74AUP1G158GF,132
74AUP1G158GF,132
    NEXPERIA(安世)
    XSON6_1X1MM
    低功耗2输入多路复用器;反转 XSON6_1X1MM 0.8~3.6V
74AUP1G158GF,132 数据手册
74AUP1G158 Low-power 2-input multiplexer; inverting Rev. 5 — 3 August 2012 Product data sheet 1. General description The 74AUP1G158 is a single 2-input multiplexer which select data from two data inputs (I0 and I1) under control of a common data select input (S). The state of the common data select input determines the particular register from which the data comes. The output (Y) presents the selected data in the complement (inverted) form. Schmitt trigger action at all inputs makes the circuit tolerant to slower input rise and fall times across the entire VCC range from 0.8 V to 3.6 V. This device ensures a very low static and dynamic power consumption across the entire VCC range from 0.8 V to 3.6 V. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2. Features and benefits  Wide supply voltage range from 0.8 V to 3.6 V  High noise immunity  Complies with JEDEC standards:  JESD8-12 (0.8 V to 1.3 V)  JESD8-11 (0.9 V to 1.65 V)  JESD8-7 (1.2 V to 1.95 V)  JESD8-5 (1.8 V to 2.7 V)  JESD8-B (2.7 V to 3.6 V)  ESD protection:  HBM JESD22-A114F Class 3A exceeds 5000 V  MM JESD22-A115-A exceeds 200 V  CDM JESD22-C101E exceeds 1000 V  Low static power consumption; ICC = 0.9 A (maximum)  Latch-up performance exceeds 100 mA per JESD 78 Class II  Inputs accept voltages up to 3.6 V  Low noise overshoot and undershoot < 10 % of VCC  IOFF circuitry provides partial Power-down mode operation  Multiple package options  Specified from 40 C to +85 C and 40 C to +125 C 74AUP1G158 Nexperia Low-power 2-input multiplexer; inverting 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AUP1G158GW 40 C to +125 C SC-88 plastic surface-mounted package; 6 leads SOT363 74AUP1G158GM 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; SOT886 6 terminals; body 1  1.45  0.5 mm 74AUP1G158GF 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; SOT891 6 terminals; body 1  1  0.5 mm 74AUP1G158GN 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9  1.0  0.35 mm SOT1115 74AUP1G158GS 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0  1.0  0.35 mm SOT1202 4. Marking Table 2. Marking Type number Marking code[1] 74AUP1G158GW aU 74AUP1G158GM aU 74AUP1G158GF aU 74AUP1G158GN aU 74AUP1G158GS aU [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram S I1 I0 1 6 3 4 6 G1 3 1 MUX 1 1 4 Y 001aae019 001aae018 Fig 1. Logic symbol Fig 2. I1 I0 IEC logic symbol 1 3 SELECTOR MULTIPLEXER OUTPUTS 4 Y 6 S Fig 3. 001aae020 Functional diagram 74AUP1G158 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 August 2012 © Nexperia B.V. 2017. All rights reserved 2 of 19 74AUP1G158 Nexperia Low-power 2-input multiplexer; inverting S I1 Y I0 Fig 4. 001aae021 Logic diagram 6. Pinning information 6.1 Pinning 74AUP1G158 74AUP1G158 I1 1 6 I1 1 6 S GND 2 5 VCC S GND 2 5 VCC I0 3 4 Y I0 Pin configuration SOT363 3 4 Y I1 1 6 S GND 2 5 VCC I0 3 4 Y 001aae024 001aae023 Transparent top view 001aae022 Fig 5. 