74HC7014
Hex non-inverting precision Schmitt-trigger
Rev. 4 — 26 November 2015
Product data sheet
1. General description
The 74HC7014 is a hex buffer with precision Schmitt-trigger inputs. The precisely defined
trigger levels are lying in a window between 0.55 VCC and 0.65 VCC. It makes the
circuit suitable to operate in a highly noisy environment. Input shorts are allowed to 1.5 V
and +16 V without disturbing other channels. Inputs include clamp diodes that enable the
use of current limiting resistors to interface inputs to voltages in excess of VCC. Schmitt
trigger inputs transform slowly changing input signals into sharply defined jitter-free output
signals.
2. Features and benefits
Operating voltage 3.0 V to 6.0 V
Complies with JEDEC standard no. 7A
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115A exceeds 200 V
Specified from 40 C to +85 C and from 40 C to +125 C
3. Applications
Wave and pulse shapers for highly noisy environments
4. Ordering information
Table 1.
Type number
74HC7014D
Package
Temperature range
Name
Description
Version
40 C to +125 C
SO14
plastic small outline package; 14 leads; body width 3.9 mm SOT108-1
74HC7014
Nexperia
5. Functional diagram
DDD
Fig 1.
Logic symbol
DDD
Fig 2.
DDD
IEC logic symbol
Fig 3.
Logic diagram (one gate)
6. Pinning information
6.1 Pinning
9&&
*1'
DDD
Fig 4.
Pin configuration
6.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1A to 6A
1, 3, 5, 9, 11, 13
data input
1Y to 6Y
2, 4, 6, 8, 10, 12
data output
GND
7
ground (0 V)
VCC
14
supply voltage
74HC7014
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 12
74HC7014
Nexperia
7. Functional description
Table 3.
Functional table[1]
Input
Output
nA
nY
L
L
H
H
[1]
H = HIGH voltage level; L = LOW voltage level
8. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
0.5
+7
V
±20
mA
±20
mA
25
mA
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
[1]
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
0.5 V < VO < VCC + 0.5 V
ICC
supply current
50
mA
IGND
ground current
50
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
500
mW
IIK
[2]
SO14 package
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO14 packages: Ptot derates linearly with 5.5 mW/K above 60 C.
9. Recommended operating conditions
Table 5.
Symbol
Parameter
VCC
supply voltage
VI
Min
Typ
Max
Unit
2.0
5.0
6.0
V
input voltage
VCC
V
VO
output voltage
VCC
V
Tamb
ambient temperature
40
+125
C
74HC7014
Product data sheet
Conditions
3 of 12
74HC7014
Nexperia
10. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Tamb = 25 C
Conditions
Min
VOH
VOL
II
ICC
CI
HIGH-level
VI = VT+ or VT
output voltage
IO = 20 A; VCC = 2.0 V
1.9
IO = 20 A; VCC = 4.5 V
4.4
Typ
Tamb = 40 C
to +85 C
Tamb = 40 C Unit
to +125 C
Max
Min
Max
Min
Max
2.0
1.9
1.9
V
4.5
4.4
4.4
V
IO = 20 A; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = 4.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = 5.2 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
LOW-level
VI = VT+ or VT
output voltage
0.1
0.1
V
0.1
0.1
V
0.1
0.1
V
0.15
0.26
0.33
0.4
V
input leakage
current
DC supply
current
input
capacitance
74HC7014
Product data sheet
0.16
0.26
0.33
0.4
V
VCC = 6.00 V;
VI = VCC or GND
0.1
1.0
1.0
A
VCC = 3.00 V to 6.00 V;
VI = 16 V or GND
0.5
5.0
5.0
A
VCC = 3.00 V
0.7
1.4
1.8
2.1
mA
VCC = 5.25 V
3.0
6.0
7.5
7.5
mA
VCC = 6.00 V
3.7
7.4
10.0
13.0
mA
3.5
pF
4 of 12
74HC7014
Nexperia
11. Dynamic characteristics
Table 7.
GND = 0 V; for test circuit, see Figure 6.
Symbol Parameter
Tamb = 25 C
Tamb = 40 C to +125 C
Min
Typ
Max
Max (85 C) Max (125 C)
95
475
VCC = 4.75 V
38
115
VCC = 6.00 V
27
Conditions
HIGH to LOW
nA to nY; see Figure 5
propagation delay
VCC = 3.00 V
tPHL
715
ns
175
ns
73
93
112
ns
47
175
220
260
ns
23
52
65
78
ns
18
46
58
70
ns
VCC = 3.00 V
12
30
ns
VCC = 4.75 V
7
15
19
22
ns
6
13
16
19
ns
9
pF
LOW to HIGH
propagation delay
VCC = 3.00 V
tPLH
VCC = 4.75 V
VCC = 6.00 V
transition time
tt
[1]
see Figure 5
VCC = 6.00 V
power dissipation
capacitance
CPD
[1]
[2]
Unit
per gate; VI = GND to VCC
[2]
tt is the same as tTHL and tTLH.
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
74HC7014
Product data sheet
5 of 12
74HC7014
Nexperia
12. Waveforms
9,
Q$LQSXW
90
90
*1'
W3/+
92+
W3+/
Q
很抱歉,暂时无法提供与“74HC7014D,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+59.11742
- 3+55.95513
- 10+33.02846
- 13+18.97380
- 29+18.00754
