA 3-State SO14_150MIL
74ALVC125D-Q100J 数据手册
74ALVC125-Q100 Quad buffer/line driver; 3-state Rev. 2 — 20 January 2014 Product data sheet 1. General description The 74ALVC125-Q100 is a quad non-inverting buffer/line driver with 3-state outputs. The output enable input (nOE) controls the 3 state outputs (nY). A HIGH on the nOE pin causes the outputs to assume a high-impedance OFF-state. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 3) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 3)  Specified from 40 C to +85 C  Wide supply voltage range from 1.65 V to 3.6 V  3.6 V tolerant inputs/outputs  CMOS low power consumption  Direct interface with TTL levels (2.7 V to 3.6 V)  Power-down mode  Latch-up performance exceeds 250 mA  Complies with JEDEC standards:  JESD8-7 (1.65 V to 1.95 V)  JESD8-5 (2.3 V to 2.7 V)  JESD8B/JESD36 (2.7 V to 3.6 V)  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 ) 74ALVC125-Q100 Nexperia Quad buffer/line driver; 3-state 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74ALVC125D-Q100 40 C to +85 C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 74ALVC125PW-Q100 40 C to +85 C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74ALVC125BQ-Q100 40 C to +85 C DHVQFN14 plastic dual in-line compatible thermal enhanced SOT762-1 very thin quad flat package; no leads;14 terminals; body 2.5 x 3 x 0.85 mm 4. Functional diagram 2 1A 1 1OE 5 2A 4 2OE 1Y 3 2 2Y 1 6 1 3 EN1 5 6 4 9 3A 3Y 8 9 10 3OE 12 4A 13 4OE 8 10 4Y 11 12 11 13 mna229 mna228 Fig 1. Logic symbol Fig 2. IEC logic symbol nY nA nOE mna227 Fig 3. Logic diagram (one buffer) 74ALVC125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 January 2014 © Nexperia B.V. 2017. All rights reserved 2 of 15 74ALVC125-Q100 Nexperia Quad buffer/line driver; 3-state 5. Pinning information 5.1 Pinning 1OE 1 terminal 1 index area 74ALVC125-Q100 1Y 3 12 4A 2OE 4 11 4Y 2A 5 10 3OE 2Y 6 9 3A GND 7 8 3Y 1Y 3 12 4A 2OE 4 2A 5 2Y 6 11 4Y GND(1) 10 3OE 9 8 14 VCC 13 4OE 13 4OE 7 2 2 3Y 1 1A 1A GND 1OE 14 VCC 74ALVC125-Q100 3A aaa-008234 Transparent top view aaa-008233 (1) The die substrate is attached to this pad using conductive die attach material. It cannot be used as a supply pin or input. Fig 4. Pin configuration SO14 and TSSOP14 Fig 5. Pin configuration DHVQFN14 5.2 Pin description Table 2. Pin description Symbol Pin Description nA 2, 5, 9, 12 data input nY 3, 6, 8, 11 bus output nOE 1, 4, 10, 13 output enable (active LOW) VCC 14 supply voltage GND 7 ground (0 V) 6. Functional description Table 3. Function table[1] Input Output nOE nA nY L L L L H H H X Z [1] H = HIGH voltage level L = LOW voltage level X= don’t care Z = high-impedance OFF-state 74ALVC125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 January 2014 © Nexperia B.V. 2017. All rights reserved 3 of 15 74ALVC125-Q100 Nexperia Quad buffer/line driver; 3-state 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current output voltage VO Conditions VI < 0 V [1] VO > VCC or VO < 0 V output HIGH or LOW state [1] [2] output 3-state Power-down mode, VCC = 0 V [2] Max Unit 0.5 +4.6 V 50 - mA 0.5 +4.6 V - 50 mA 0.5 VCC + 0.5 V 0.5 +4.6 V 0.5 +4.6 V - 50 mA 100 mA IO output current ICC supply current - IGND ground current 100 - mA Tstg storage temperature 65 +150 C - 500 mW total power dissipation Ptot [1] VO = 0 V to VCC Min Tamb = 40 C to +85 C [3] The minimum input voltage ratings may be exceeded if the input current ratings are observed. [2] When VCC = 0 V (power-down mode), the output voltage can be 3.6 V in normal operation. [3] For SO14 packages: above 70 C derate linearly with 8 mW/K. For TSSOP14 packages: above 60 C derate linearly with 5.5 mW/K. For DHVQFN20 packages: above 60 C derate linearly with 4.5 mW/K. 74ALVC125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 January 2014 © Nexperia B.V. 2017. All rights reserved 4 of 15 74ALVC125-Q100 Nexperia Quad buffer/line driver; 3-state 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC Conditions Min Max Unit supply