74AHCT240
Octal buffer/line driver; inverting; 3-state
Rev. 5 — 29 February 2016
Product data sheet
1. General description
The 74AHCT240 is an 8-bit inverting buffer/line driver with 3-state outputs. This device
can be used as two 4-bit buffers or one 8-bit buffer. It features two output enables (1OE
and 2OE), each controlling four of the 3-state outputs. A HIGH on nOE causes the outputs
to assume a high-impedance OFF-state. Inputs are over voltage tolerant. This feature
allows the use of these devices as translators in mixed voltage environments.
2. Features and benefits
Balanced propagation delays
All inputs have a Schmitt-trigger action
Inputs accepts voltages higher than VCC
Operates with TTL input levels
ESD protection:
HBM JESD22-A114F exceeds 2000 V
CDM JESD22-C101D exceeds 1000 V
Multiple package options
Specified from 40 C to +85 C and from 40 C to +125 C
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74AHCT240D
40 C to +125 C
SO20
plastic small outline package; 20 leads;
body width 7.5 mm
SOT163-1
74AHCT240PW
40 C to +125 C
TSSOP20
plastic thin shrink small outline package; 20 leads;
body width 4.4 mm
SOT360-1
74AHCT240BQ
40 C to +125 C
DHVQFN20
plastic dual in-line compatible thermal enhanced
SOT764-1
very thin quad flat package; no leads; 20 terminals;
body 2.5 4.5 0.85 mm
74AHCT240
Nexperia
4. Functional diagram
很抱歉,暂时无法提供与“74AHCT240PW,112”相匹配的价格&库存,您可以联系我们找货
