74HC2G125-Q100;
74HCT2G125-Q100
Dual buffer/line driver; 3-state
Rev. 2 — 1 November 2018
Product data sheet
1. General description
The 74HC2G125-Q100; 74HC2G125-Q100 are dual buffer/line drivers with 3-state outputs
controlled by the output enable inputs (nOE). Inputs include clamp diodes which enable the use of
current limiting resistors to interface inputs to voltages in excess of VCC.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
Wide supply voltage range from 2.0 V to 6.0 V
Input levels:
• For 74HC2G125-Q100: CMOS level
• For 74HCT2G125-Q100: TTL level
Symmetrical output impedance
High noise immunity
Low power dissipation
Balanced propagation delays
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω)
Multiple package options
3. Ordering information
Table 1. Ordering information
Type number
Package
74HC2G125DP-Q100
Temperature range
Name
Description
-40 °C to +125 °C
TSSOP8
plastic thin shrink small outline package; 8 leads; SOT505-2
body width 3 mm; lead length 0.5 mm
-40 °C to +125 °C
VSSOP8
plastic very thin shrink small outline package;
8 leads; body width 2.3 mm
74HCT2G125DP-Q100
74HC2G125DC-Q100
74HCT2G125DC-Q100
Version
SOT765-1
Nexperia
74HC2G125-Q100; 74HCT2G125-Q100
4. Marking
Table 2. Marking codes
Type number
Marking code[1]
74HC2G125DP-Q100
H25
74HCT2G125DP-Q100
T25
74HC2G125DC-Q100
H25
74HCT2G125DC-Q100
T25
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
2
1A
1
1OE
5
2A
7
2OE
1Y
6
2
1
2Y
3
EN1
7
Logic symbol
6
Y
A
5
EN2
mce185
Fig. 1.
1
2
3
OE
mce186
Fig. 2.
mna120
IEC logic symbol
Fig. 3.
Logic diagram (one driver)
6. Pinning information
6.1. Pinning
74HC2G125
74HCT2G125
1OE
1
8
VCC
1A
2
7
2OE
2Y
3
6
1Y
GND
4
5
2A
001aae074
Fig. 4.
Pin configuration SOT505-2 (TSSOP8) and SOT765-1 (VSSOP8)
6.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
1OE, 2OE
1, 7
output enable input (active LOW)
1A, 2A
2, 5
data input
GND
4
ground (0 V)
1Y, 2Y
6, 3
data output
VCC
8
supply voltage
74HC_HCT2G125_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2018. All rights reserved
2 / 13
Nexperia
7. Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
Control
Input
Output
nOE
nA
nY
L
L
L
L
H
H
H
X
Z
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Min
Max
Unit
VCC
supply voltage
IIK
input clamping current
VI < -0.5 V or VI > VCC + 0.5 V
[1]
-0.5
+7.0
V
±20
mA
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
[1]
±20
mA
IO
output current
VO = -0.5 V to (VCC + 0.5 V)
[1]
35
mA
ICC
supply current
70
mA
IGND
ground current
-70
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
300
mW
[1]
[2]
Conditions
Tamb = -40 °C to +125 °C
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For TSSOP8 package: above 55 °C the value of Ptot derates linearly with 2.5 mW/K.
For VSSOP8 package: above 110 °C the value of Ptot derates linearly with 8 mW/K.
9. Recommended operating conditions
Table 6. Recommended operating conditions
Symbol Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
Δt/ΔV
Conditions
74HC2G125
74HCT2G125
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VCC
VCC
V
VCC
VCC
V
-40
+25
+125
-40
+25
+125
°C
input transition rise and fall rate VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
74HC_HCT2G125_Q100
Product data sheet
3 / 13
Nexperia
10. Static characteristics
Table 7. Static characteristics
Voltages are referenced to GND (ground = 0 V). All typical values are measured at Tamb = 25 °C.
