74ALVC16835ADGG:11
74ALVC16835ADGG:11
    NEXPERIA(安世)
    TSSOP56_14X6.1MM
    IC BUF NON-INVERT 3.6V 56TSSOP
74ALVC16835ADGG:11 数据手册
74ALVC16835A 18-bit registered driver; 3-state Rev. 7 — 19 January 2018 1 Product data sheet General description The 74ALVC16835A is a 18–bit registered driver. Data flow is controlled by active low output enable (OE), active low latch enable (LE) and clock inputs (CP). When LE is LOW, the A to Y data flow is transparent. When LE is HIGH and CP is held at LOW or HIGH, the data is latched; on the LOW to HIGH transient of CP the A-data is stored in the latch/flip-flop. When OE is LOW the outputs are active. When OE is HIGH, the outputs go to the high impedance OFF–state. Operation of the OE input does not affect the state of the latch/flip-flop. To ensure the high-impedance state during power up or power down, OE should be tied to VCC through a pullup resistor; the minimum value of the resistor is determined by the current-sinking capability of the driver. 2 Features and benefits • • • • • • • • • Wide supply voltage range from 1.2 V to 3.6 V CMOS low-power consumption Direct interface with TTL levels Current drive ± 24 mA at 3.0 V MULTIBYTE flow-through standard pin-out architecture Low inductance multiple VCC and GND pins for minimum noise and ground bounce Output drive capability 50 Ω transmission lines at 85°C Input diodes to accommodate strong drivers Complies with JEDEC standards: – JESD8-5 (2.3 V to 2.7 V) – JESD8B/JESD36 (2.7 V to 3.6 V) • ESD protection: – HBM ANSI/ESDA/JEDEC JS-001 exceeds 2000 V – CDM JESD22-C101E exceeds 1000 V 3 Ordering information Table 1. Ordering information Type number Package Temperature range Name 74ALVC16835ADGG −40 °C to + 85 °C Description TSSOP56 plastic thin shrink small outline package; 56 leads; body width 6.1 mm Version SOT364-1 74ALVC16835A Nexperia 18-bit registered driver; 3-state 4 Functional diagram 27 OE 30 CP 28 LE A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 A11 A12 A13 A14 A15 A16 A17 A18 OE CP LE A1 D LE Y1 CP to the 17 other channels 54 52 51 49 48 47 45 44 43 42 41 40 38 37 36 34 33 31 EN1 2C3 G3 G2 3D 1 1 3 5 6 8 9 10 12 13 14 15 16 17 19 20 21 23 24 26 Y1 Y2 Y3 Y4 Y5 Y6 Y7 Y8 Y9 Y10 Y11 Y12 Y13 Y14 Y15 Y16 Y17 Y18 aaa-027575 aaa-027574 Figure 1. Logic diagram Figure 2. Logic symbol (IEEE/IEC) VCC A1 002aac725 Figure 3. Typical input (data or control) 74ALVC16835A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 January 2018 © Nexperia B.V. 2018. All rights reserved. 2 / 15 74ALVC16835A Nexperia 18-bit registered driver; 3-state 5 Pinning information 5.1 Pinning 74ALVC16835A n.c. 1 56 GND n.c. 2 55 n.c. Y1 3 54 A1 GND 4 53 GND Y2 5 52 A2 Y3 6 51 A3 VCC 7 Y4 8 50 VCC 49 A4 Y5 9 48 A5 Y6 10 47 A6 GND 11 46 GND Y7 12 45 A7 Y8 13 44 A8 Y9 14 43 A9 Y10 15 42 A10 Y11 16 41 A11 Y12 17 40 A12 GND 18 39 GND Y13 19 38 A13 Y14 20 37 A14 Y15 21 36 A15 VCC 22 Y16 23 35 VCC 34 A16 Y17 24 33 A17 GND 25 32 GND Y18 26 31 A18 OE 27 30 CP LE 28 29 GND aaa-028080 Figure 4. Pin configuration SOT364-1 (TSSOP56) 74ALVC16835A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 January 2018 © Nexperia B.V. 2018. All rights reserved. 3 / 15 74ALVC16835A Nexperia 18-bit registered driver; 3-state 5.2 Pin description Table 2. Pin description Symbol Pin Description A1, A2, A3, A4, A5, A6, A7, A8, A9, A10, A11, A12, A13, A14, A15, A16, A17, A18 54, 52, 51, 49, 48, 47, 45, 44, 43, 42, 41, 40, 38, 37, 36, 34, 33, 31 data inputs Y1, Y2, Y3, Y4, Y5, Y6, Y7, Y8, Y9, Y10, Y11, Y12, Y13, Y14, Y15, Y16, Y17, Y18 3, 5, 6, 8, 9, 10, 12, 13, 14, 15, 16, 17, 19, 20, 21, 23, 24, 26 data outputs n.c. 1, 2, 55 not connected LE 28 latch enable input OE 27 output enable input (active LOW) CP 30 clock input GND 4, 11, 18, 25, 32, 39, 46, 53, 56 ground (0 V) VCC 7, 22, 35, 50 supply voltage 6 Functional description Table 3. Function table [1] Input Output OE LE CP An Yn H X X X Z L H X L L L H X H H L L ↑ L L L L ↑ H H L L H X Yn [2] L L L X Yn [3] [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state; ↑ = LOW-to-HIGH clock transition. [2] Yn = Output level before the indicated steady-state input conditions were established, provided that CP is high before LE goes low. [3] Yn = Output level before the indicated steady-state input conditions were established. 