74ALVCH16543DGGY
74ALVCH16543DGGY
    NEXPERIA(安世)
    TSSOP56_14X6.1MM
    IC TXRX NON-INVERT 3.6V 56TSSOP
74ALVCH16543DGGY 数据手册
74ALVCH16543 16-bit D-type registered transceiver; 3-state Rev. 3 — 15 December 2017 1 Product data sheet General description The 74ALVCH16543 is a dual octal registered transceiver. Each section contains two sets of D-type latches for temporary storage of the data flow in either direction. Separate latch enable (nLEAB, nLEBA) and output enable (nOEAB, nOEBA) inputs are provided for each register to permit independent control in either direction of the data flow. The 74ALVCH16543 contains two sections each consisting of two sets of eight D-type latches with separate inputs and controls for each set. For data flow from A to B, for example, the A-to-B enable (nEAB) inputs must be LOW in order to enter data from nA0 to nA7, or take data from nB0 to nB7, as indicated in the function table. With nEAB LOW, a LOW signal on the A-to-B latch enable (nLEAB) input makes the A-to-B latches transparent; a subsequent LOW-to-HIGH transition of the nLEAB signal stores the A data into the latches. With nEAB and nOEAB both LOW, the 3-state B output buffers are active and display the data present at the output of the A latches. Similarly, the nEBA, nLEBA and nOEBA signals control the data flow from B-to-A. Active bus hold circuitry is provided to hold unused or floating data inputs at a valid logic level. 2 Features and benefits • • • • • • • • • • CMOS low power consumption Direct interface with TTL levels MULTIBYTE flow-through standard pin-out architecture Back-to-back registers for storage Output drive capability 50 Ω transmission lines at 85 °C All data inputs have bushold Low inductance multiple VCC and GND pins for minimize noise and ground bounce Current drive ±24 mA at VCC = 3.0 V. 3-state non-inverting outputs for bus oriented applications Complies with JEDEC standards: – JESD8-5 (2.3 V to 2.7 V) – JESD8B/JESD36 (2.7 V to 3.6 V) • ESD protection: – HBM ANSI/ESDA/JEDEC JS-001 exceeds 2000 V – CDM JESD22-C101E exceeds 1000 V 74ALVCH16543 Nexperia 16-bit D-type registered transceiver; 3-state 3 Ordering information Table 1. Ordering information Type number Package Temperature range Name 74ALVCH16543DGG -40 °C to +85 °C 4 TSSOP56 Description Version plastic thin shrink small outline package; 56 leads; body width 6.1 mm SOT364-1 Functional diagram 5 6 8 9 10 12 13 14 1 56 3 54 2 55 1A0 1B0 1A1 1B1 1A2 1B2 1A3 1B3 1A4 1B4 1A5 1B5 1A6 1B6 1A7 1B7 52 15 51 16 49 17 48 19 47 20 45 21 44 23 43 24 2A0 2B0 2A1 2B1 2A2 2B2 2A3 2B3 2A4 2B4 2A5 2B5 2A6 2B6 2A7 2B7 1OEAB 2OEAB 1OEBA 2OEBA 1EAB 2EAB 1EBA 2EBA 1LEAB 2LEAB 1LEBA 2LEBA 42 41 40 38 37 36 34 33 28 29 26 31 27 30 aaa-027924 Figure 1. Logic symbol 56 1EN3 (BA) 29 7EN9 (BA) 54 G1 31 G7 55 1C5 30 7C11 1 2EN4 (AB) 28 8EN10 (AB) 3 G2 26 G8 2 2C6 27 8C12 5 3 6D 5D 52 15 4 9 12D 11D 42 10 6 51 16 41 8 49 17 40 9 48 19 38 10 47 20 37 12 45 21 36 13 44 23 34 14 43 24 33 aaa-027925 Figure 2. IEC logic symbol 74ALVCH16543 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 17 74ALVCH16543 Nexperia 16-bit D-type registered transceiver; 3-state nOEBA nEBA nLEBA nOEAB nEAB nLEAB LE Q nA1 D nB1 LE Q 8 IDENTICAL CHANNELS D to 7 other channels aaa-027926 Figure 3. Logic diagram VCC data input to internal circuit mna004 Figure 4. Bushold circuit 74ALVCH16543 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 