74LVC3G16
Triple buffer
Rev. 2 — 11 October 2016
Product data sheet
1. General description
The 74LVC3G16 provides three buffers.
The inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of
the 74LVC3G16 as a translator in a mixed 3.3 V and 5 V environment.
This device is fully specified for partial power-down applications using IOFF. The IOFF
circuitry disables the output, preventing a damaging backflow current through the device
when it is powered down.
2. Features and benefits
Wide supply voltage range from 1.65 V to 5.5 V
5 V tolerant input/output for interfacing with 5 V logic
High noise immunity
Complies with JEDEC standard:
JESD8-7 (1.65 V to 1.95 V)
JESD8-5 (2.3 V to 2.7 V)
JESD8B/JESD36 (2.7 V to 3.6 V)
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
24 mA output drive (VCC = 3.0 V)
CMOS low power consumption
Latch-up performance exceeds 250 mA
Direct interface with TTL levels
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
74LVC3G16
Nexperia
Triple buffer
3. Ordering information
Table 1.
Type number
Package
Temperature range Name
Description
Version
74LVC3G16DP
40 C to +125 C
TSSOP8
plastic thin shrink small outline package; 8 leads;
body width 3 mm; lead length 0.5 mm
SOT505-2
74LVC3G16GF
40 C to +125 C
XSON8
extremely thin small outline package; no leads;
8 terminals; body 1.35 1 0.5 mm
SOT1089
74LVC3G16GM
40 C to +125 C
XQFN8
plastic, extremely thin quad flat package; no leads;
8 terminals; body 1.6 1.6 0.5 mm
SOT902-2
4. Marking
Table 2.
Marking codes
Type number
Marking code[1]
74LVC3G16DP
YU
74LVC3G16GF
YU
74LVC3G16GM
YU
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
DDK
DDK
Fig 1.
Logic symbol
74LVC3G16
Product data sheet
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
DDF
Fig 3.
Logic diagram (one gate)
Nexperia B.V. 2017. All rights reserved
2 of 15
74LVC3G16
Nexperia
Triple buffer
6. Pinning information
6.1 Pinning
/9&*
9&&
*1'
/9&*
9&&
*1'
DDD
7UDQVSDUHQWWRSYLHZ
DDD
Pin configuration SOT505-2 (TSSOP8)
Fig 5.
Pin configuration SOT1089 (XSON8)
/9&*
9&&
WHUPLQDO
LQGH[DUHD
*1'
Fig 4.
DDD
7UDQVSDUHQWWRSYLHZ
Fig 6.
Pin configuration SOT902-2 (XQFN8)
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
SOT505-2 and SOT1089
SOT902-2
1A, 2A, 3A
1, 3, 6
7, 5, 2
data input
1Y, 2Y, 3Y
7, 5, 2
1, 3, 6
data output
GND
4
4
ground (0 V)
VCC
8
8
supply voltage
74LVC3G16
Product data sheet
3 of 15
74LVC3G16
Nexperia
Triple buffer
7. Functional description
Table 4.
Function table[1]
Input nA
Output nY
L
L
H
H
[1]
H = HIGH voltage level; L = LOW voltage level.
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
Conditions
input voltage
IOK
output clamping current
VO > VCC or VO < 0 V
VO
output voltage
Active mode
Power-down mode
Max
Unit
+6.5
V
50
[1]
0.5
+6.5
50
[1]
0.5
VCC + 0.5
V
[1][2]
0.5
+6.5
V
50
mA
VI < 0 V
VI
Min
0.5
VO = 0 V to VCC
mA
V
mA
IO
output current
ICC
supply current
100
mA
IGND
ground current
100
mA
Ptot
total power dissipation
250
mW
Tstg
storage temperature
65
+150
C
Tamb = 40 C to +125 C
[3]
[1]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation.
[3]
For TSSOP8 package: above 55 C the value of Ptot derates linearly with 2.5 mW/K.
For XSON8, XQFN8 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 6.
