74LVT244A-Q100;
74LVTH244A-Q100
3.3 V octal buffer/line driver; 3-state
Rev. 1 — 22 April 2013
Product data sheet
1. General description
The 74LVT244A-Q100; 74LVTH244A-Q100 is a high-performance BiCMOS product
designed for VCC operation at 3.3 V.
This device is an octal buffer that is ideal for driving bus lines. The device features two
output enables (1OE, 2OE), each controlling four of the 3-state outputs.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 3) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 3)
Specified from 40 C to +85 C
Octal bus interface
3-state buffers
Output capability: +64 mA and 32 mA
TTL input and output switching levels
Input and output interface capability to systems at 5 V supply
Bus hold data inputs eliminate need for external pull-up resistors to hold unused inputs
Live insertion and extraction permitted
Power-up 3-state
No bus current loading when output is tied to 5 V bus
Latch-up protection
JESD78 Class II exceeds 500 mA
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
Nexperia
3. Ordering information
Table 1.
Type number
Package
74LVT244AD-Q100
Temperature range Name
Description
Version
40 C to +85 C
SO20
plastic small outline package; 20 leads;
body width 7.5 mm
SOT163-1
40 C to +85 C
TSSOP20
plastic thin shrink small outline package;
20 leads; body width 4.4 mm
SOT360-1
40 C to +85 C
DHVQFN20 plastic dual in-line compatible thermal enhanced SOT764-1
very thin quad flat package; no leads;
20 terminals; body 2.5 4.5 0.85 mm
74LVTH244AD-Q100
74LVT244APW-Q100
74LVTH244APW-Q100
74LVT244ABQ-Q100
74LVTH244ABQ-Q100
4. Functional diagram
2
4
1A0
1Y0
1A1
1Y1
1A2
1Y2
1A3
1Y3
18
16
1
6
8
1
11
13
15
17
19
12
1OE
2A0
2A1
2A2
2A3
2Y0
2Y1
2Y2
2Y3
EN
14
9
2
18
4
16
6
14
8
12
19
7
5
EN
11
9
13
7
15
5
17
3
3
mna826
2OE
mna825
Fig 1.
Logic symbol
74LVT_LVTH244A_Q100
Product data sheet
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 15
Nexperia
5. Pinning information
5.1 Pinning
2(
WHUPLQDO
LQGH[DUHD
/97$4
/97+$4
9&&
/97$4
/97+$4
2(
很抱歉,暂时无法提供与“74HCT3G34DP-Q100H”相匹配的价格&库存,您可以联系我们找货