74ALVC16835A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 January 2018 © Nexperia B.V. 2018. All rights reserved. 4 / 15 74ALVC16835A Nexperia 18-bit registered driver; 3-state 7 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI input voltage Conditions Min Max Unit -0.5 +4.6 V For control pins [1] -0.5 +4.6 V For data inputs [1] -0.5 VCC + 0.5 V [1] -0.5 VCC + 0.5 V VO output voltage IIK input clamping current VI < 0 V IOK output clamping current IO output current ICC -50 - mA VO > VCC or VO < 0 V - ±50 mA VO = 0 V to VCC - ±50 mA supply current - +100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C - 600 mW Ptot [2] total power dissipation [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For TSSOP56 package: Ptot derates linearly with 8 mW/K above 55 °C. 8 Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit VCC supply voltage 2.5 V range for maximum speed performance at 30 pF output load 2.3 - 2.7 V 3.3 V range for maximum speed performance at 50 pF output load 3.0 - 3.6 V for low-voltage applications 1.2 - 3.6 V VI input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature operating in free-air −40 - +85 °C Δt/ΔV input transition rise and fall rate VCC = 2.3 V to 3.0 V 0 - 20 ns/V VCC = 3.0 V to 3.6 V 0 - 10 ns/V 74ALVC16835A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 January 2018 © Nexperia B.V. 2018. All rights reserved. 5 / 15 74ALVC16835A Nexperia 18-bit registered driver; 3-state 9 Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). [1] Symbol Parameter Conditions Min Typ VIH HIGH-level input voltage VCC = 2.3 V to 2.7 V 1.7 1.2 - V VCC = 2.7 V to 3.6 V 2.0 1.5 - V LOW-level input voltage VCC = 2.3 V to 2.7 V - 1.2 0.7 V VCC = 2.7 V to 3.6 V - 1.5 0.8 V HIGH-level output voltage VI = VIH or VIL VCC = 2.3 V to 3.6 V; IO = -100 μA VCC - 0.2 VCC - V VCC = 2.3 V; IO = -6 mA VCC - 0.3 VCC - 0.08 - V VCC = 2.3 V; IO = -12 mA VCC - 0.6 VCC - 0.26 - V VCC = 2.7 V; IO = -12 mA VCC - 0.5 VCC - 0.14 - V VCC = 3.0 V; IO = -12 mA VCC - 0.6 VCC - 0.09 - V VCC = 3.0 V; IO = -24 mA VCC - 1.0 VCC - 0.28 - V VCC = 2.3 V to 3.6 V; IO = 100 μA - GND 0.20 V VCC = 2.3 V; IO = 6 mA - 0.07 0.40 V VCC = 2.3 V; IO = 12 mA - 0.15 0.70 V VCC = 2.7 V; IO = 12 mA - 0.14 0.40 V VCC = 3.0 V; IO = 24 mA - 0.27 0.55 V VIL VOH VOL LOW-level output voltage Max Unit VI = VIH or VIL II input leakage current VCC = 2.3 V to 3.6 V; VI = VCC or GND - 0.1 5 μA IOZ OFF-state output current VCC = 2.3 V to 3.6 V; VI = VIH or VIL; VO = VCC or GND - 0.1 10 μA ICC supply current VCC = 2.3 V to 3.6 V; VI = VCC or GND; IO = 0 A - 0.2 40 μA ΔICC additional supply current VCC = 2.3 V to 3.6 V; VI = VCC - 0.6 V; IO = 0 A - 150 750 μA Ci input capacitance - 4.0 - pF CO output capacitance - 8.0 - pF [1] Typical values are measured at Tamb = 25 °C 74ALVC16835A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 January 2018 © Nexperia B.V. 2018. All rights reserved. 6 / 15 74ALVC16835A Nexperia 18-bit registered driver; 3-state 10 Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit, see Figure 11. Symbol tpd Parameter propagation delay Conditions Min An to Yn; Figure 5 2.4 4.2 ns VCC = 2.7 V 1.3 2.7 4.0 ns 1.0 2.3 3.6 ns VCC = 2.3 V to 2.7 V 1.3 2.8 4.5 ns VCC = 2.7 V 1.3 2.8 4.5 ns 1.3 2.6 4.2 ns VCC = 2.3 V to 2.7 V 1.4 2.8 5.0 ns VCC = 2.7 V 1.3 2.7 4.5 ns 1.3 2.5 4.2 ns VCC = 2.3 V to 2.7 V 1.4 2.2 4.0 ns VCC = 2.7 V 1.4 3.0 4.5 ns 1.1 2.3 4.4 ns VCC = 2.3 V to 2.7 V 1.4 2.0 4.5 ns VCC = 2.7 V 1.4 3.1 4.3 ns VCC = 3.0 V to 3.6 V 1.3 2.8 4.3 ns CP; HIGH or LOW; VCC = 2.3 V to 3.6 V; Figure 8 2.0 - - ns LE; HIGH; VCC = 2.3 V to 3.6 V; Figure 6 2.0 - - ns An to CP; VCC = 2.3 V to 3.6 V; Figure 9 1.0 - - ns An to LE; VCC = 2.3 V to 3.6 V; Figure 7 1.5 - - ns VCC = 2.3 V to 2.7 V 0.6 0.2 - ns VCC = 2.7 V 0.6 0.3 - ns VCC = 3.0 V to 3.6 V 0.9 0.3 - ns VCC = 2.3 V to 2.7 V 1.4 0.4 - ns VCC = 2.7 V 1.7 0.4 - ns VCC = 3.0 V to 3.6 V 1.4 0.3 - ns CP to Yn; Figure 8 [2] [2] VCC = 3.0 V to 3.6 V OE to Yn; Figure 10 [3] VCC = 3.0 V to 3.6 V tw tsu th disable time pulse width set-up time hold time Unit 1.0 VCC = 3.0 V to 3.6 V tdis Max VCC = 2.3 V to 2.7 V LE to Yn; Figure 6 enable time [1] [2] VCC = 3.0 V to 3.6 V ten Typ OE to Yn; Figure 10 [4] An to CP; Figure 9 An to LE; Figure 7 74ALVC16835A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 January 2018 © Nexperia B.V. 2018. All rights reserved. 