Symbol
Parameter
Conditions
Tamb = -40 °C to +85 °C
Min
Typ
Max
VCC = 2.0 V
1.5
1.2
VCC = 4.5 V
3.15
2.4
VCC = 6.0 V
4.2
VCC = 2.0 V
Tamb = -40 °C to +125 °C Unit
Min
Max
1.5
V
3.15
V
3.2
4.2
V
0.8
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
V
VCC = 6.0 V
74HC2G125-Q100
VIH
VIL
VOH
VOL
HIGH-level input
voltage
LOW-level input
voltage
2.8
1.8
1.8
V
HIGH-level output VI = VIH or VIL
voltage
IO = -20 μA; VCC = 2.0 V
1.9
2.0
1.9
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
4.4
V
IO = -20 μA; VCC = 6.0 V
5.9
6.0
5.9
V
IO = -6.0 mA; VCC = 4.5 V
3.84
4.32
3.7
V
IO = -7.8 mA; VCC = 6.0 V
5.34
5.81
5.2
V
LOW-level output VI = VIH or VIL
voltage
IO = 20 μA; VCC = 2.0 V
0.1
V
IO = 20 μA; VCC = 4.5 V
0.1
V
IO = 20 μA; VCC = 6.0 V
0.1
V
IO = 6.0 mA; VCC = 4.5 V
0.15
0.33
0.4
V
IO = 7.8 mA; VCC = 6.0 V
0.16
0.33
0.4
V
±1.0
±1.0
μA
II
input leakage
current
VI = VCC or GND; VCC = 6.0 V
IOZ
OFF-state output VI = VIH or VIL;
current
VO = VCC or GND; VCC = 6.0 V
±5.0
±10
μA
ICC
supply current
10
μA
CI
input capacitance
1.0
pF
CO
output
capacitance
1.5
pF
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
74HCT2G125-Q100
VIH
HIGH-level input
voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
V
VIL
LOW-level input
voltage
1.2
0.8
0.8
V
VOH
HIGH-level output VI = VIH or VIL; VCC = 4.5 V
voltage
IO = -20 μA
4.4
4.5
4.4
V
3.84
4.32
3.7
V
0.1
V
0.16
0.33
0.4
V
±1.0
±1.0
μA
IO = -6.0 mA
VOL
LOW-level output VI = VIH or VIL; VCC = 4.5 V
voltage
IO = 20 μA
IO = 6.0 mA
II
input leakage
current
74HC_HCT2G125_Q100
Product data sheet
VI = VCC or GND; VCC = 5.5 V
4 / 13
Nexperia
Symbol
Parameter
Conditions
Min
Typ
Max
Min
Max
IOZ
current
VO = VCC or GND; VCC = 5.5 V
±5.0
±10
μA
ICC
supply current
VCC = 5.5 V
10
μA
ΔICC
additional supply
current
per input; VCC = 4.5 V to 5.5 V;
VI = VCC - 2.1 V; IO = 0 A
375
410
μA
CI
input capacitance
1.0
pF
CO
output
capacitance
1.5
pF
11. Dynamic characteristics
Table 8. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Fig. 7.
Symbol Parameter
Conditions
Min
Typ [1]
Max
Min
Max
VCC = 2.0 V
35
115
135
ns
VCC = 4.5 V
11
23
27
ns
VCC = 5.0 V; CL = 15 pF
10
ns
VCC = 6.0 V
8
ns
VCC = 2.0 V
40
115
135
ns
VCC = 4.5 V
11
23
27
ns
VCC = 6.0 V
8
ns
VCC = 2.0 V
24
125
150
ns
VCC = 4.5 V
12
25
30
ns
VCC = 6.0 V
10
21
26
ns
VCC = 2.0 V
18
75
90
ns
VCC = 4.5 V
6
15
18
ns
VCC = 6.0 V
5
13
15
ns
output enabled
11
pF
output disabled
1
pF
74HC2G125-Q100
tpd
ten
tdis
tt
CPD
propagation
delay
enable time
disable time
transition
time
power
dissipation
capacitance
74HC_HCT2G125_Q100
Product data sheet
nA to nY; see Fig. 5
[2]
nOE to nY; see Fig. 6
[2]
[2]
see Fig. 5
[2]
per buffer; VI = GND to VCC
[3]
5 / 13
Nexperia
Symbol Parameter
Conditions
Min
Typ [1]
Max
Min
Max
VCC = 4.5 V
15
31
38
ns
12
ns
74HCT2G125-Q100
tpd
propagation
delay
[2]
ten
enable time
nOE to nY; see Fig. 6;VCC = 4.5 V [2]
15
35
42
ns
tdis
disable time
15
31
38
ns
tt
transition
time
see Fig. 5; VCC = 4.5 V
[2]
6
15
18
ns
CPD
power
dissipation
capacitance
per buffer;
VI = GND to VCC - 1.5 V
[3]
output enabled
11
pF
output disabled
1
pF
[1]
[2]
[3]
tpd is the same as tPLH and tPHL.
ten is the same as tPZL and tPZH.
tdis is the same as tPLZ and tPHZ.
tt is the same as tTHL and tTLH.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL x VCC x fo) = sum of outputs.
11.1. Waveforms and test circuit
VI
input
nA
VM
VM
GND
t PHL
t PLH
VOH
output
nY
90 %
VM
VM
10 %
VOL
t THL
t TLH
001aad982
Measurement points are given in Table 9.