17 74ALVCH16543 Nexperia 16-bit D-type registered transceiver; 3-state 5 Pinning information 5.1 Pinning 74ALVCH16543 1OEAB 1 56 1OEBA 1LEAB 2 55 1LEBA 1EAB 3 54 1EBA GND 4 53 GND 1A0 5 52 1B0 1A1 6 51 1B1 VCC 7 1A2 8 50 VCC 49 1B2 1A3 9 48 1B3 1A4 10 47 1B4 GND 11 46 GND 1A5 12 45 1B5 1A6 13 44 1B6 1A7 14 43 1B7 2A0 15 42 2B0 2A1 16 41 2B1 2A2 17 40 2B2 GND 18 39 GND 2A3 19 38 2B3 2A4 20 37 2B4 2A5 21 36 2B5 VCC 22 2A6 23 35 VCC 34 2B6 2A7 24 33 2B7 GND 25 32 GND 2EAB 26 31 2EBA 2LEAB 27 30 2LEBA 2OEAB 28 29 2OEBA aaa-027927 Figure 5. Pin configuration for TSSOP56 74ALVCH16543 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 17 74ALVCH16543 Nexperia 16-bit D-type registered transceiver; 3-state 5.2 Pin description Table 2. Pin description Symbol Pin Description 1A0, 1A1, 1A2, 1A3, 1A4, 1A5, 1A6, 1A7 5, 6, 8, 9, 10, 12, 13, 14 data inputs/outputs 2A0, 2A1, 2A2, 2A3, 2A4, 2A5, 2A6, 2A7 15, 16, 17, 19, 20, 21, 23, 24 data inputs/outputs 1B0, 1B1, 1B2, 1B3, 1B4, 1B5, 1B6, 1B7 52, 51, 49, 48, 47, 45, 44, 43 data inputs/outputs 2B0, 2B1, 2B2, 2B3, 2B4, 2B5, 2B6, 2B7 42, 41, 40, 38, 37, 36, 34, 33 data inputs/outputs 1OEAB, 2OEAB 1, 28 A to B output enable inputs (active LOW) 1OEBA, 2OEBA 56, 29 B to A output enable inputs (active LOW) 1EAB, 2EAB 3, 26 A to B enable inputs (active LOW) 1EBA, 2EBA 54, 31 B to A enable inputs (active LOW) 1LEAB, 2LEAB 2, 27 A to B latch enable inputs (active LOW) 1LEBA, 2LEBA 55, 30 B to A latch enable inputs (active LOW) GND 4, 11, 18, 25, 32, 39, 46, 53 ground (0 V) VCC 7, 22, 35, 50 supply voltage 6 Functional description Table 3. Function selection [1] Outputs Inputs Status nOEAB or nOEBA nEAB or nEBA nLEAB or nLEBA nAn or nBn nBn or nAn H X X X Z disabled X H X X Z disabled L ↑ L h Z disabled + latch L ↑ L l Z disabled + latch L L ↑ h H latch + display L L ↑ l L latch + display L L L H H transparent L L L L L transparent L L H X NC hold [1] H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the LOW-to-HIGH transition of nLEAB, nLEBA, nEAB or nEBA; L = LOW voltage level; l = LOW voltage level one set-up time prior to the LOW-to-HIGH transition of nLEAB, nLEBA, nEAB or nEBA; X = don’t care; ↑ = LOW-to-HIGH transition of nLEAB, nLEBA, nEAB or nEBA; NC = no change; Z = high-impedance OFF-state. 74ALVCH16543 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 17 74ALVCH16543 Nexperia 16-bit D-type registered transceiver; 3-state 7 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit -0.5 +4.6 V input voltage [1] -0.5 +4.6 V VO output voltage [1] -0.5 VCC + 0.5 V IIK input clamping current VI < 0 V -50 - mA IOK output clamping current VO > VCC or VO < 0 V - ±50 mA IO output current VO = 0 V to VCC - ±50 mA ICC supply current - 100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C - 600 mW VI Ptot total power dissipation Tamb = -40 °C to +85 °C [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] Above 55 °C the value of Ptot derates linearly with 8 mW/K. 8 Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit VCC supply voltage maximum speed performance CL = 30 pF 2.3 2.5 2.7 V CL = 50 pF 3.0 3.3 3.6 V 1.2 2.4 3.6 V low-voltage applications VI input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature in free air -40 - +85 °C Δt/ΔV input transition rise and fall rate VCC = 2.3 V to 3.0 V - - 20 ns/V VCC = 3.0 V to 3.6 V - - 10 ns/V 74ALVCH16543 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 17 