7 / 15 74ALVC16835A Nexperia 18-bit registered driver; 3-state Symbol Parameter Conditions fmax maximum frequency CP; Figure 8 Min power dissipation capacitance [1] Max Unit VCC = 2.3 V to 2.7 V 150 300 - MHz VCC = 2.7 V 200 350 - MHz 150 300 - MHz transparent mode; output enabled - 13 - pF transparent mode; output disabled - 3 - pF clocked mode; output enabled - 22 - pF clocked mode; output disabled - 15 - pF VCC = 3.0 V to 3.6 V CPD Typ [5] per buffer; VI = GND to VCC [1] Typical values are measured at Tamb = 25 °C Typical values for VCC = 2.3 V to 2.7 V are measured at VCC = 2.5 V Typical values for VCC = 3.0 V to 3.6 V are measured at VCC = 3.3 V [2] tpd is the same as tPHL and tPLH. [3] ten is the same as tPZH and tPZL. [4] tdis is the same as tPHZ and tPLZ. [5] CPD is used to determine the dynamic power dissipation (PD in μW): 2 2 PD = CPD × VCC × fi × N + ∑(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 ∑(CL × VCC × fo) = sum of outputs. 10.1 Waveforms and test circuit An input VI VM tPHL Yn output tPLH VM VI LE input GND GND VOH VOL VOH Yn output VOL VM VM tW tPHL tPLH VM aaa-027577 002aac726 Measurement points are given in Table 8. Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with VOL and VOH are typical voltage output levels that occur with the output load. the output load. Figure 6. Latch enable input (LE) pulse width, the latch Figure 5. Input (An) to output (Yn) propagation delay 74ALVC16835A Product data sheet enable input to output (Yn) propagation delays All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 January 2018 © Nexperia B.V. 2018. All rights reserved. 8 / 15 74ALVC16835A Nexperia 18-bit registered driver; 3-state VI An input GND VI LE input GND VM VM th 1 / fmax th tsu CP input tsu VM VM tw VM aaa-027578 Yn output VI VM GND tPLH tPHL VOH VM VOL Measurement points are given in Table 8. 002aac729 VOL and VOH are typical voltage output levels that occur with the output load. Measurement points are given in Table 8. The shaded areas indicate when the input is permitted to VOL and VOH are typical voltage output levels that occur with change for predictable output performance. the output load. Figure 7. Data set-up and hold times, An input to LE input CP input Figure 8. The clock (CP) to Yn propagation delays, the clock pulse width and the maximum clock frequency VI VM tsu th tsu GND th OE input VI An input GND VOH Yn output VOL 002aac730 output LOW-to-OFF OFF-to-LOW VI VM tPLZ GND tPZL VM VX tPHZ output HIGH-to-OFF OFF-to-HIGH tPZH VY VM VCC VOL VOH GND Measurement points are given in Table 8. outputs outputs outputs enabled disabled enabled VOL and VOH are typical voltage output levels that occur with 002aac731 the output load. Measurement points are given in Table 8. The shaded areas indicate when the input is permitted to change for predictable output performance. VOL and VOH are typical voltage output levels that occur with the output load. Figure 9. Data set-up and hold times, An input to CP input Figure 10. 3-state enable and disable times Table 8. Measurement points Supply voltage Input VCC VI VM VM VX VY ≤ 2.3 V VCC 0.5 x VCC 0.5 x VCC VOL + 0.15 V VOH - 0.15 V 2.3 V to 2.7 V VCC 0.5 x VCC 0.5 x VCC VOL + 0.15 V VOH - 0.15 V 2.7 V 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V 3.0 V to 3.6 V 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V 74ALVC16835A Product data sheet Output All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 January 2018 © Nexperia B.V. 2018. All rights reserved. 