74HC7014-Q100
Hex non-inverting precision Schmitt-trigger
Rev. 1 — 26 May 2014
Product data sheet
1. General description
The 74HC7014-Q100 is a hex buffer with precision Schmitt-trigger inputs. The precisely
defined trigger levels are lying in a window between 0.55 VCC and 0.65 VCC. It makes
the circuit suitable to operate in a highly noisy environment. Input shorts are allowed to
1.5 V and +16 V without disturbing other channels. Inputs include clamp diodes that
enable the use of current limiting resistors to interface inputs to voltages in excess of VCC.
Schmitt trigger inputs transform slowly changing input signals into sharply defined
jitter-free output signals.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Operating voltage 3.0 V to 6.0 V
Complies with JEDEC standard no. 7A
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
3. Applications
Wave and pulse shapers for highly noisy environments
4. Ordering information
Table 1.
Type number
Package
Temperature range Name
74HC7014D-Q100 40 C to +125 C
SO14
Description
Version
plastic small outline package; 14 leads; body width 3.9 mm SOT108-1
74HC7014-Q100
Nexperia
5. Functional diagram
1
3
5
1A
1Y
2A
2Y
3A
3Y
4A
4Y
5A
5Y
6A
6Y
1
2
3
4
5
6
9
8
2
4
6
A
9
11
13
8
11
10
13
12
10
12
aaa-012607
Fig 1.
Y
aaa-012611
Logic symbol
aaa-012609
Fig 2.
IEC logic symbol
Fig 3.
Logic diagram (one gate)
6. Pinning information
6.1 Pinning
+&4
9&&
*1'
DDD
Fig 4.
Pin configuration
6.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1A to 6A
1, 3, 5, 9, 11, 13
data input
1Y to 6Y
2, 4, 6, 8, 10, 12
data output
GND
7
ground (0 V)
VCC
14
supply voltage
74HC7014_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 12
74HC7014-Q100
Nexperia
7. Functional description
Table 3.
Functional table[1]
Input
Output
nA
nY
L
L
H
H
[1]
H = HIGH voltage level; L = LOW voltage level
8. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
0.5
+7
V
±20
mA
±20
mA
25
mA
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
[1]
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
0.5 V < VO < VCC + 0.5 V
ICC
supply current
50
mA
IGND
ground current
50
mA
Tstg
storage temperature
Ptot
total power dissipation
IIK
[2]
65
+150
C
500
mW
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO14 packages: Ptot derates linearly with 5.5 mW/K above 60 C.
9. Recommended operating conditions
Table 5.
Symbol
Parameter
Min
Typ
Max
Unit
VCC
supply voltage
2.0
5.0
6.0
V
VI
input voltage
VCC
V
VO
output voltage
VCC
V
Tamb
ambient temperature
40
+125
C
74HC7014_Q100
Product data sheet
Conditions
3 of 12
74HC7014-Q100
Nexperia
10. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Tamb = 25 C
Conditions
Min
VOH
VOL
I
ICC
CI
HIGH-level
VI = VT+ or VT
output voltage
IO = 20 A; VCC = 2.0 V
1.9
IO = 20 A; VCC = 4.5 V
4.4
Typ
Tamb = 40 C
to +85 C
Tamb = 40 C Unit
to +125 C
Max
Min
Max
Min
Max
2.0
1.9
1.9
V
4.5
4.4
4.4
V
IO = 20 A; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = 4.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = 5.2 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
LOW-level
VI = VT+ or VT
output voltage
0.1
0.1
V
0.1
0.1
V
0.1
0.1
V
0.15
0.26
0.33
0.4
V
0.16
0.26
0.33
0.4
V
VCC = 6.00 V;
VI = VCC or GND
0.1
1.0
1.0
A
VCC = 3.00 V to 6.00 V;
VI = 16 V or GND
0.5
5.0
5.0
A
supply current VCC = 3.00 V
0.7
1.4
1.8
2.1
mA
VCC = 5.25 V
3.0
6.0
7.5
7.5
mA
VCC = 6.00 V
3.7
7.4
10.0
13.0
mA
3.5
pF
input leakage
current
input
capacitance
74HC7014_Q100
Product data sheet
4 of 12
74HC7014-Q100
Nexperia
11. Dynamic characteristics
Table 7.
GND = 0 V; for test circuit, see Figure 6.