74AUP1G158 Fig 6. Pin configuration SOT886 Transparent top view Fig 7. Pin configuration SOT891, SOT1115 and SOT1202 6.2 Pin description Table 3. Pin description Symbol Pin Description I1 1 data input from source 1 GND 2 ground (0 V) I0 3 data input from source 0 Y 4 multiplexer output VCC 5 supply voltage S 6 common data select input 74AUP1G158 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 August 2012 © Nexperia B.V. 2017. All rights reserved 3 of 19 74AUP1G158 Nexperia Low-power 2-input multiplexer; inverting 7. Functional description Table 4. Function table[1] Input Output S I1 I0 Y L X L H L X H L H L X H H H X L [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care. 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current Conditions Min VI < 0 V [1] VI input voltage IOK output clamping current VO < 0 V Max Unit 0.5 +4.6 V 50 - mA 0.5 +4.6 V 50 - mA 0.5 +4.6 V - 20 mA supply current - 50 mA IGND ground current 50 - mA Tstg storage temperature Ptot total power dissipation VO output voltage Active mode and Power-down mode IO output current VO = 0 V to VCC ICC Tamb = 40 C to +125 C [1] [2] 65 +150 C - 250 mW [1] The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SC-88 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. For XSON6 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC VI VO output voltage Conditions Min Max Unit supply voltage 0.8 3.6 V input voltage 0 3.6 V Active mode 0 VCC V Power-down mode; VCC = 0 V 0 3.6 V 40 +125 C VCC = 0.8 V to 3.6 V 0 200 ns/V Tamb ambient temperature t/V input transition rise and fall rate 74AUP1G158 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 August 2012 © Nexperia B.V. 2017. All rights reserved 4 of 19 74AUP1G158 Nexperia Low-power 2-input multiplexer; inverting 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min VCC = 0.8 V VCC = 0.9 V to 1.95 V Typ Max Unit 0.70  VCC - - V 0.65  VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V VCC = 0.8 V - - 0.30  VCC V VCC = 0.9 V to 1.95 V - - 0.35  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.1 - - V IO = 1.1 mA; VCC = 1.1 V 0.75  VCC - - V IO = 1.7 mA; VCC = 1.4 V 1.11 - V Tamb = 25 C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL - IO = 1.9 mA; VCC = 1.65 V 1.32 - - V IO = 2.3 mA; VCC = 2.3 V 2.05 - - V IO = 3.1 mA; VCC = 2.3 V 1.9 - - V IO = 2.7 mA; VCC = 3.0 V 2.72 - - V IO = 4.0 mA; VCC = 3.0 V 2.6 - - V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - 0.3  VCC V VI = VIH or VIL IO = 1.7 mA; VCC = 1.4 V - - 0.31 V IO = 1.9 mA; VCC = 1.65 V - - 0.31 V IO = 2.3 mA; VCC = 2.3 V - - 0.31 V IO = 3.1 mA; VCC = 2.3 V - - 0.44 V IO = 2.7 mA; VCC = 3.0 V - - 0.31 V IO = 4.0 mA; VCC = 3.0 V - - 0.44 V II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - 0.1 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - 0.2 A IOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V - - 0.2 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 0.5 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V - - 40 A CI input capacitance VCC = 0 V to 3.6 V; VI = GND or VCC - 0.8 - pF CO output capacitance VO = GND; VCC = 0 V - 1.7 - pF 74AUP1G158 Product data sheet [1] All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 August 2012 © Nexperia B.V. 2017. All rights reserved 5 of 19 74AUP1G158 Nexperia Low-power 2-input multiplexer; inverting Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min VCC = 0.8 V Typ Max Unit 0.70  VCC - - V VCC = 0.9 V