74ALVCH16543 Nexperia 16-bit D-type registered transceiver; 3-state 9 Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Tamb = -40 °C to +85 °C [1] Symbol Parameter Conditions Min Typ VIH HIGH-level input voltage VCC = 2.3 V to 2.7 V 1.7 1.2 - V VCC = 2.7 V to 3.6 V 2.0 1.5 - V LOW-level input voltage VCC = 2.3 V to 2.7 V - 1.2 0.7 V VCC = 2.7 V to 3.6 V - 1.5 0.8 V HIGH-level output voltage VI = VIH or VIL IO = -100 μA; VCC = 2.3 V to 3.6 V VCC - 0.2 VCC - V IO = -6 mA; VCC = 2.3 V VCC - 0.3 VCC - 0.08 - V IO = -12 mA; VCC = 2.3 V VCC - 0.6 VCC - 0.26 - V IO = -12 mA; VCC = 2.7 V VCC - 0.5 VCC - 0.14 - V IO = -12 mA; VCC = 3.0 V VCC - 0.6 VCC - 0.09 - V IO = -24 mA; VCC = 3.0 V VCC - 1.0 VCC - 0.28 - V IO = 100 μA; VCC = 2.3 V to 3.6 V - GND 0.20 V IO = 6 mA; VCC = 2.3 V - 0.07 0.40 V IO = 12 mA; VCC = 2.3 V - 0.15 0.70 V IO = 12 mA; VCC = 2.7 V - 0.14 0.40 V IO = 24 mA; VCC = 3.0 V - 0.27 0.55 V VIL VOH VOL LOW-level output voltage Max Unit VI = VIH or VIL II input leakage current VCC = 2.3 V to 3.6 V; VI = VCC or GND - 0.1 5 μA IOZ OFF-state output current VCC = 2.3 V to 3.6 V; VI = VIH or VIL; VO = VCC or GND - 0.1 10 μA ICC supply current VCC = 2.3 V to 3.6 V; VI = VCC or GND; IO = 0 A - 0.2 40 μA ΔICC additional supply current per data I/O pin; VCC = 2.3 V to 3.6 V; VI = VCC - 0.6 V; IO = 0 A - 150 750 μA IBHL bus hold LOW current VCC = 2.3 V; VI = 0.7 V 45 - - μA VCC = 3.0 V; VI = 0.8 V 75 150 - μA bus hold HIGH current VCC = 2.3 V; VI = 1.7 V -45 - - μA VCC = 3.0 V; VI = 2.0 V -75 -175 - μA IBHLO bus hold LOW overdrive current VCC = 3.6 V 500 - - μA IBHHO bus hold HIGH overdrive current VCC = 3.6 V -500 - - μA CI input capacitance - 4.0 - pF IBHH [1] All typical values are measured at Tamb = 25 °C. 74ALVCH16543 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 17 74ALVCH16543 Nexperia 16-bit D-type registered transceiver; 3-state 10 Dynamic characteristics Table 7. Dynamic characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Figure 10. Tamb = -40 °C to +85 °C Symbol tpd Parameter propagation delay Conditions Typ 1.0 [1] Max Unit 3.4 5.1 ns - 2.9 4.8 ns 1.0 3.8 4.3 ns 1.0 3.3 6.5 ns - 3.6 6.2 ns 1.4 3.1 5.0 ns 1.0 3.3 6.8 ns - 3.4 6.3 ns 1.0 2.9 5.3 ns 1.0 3.3 7.2 ns - 3.5 6.9 ns 1.0 3.0 5.6 ns 1.0 2.9 5.7 ns - 3.3 4.8 ns 1.0 3.2 4.6 ns 1.3 3.3 6.1 ns - 3.5 6.2 ns 1.1 3.3 5.1 ns VCC = 2.3 V to 2.7 V 3.3 1.2 - ns VCC = 2.7 V 3.3 1.3 - ns VCC = 3.0 V to 3.6 V 3.3 0.9 - ns VCC = 2.3 V to 2.7 V 1.2 0.2 - ns VCC = 2.7 V 0.8 0.2 - ns VCC = 3.0 V to 3.6 V 1.3 0.1 - ns nAn to nBn; nBn to nAn; see Figure 6 Min [2] VCC = 2.3 V to 2.7 V VCC = 2.7 V VCC = 3.0 V to 3.6 V nLEAB to nBn; nLEBA to nAn; see Figure 7 VCC = 2.3 V to 2.7 V VCC = 2.7 V VCC = 3.0 V to 3.6 V ten enable time nOEBA to nAn; nOEAB to nBn; see Figure 8 [3] VCC = 2.3 V to 2.7 V VCC = 2.7 V VCC = 3.0 V to 3.6 V nEBA to nAn; nEAB to nBn; see Figure 8 VCC = 2.3 V to 2.7 V VCC = 2.7 V VCC = 3.0 V to 3.6 V tdis disable time nOEBA to nAn; nOEAB to nBn; see Figure 8 [4] VCC = 2.3 V to 2.7 V VCC = 2.7 V VCC = 3.0 V to 3.6 V nEBA to nAn; nEAB to nBn; see Figure 8 VCC = 2.3 V to 2.7 V VCC = 2.7 V VCC = 3.0 V to 3.6 V tW tsu pulse width set-up time 74ALVCH16543 Product data sheet nLEAB, nLEBA LOW; see Figure 7 nAn to nLEAB; nBn to nLEBA; nAn to nEAB; nBn to nEBA; see Figure 9 All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 17 74ALVCH16543 Nexperia 16-bit D-type registered transceiver; 