74AUP1G132
Low-power 2-input NAND Schmitt trigger
Rev. 6 — 1 May 2019
Product data sheet
1. General description
The 74AUP1G132 provides the single 2-input NAND Schmitt trigger function which accept
standard input signals. They are capable of transforming slowly changing input signals into sharply
defined, jitter-free output signals.
This device ensures a very low static and dynamic power consumption across the entire VCC range
from 0.8 V to 3.6 V.
This device is fully specified for partial Power-down applications using IOFF. The IOFF circuitry
disables the output, preventing the damaging backflow current through the device when it is
powered down.
The inputs switch at different points for positive and negative-going signals. The difference between
the positive voltage VT+ and the negative voltage VT- is defined as the input hysteresis voltage VH.
2. Features and benefits
Wide supply voltage range from 0.8 V to 3.6 V
High noise immunity
ESD protection:
• HBM JESD22-A114F Class 3A exceeds 5000 V
• MM JESD22-A115-A exceeds 200 V
• CDM JESD22-C101E exceeds 1000 V
Low static power consumption; ICC = 0.9 μA (maximum)
Latch-up performance exceeds 100 mA per JESD 78 Class II
Inputs accept voltages up to 3.6 V
Low noise overshoot and undershoot < 10 % of VCC
IOFF circuitry provides partial Power-down mode operation
Multiple package options
Specified from -40 °C to +85 °C and -40 °C to +125 °C
3. Applications
Wave and pulse shaper
Astable multivibrator
Monostable multivibrator.
74AUP1G132
Nexperia
4. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
Name
Description
Version
74AUP1G132GW
-40 °C to +125 °C
TSSOP5
plastic thin shrink small outline package; 5 leads; SOT353-1
body width 1.25 mm
74AUP1G132GM
-40 °C to +125 °C
XSON6
plastic extremely thin small outline package;
no leads; 6 terminals; body 1 × 1.45 × 0.5 mm
SOT886
74AUP1G132GF
-40 °C to +125 °C
XSON6
no leads; 6 terminals; body 1 × 1 × 0.5 mm
SOT891
74AUP1G132GN
-40 °C to +125 °C
XSON6
extremely thin small outline package; no leads;
6 terminals; body 0.9 × 1.0 × 0.35 mm
SOT1115
74AUP1G132GS
-40 °C to +125 °C
XSON6
6 terminals; body 1.0 × 1.0 × 0.35 mm
SOT1202
74AUP1G132GX
-40 °C to +125 °C
X2SON5
plastic thermal enhanced extremely thin
small outline package; no leads; 5 terminals;
body 0.8 × 0.8 × 0.35 mm
SOT1226
5. Marking
Table 2. Marking
Type number
Marking code [1]
74AUP1G132GW
aE
74AUP1G132GM
aE
74AUP1G132GF
aE
74AUP1G132GN
aE
74AUP1G132GS
aE
74AUP1G132GX
aE
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
6. Functional diagram
1
B
2
A
Y
1
4
Logic symbol
74AUP1G132
Product data sheet
4
mna098
mna097
Fig. 1.
2
Fig. 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Rev. 6 — 1 May 2019
A
Y
B
001aac532
Fig. 3.
Logic diagram
Nexperia B.V. 2019. All rights reserved
2 / 20
74AUP1G132
Nexperia
7. Pinning information
7.1. Pinning
74AUP1G132
74AUP1G132
B
1
A
2
GND
3
5
VCC
4
Y
B
1
6
VCC
A
2
5
n.c.
GND
3
4
Y
001aac530
Transparent top view
001aac531
Fig. 4.
Pin configuration SOT353-1 (TSSOP5)
Fig. 5.
Pin configuration SOT886 (XSON6)
74AUP1G132
74AUP1G132
B
1
A
2
GND
3
6
VCC
5
n.c.
4
Y
B
5
VCC
4
Y
3
GND
A
001aaf508
Fig. 6.
