74AXP2G17GSH
74AXP2G17GSH
    NEXPERIA(安世)
    X2-DFN1409-6
    IC BUF NON-INVERT 2.75V 6XSON
74AXP2G17GSH 数据手册
74AXP2G17 Low-power dual Schmitt trigger Rev. 1 — 12 November 2015 Poduct data sheet 1. General description The 74AXP2G17 is a dual Schmitt trigger buffer. It can transform slowly changing input signals into sharply defined, jitter-free output signals. This device ensures very low static and dynamic power consumption across the entire VCC range from 0.7 V to 2.75 V. It is fully specified for partial power down applications using IOFF. The IOFF circuitry disables the output, preventing the potentially damaging backflow current through the device when it is powered down. 2. Features and benefits               Wide supply voltage range from 0.7 V to 2.75 V Low input capacitance; CI = 0.5 pF (typical) Low output capacitance; CO = 1.0 pF (typical) Low dynamic power consumption; CPD = 2.5 pF at VCC = 1.2 V (typical) Low static power consumption; ICC = 0.6 A (85 C maximum) High noise immunity Complies with JEDEC standard:  JESD8-12A.01 (1.1 V to 1.3 V)  JESD8-11A.01 (1.4 V to 1.6 V)  JESD8-7A (1.65 V to 1.95 V)  JESD8-5A.01 (2.3 V to 2.7 V) ESD protection:  HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 2 kV  CDM JESD22-C101E exceeds 1000 V Latch-up performance exceeds 100 mA per JESD 78 Class II Inputs accept voltages up to 2.75 V Low noise overshoot and undershoot < 10 % of VCC IOFF circuitry provides partial Power-down mode operation Multiple package options Specified from 40 C to +85 C 74AXP2G17 Nexperia Low-power dual Schmitt trigger 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AXP2G17GM 40 C to +85 C XSON6 plastic extremely thin small outline package; no leads; SOT886 6 terminals; body 1  1.45  0.5 mm 74AXP2G17GN 40 C to +85 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9  1.0  0.35 mm SOT1115 74AXP2G17GS 40 C to +85 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0  1.0  0.35 mm SOT1202 4. Marking Table 2. Marking Type number Marking code[1] 74AXP2G17GM rV 74AXP2G17GN rV 74AXP2G17GS rV [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram  $ <   $ <      PQE PQE Fig 1. Logic symbol Fig 2. IEC logic symbol $ < $ < PQE Fig 3. Logic diagram 74AXP2G17 Poduct data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 12 November 2015 © Nexperia B.V. 2017. All rights reserved 2 of 16 74AXP2G17 Nexperia Low-power dual Schmitt trigger 6. Pinning information 6.1 Pinning $;3* $;3* $   < *1'   9&& $   < $   < *1'   9&& $   < DDD DDD 7UDQVSDUHQWWRSYLHZ 7UDQVSDUHQWWRSYLHZ Fig 4. Pin configuration SOT886 Fig 5. Pin configuration SOT1115 and SOT1202 6.2 Pin description Table 3. Pin description Symbol Pin Description 1A 1 data input GND 2 ground (0 V) 2A 3 data input 2Y 4 data output VCC 5 supply voltage 1Y 6 data output 7. Functional description Table 4. Function table[1] Input Output nA nY L L H H [1] H = HIGH voltage level; L = LOW voltage level. 74AXP2G17 Poduct data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 12 November 2015 © Nexperia B.V. 2017. All rights reserved 3 of 16 74AXP2G17 Nexperia Low-power dual Schmitt trigger 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current Conditions VI < 0 V [1] VO < 0 V [1] Min Max Unit 0.5 +3.3 V 50 - 0.5 +3.3 50 - 0.5 +3.3 mA V mA VO output voltage IO output current - 20 mA ICC supply current - 50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation - 250 mW [1] VO = 0 V to VCC Tamb = 40 C to +85 C V The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. 9. