74LVT2244PW,118
74LVT2244PW,118
    NEXPERIA(安世)
    TSSOP20_6.5X4.4MM
    IC BUF NON-INVERT 3.6V 20TSSOP
74LVT2244PW,118 数据手册
74LVT2244 3.3 V octal buffer/line driver with 30  termination resistors; 3-state Rev. 3 — 1 September 2016 Product data sheet 1. General description The 74LVT2244 is a high-performance BiCMOS product designed for VCC operation at 3.3 V. This device is an octal buffer that is ideal for driving bus lines. The device features two output enables (1OE, 2OE), each controlling four of the 3-state outputs. The 74LVT2244 is designed with 30  series resistance in both the HIGH and LOW states of the output. This design reduces line noise in applications such as memory address drivers, clock drivers, and bus receivers/transmitters. 2. Features and benefits           Octal bus interface 3-state buffers Output capability: +12 mA and 12 mA TTL input and output switching levels Input and output interface capability to systems at 5 V supply Bus hold data inputs eliminate need for external pull-up resistors to hold unused inputs Power-up 3-state Live insertion and extraction permitted No bus current loading when output is tied to 5 V bus Latch-up protection  JESD78 Class II exceeds 500 mA  ESD protection:  HBM JESD22-A114E exceeds 2000 V  MM JESD22-A115-A exceeds 200 V 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description 74LVT2244D 40 C to +85 C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 74LVT2244DB 40 C to +85 C SSOP20 plastic shrink small outline package; 20 leads; body width 5.3 mm 74LVT2244PW 40 C to +85 C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm Version SOT339-1 SOT360-1 74LVT2244 Nexperia 3.3 V octal buffer/line driver with 30  termination resistors; 3-state 4. Functional diagram           $
74LVT2244PW,118 价格&库存
很抱歉,暂时无法提供与“74LVT2244PW,118”相匹配的价格&库存,您可以联系我们找货