Operating conditions
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Conditions
Tamb
ambient temperature
t/V
input transition rise and fall rate
74LVC3G16
Product data sheet
Min
Max
Unit
1.65
5.5
V
V
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
40
+125
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 5.5 V
10
ns/V
C
4 of 15
74LVC3G16
Nexperia
Triple buffer
10. Static characteristics
Table 7.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ[1]
Max
Unit
Tamb = 40 C to +85 C
VIH
VIL
VOH
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
0.65 VCC
V
VCC = 2.3 V to 2.7 V
1.7
V
VCC = 2.7 V to 3.6 V
2.0
V
VCC = 4.5 V to 5.5 V
0.7 VCC
V
VCC = 1.65 V to 1.95 V
0.7
V
0.8
V
0.3 VCC
V
VCC 0.1
V
IO = 4 mA; VCC = 1.65 V
1.2
V
IO = 8 mA; VCC = 2.3 V
1.9
V
IO = 12 mA; VCC = 2.7 V
2.2
V
IO = 24 mA; VCC = 3.0 V
2.3
V
IO = 32 mA; VCC = 4.5 V
3.8
V
IO = 100 A; VCC = 1.65 V to 5.5 V
0.1
V
0.45
V
0.3
V
0.4
V
0.55
V
0.55
V
VI = VIH or VIL
VOL
LOW-level output voltage
0.35 VCC V
VI = VIH or VIL
II
input leakage current
VI = 5.5 V or GND; VCC = 0 V to 5.5 V
0.1
5
A
IOFF
power-off leakage current
VCC = 0 V; VI or VO = 5.5 V
0.1
10
A
ICC
supply current
VI = 5.5 V or GND;
VCC = 1.65 V to 5.5 V; IO = 0 A
0.1
10
A
ICC
additional supply current
per pin; VCC = 2.3 V to 5.5 V;
VI = VCC 0.6 V; IO = 0 A
5
500
A
CI
input capacitance
VCC = 3.3 V; VI = GND to VCC
2.5
pF
74LVC3G16
Product data sheet
5 of 15
74LVC3G16
Nexperia
Triple buffer
Table 7.
Static characteristics …continued
Symbol Parameter
Conditions
Min
Typ[1]
Max
0.65 VCC
V
Unit
VIH
VIL
VOH
1.7
V
2.0
V
0.7 VCC
V
0.7
V
0.8
V
0.3 VCC
V
VI = VIH or VIL
VOL
0.35 VCC V
VCC 0.1
V
0.95
V
1.7
V
1.9
V
2.0
V
3.4
V
0.1
V
VI = VIH or VIL
0.7
V
0.45
V
0.6
V
0.8
V
0.8
V
II
A
IOFF
A
ICC
supply current
VI = 5.5 V or GND;
40
A
ICC
5000
A
[1]
All typical values are measured at VCC = 3.3 V and Tamb = 25 C.
74LVC3G16
Product data sheet
6 of 15
74LVC3G16
Nexperia
Triple buffer
11. Dynamic characteristics
Table 8.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 8.
Symbol Parameter
40 C to +85 C
Conditions
Min
Max
Min
Max
1.0
3.8
8.6
1.0
10.8
ns
0.5
2.4
4.4
0.5
5.5
ns
VCC = 2.7 V
0.5
2.5
5.0
0.5
6.3
ns
VCC = 3.0 V to 3.6 V
0.5
2.2
4.1
0.5
5.1
ns
0.5
1.9
3.2
0.5
4.0
ns
14
pF
propagation delay nA to nY; see Figure 7
tpd
power dissipation
capacitance
CPD
40 C to +125 C Unit
Typ[1]
VI = GND to VCC; VCC = 3.3 V
[2]
[3]
[1]
Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively.
[2]
tpd is the same as tPLH and tPHL.
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
74LVC3G16
Product data sheet
7 of 15
74LVC3G16
Nexperia
Triple buffer
12. AC waveforms
9,
Q$LQSXW
90
9(;7
90
9&&
*1'
W3/+
W3+/
92+
90
Q
很抱歉,暂时无法提供与“74LVC3G16GFX”相匹配的价格&库存,您可以联系我们找货
