74HC2G34-Q100; 74HCT2G34-Q100
Dual buffer gate
Rev. 2 — 4 November 2013
Product data sheet
1. General description
The 74HC2G34-Q100; 74HCT2G34-Q100 is a dual buffer. Inputs include clamp diodes.
This enables the use of current limiting resistors to interface inputs to voltages in excess
of VCC.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Input levels:
For 74HC2G34-Q100: CMOS level
For 74HCT2G34-Q100: TTL level
Wide supply voltage range from 2.0 V to 6.0 V
Complies with JEDEC standard no. 7A
High noise immunity
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
Low power dissipation
Balanced propagation delays
Unlimited input rise and fall times
3. Ordering information
Table 1.
Type number
74HC2G34GW-Q100
Package
Temperature range
Name
Description
Version
40 C to +125 C
SC-88 plastic surface-mounted package; 6 leads
SOT363
40 C to +125 C
SC-74 plastic surface-mounted package (TSOP6); 6 leads
SOT457
74HCT2G34GW-Q100
74HC2G34GV-Q100
74HCT2G34GV-Q100
Nexperia
Dual buffer gate
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74HC2G34GW-Q100
PA
74HCT2G34GW-Q100
UA
74HC2G34GV-Q100
P34
74HCT2G34GV-Q100
U34
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
1
1A
1Y
6
3
2A
2Y
4
1
1
1
3
Logic symbol
4
A
Y
mnb064
mnb063
Fig 1.
6
Fig 2.
001aac536
IEC logic symbol
Fig 3.
Logic diagram (one gate)
6. Pinning information
6.1 Pinning
74HC2G34-Q100
74HCT2G34-Q100
1A
1
6
1Y
GND
2
5
VCC
2A
3
4
2Y
aaa-007162
Fig 4.
Pin configuration
74HC_HCT2G34_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
2 of 15
Nexperia B.V. 2017. All rights reserved
Nexperia
Dual buffer gate
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
1A
1
data input
GND
2
ground (0 V)
2A
3
data input
2Y
4
data output
VCC
5
supply voltage
1Y
6
data output
7. Functional description
Table 4.
Function table[1]
Input
Output
nA
nY
L
L
H
H
[1]
H = HIGH voltage level; L = LOW voltage level.
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Min
Max
Unit
0.5
+7.0
V
IIK
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
[1]
mA
VO < 0.5 V or VO > VCC + 0.5 V
[1]
output clamping current
mA
VO = 0.5 V to VCC + 0.5 V
[1]
IO
output current
ICC
25
mA
supply current
[1]
+50
mA
IGND
ground current
[1]
50
mA
Tstg
storage temperature
65
+150
C
250
mW
IOK
Ptot
Conditions
[2]
total power dissipation
[1]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SC-88 and SC-74 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
74HC_HCT2G34_Q100
Product data sheet
3 of 15
Nexperia
Dual buffer gate
9. Recommended operating conditions
Table 6.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Type 74HC2G34-Q100
VCC
supply voltage
2.0
5.0
6.0
V
VI
input voltage
VCC
V
VO
output voltage
VCC
V
Tamb
ambient temperature
40
+25
+125
C
tr
rise time
VCC = 2.0 V
1000
ns
VCC = 4.5 V
500
ns
VCC = 6.0 V
400
ns
VCC = 2.0 V
1000
ns
VCC = 4.5 V
500
ns
VCC = 6.0 V
400
ns
tf
fall time
except for Schmitt trigger inputs
Type 74HCT2G34-Q100
VCC
supply voltage
4.5
5.0
5.5
V
VI
input voltage
VCC
V
VO
output voltage
VCC
V
Tamb
ambient temperature
40
+25
+125
C
tr
rise time
500
ns
500
ns
VCC = 4.5 V
tf
fall time
VCC = 4.5 V
10. Static characteristics
Table 7.
Static characteristics for 74HC2G34-Q100
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
HIGH-level input voltage
VCC = 2.0 V
1.5
1.2
V
Tamb = 25 C
VIH
VIL
LOW-level input voltage
74HC_HCT2G34_Q100
Product data sheet
VCC = 4.5 V
3.15
2.4
V
VCC = 6.0 V
4.2
3.2
V
VCC = 2.0 V
0.8
0.5
V
VCC = 4.5 V
2.1
1.35
V
VCC = 6.0 V
2.8
1.8
V
4 of 15
Nexperia
Dual buffer gate
Table 7.