to 1.95 V 0.65  VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V VCC = 0.8 V - - 0.30  VCC V VCC = 0.9 V to 1.95 V - - 0.35  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V Tamb = 40 C to +85 C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.1 - - V IO = 1.1 mA; VCC = 1.1 V 0.7  VCC - - V IO = 1.7 mA; VCC = 1.4 V 1.03 - - V IO = 1.9 mA; VCC = 1.65 V 1.30 - - V IO = 2.3 mA; VCC = 2.3 V 1.97 - - V IO = 3.1 mA; VCC = 2.3 V 1.85 - - V IO = 2.7 mA; VCC = 3.0 V 2.67 - - V IO = 4.0 mA; VCC = 3.0 V 2.55 - - V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - 0.3  VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.37 V VI = VIH or VIL IO = 1.9 mA; VCC = 1.65 V - - 0.35 V IO = 2.3 mA; VCC = 2.3 V - - 0.33 V IO = 3.1 mA; VCC = 2.3 V - - 0.45 V IO = 2.7 mA; VCC = 3.0 V - - 0.33 V IO = 4.0 mA; VCC = 3.0 V - - 0.45 V II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - 0.5 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - 0.5 A IOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V - - 0.6 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 0.9 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V - - 50 A 74AUP1G158 Product data sheet [1] All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 August 2012 © Nexperia B.V. 2017. All rights reserved 6 of 19 74AUP1G158 Nexperia Low-power 2-input multiplexer; inverting Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min VCC = 0.8 V Typ Max Unit 0.75  VCC - - V VCC = 0.9 V to 1.95 V 0.70  VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V VCC = 0.8 V - - 0.25  VCC V VCC = 0.9 V to 1.95 V - - 0.30  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V Tamb = 40 C to +125 C HIGH-level input voltage VIH LOW-level input voltage VIL VOH HIGH-level output voltage LOW-level output voltage VOL VI = VIH or VIL IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.11 - - V IO = 1.1 mA; VCC = 1.1 V 0.6  VCC - - V IO = 1.7 mA; VCC = 1.4 V 0.93 - - V IO = 1.9 mA; VCC = 1.65 V 1.17 - - V IO = 2.3 mA; VCC = 2.3 V 1.77 - - V IO = 3.1 mA; VCC = 2.3 V 1.67 - - V IO = 2.7 mA; VCC = 3.0 V 2.40 - - V IO = 4.0 mA; VCC = 3.0 V 2.30 - - V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.11 V IO = 1.1 mA; VCC = 1.1 V - - 0.33  VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.41 V VI = VIH or VIL IO = 1.9 mA; VCC = 1.65 V - - 0.39 V IO = 2.3 mA; VCC = 2.3 V - - 0.36 V IO = 3.1 mA; VCC = 2.3 V - - 0.50 V IO = 2.7 mA; VCC = 3.0 V - - 0.36 V IO = 4.0 mA; VCC = 3.0 V - - 0.50 V II input leakage current VI = GND to 3.6 V; VCC = 0 V to 3.6 V - - 0.75 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V - - 0.75 A IOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V - - 0.75 A ICC supply current VI = GND or VCC; IO = 0 A; VCC = 0.8 V to 3.6 V - - 1.4 A ICC additional supply current VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V - - 75 A [1] [1] One input at VCC  0.6 V, other input at VCC or GND. 74AUP1G158 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 August 2012 © Nexperia B.V. 2017. All rights reserved 7 of 19 74AUP1G158 Nexperia Low-power 2-input multiplexer; inverting 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min - 20.0 - - - - ns Max Max (85 C) (125 C) CL = 5 pF tpd propagation delay