74LVCH16541A
16-bit buffer/line driver; 3-state
Rev. 4 — 1 May 2019
Product data sheet
1. General description
The 74LVCH16541A is a 16-bit buffer/line driver with 3-state outputs. The 3-state outputs are
controlled by the output enable inputs (1OEn and 2OEn). A HIGH on nOEn causes the outputs to
assume a high-impedance OFF-state.
Inputs can be driven from either 3.3 V or 5 V devices. When disabled, up to 5.5 V can be applied to
the outputs. These features allow the use of these devices in mixed 3.3 V and 5 V applications.
Bus hold on data inputs eliminates the need for external pull-up resistors to hold unused inputs.
2. Features and benefits
5 Volt tolerant inputs and outputs for interfacing with 5 V logic
Wide supply voltage range from 1.2 V to 3.6 V
CMOS low-power consumption
MULTIBYTE flow-through standard pin-out architecture
Low inductance multiple power and ground pins for minimum noise and ground bounce
Direct interface with TTL levels
High-impedance outputs when VCC = 0 V
All data inputs have bus hold
Complies with JEDEC standard:
• JESD8-7A (1.65 V to 1.95 V)
• JESD8-5A (2.3 V to 2.7 V)
• JESD8-C/JESD36 (2.7 V to 3.6 V)
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-B exceeds 200 V
• CDM JESD22-C101E exceeds 1000 V
Specified from -40 °C to +85 °C and -40 °C to +125 °C.
3. Ordering information
Table 1. Ordering information
Type number
Package
74LVCH16541ADGG
Temperature range
Name
Description
Version
-40 to +125 °C
TSSOP48
plastic thin shrink small outline package; 48 leads; SOT362-1
body width 6.1 mm
74LVCH16541A
Nexperia
4. Functional diagram
1OE1
1
1OE2 48
2OE1 24
25
2OE2
A0
A1
A2
A3
A4
A5
A6
A7
A0
A1
A2
A3
A4
A5
A6
A7
1A0
EN
47
46
1A1
1
1
2
3
44
5
43
6
41
8
40
9
38
11
37
12
36
35
2 2
13
14
33
16
32
17
30
19
29
22
26
23
1Y0
1A2
1Y1
1Y2
1A3
1Y3
47
2
46
3
44
5
43
6
41
8
40
9
38
11
37
12
1Y0
2A0
1Y1
2A1
1Y2
2A2
1Y3
2A3
1Y4
2A4
1Y5
2A5
1Y6
2A6
1Y7
2A7
36
13
35
14
33
16
32
17
30
19
29
22
26
23
2Y1
2Y2
2Y3
1Y4
1Y5
1A4
2Y4
1Y6
1Y7
1A5
2Y5
2Y0
2Y1
1A6
2Y2
2Y3
1A7
2Y4
2Y6
2Y7
2Y5
2Y6
1OE1
2Y7
1OE2
1
48
2OE1 24
25
2OE2
mna056
mna057
Fig. 1.
2Y0
IEC logic symbol
Fig. 2.
Logic diagram
VCC
data
input
to internal circuit
mna004
Fig. 3.
Bus hold circuit
74LVCH16541A
Product data sheet
All information provided in this document is subject to legal disclaimers.
Rev. 4 — 1 May 2019
Nexperia B.V. 2019. All rights reserved
2 / 12
74LVCH16541A
Nexperia
5. Pinning information
5.1. Pinning
74LVCH16541A
1OE1
1
48 1OE2
1Y0
2
47 1A0
1Y1
3
46 1A1
GND
4
45 GND
1Y2
5
44 1A2
1Y3
6
43 1A3
VCC
7
42 VCC
1Y4
8
41 1A4
1Y5
9
40 1A5
GND 10
39 GND
1Y6 11
38 1A6
1Y7 12
37 1A7
2Y0 13
36 2A0
2Y1 14
35 2A1
GND 15
34 GND
2Y2 16
33 2A2
2Y3 17
32 2A3
VCC 18
31 VCC
2Y4 19
30 2A4
2Y5 20
29 2A5
GND 21
28 GND
2Y6 22
27 2A6
2Y7 23
26 2A7
2OE1 24
25 2OE2
mna055
Fig. 4.