9 / 15 74ALVC16835A Nexperia 18-bit registered driver; 3-state VI negative pulse tW 90 % VM VM 10 % 0V tf tr VI positive pulse 0V tr tf 90 % VM VM 10 % tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Figure 11. Test circuit for measuring switching times Table 9. Test data Supply voltage Input VCC VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH ≤ 2.3 V VCC ≤ 2.0 ns 30 pF 500 Ω open 2 × VCC GND 2.3 V to 2.7 V VCC ≤ 2.0 ns 30 pF 500 Ω open 2 × VCC GND 2.7 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 2 × VCC GND 3.0 V to 3.6 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 2 × VCC GND 74ALVC16835A Product data sheet Load VEXT All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 January 2018 © Nexperia B.V. 2018. All rights reserved. 10 / 15 74ALVC16835A Nexperia 18-bit registered driver; 3-state 11 Package outline TSSOP56: plastic thin shrink small outline package; 56 leads; body width 6.1 mm SOT364-1 E D A X c HE y v M A Z 56 29 Q A2 (A 3 ) A1 pin 1 index A θ Lp L 1 28 w M bp e detail X 2.5 0 5 mm scale DIMENSIONS (mm are the original dimensions). UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z θ mm 1.2 0.15 0.05 1.05 0.85 0.25 0.28 0.17 0.2 0.1 14.1 13.9 6.2 6.0 0.5 8.3 7.9 1 0.8 0.4 0.50 0.35 0.25 0.08 0.1 0.5 0.1 8 o 0 o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT364-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Figure 12. Package outline SOT364-1 (TSSOP56) 74ALVC16835A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 January 2018 © Nexperia B.V. 2018. All rights reserved. 11 / 15 74ALVC16835A Nexperia 18-bit registered driver; 3-state 12 Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model TTL Transistor-Transistor Logic 13 Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74ALVC16835A v.7 20180119 Product data sheet - 74ALVC16835A v.6 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74ALVC16835A v.6 20000314 Product specification - 74ALVC16835 v.5 74ALVC16835 v.5 19990318 Product specification - 74ALVC16835 v.4 74ALVC16835 v.4 19980727 Product specification - 74ALVC16835 v.3 74ALVC16835 v.3 19980727 Product specification - 74ALVC16835 v.2 74ALVC16835 v.2 19980727 Product specification - 74ALVC16835 v.1 74ALVC16835A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 January 2018 © Nexperia B.V. 2018. All rights reserved. 12 / 15 74ALVC16835A Nexperia 18-bit registered driver; 3-state 14 Legal information 14.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74ALVC16835A Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 January 2018 © Nexperia B.V. 2018. All rights reserved. 13 / 15 74ALVC16835A Nexperia 18-bit registered driver; 3-state Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74ALVC16835A Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 January 2018 © Nexperia B.V. 2018. All rights reserved. 14 / 15 74ALVC16835A Nexperia 18-bit registered driver; 3-state Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 10.1 11 12 13 14 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 1 Functional diagram ............................................. 2 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 4 Functional description ........................................4 Limiting values .................................................... 5 Recommended operating conditions ................ 5 Static characteristics .......................................... 6 Dynamic characteristics .....................................7 Waveforms and test circuit ................................ 8 Package outline .................................................11 Abbreviations .................................................... 12 Revision history ................................................ 12 Legal information .............................................. 13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2018. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 19 January 2018 Document identifier: 74ALVC16835A
74ALVC16835ADGG:11 价格&库存
很抱歉,暂时无法提供与“74ALVC16835ADGG:11”相匹配的价格&库存,您可以联系我们找货