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI input voltage VO output voltage Tamb Conditions Poduct data sheet Max Unit 0.7 2.75 V 0 2.75 V Active mode 0 VCC V Power-down mode; VCC = 0 V 0 2.75 V 40 +85 C ambient temperature 74AXP2G17 Min All information provided in this document is subject to legal disclaimers. Rev. 1 — 12 November 2015 © Nexperia B.V. 2017. All rights reserved 4 of 16 74AXP2G17 Nexperia Low-power dual Schmitt trigger 10. Static characteristics Table 7. Static characteristics At recommended operating conditions, unless otherwise specified; voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 40 C to +85 C Conditions Min Typ 25 C 0.3VCC - 0.8VCC 0.8VCC V VCC = 1.1 V to 1.95 V 0.4VCC - 0.7VCC 0.7VCC V VCC = 2.3 V to 2.7 V 0.9 - 1.7 1.7 V 0.2VCC - 0.7VCC 0.7VCC V VCC = 1.1 V to 1.95 V 0.3VCC - 0.6VCC 0.6VCC V VCC = 2.3 V to 2.7 V 0.7 - 1.5 1.5 V VCC = 0.75 V to 0.85 V 0.06VCC - 0.5VCC 0.5VCC V VCC = 1.1 V to 1.95 V 0.1VCC - 0.4VCC 0.4VCC V VCC = 2.3 V to 2.7 V 0.2 - 1.0 1.0 V positive-going see Figure 6 and Figure 7 threshold voltage VCC = 0.75 V to 0.85 V VT+ negative-going see Figure 6 and Figure 7 threshold voltage VCC = 0.75 V to 0.85 V VT hysteresis voltage VH VOH HIGH-level output voltage LOW-level output voltage VOL Unit Max 25 C Max 85 C see Figure 6 and Figure 7 IO = 20 A; VCC = 0.7 V - 0.69 - - V IO = 100 A; VCC = 0.75 V 0.65 - - - V IO = 2 mA; VCC = 1.1 V 0.825 - - - V IO = 3 mA; VCC = 1.4 V 1.05 - - - V IO = 4.5 mA; VCC = 1.65 V 1.2 - - - V IO = 8 mA; VCC = 2.3 V 1.7 - - - V IO = 20 A; VCC = 0.7 V - 0.01 - - V IO = 100 A; VCC = 0.75 V - - 0.1 0.1 V IO = 2 mA; VCC = 1.1 V - - 0.275 0.275 V IO = 3 mA; VCC = 1.4 V - - 0.35 0.35 V IO = 4.5 mA; VCC = 1.65 V - - 0.45 0.45 V IO = 8 mA; VCC = 2.3 V - - 0.7 0.7 V - 0.001 0.1 0.5 A II input leakage current VI = 0 V to 2.75 V; VCC = 0 V to 2.75 V [1] IOFF power-off leakage current VI or VO = 0 V to 2.75 V; VCC = 0 V [1] - 0.01 0.1 0.5 A IOFF additional power-off leakage current VI or VO = 0 V or 2.75 V; VCC = 0 V to 0.1 V [1] - 0.02 0.1 0.5 A ICC supply current VI = 0 V or VCC; IO = 0 A [1] - 0.01 0.3 0.6 A ICC additional supply VI = VCC  0.5 V; IO = 0 A; current VCC = 2.5 V - 2 100 150 A [1] Typical values are measured at VCC = 1.2 V. 74AXP2G17 Poduct data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 12 November 2015 © Nexperia B.V. 2017. All rights reserved 5 of 16 74AXP2G17 Nexperia Low-power dual Schmitt trigger 10.1 Waveform transfer characteristics 92 97 9, 9+ 97 97 Fig 6. 92 9, 9+ 97 PQE PQE Transfer characteristic Fig 7. Definition of VT+, VT, and VH 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 14. Symbol Parameter tpd Tamb = 25 C Conditions Tamb = 40 C to +85 C Unit Min Typ[1] Max Min Max 3 11 39 2 136 ns VCC = 1.1 V to 1.3 V 2.1 4.4 7.0 1.9 7.3 ns VCC = 1.4 V to 1.6 V 1.8 3.3 4.7 1.6 5.0 ns VCC = 1.65 V to 1.95 V 1.5 2.8 3.9 1.3 4.2 ns VCC = 2.3 V to 2.7 V 1.2 2.3 3.0 1.1 3.3 ns - - - 1.0 - ns propagation delay nA to nY; see Figure 8 [2][3] VCC = 0.75 V to 0.85 V [4] tt transition time VCC = 2.7 V; see Figure 8 CI input capacitance VI = 0 V or VCC; VCC = 0 V to 2.75 V - 0.5 - - - pF CO output capacitance VO = 0 V; VCC = 0 V - 1.0 - - - pF 74AXP2G17 Poduct data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 12 November 2015 © Nexperia B.V. 2017. All rights reserved 6 of 16 74AXP2G17 Nexperia Low-power dual Schmitt trigger Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 14. Symbol Parameter CPD Tamb = 25 C Conditions power dissipation capacitance Tamb = 40 C to +85 C Unit Min Typ[1] Max Min fi = 1 MHz; VI = 0 V to VCC VCC = 0.75 V to 0.85 V - 2.3 - - - pF VCC = 1.1 V to 1.3 V - 2.5 - - - pF VCC = 1.4 V to 1.6 V - 2.6 - - - pF VCC = 1.65 V to 1.95 V - 2.7 - - - pF VCC = 2.3 V to 2.7 V - 3.1 - - - pF [1] All typical values are measured at nominal VCC. [2] tpd is the same as tPLH and tPHL. [3] For additional propagation delay values at different load capacitances, see Figure 9 to Figure 13. [4] tt is the same as tTHL and tTLH. [5] Max [5] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi + CL  VCC2  fo where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; 12. Waveforms 9, Q$LQSXW 90 90 *1' W3/+ 92+  Q
74AXP2G17GSH 价格&库存
很抱歉,暂时无法提供与“74AXP2G17GSH”相匹配的价格&库存,您可以联系我们找货