Logic levels: VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 5.
Propagation delays data input (nA) to output (nY)
74HC_HCT2G125_Q100
Product data sheet
6 / 13
Nexperia
VI
nOE input
VM
GND
tPLZ
tPZL
VCC
output
LOW-to-OFF
OFF-to-LOW
VM
VX
VOL
tPHZ
VOH
tPZH
VY
output
HIGH-to-OFF
OFF-to-HIGH
GND
VM
outputs
enabled
outputs
enabled
outputs
disabled
mna362
Fig. 6.
Enable and disable times
Table 9. Measurement points
Input
Type
Output
VM
VM
VX
VY
74HC2G125-Q100
0.5VCC
0.5VCC
VOL + 0.3 V
VOH - 0.3 V
74HCT2G125-Q100
1.3 V
1.3 V
VOL + 0.3 V
VOH - 0.3 V
74HC_HCT2G125_Q100
Product data sheet
7 / 13
Nexperia
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC
VI
G
DUT
VCC
VO
RT
RL
S1
open
CL
001aad983
Test data is given in Table 10.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
RL = Load resistance.
S1 = Test selection switch.
Fig. 7.
Test circuit for measuring switching times
Table 10. Test data
Type
Input
Load
S1 position
VI
tr, tf
CL
RL
tPHL, tPLH
tPZH, tPHZ
tPZL, tPLZ
74HC2G125-Q100
VCC
≤ 6 ns
15 pF, 50 pF
1 kΩ
open
GND
VCC
74HCT2G125-Q100
3V
≤ 6 ns
15 pF, 50 pF
1 kΩ
open
GND
VCC
74HC_HCT2G125_Q100
Product data sheet
8 / 13
Nexperia
12. Package outline
TSSOP8: plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm
D
E
A
SOT505-2
X
c
HE
y
v M A
Z
5
8
A
A2
pin 1 index
(A3)
A1
θ
Lp
L
1
4
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.15
0.00
0.95
0.75
0.25
0.38
0.22
0.18
0.08
3.1
2.9
3.1
2.9
0.65
4.1
3.9
0.5
0.47
0.33
0.2
0.13
0.1
0.70
0.35
8°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT505-2
Fig. 8.
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-01-16
Package outline SOT505-2 (TSSOP8)
74HC_HCT2G125_Q100
Product data sheet
9 / 13
Nexperia
VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm
D
SOT765-1
E
A
X
c
y
HE
v
A
Z
5
8
Q
A
A2
A1
pin 1 index
(A3)
θ
Lp
1
detail X
4
e
L
w
bp
5 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
A
max.
max
nom
min
1
A1
A2
0.15 0.85
0.00 0.60
A3
0.12
D(1)
E(2)
0.27 0.23
2.1
2.4
0.17 0.08
1.9
2.2
bp
c
e
HE
0.5
3.2
3.0
L
0.4
Lp
Q
0.40 0.21
0.15 0.19
v
w
y
0.2
0.08
0.1
Z(1)
θ
0.4
8°
0.1
0°
Note
2. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
Outline
version
SOT765-1
Fig. 9.
References
IEC
JEDEC
JEITA
sot765-1_po
European
projection
Issue date
07-06-02
16-05-31
MO-187
Package outline SOT765-1 (VSSOP8)
74HC_HCT2G125_Q100
Product data sheet
10 / 13
Nexperia
13. Abbreviations
Table 11. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 12. Revision history
Document ID
Release date
Data sheet status Change notice
Supersedes
74HC_HCT2G125_Q100 v.2
20181101
Product data sheet -
74HC_HCT2G125_Q100 v.1
Modifications:
74HC_HCT2G125_Q100
Product data sheet
The format of this data sheet has been redesigned to comply with the identity guidelines
of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
20130403
11 / 13
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
15. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
74HC_HCT2G125_Q100
Product data sheet
12 / 13
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Marking.......................................................................... 2
5. Functional diagram.......................................................2
6. Pinning information......................................................2
6.1. Pinning.........................................................................2
6.2. Pin description............................................................. 2
7. Functional description................................................. 3
8. Limiting values............................................................. 3
9. Recommended operating conditions..........................3
10. Static characteristics..................................................4
11. Dynamic characteristics.............................................5
11.1. Waveforms and test circuit........................................ 6
12. Package outline.......................................................... 9
13. Abbreviations............................................................ 11
14. Revision history........................................................11
15. Legal information......................................................12
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 1 November 2018
74HC_HCT2G125_Q100
Product data sheet
13 / 13