3-state Symbol Parameter Conditions th hold time nAn to nLEAB; nBn to nLEBA; nAn to nEAB; nBn to nEBA; see Figure 9 Typ VCC = 2.3 V to 2.7 V 1.2 0.2 - ns VCC = 2.7 V 0.4 0.1 - ns 0.7 0.2 - ns outputs enabled - 44 - pF outputs disabled - 14 - pF VCC = 3.0 V to 3.6 V CPD power dissipation capacitance [1] Min per latch; VI = GND to VCC Max Unit [5] [1] Typical values are measured at Tamb = 25 °C Typical values for VCC = 2.3 V to 2.7 V are measured at VCC = 2.5 V. Typical values for VCC = 3.0 V to 3.6 V are measured at VCC = 3.3 V. [2] tpd is the same as tPLH and tPHL. [3] ten is the same as tPZL and tPZH. [4] tdis is the same as tPLZ and tPHZ. [5] CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + ∑ (CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in Volts; N = total load switching outputs; 2 ∑(CL × VCC × fo) = sum of outputs. 74ALVCH16543 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 17 74ALVCH16543 Nexperia 16-bit D-type registered transceiver; 3-state 10.1 Waveforms and test circuit VI nAn, nBn input VM VM tPHL tPLH GND VOH nBn, nAn output VM VM VOL aaa-027928 See Table 8 for measurement points. VOL and VOH are typical output voltage levels that occur with the output load. Figure 6. Input (nAn, nBn) to output (nBn, nAn) propagation delays VI nLEAB, nLEBA input VM VM VM GND tW tPHL tPLH VOH nAn, nBn output VM VM VOL aaa-027929 See Table 8 for measurement points. VOL and VOH are typical output voltage levels that occur with the output load. Figure 7. Input (nLEAB, nLEBA) to output (nBn, nAn) propagation delays and (nLEAB, nLEBA) pulse width VI nOEAB, nOEBA nEAB, nEBA input VM GND tPLZ output LOW-to-OFF OFF-to-LOW tPZL VCC VM VX VOL tPHZ output HIGH-to-OFF OFF-to-HIGH VOH tPZH VY VM GND outputs enabled outputs disabled outputs enabled aaa-027930 See Table 8 for measurement points. VOL and VOH are typical output voltage levels that occur with the output load. Figure 8. 3-state output enable and disable times 74ALVCH16543 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 17 74ALVCH16543 Nexperia 16-bit D-type registered transceiver; 3-state VI nAn, nBn input VM VM VM VM GND th tsu VI nLEBA, nLEAB nEBA, nEAB input th tsu VM VM GND aaa-027931 See Table 8 for measurement points. VOL and VOH are typical output voltage levels that occur with the output load. Figure 9. Data set-up and hold times for nAn, nBn inputs to nLEBA, nLEAB, nEBA and nEAB inputs Table 8. Measurement points Input Output VCC VI VM VM Vx Vy 2.3 V to 2.7 V VCC 0.5VCC 0.5VCC VOL + 0.15 V VOH - 0.15 V 2.7 V 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V 3.0 V to 3.6 V 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V 74ALVCH16543 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 17 74ALVCH16543 Nexperia 16-bit D-type registered transceiver; 3-state VI negative pulse tW 90 % VM 0V VI tf tr tr tf 90 % positive pulse 0V VM 10 % VM VM 10 % tW VEXT VCC PULSE GENERATOR VI RL VO DUT RT CL RL 001aae235 Test data is given in Table 9. Definitions test circuit: RL = Load resistance; CL = Load capacitance including jig and probe capacitance; RT = Termination resistance should be equal to output impedance Zo of the pulse generator; VEXT = External voltage for measuring switching times. Figure 10. Test circuit for measuring switching times Table 9. Test data Input Load VEXT VCC VI tr, tf RL CL tPHZ, tPZH tPLZ, tPZL tPLH, tPHL 2.3 V to 2.7 V VCC ≤ 2.0 ns 500 Ω 30 pF GND 2 × VCC open 2.7 V 2.7 V ≤ 2.5 ns 500 Ω 50 pF GND 2 × VCC open 3.0 V to 3.6 V 2.7 V ≤ 2.5 ns 500 Ω 50 pF GND 2 × VCC open 74ALVCH16543 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2017 © Nexperia B.V. 2017. All rights reserved. 