Symbol Parameter
Tamb = 25 C
Tamb = 40 C to +125 C
Min
Typ
Max
Max (85 C) Max (125 C)
95
475
VCC = 4.75 V
38
115
VCC = 6.00 V
27
Conditions
HIGH to LOW
nA to nY; see Figure 5
propagation delay
VCC = 3.00 V
tPHL
715
ns
175
ns
73
93
112
ns
47
175
220
260
ns
23
52
65
78
ns
18
46
58
70
ns
VCC = 3.00 V
12
30
ns
VCC = 4.75 V
7
15
19
22
ns
6
13
16
19
ns
9
pF
LOW to HIGH
propagation delay
VCC = 3.00 V
tPLH
VCC = 4.75 V
VCC = 6.00 V
transition time
tt
[1]
see Figure 5
VCC = 6.00 V
power dissipation
capacitance
CPD
[1]
[2]
Unit
per gate; VI = GND to VCC
[2]
tt is the same as tTHL and tTLH.
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
74HC7014_Q100
Product data sheet
5 of 12
74HC7014-Q100
Nexperia
12. Waveforms
VI
VM
VM
nA input
GND
tPHL
tPLH
VOH
90 %
90 %
nY output
10 %
VOL
10 %
tTLH
tTHL
001aaf302
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 5.
Table 8.
The input (nA) to output (nY) propagation delays and output transition times
Measurement points
Type
74HC7014-Q100
Input
Output
VM
VM
0.5VCC
0.5VCC
VCC
VCC
PULSE
GENERATOR
VI
VO
RL = 1 kΩ
open
D.U.T
RT
CL
50 pF
mgk563
Test data is given in Table 9.
Definitions test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
Fig 6.
Table 9.
Test circuit for measuring switching times
Test data
Type
74HC7014-Q100
74HC7014_Q100
Product data sheet
Input
Test
VI
tr, tf
tPHL, tPLH
GND to VCC
6 ns
open
6 of 12
74HC7014-Q100
Nexperia
13. Transfer characteristics
Table 10. Transfer characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V); see Figure 7 and Figure 8.
Symbol Parameter
VT+
VT
VH
Tamb = 25 C
Conditions
Tamb = 40 C
to +85 C
Tamb = 40 C
to +125 C
Unit
Min
Typ
Max
Min
Max
Min
Max
positive-going
VCC = 3.00 V
threshold voltage V = 4.75 V
CC
1.86
1.95
1.95
1.95
V
2.94
3.08
3.08
3.08
V
VCC = 5.00 V
3.10
3.25
3.25
3.25
V
VCC = 5.25 V
3.25
3.41
3.41
3.41
V
VCC = 6.00 V
3.72
3.90
3.90
3.90
V
negative-going
VCC = 3.00 V
CC
1.65
1.74
1.65
1.65
V
2.62
2.76
2.62
2.62
V
VCC = 5.00 V
2.75
2.90
2.75
2.75
V
VCC = 5.25 V
2.89
3.05
2.89
2.89
V
VCC = 6.00 V
3.30
3.48
3.30
3.30
V
VCC = 3.00 V
50
120
50
50
V
VCC = 4.75 V
100
180
100
100
V
VCC = 5.00 V
120
200
120
120
V
VCC = 5.25 V
130
210
130
130
V
VCC = 6.00 V
160
240
160
160
V
hysteresis
voltage
VO
VI
VT+
VH
VT−
VO
VI
VH
VT−
Fig 7.
VT+
74HC7014_Q100
Product data sheet
mnb155
mnb154
VT+ and VT limits at 70 % and 20 %.
Fig 8.
Definition of VT+, VT and VH
7 of 12
74HC7014-Q100
Nexperia
14. Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.010 0.057
inches 0.069
0.004 0.049
0.05
0.244
0.039
0.041
0.228
0.016
0.028
0.024
0.01
0.01
0.028
0.004
0.012
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
Fig 9.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Package outline SOT108-1 (SO14)
74HC7014_Q100
Product data sheet
8 of 12
74HC7014-Q100
Nexperia
15. Abbreviations
Table 11.
Abbreviations
Acronym
Description
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
16. Revision history
Table 12.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC7014_Q100 v.1
20140526
Product data sheet
74HC7014_Q100
Product data sheet
9 of 12
74HC7014-Q100
Nexperia
17. Legal information
17.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
17.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
17.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74HC7014_Q100
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
10 of 12
74HC7014-Q100
Nexperia
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
17.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
18. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74HC7014_Q100
Product data sheet
11 of 12
Nexperia
74HC7014-Q100
19. Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
12
13
14
15
16
17
17.1
17.2
17.3
17.4
18
19
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 2
Functional description . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Recommended operating conditions. . . . . . . . 3
Static characteristics. . . . . . . . . . . . . . . . . . . . . 4
Dynamic characteristics . . . . . . . . . . . . . . . . . . 5
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Transfer characteristics . . . . . . . . . . . . . . . . . . 7
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9
Legal information. . . . . . . . . . . . . . . . . . . . . . . 10
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . 11
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Date of release: 26 May 2014
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74HC7014D-Q100J