Pin configuration SOT362-1 (TSSOP48)
5.2. Pin description
Table 2. Pin description
Name
Pin
Description
1OE1
1
output enable input (active LOW)
1OE2
48
2OE1
24
2OE2
25
GND
4, 10, 15, 21, 28, 34, 39, 45
ground (0 V)
VCC
7, 18, 31, 42
positive supply voltage
1Y0, 1Y1, 1Y2, 1Y3, 1Y4, 1Y5, 1Y6, 1Y7
2, 3, 5, 6, 8, 9, 11, 12
data output
2Y0, 2Y1, 2Y2, 2Y3, 2Y4, 2Y5, 2Y6 2Y7
13, 14, 16, 17, 19, 20, 22, 23
data output
1A0, 1A1, 1A2, 1A3, 1A4, 1A5, 1A6, 1A7
47, 46, 44, 43, 41, 40, 38, 37
data input
2A0, 2A1, 2A2, 2A3, 2A4, 2A5, 2A6, 2A7
36, 35, 33, 32, 30, 29, 27, 26
data input
74LVCH16541A
Product data sheet
Rev. 4 — 1 May 2019
3 / 12
74LVCH16541A
Nexperia
6. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state
Output
Input
nOE1
nOE2
nAn
nYn
L
L
L
L
L
L
H
H
X
H
X
Z
H
X
X
Z
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Max
Unit
-0.5
+6.5
V
-0.5
+6.5
V
-50
mA
±50
mA
VCC
supply voltage
VI
input voltage
IIK
input clamping current
VI < 0
IOK
output clamping current
VO > VCC or VO < 0
VO
output voltage
output HIGH or LOW state
[2]
-0.5
output 3-state
[2]
-0.5
+6.5
V
±50
mA
[1]
IO
output current
ICC
supply current
100
mA
IGND
ground current
-100
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
Min
Max
Unit
1.65
3.6
V
1.2
V
[1]
[2]
[3]
VO = 0 V to VCC
VCC + 0.5 V
Tamb = -40 °C to +125 °C
[3]
The minimum input voltage ratings may be exceeded if the input current ratings are observed.
The output voltage ratings may be exceeded if the output current ratings are observed.
Above 60 °C the value of Ptot derates linearly with 5.5 mW/K.
8. Recommended operating conditions
Table 5. Recommended operating operations
Symbol Parameter
VCC
Conditions
supply voltage
functional
VI
input voltage
VO
output voltage
V
VCC
V
output 3-state or VCC = 0 V
V
-40
+125
°C
Tamb
ambient temperature
in free air
Δt/ΔV
input transition rise and fall rate
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 3.6 V
ns/V
74LVCH16541A
Product data sheet
Rev. 4 — 1 May 2019
4 / 12
74LVCH16541A
Nexperia
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
Conditions
-40 °C to +85 °C
VCC = 1.2 V
VCC = 1.65 V to 1.95 V
-40 °C to +125 °C
Unit
Min
Typ [1]
Max
Min
Max
1.08
1.08
V
0.65VCC
0.65VCC
V
VCC = 2.3 V to 2.7 V
1.7
1.7
V
2.0
2.0
V
VCC = 1.2 V
0.12
0.12
V
0.35VCC
0.7
0.7
V
0.8
0.8
V
VCC - 0.2
VCC
VCC - 0.3
V
IO = -4 mA; VCC = 1.65 V
1.2
1.05
V
IO = -8 mA; VCC = 2.3 V
1.8
1.65
V
IO = -12 mA; VCC = 2.7 V
2.2
2.05
V
IO = -18 mA; VCC = 3.0 V
2.4
2.25
V
IO = -24 mA; VCC = 3.0 V
2.2
2.0
V
0.2
0.3
V
IO = 4 mA; VCC = 1.65 V
0.45
0.65
V
IO = 8 mA; VCC = 2.3 V
0.6
0.8
V
IO = 12 mA; VCC = 2.7 V
0.4
0.6
V
IO = 24 mA; VCC = 3.0 V
0.55
0.8
V
VI = VIH or VIL
HIGH-level
output voltage
IO = -100 μA;
VCC = 1.65 V to 3.6 V
VI = VIH or VIL
LOW-level
output voltage
IO = 100 μA;
0.35VCC V
II
input leakage
current
VCC = 3.6 V;
VI = 5.5 V or GND
[2]
±0.1
±5
±20
μA
IOZ
OFF-state
output current
VI = VIH or VIL; VCC = 3.6 V;
VO = 5.5 V or GND
[2]
±0.1
±5
±20
μA
IOFF
power-off
VCC = 0 V; VI or VO = 5.5 V
leakage supply
±0.1
±10
±20
μA
ICC
supply current VCC = 3.6 V;
VI = VCC or GND; IO = 0 A
0.1
μA
ΔICC
additional
per input pin;
supply current VCC = 1.65 V to 3.6 V;