12 / 17 74ALVCH16543 Nexperia 16-bit D-type registered transceiver; 3-state 11 Package outline TSSOP56: plastic thin shrink small outline package; 56 leads; body width 6.1 mm SOT364-1 E D A X c HE y v M A Z 56 29 Q A2 (A 3 ) A1 pin 1 index A θ Lp L 1 28 w M bp e detail X 2.5 0 5 mm scale DIMENSIONS (mm are the original dimensions). UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z θ mm 1.2 0.15 0.05 1.05 0.85 0.25 0.28 0.17 0.2 0.1 14.1 13.9 6.2 6.0 0.5 8.3 7.9 1 0.8 0.4 0.50 0.35 0.25 0.08 0.1 0.5 0.1 8 o 0 o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT364-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Figure 11. Package outline SOT364-1 (TSSOP56) 74ALVCH16543 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2017 © Nexperia B.V. 2017. All rights reserved. 13 / 17 74ALVCH16543 Nexperia 16-bit D-type registered transceiver; 3-state 12 Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model TTL Transistor-Transistor Logic 13 Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74ALVCH16543 v.3 20171215 Product data sheet - 74ALVCH16543 v.2 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74ALVCH16543 v.2 19991123 Product specification - 74ALVCH16543 v.1 74ALVCH16543 v.1 19980831 Product specification - - 74ALVCH16543 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2017 © Nexperia B.V. 2017. All rights reserved. 14 / 17 74ALVCH16543 Nexperia 16-bit D-type registered transceiver; 3-state 14 Legal information 14.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74ALVCH16543 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2017 © Nexperia B.V. 2017. All rights reserved. 15 / 17 74ALVCH16543 Nexperia 16-bit D-type registered transceiver; 3-state Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74ALVCH16543 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2017 © Nexperia B.V. 2017. All rights reserved. 16 / 17 74ALVCH16543 Nexperia 16-bit D-type registered transceiver; 3-state Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 10.1 11 12 13 14 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 2 Functional diagram ............................................. 2 Pinning information ............................................ 4 Pinning ............................................................... 4 Pin description ................................................... 5 Functional description ........................................5 Limiting values .................................................... 6 Recommended operating conditions ................ 6 Static characteristics .......................................... 7 Dynamic characteristics .....................................8 Waveforms and test circuit .............................. 10 Package outline .................................................13 Abbreviations .................................................... 14 Revision history ................................................ 14 Legal information .............................................. 15 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 15 December 2017 Document identifier: 74ALVCH16543
74ALVCH16543DGGY 价格&库存
很抱歉,暂时无法提供与“74ALVCH16543DGGY”相匹配的价格&库存,您可以联系我们找货