voltage 1.65 3.6 V VI input voltage 0 3.6 V VO output voltage output HIGH or LOW state 0 VCC V output 3-state 0 3.6 V power-down mode; VCC = 0 V 0 3.6 V Tamb ambient temperature in free air 40 +85 C t/V input transition rise and fall rate VCC = 1.65 V to 2.7 V 0 20 ns/V VCC = 2.7 V to 3.6 V 0 10 ns/V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter 40 C to +85 C Conditions Typ[1] Min VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage input leakage current 74ALVC125_Q100 Product data sheet Max VCC = 1.65 V to 1.95 V 0.65  VCC - - V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 1.65 V to 1.95 V - - 0.35  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 V IO = 100 A; VCC = 1.65 V to 3.6 V VCC  0.2 - - V VI = VIH or VIL IO = 6 mA; VCC = 1.65 V 1.25 1.51 - V IO = 12 mA; VCC = 2.3 V 1.8 2.10 - V IO = 8 mA; VCC = 2.3 V 1.7 2.01 - V IO = 12 mA; VCC = 2.7 V 2.2 2.53 - V IO = 18 mA; VCC = 3.0 V 2.4 2.76 - V IO = 24 mA; VCC = 3.0 V 2.2 2.68 - V - - 0.2 V VI = VIH or VIL IO = 100 A; VCC = 1.65 V to 3.6 V II Unit IO = 6 mA; VCC = 1.65 V - 0.11 0.3 V IO = 12 mA; VCC = 2.3 V - 0.17 0.4 V IO = 18 mA; VCC = 2.3 V - 0.25 0.6 V IO = 12 mA; VCC = 2.7 V - 0.16 0.4 V IO = 18 mA; VCC = 3.0 V - 0.23 0.4 V IO = 24 mA; VCC = 3.0 V - 0.30 0.55 V - 0.1 5 A VCC = 3.6 V; VI = 3.6 V or GND All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 January 2014 © Nexperia B.V. 2017. All rights reserved 5 of 15 74ALVC125-Q100 Nexperia Quad buffer/line driver; 3-state Table 6. Static characteristics …continued At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter 40 C to +85 C Conditions Typ[1] Min Unit Max IOZ OFF-state output current VI = VIH or VIL; VCC = 1.65 V to 3.6 V; VO = 3.6 V or GND; - 0.1 10 A IOFF power-off leakage current VCC = 0 V; VI or VO = 0 V to 3.6 V - 0.1 10 A ICC supply current VCC = 3.6 V; VI = VCC or GND; IO = 0 A - 0.2 10 A ICC additional supply current per input pin; VCC = 3.0 V to 3.6 V; VI = VCC  0.6 V; IO = 0 A - 5 750 A CI input capacitance - 3.5 - pF [1] All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 C. 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit, see Figure 8. Symbol tpd Parameter propagation delay 40 C to +85 C Conditions Min Max VCC = 1.65 V to 1.95 V 1.3 2.4 5.3 ns VCC = 2.3 V to 2.7 V 1.0 1.7 3.2 ns nA to nY; see Figure 6 [2] VCC = 2.7 V - 2.0 3.1 ns 1.1 1.8 2.8 ns VCC = 1.65 V to 1.95 V 1.4 3.9 6.4 ns VCC = 2.3 V to 2.7 V 1.0 2.2 4.1 ns - 2.7 4.3 ns 1.0 1.9 3.5 ns VCC = 1.65 V to 1.95 V 1.8 3.9 5.9 ns VCC = 2.3 V to 2.7 V 1.0 2.1 3.4 ns - 2.9 4.0 ns 1.4 2.7 4.0 ns VCC = 3.0 V to 3.6 V ten enable time nOE to nY; see Figure 7 [2] VCC = 2.7 V VCC = 3.0 V to 3.6 V tdis disable time nOE to nY; see Figure 7 VCC = 2.7 V VCC = 3.0 V to 3.6 V 74ALVC125_Q100 Product data sheet Unit Typ[1] All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 January 2014 [2] © Nexperia B.V. 2017. All rights reserved 6 of 15 74ALVC125-Q100 Nexperia Quad buffer/line driver; 3-state Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V). For test circuit, see Figure 8. Symbol CPD [1] [2] Parameter 40 C to +85 C Conditions power dissipation capacitance Unit Min Typ[1] outputs HIGH or LOW state - 27 - pF outputs 3-state - 5 - pF Max [3] per buffer; VI = GND to VCC; VCC = 3.3 V Typical values are measured at Tamb = 25 C tpd is the same as tPHL and tPLH. ten is the same as tPZH and tPZL. tdis is the same as tPHZ and tPLZ. [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in Volts N = number of inputs switching (CL  VCC2  fo) = sum of the outputs 11. Waveforms VI VM nA input GND tPHL tPLH VOH VM nY output VOL mna230 Measurement points are given in Table 8. VOL and VOH are the typical output voltage levels that occur with the output load. Fig 6. Table 8. Input nA to output nY propagation delay times Measurement points Supply voltage Input Output VCC VM VM Vx Vy 1.65 V to 1.95 V 0.5VCC 0.5VCC VOL + 0.15 V VOH  0.15 V 2.3 V to 2.7 V 0.5VCC 0.5VCC VOL + 0.15 V VOH  0.15 V 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH  0.3 V 3.0 V to 3.6 V 1.5 V 1.5 V VOL + 0.3 V VOH  0.3 V 74ALVC125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 January 2014 © Nexperia B.V. 2017. All rights reserved 7 of 15 74ALVC125-Q100 Nexperia Quad buffer/line driver; 3-state VI nOE input VM GND tPLZ tPZL VCC output LOW-to-OFF OFF-to-LOW VM VX VOL tPHZ tPZH VOH VY output HIGH-to-OFF OFF-to-HIGH GND VM outputs enabled outputs enabled outputs disabled mna362 Measurement points are given in Table 8. VOL and VOH are the typical output voltage levels that occur with the output load. Fig 7. Enable and disable times VEXT VCC VI RL VO G DUT RT CL RL mna616 Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig 8. Table 9. Test circuitry for switching times Test data Supply voltage Input Load VEXT VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH 1.65 V to 1.95 V VCC  2.0 ns 30 pF 1 k open 2  VCC GND 2.3 V to 2.7 V VCC  2.0 ns 30 pF 500  open 2  VCC GND 2.7 V 2.7 V  2.5 ns 50 pF 500  open 6V GND 3.0 V to 3.6 V 2.7 V  2.5 ns 50 pF 500  open 6V GND 74ALVC125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 January 2014 © Nexperia B.V. 2017. All rights reserved 8 of 15 74ALVC125-Q100 Nexperia Quad buffer/line driver; 3-state 12. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.010 0.057 inches 0.069 0.004 0.049 0.05 0.244 0.039 0.041 0.228 0.016 0.028 0.024 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig 9. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT108-1 (SO14) 74ALVC125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 January 2014 © Nexperia B.V. 2017. All rights reserved 9 of 15 74ALVC125-Q100 Nexperia Quad buffer/line driver; 3-state TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 E D A X c y HE v M A Z 8 14 Q (A 3) A2 A A1 pin 1 index θ Lp L 1 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig 10. Package outline SOT402-1 (TSSOP14) 74ALVC125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 January 2014 © Nexperia B.V. 2017. All rights reserved 10 of 15 74ALVC125-Q100 Nexperia Quad buffer/line driver; 3-state DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT762-1 14 terminals; body 2.5 x 3 x 0.85 mm A B D A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e 2 6 y y1 C v M C A B w M C b L 1 7 Eh e 14 8 13 9 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b c D (1) Dh E (1) Eh e e1 L v w y y1 mm 1 0.05 0.00 0.30 0.18 0.2 3.1 2.9 1.65 1.35 2.6 2.4 1.15 0.85 0.5 2 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT762-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig 11. Package outline SOT762-1 (DHVQFN14) 74ALVC125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 January 2014 © Nexperia B.V. 2017. All rights reserved 11 of 15 74ALVC125-Q100 Nexperia Quad buffer/line driver; 3-state 13. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74ALVC125_Q100 v.2 20140120 Product data sheet - 74ALVC125_Q100 v.1 - - Modifications: 74ALVC125_Q100 v.1 74ALVC125_Q100 Product data sheet • Feature list corrected (errata). 20130628 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 January 2014 © Nexperia B.V. 2017. All rights reserved 12 of 15 74ALVC125-Q100 Nexperia Quad buffer/line driver; 3-state 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74ALVC125_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 January 2014 © Nexperia B.V. 2017. All rights reserved 13 of 15 74ALVC125-Q100 Nexperia Quad buffer/line driver; 3-state No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74ALVC125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 20 January 2014 © Nexperia B.V. 2017. All rights reserved 14 of 15 Nexperia 74ALVC125-Q100 Quad buffer/line driver; 3-state 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 6 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Contact information. . . . . . . . . . . . . . . . . . . . . 14 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 20 January 2014
74ALVC125D-Q100J 价格&库存
很抱歉,暂时无法提供与“74ALVC125D-Q100J”相匹配的价格&库存,您可以联系我们找货