1
2
aaa-003012
Pin configuration SOT891, SOT1115 and
SOT1202 (XSON6)
Fig. 7.
Pin configuration SOT1226 (X2SON5)
7.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
TSSOP5 and X2SON5
XSON6
B
1
1
data input
A
2
2
data input
GND
3
3
ground (0 V)
Y
4
4
data output
n.c.
5
not connected
VCC
5
6
supply voltage
74AUP1G132
Product data sheet
Rev. 6 — 1 May 2019
3 / 20
74AUP1G132
Nexperia
8. Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level.
Output
Input
A
B
Y
L
L
H
L
H
H
H
L
H
H
H
L
9. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Max
Unit
-0.5
+4.6
V
-50
-0.5
+4.6
-50
-0.5
+4.6
V
±20
mA
supply current
50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
250
mW
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
VO < 0 V
VO
output voltage
Active mode and Power-down mode
IO
output current
VO = 0 V to VCC
ICC
[1]
[2]
VI < 0 V
[1]
Tamb = -40 °C to +125 °C
[1]
[2]
mA
V
mA
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For TSSOP5 packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 and X2SON5 packages: above 118 °C the value of Ptot derates linearly with 7.8 mW/K.
10. Recommended operating conditions
Table 6. Recommended operating conditions
Symbol Parameter
Conditions
Min
Max
Unit
VCC
supply voltage
0.8
3.6
V
VI
input voltage
V
VO
output voltage
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
-40
+125
°C
Tamb
ambient temperature
74AUP1G132
Product data sheet
Rev. 6 — 1 May 2019
4 / 20
74AUP1G132
Nexperia
11. Static characteristics
Table 7. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ
Max
Unit
IO = -20 μA; VCC = 0.8 V to 3.6 V
VCC - 0.1
V
IO = -1.1 mA; VCC = 1.1 V
0.75VCC
V
IO = -1.7 mA; VCC = 1.4 V
1.11
V
IO = -1.9 mA; VCC = 1.65 V
1.32
V
IO = -2.3 mA; VCC = 2.3 V
2.05
V
IO = -3.1 mA; VCC = 2.3 V
1.9
V
IO = -2.7 mA; VCC = 3.0 V
2.72
V
IO = -4.0 mA; VCC = 3.0 V
2.6
V
IO = 20 μA; VCC = 0.8 V to 3.6 V
0.1
V
IO = 1.1 mA; VCC = 1.1 V
0.3VCC
V
IO = 1.7 mA; VCC = 1.4 V
0.31
V
IO = 1.9 mA; VCC = 1.65 V
0.31
V
IO = 2.3 mA; VCC = 2.3 V
0.31
V
IO = 3.1 mA; VCC = 2.3 V
0.44
V
IO = 2.7 mA; VCC = 3.0 V
0.31
V
IO = 4.0 mA; VCC = 3.0 V
0.44
V
Tamb = 25 °C
VOH
VOL
HIGH-level output
voltage
LOW-level output
voltage
VI = VT+ or VT-
VI = VT+ or VT-
II
input leakage current
VI = GND to 3.6 V; VCC = 0 V to 3.6 V
±0.1
μA
IOFF
power-off leakage
current
VI or VO = 0 V to 3.6 V; VCC = 0 V
±0.2
μA
ΔIOFF
additional power-off
leakage current
VCC = 0 V to 0.2 V
±0.2
μA
ICC
supply current
VI = GND or VCC; IO = 0 A;