VI = VCC - 0.6 V; IO = 0 A
5
500
5000
μA
CI
input
capacitance
5.0
pF
74LVCH16541A
Product data sheet
VCC = 0 V to 3.6 V;
VI = GND to VCC
Rev. 4 — 1 May 2019
5 / 12
74LVCH16541A
Nexperia
Symbol Parameter
Conditions
-40 °C to +85 °C
bus hold LOW VCC = 1.65; VI = 0.58 V
current
VCC = 2.3; VI = 0.7 V
IBHL
[3][4]
VCC = 3.0; VI = 0.8 V
IBHH
bus hold HIGH VCC = 1.65; VI = 1.07 V
current
VCC = 2.3; VI = 1.7 V
[3][4]
VCC = 3.0; VI = 2.0 V
IBHLO
IBHHO
[1]
[2]
[3]
[4]
[5]
bus hold LOW VCC = 1.95 V
overdrive
VCC = 2.7 V
current
VCC = 3.6 V
[3][5]
bus hold HIGH VCC = 1.95 V
overdrive
VCC = 2.7 V
current
VCC = 3.6 V
[3][5]
-40 °C to +125 °C
Unit
Min
Typ [1]
Max
Min
Max
10
10
μA
30
25
μA
75
60
μA
-10
-10
μA
-30
-25
μA
-75
-60
μA
200
200
μA
300
300
μA
500
500
μA
-200
-200
μA
-300
-300
μA
-500
-500
μA
All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 °C.
The bus hold circuit is switched off when VI > VCC allowing 5.5 V on the input pin.
For data inputs only; control inputs do not have a bus hold circuit.
The specified sustaining current at the data inputs holds the input below the specified VI level.
The specified overdrive current at the data input forces the data input to the opposite logic input state.
10. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 7.
Symbol Parameter
Conditions
-40 °C to +85 °C
Min
tpd
propagation delay nAn to nYn; see Fig. 5
enable time
10
ns
4.7
10.4
1.8
12.0
ns
1.5
2.6
5.2
1.5
6.0
ns
VCC = 2.7 V
1.0
2.5
5.0
1.0
6.5
ns
VCC = 3.0 V to 3.6 V
1.0
2.2
4.2
1.0
5.5
ns
17
ns
1.5
5.5
14.6
1.5
16.8
ns
1.0
3.2
7.7
1.0
8.9
ns
VCC = 2.7 V
1.5
3.4
6.9
1.5
9.0
ns
1.0
2.6
5.6
1.0
7.0
ns
9.0
ns
2.6
7.3
9.2
2.6
10.6
ns
1.0
4.1
5.2
1.0
6.0
ns
VCC = 2.7 V
1.5
4.6
6.5
1.5
8.5
ns
1.5
4.5
5.5
1.5
7.0
ns
1.0
1.5
ns
nOEn to nYn; see Fig. 6
[2]
[2]
VCC = 1.2 V
tsk(o)
output skew time
74LVCH16541A
Product data sheet
Max
1.8
disable time
Min
VCC = 1.2 V
tdis
Max
[2]
VCC = 1.2 V
ten
Typ [1]
-40 °C to +125 °C Unit
nYn; VCC = 3.0 V to 3.6 V
[3]
Rev. 4 — 1 May 2019
6 / 12
74LVCH16541A
Nexperia
Symbol Parameter
Conditions
-40 °C to +85 °C
Min
CPD
[1]
[2]
[3]
[4]
power dissipation
capacitance
per input; VI = GND to VCC
Typ [1]
Max
Min
Max
[4]
8.5
pF
12.1
pF
15.3
pF
Typical values are measured at Tamb = 25 °C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V, and 3.3 V respectively.
tpd is the same as tPLH and tPHL.
ten is the same as tPZL and tPZH.
tdis is the same as tPLZ and tPHZ.
Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where:
fi = input frequency in MHz; fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in Volts
N = number of inputs switching
2
Σ(CL × VCC × fo) = sum of the outputs
10.1. Waveforms and test circuit
VI
nAn input
VM
VM
GND
tPLH
tPHL
VOH
VM
nYn output
VM
VOL
mna171
Measurement points are given in Table 8.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 5.
Input nAn to output nYn propagation delays
VI
nOEn input
VM
GND
tPLZ
VCC
output
LOW-to-OFF
OFF-to-LOW
VOL
tPZL
VM
VX
tPHZ
VOH
output
HIGH-to-OFF
OFF-to-HIGH
GND
tPZH
VY
VM
outputs
enabled
outputs
disabled
outputs
enabled
col015
Logic levels: VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 6.