I0, I1 or S to Y; see Figure 8 [2] VCC = 0.8 V VCC = 1.1 V to 1.3 V 2.4 5.7 11.2 2.2 11.6 11.8 ns VCC = 1.4 V to 1.6 V 1.8 4.0 6.6 1.9 7.2 7.5 ns VCC = 1.65 V to 1.95 V 1.6 3.2 5.2 1.4 5.9 6.2 ns VCC = 2.3 V to 2.7 V 1.4 2.5 3.7 1.2 4.2 4.4 ns VCC = 3.0 V to 3.6 V 1.2 2.2 3.2 0.9 3.5 3.6 ns - 23.6 - - - - ns CL = 10 pF tpd propagation delay I0, I1 or S to Y; see Figure 8 [2] VCC = 0.8 V VCC = 1.1 V to 1.3 V 2.6 6.6 13.0 2.5 13.6 13.8 ns VCC = 1.4 V to 1.6 V 2.2 4.6 7.9 2.0 8.5 8.8 ns VCC = 1.65 V to 1.95 V 2.1 3.8 6.1 1.9 6.7 7.0 ns VCC = 2.3 V to 2.7 V 1.7 3.1 4.4 1.5 4.9 5.2 ns VCC = 3.0 V to 3.6 V 1.5 2.8 4.0 1.4 4.2 4.4 ns - 27.1 - - - - ns CL = 15 pF tpd propagation delay I0, I1 or S to Y; see Figure 8 [2] VCC = 0.8 V VCC = 1.1 V to 1.3 V 3.0 7.4 14.7 2.8 15.4 15.7 ns VCC = 1.4 V to 1.6 V 2.5 5.2 8.8 2.4 9.7 10.1 ns VCC = 1.65 V to 1.95 V 2.2 4.3 6.8 2.2 7.7 8.1 ns VCC = 2.3 V to 2.7 V 2.1 3.5 5.1 1.9 5.6 5.9 ns VCC = 3.0 V to 3.6 V 1.9 3.2 4.5 1.6 4.9 5.1 ns - 35.6 - - - - ns CL = 30 pF tpd propagation delay I0, I1 or S to Y; see Figure 8 VCC = 0.8 V 74AUP1G158 Product data sheet [2] VCC = 1.1 V to 1.3 V 3.6 9.7 19.6 3.5 20.5 21.0 ns VCC = 1.4 V to 1.6 V 3.2 6.7 11.4 3.2 12.6 13.2 ns VCC = 1.65 V to 1.95 V 3.0 5.6 8.9 2.9 10.0 10.5 ns VCC = 2.3 V to 2.7 V 2.9 4.6 6.5 2.6 7.1 7.6 ns VCC = 3.0 V to 3.6 V 2.7 4.3 5.8 2.5 6.7 7.1 ns All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 August 2012 © Nexperia B.V. 2017. All rights reserved 8 of 19 74AUP1G158 Nexperia Low-power 2-input multiplexer; inverting Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter 25 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min VCC = 0.8 V - 2.6 - - - - pF VCC = 1.1 V to 1.3 V - 2.8 - - - - pF VCC = 1.4 V to 1.6 V - 2.9 - - - - pF VCC = 1.65 V to 1.95 V - 3.1 - - - - pF VCC = 2.3 V to 2.7 V - 3.6 - - - - pF VCC = 3.0 V to 3.6 V - 4.2 - - - - pF Max Max (85 C) (125 C) CL = 5 pF, 10 pF, 15 pF and 30 pF power dissipation capacitance CPD fi = 1 MHz; VI = GND to VCC [1] All typical values are measured at nominal VCC. [2] tpd is the same as tPLH and tPHL. [3] [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of the outputs. 12. Waveforms VI I0, I1, S input VM VM GND t PHL t PLH VOH VM Y output VM VOL 001aae025 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig 8. Table 9. The data inputs (I0, I1) and common data select input (S) to output (Y) propagation delays Measurement points Supply voltage Output Input VCC VM VM VI tr = tf 0.8 V to 3.6 V 0.5  VCC 0.5  VCC VCC  3.0 ns 74AUP1G158 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 August 2012 © Nexperia B.V. 2017. All rights reserved 9 of 19 74AUP1G158 Nexperia Low-power 2-input multiplexer; inverting VCC VEXT 5 kΩ G VI VO DUT CL RT RL 001aac521 Test data is given in Table 10. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig 9. Table 10. Test circuit for measuring switching times Test data Supply voltage Load VEXT [1] VCC CL RL 0.8 V to 3.6 V 5 pF, 10 pF, 15 pF and 30 pF 5 k or 1 M [1] tPLH, tPHL tPZH, tPHZ tPZL, tPLZ open GND 2  VCC For measuring enable and disable times, RL = 5 k. For measuring propagation delays, setup and hold times and pulse width, RL = 1 M. 74AUP1G158 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 August 2012 © Nexperia B.V. 2017. All rights reserved 10 of 19 74AUP1G158 Nexperia Low-power 2-input multiplexer; inverting 13. Package outline Plastic surface-mounted package; 6 leads SOT363 D E B y X A HE 6 5 v M A 4 Q pin 1 index A A1 1 2 e1 3 bp c Lp w M B e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E e e1 HE Lp Q v w y mm 1.1 0.8 0.1 0.30 0.20 0.25 0.10 2.2 1.8 1.35 1.15 1.3 0.65 2.2 2.0 0.45 0.15 0.25 0.15 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT363 JEITA EUROPEAN PROJECTION ISSUE DATE 04-11-08 06-03-16 SC-88 Fig 10. Package outline SOT363 (SC-88) 74AUP1G158 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 August 2012 © Nexperia B.V. 2017. All rights reserved 11 of 19 74AUP1G158 Nexperia Low-power 2-input multiplexer; inverting SOT886 XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm b 1 2 3 4x (2) L L1 e 6 5 e1 4 e1 6x A (2) A1 D E terminal 1 index area 0 1 2 mm scale Dimensions (mm are the original dimensions) Unit mm max nom min A(1) 0.5 A1 b D E 0.04 0.25 1.50 1.05 0.20 1.45 1.00 0.17 1.40 0.95 e e1 0.6 0.5 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. Outline version SOT886 sot886_po References IEC JEDEC JEITA European projection Issue date 04-07-22 12-01-05 MO-252 Fig 11. Package outline SOT886 (XSON6) 74AUP1G158 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 August 2012 © Nexperia B.V. 2017. All rights reserved 12 of 19 74AUP1G158 Nexperia Low-power 2-input multiplexer; inverting XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1 x 0.5 mm 1 SOT891 b 3 2 4× (1) L L1 e 6 5 e1 4 e1 6× A (1) A1 D E terminal 1 index area 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max A1 max b D E e e1 L L1 mm 0.5 0.04 0.20 0.12 1.05 0.95 1.05 0.95 0.55 0.35 0.35 0.27 0.40 0.32 Note 1. Can be visible in some manufacturing processes. OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 05-04-06 07-05-15 SOT891 Fig 12. Package outline SOT891 (XSON6) 74AUP1G158 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 August 2012 © Nexperia B.V. 2017. All rights reserved 13 of 19 74AUP1G158 Nexperia Low-power 2-input multiplexer; inverting XSON6: extremely thin small outline package; no leads; 6 terminals; body 0.9 x 1.0 x 0.35 mm 1 SOT1115 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 scale Dimensions Unit mm 1 mm A(1) A1 b D E e e1 max 0.35 0.04 0.20 0.95 1.05 nom 0.15 0.90 1.00 0.55 min 0.12 0.85 0.95 0.3 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1115_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-07 SOT1115 Fig 13. Package outline SOT1115 (XSON6) 74AUP1G158 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 August 2012 © Nexperia B.V. 2017. All rights reserved 14 of 19 74AUP1G158 Nexperia Low-power 2-input multiplexer; inverting XSON6: extremely thin small outline package; no leads; 6 terminals; body 1.0 x 1.0 x 0.35 mm 1 SOT1202 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 scale Dimensions Unit mm 1 mm A(1) A1 b D E e e1 L L1 max 0.35 0.04 0.20 1.05 1.05 0.35 0.40 nom 0.15 1.00 1.00 0.55 0.35 0.30 0.35 min 0.12 0.95 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1202_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-06 SOT1202 Fig 14. Package outline SOT1202 (XSON6) 74AUP1G158 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 August 2012 © Nexperia B.V. 2017. All rights reserved 15 of 19 74AUP1G158 Nexperia Low-power 2-input multiplexer; inverting 14. Abbreviations Table 11. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 15. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AUP1G158 v.5 20120803 Product data sheet - 74AUP1G158 v.4 Modifications: 74AUP1G158 v.4 Modifications: 74AUP1G158 v.3 • Package outline drawing of SOT886 (Figure 11) modified. 20111124 • Product data sheet - 74AUP1G158 v.3 - 74AUP1G158 v.2 Legal pages updated. 20100713 Product data sheet 74AUP1G158 v.2 20090702 Product data sheet - 74AUP1G158 v.1 74AUP1G158 v.1 20061107 Product data sheet - - 74AUP1G158 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 August 2012 © Nexperia B.V. 2017. All rights reserved 16 of 19 74AUP1G158 Nexperia Low-power 2-input multiplexer; inverting 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74AUP1G158 Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 August 2012 © Nexperia B.V. 2017. All rights reserved 17 of 19 74AUP1G158 Nexperia Low-power 2-input multiplexer; inverting Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74AUP1G158 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 3 August 2012 © Nexperia B.V. 2017. All rights reserved 18 of 19 Nexperia 74AUP1G158 Low-power 2-input multiplexer; inverting 18. Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 12 13 14 15 16 16.1 16.2 16.3 16.4 17 18 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 8 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 16 Legal information. . . . . . . . . . . . . . . . . . . . . . . 17 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 17 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Contact information. . . . . . . . . . . . . . . . . . . . . 18 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 03 August 2012 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Nexperia: 74AUP1G158GF,132 74AUP1G158GM,115 74AUP1G158GM,132 74AUP1G158GW,125 74AUP1G158GN,132 74AUP1G158GS,132
74AUP1G158GF,132
物料型号:74AUP1G158
器件简介: - 74AUP1G158是一款单2输入多路选择器,能够根据公共数据选择输入(S)控制从两个数据输入(I0和I1)中选择数据。公共数据选择输入的状态决定了来自哪个寄存器的数据。输出(Y)以互补(反相)形式呈现所选数据。 - 所有输入都采用施密特触发器动作,使电路在整个VCC范围(0.8 V至3.6 V)内能够容忍较慢的输入上升和下降时间。 - 该设备确保在整个VCC范围内具有非常低的静态和动态功耗。 - 该设备完全适用于使用IOFF的局部断电应用。IOFF电路在断电时禁用输出,防止通过设备产生有害的回流电流。
引脚分配: - 引脚1:I1(来自源1的数据输入) - 引脚2:GND(地,0V) - 引脚3:I0(来自源0的数据输入) - 引脚4:Y(多路选择器输出) - 引脚5:VCC(供电电压) - 引脚6:S(公共数据选择输入)
参数特性: - 供电电压范围:0.8 V至3.6 V - 高抗干扰性 - 符合JEDEC标准 - ESD保护:HBM JESD22-A114F Class 3A超过5000 V,MM JESD22-A115-A超过200 V,CDM JESD22-C101E超过1000 V - 低静态功耗:ICC最大为0.9 μA - 抗锁定性能超过100 mA每JESD 78 Class II - 输入接受高达3.6 V的电压 - 低噪声过冲和下冲小于VCC的10% - IOFF电路提供部分断电模式操作 - 多种封装选项 - 规定从-40°C至+85°C和-40°C至+125°C
功能详解: - 功能表显示了输入S、I1和I0对输出Y的影响,其中H表示高电平,L表示低电平,X表示无关紧要。
应用信息: - 该多路选择器适用于需要数据选择的应用,例如数字电路设计中的数据路由。
封装信息: - 74AUP1G158GW:SC-88塑料表面贴装封装;6个引脚;SOT363 - 74AUP1G158GM:XSON6塑料超薄小外形封装;无引脚;6个终端;1x1.45x0.5 mm的封装体;SOT886 - 74AUP1G158GF:XSON6塑料超薄小外形封装;无引脚;6个终端;1x1x0.5 mm的封装体;SOT891 - 74AUP1G158GN:XSON6超薄小外形封装;无引脚;6个终端;0.9x1.0x0.35mm的封装体;SOT1115 - 74AUP1G158GS:XSON6超薄小外形封装;无引脚;6个终端;1.0x1.0x0.35mm的封装体;SOT1202
74AUP1G158GF,132 价格&库存
很抱歉,暂时无法提供与“74AUP1G158GF,132”相匹配的价格&库存,您可以联系我们找货