Static characteristics for 74HC2G34-Q100 …continued
Symbol
Parameter
Conditions
VOH
HIGH-level output voltage
VI = VIH or VIL
VOL
LOW-level output voltage
Min
Typ
Max
Unit
IO = 20 A; VCC = 2.0 V
1.9
2.0
V
IO = 20 A; VCC = 4.5 V
4.4
4.5
V
IO = 20 A; VCC = 6.0 V
5.9
6.0
V
IO = 4.0 mA; VCC = 4.5 V
4.18
4.32
V
IO = 5.2 mA; VCC = 6.0 V
5.68
5.81
V
V
V
V
0.15
0.26
V
0.16
0.26
V
VI = VIH or VIL
II
input leakage current
VI = GND or VCC; VCC = 6.0 V
0.1
A
ICC
supply current
VI = GND or VCC; IO = 0 A;
1.0
A
1.5
pF
VCC = 2.0 V
1.5
V
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.8
V
VCC = 6.0 V
CI
input capacitance
Tamb = 40 C to +85 C
VIH
VIL
VOH
VOL
VI = VIH or VIL
1.9
V
4.4
V
5.9
V
4.13
V
5.63
V
0.1
V
0.1
V
0.1
V
0.33
V
0.33
V
VI = VIH or VIL
II
1.0
A
ICC
supply current
10.0
A
VCC = 6.0 V
74HC_HCT2G34_Q100
Product data sheet
5 of 15
Nexperia
Dual buffer gate
Table 7.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCC = 2.0 V
1.5
V
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.8
V
1.9
V
4.4
V
5.9
V
3.7
V
5.2
V
0.1
V
0.1
V
0.1
V
0.4
V
0.4
V
Tamb = 40 C to +125 C
VIH
VIL
VOH
VOL
VI = VIH or VIL
VI = VIH or VIL
II
1.0
A
ICC
supply current
20.0
A
VCC = 6.0 V
Table 8.
Static characteristics for 74HCT2G34-Q100
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VIH
VCC = 4.5 V to 5.5 V
2.0
1.6
V
VIL
1.2
0.8
V
VOH
VI = VIH or VIL
4.4
4.5
V
4.18
4.32
V
Tamb = 25 C
VOL
VI = VIH or VIL
V
0.15
0.26
V
II
VI = GND or VCC; VCC = 5.5 V
0.1
A
ICC
supply current
VCC = 5.5 V
1.0
A
ICC
additional supply current
VI = VCC 2.1 V;
VCC = 4.5 V to 5.5 V; IO = 0 A
300
A
CI
input capacitance
1.5
pF
74HC_HCT2G34_Q100
Product data sheet
6 of 15
Nexperia
Dual buffer gate
Table 8.
Static characteristics for 74HCT2G34-Q100 …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VIH
2.0
V
VIL
0.8
V
VOH
VI = VIH or VIL
4.4
V
4.13
V
0.1
V
0.33
V
VOL
VI = VIH or VIL
II
1.0
A
ICC
supply current
VCC = 5.5 V
10.0
A
ICC
VI = VCC 2.1 V;
375
A
VIH
2.0
V
VIL
0.8
V
VOH
VI = VIH or VIL
4.4
V
3.7
V
VOL
VI = VIH or VIL
0.1
V
0.4
V
II
1.0
A
ICC
supply current
VCC = 5.5 V
20.0
A
ICC
VI = VCC 2.1 V;
410
A
74HC_HCT2G34_Q100
Product data sheet
7 of 15
Nexperia
Dual buffer gate
11. Dynamic characteristics
Table 9.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6.
Symbol
Parameter
25 C
Conditions
40 C to +125 C
Unit
Min
Typ
Max
Min
Max
(85 C)
Max
(125 C)
VCC = 2.0 V; CL = 50 pF
29
75
95
125
ns
VCC = 4.5 V; CL = 50 pF
9
15
19
25
ns
8
13
16
ns
18
75
95
125
ns
6
15
19
25
ns
5
13
16
ns
10
pF
10
18
23
29
ns
6
15
19
25
ns
9
pF
74HC2G34-Q100
tpd
propagation delay
nA to nY; see Figure 5
[1]
VCC = 6.0 V; CL = 50 pF
tt
transition time
nY; see Figure 5
[2]
CPD
power dissipation
capacitance
VI = GND to VCC
[3]
[1]
74HCT2G34-Q100
tpd
propagation delay
tt
transition time
nY; see Figure 5
[2]
CPD
power dissipation
capacitance
[1]
tpd is the same as tPLH and tPHL
[2]
tt is the same as tTLH and tTHL
[3]
VI = GND to VCC 1.5 V
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of the outputs.