3-state enable and disable times
74LVCH16541A
Product data sheet
Rev. 4 — 1 May 2019
7 / 12
74LVCH16541A
Nexperia
Table 8. Measurement points
Supply voltage
Input
Output
VCC
VI
VM
VM
VX
VY
1.2 V
VCC
0.5 × VCC
0.5 × VCC
VOL + 0.15 V
VOH - 0.15 V
1.65 V to 1.95 V
VCC
0.5 × VCC
0.5 × VCC
VOL + 0.15 V
VOH - 0.15 V
2.3 V to 2.7 V
VCC
0.5 × VCC
0.5 × VCC
VOL + 0.15 V
VOH - 0.15 V
2.7 V
2.7 V
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
3.0 V to 3.6 V
2.7 V
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
tW
VI
90 %
negative
pulse
VM
VM
10 %
0V
tf
tr
tr
VI
tf
90 %
positive
pulse
VM
VM
10 %
0V
tW
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
001aae331
Test data is given in Table 9.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 7.
Test circuit for measuring switching times
Table 9. Test data
Supply voltage
Input
Load
VEXT
VI
tr, tf
CL
RL
tPLH, tPHL
tPLZ, tPZL
tPHZ, tPZH
1.2 V
VCC
≤ 2 ns
30 pF
1 kΩ
open
2 × VCC
GND
1.65 V to 1.95 V
VCC
≤ 2 ns
30 pF
1 kΩ
open
2 × VCC
GND
2.3 V to 2.7 V
VCC
≤ 2 ns
30 pF
500 Ω
open
2 × VCC
GND
2.7 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
2 × VCC
GND
3.0 V to 3.6 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
2 × VCC
GND
74LVCH16541A
Product data sheet
Rev. 4 — 1 May 2019
8 / 12
74LVCH16541A
Nexperia
11. Package outline
TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm
SOT362-1
D
E
A
X
c
v
HE
y
A
Z
48
25
Q
A2
A1
(A3)
pin 1 index
A
θ
Lp
1
L
24
bp
e
detail X
w
5 mm
2.5
scale
Dimensions (mm are the original dimensions)
Unit
max
nom
min
mm
A
1.2
A1
A2
0.15 1.05
0.05 0.85
A3
0.25
bp
c
D(1)
E(2)
0.28
0.2
12.6
6.2
0.17
0.1
12.4
6.0
e
HE
0.5
8.3
7.9
L
1
Lp
Q
0.8
0.50
0.4
0.35
v
w
0.25 0.08
y
0.1
Z
θ
0.8
8°
0.4
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
Outline
version
SOT362-1
Fig. 8.
References
IEC
JEDEC
JEITA
sot362-1_po
European
projection
Issue date
03-02-19
13-08-05
MO-153
Package outline SOT362-1 (TSSOP48)
74LVCH16541A
Product data sheet
Rev. 4 — 1 May 2019
9 / 12
74LVCH16541A
Nexperia
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74LVCH16541A v.4
20190501
Product data sheet
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines
of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type number 74LVCH16541ADL (SOT370-1) removed.
Package outline drawing SOT362-1 (TSSOP48) updated.
Typo corrected in Table 8.
74LVCH16541A v.3
20120215
Modifications:
74LVCH16541A v.3
Product data sheet
74LVCH16541A v.2
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Table 4, Table 5, Table 6, Table 7, and Table 9: values added for lower voltage ranges.
74LVCH16541A v.2
20040218
Product specification
74LVCH16541A v.1
74LVCH16541A v.1
19980519
74LVCH16541A
Product data sheet
Rev. 4 — 1 May 2019
10 / 12
74LVCH16541A
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74LVCH16541A
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Rev. 4 — 1 May 2019
11 / 12
74LVCH16541A
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................3
5.1. Pinning.........................................................................3
5.2. Pin description............................................................. 3
6. Functional description................................................. 4
7. Limiting values............................................................. 4
8. Recommended operating conditions..........................4
9. Static characteristics....................................................5
10. Dynamic characteristics............................................ 6
10.1. Waveforms and test circuit........................................ 7
11. Package outline.......................................................... 9
12. Abbreviations............................................................ 10
13. Revision history........................................................10
14. Legal information......................................................11
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 1 May 2019
74LVCH16541A
Product data sheet
Rev. 4 — 1 May 2019
12 / 12
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74LVCH16541ADGG,11 74LVCH16541ADGG:11 74LVCH16541ADL,112 74LVCH16541ADL,118
