74HC7541D,112
74HC7541D,112
    NEXPERIA(安世)
    SO-20_12.8X7.5MM
    八路施密特触发器缓冲器/线路驱动器;三态
74HC7541D,112 数据手册
74HC7541; 74HCT7541 Octal Schmitt trigger buffer/line driver; 3-state Rev. 7 — 4 March 2016 Product data sheet 1. General description The 74HC7541; 74HCT7541 is an 8-bit buffer/line driver with Schmitt-trigger inputs and 3-state outputs. The device features two output enables (OE1 and OE2). A HIGH on OEn causes the outputs to assume a high-impedance OFF-state. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. Schmitt trigger inputs transform slowly changing input signals into sharply defined jitter-free output signals. 2. Features and benefits  Non-inverting outputs  Low-power dissipation  Input levels:  For 74HC7541: CMOS level  For 74HCT7541: TTL level  Complies with JEDEC standard no. 7A  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 40 C to +125 C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 74HC7541DB 40 C to +125 C SSOP20 plastic shrink small outline package; 20 leads; body width 5.3 mm SOT339-1 74HC7541PW 40 C to +125 C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 74HC7541D 74HCT7541D 74HCT7541PW 74HC7541; 74HCT7541 Nexperia Octal Schmitt trigger buffer/line driver; 3-state 4. Functional diagram     $
74HC7541D,112 价格&库存
很抱歉,暂时无法提供与“74HC7541D,112”相匹配的价格&库存,您可以联系我们找货