74HC_HCT2G34_Q100
Product data sheet
8 of 15
Nexperia
Dual buffer gate
12. Waveforms
VI
VM
VM
nA input
GND
tPHL
tPLH
VOH
90 %
90 %
nY output
10 %
VOL
10 %
tTLH
tTHL
001aaf302
Measurement points are given in Table 10.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 5.
Table 10.
The data input (nA) to output (nY) propagation delays and output transition times
Measurement points
Type
Input
Output
VM
VI
tr = tf
VM
74HC2G34-Q100
0.5VCC
GND to VCC
6.0 ns
0.5VCC
74HCT2G34-Q100
1.3 V
GND to 3.0 V
6.0 ns
1.3 V
VCC
VCC
PULSE
GENERATOR
VI
VO
RL = 1 kΩ
open
D.U.T
RT
CL
50 pF
mgk563
Test data is given in Table 11.
Definitions test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
Fig 6.
Table 11.
Test circuit for measuring switching times
Test data
Type
Input
VI
tr, tf
tPHL, tPLH
74HC2G34-Q100
GND to VCC
6 ns
open
74HCT2G34-Q100
GND to 3.0 V
6 ns
open
74HC_HCT2G34_Q100
Product data sheet
Test
9 of 15
Nexperia
Dual buffer gate
13. Package outline
Plastic surface-mounted package; 6 leads
SOT363
D
E
B
y
X
A
HE
6
5
v M A
4
Q
pin 1
index
A
A1
1
2
e1
3
c
bp
Lp
w M B
e
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
max
bp
c
D
E
e
e1
HE
Lp
Q
v
w
y
mm
1.1
0.8
0.1
0.30
0.20
0.25
0.10
2.2
1.8
1.35
1.15
1.3
0.65
2.2
2.0
0.45
0.15
0.25
0.15
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT363
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
04-11-08
06-03-16
SC-88
Fig 7. Package outline SOT363 (SC-88)
74HC_HCT2G34_Q100
Product data sheet
10 of 15
Nexperia
Dual buffer gate
Plastic surface-mounted package (TSOP6); 6 leads
D
SOT457
E
B
y
A
HE
6
5
X
v M A
4
Q
pin 1
index
A
A1
c
1
2
3
Lp
bp
e
w M B
detail X
2 mm
scale
UNIT
A
A1
bp
c
D
E
e
HE
Lp
Q
v
w
y
mm
1.1
0.9
0.1
0.013
0.40
0.25
0.26
0.10
3.1
2.7
1.7
1.3
0.95
3.0
2.5
0.6
0.2
0.33
0.23
0.2
0.2
0.1
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT457
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
05-11-07
06-03-16
SC-74
Fig 8. Package outline SOT457 (SC-74)
74HC_HCT2G34_Q100
Product data sheet
11 of 15
Nexperia
Dual buffer gate
14. Abbreviations
Table 12.
Abbreviations
Acronym
Description
CMOS
Complementary Metal Oxide Semiconductor
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
DUT
Device Under Test
15. Revision history
Table 13.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT2G34_Q100 v.2
20131104
Product data sheet
74HC_HCT2G34_Q100 v.1
Modifications:
74HC_HCT2G34_Q100
Product data sheet
Added type number 74HC2G34GW and 74HCT2G34GW (SOT363)
20130417
Product data sheet
12 of 15
Nexperia
Dual buffer gate
16. Legal information
16.1 Data sheet status
Document status[1][2]
Product status[3]
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
Definition
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
16.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
16.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74HC_HCT2G34_Q100
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
13 of 15
Nexperia
Dual buffer gate
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
16.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
17. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74HC_HCT2G34_Q100
Product data sheet
14 of 15
Nexperia
Dual buffer gate
18. Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
12
13
14
15
16
16.1
16.2
16.3
16.4
17
18
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 4
Dynamic characteristics . . . . . . . . . . . . . . . . . . 8
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12
Legal information. . . . . . . . . . . . . . . . . . . . . . . 13
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Contact information. . . . . . . . . . . . . . . . . . . . . 14
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
04 November 2013
Date of release:
很抱歉,暂时无法提供与“74HCT2G34GV-Q100H”相匹配的价格&库存,您可以联系我们找货