0.5
μA
ΔICC
additional supply current VI = VCC - 0.6 V; IO = 0 A; VCC = 3.3 V [1]
40
μA
CI
input capacitance
VI = GND or VCC; VCC = 0 V to 3.6 V
1.1
pF
CO
output capacitance
VO = GND; VCC = 0 V
1.7
pF
Tamb = -40 °C to +85 °C
VOH
HIGH-level output
voltage
74AUP1G132
Product data sheet
VI = VT+ or VTIO = -20 μA; VCC = 0.8 V to 3.6 V
VCC - 0.1
V
0.7VCC
V
1.03
V
1.30
V
1.97
V
1.85
V
2.67
V
2.55
V
Rev. 6 — 1 May 2019
5 / 20
74AUP1G132
Nexperia
Symbol Parameter
Conditions
VOL
VI = VT+ or VT-
LOW-level output
voltage
Min
Typ
Max
Unit
0.1
V
0.3VCC
V
0.37
V
0.35
V
0.33
V
0.45
V
0.33
V
0.45
V
II
±0.5
μA
IOFF
power-off leakage
current
±0.5
μA
ΔIOFF
leakage current
VCC = 0 V to 0.2 V
±0.6
μA
ICC
supply current
0.9
μA
ΔICC
50
μA
VCC - 0.11
V
0.6VCC
V
0.93
V
1.17
V
1.77
V
1.67
V
2.40
V
2.30
V
0.11
V
0.33VCC
V
0.41
V
0.39
V
0.36
V
0.50
V
0.36
V
0.50
V
VOH
VOL
HIGH-level output
voltage
LOW-level output
voltage
VI = VT+ or VT-
II
±0.75
μA
IOFF
power-off leakage
current
±0.75
μA
ΔIOFF
leakage current
VCC = 0 V to 0.2 V
±0.75
μA
ICC
supply current
1.4
μA
ΔICC
75
μA
[1]
One input at VCC - 0.6 V, other input at VCC or GND.
74AUP1G132
Product data sheet
Rev. 6 — 1 May 2019
6 / 20
74AUP1G132
Nexperia
11.1. Transfer characteristics
Table 8. Transfer characteristics
Voltages are referenced to GND (ground = 0 V; for test circuit see Fig. 13.
Symbol Parameter
VT+
VT-
VH
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 0.8 V
0.30
0.60
0.30
0.60
0.30
0.62
V
VCC = 1.1 V
0.53
0.90
0.53
0.90
0.53
0.92
V
VCC = 1.4 V
0.74
1.11
0.74
1.11
0.74
1.13
V
VCC = 1.65 V
0.91
1.29
0.91
1.29
0.91
1.31
V
VCC = 2.3 V
1.37
1.77
1.37
1.77
1.37
1.80
V
VCC = 3.0 V
1.88
2.29
1.88
2.29
1.88
2.32
V
0.10
0.60
0.10
0.60
0.10
0.60
V
0.26
0.65
0.26
0.65
0.26
0.65
V
VCC = 1.4 V
0.39
0.75
0.39
0.75
0.39
0.75
V
VCC = 1.65 V
0.47
0.84
0.47
0.84
0.47
0.84
V
VCC = 2.3 V
0.69
1.04
0.69
1.04
0.69
1.04
V
VCC = 3.0 V
0.88
1.24
0.88
1.24
0.88
1.24
V
VCC = 0.8 V
0.07
0.50
0.07
0.50
0.07
0.50
V
VCC = 1.1 V
0.08
0.46
0.08
0.46
0.08
0.46
V
VCC = 1.4 V
0.18
0.56
0.18
0.56
0.18
0.56
V
VCC = 1.65 V
0.27
0.66
0.27
0.66
0.27
0.66
V
VCC = 2.3 V
0.53
0.92
0.53
0.92
0.53
0.92
V
VCC = 3.0 V
0.79
1.31
0.79
1.31
0.79
1.31
V
see Fig. 8 and Fig. 9
positive-going
threshold
voltage
negative-going see Fig. 8 and Fig. 9
threshold
VCC = 0.8 V
voltage
VCC = 1.1 V
(VT+ - VT-); see Fig. 8, Fig. 9,
Fig. 10 and Fig. 11
hysteresis
voltage
11.2. Waveforms transfer characteristics
VO
VI
VT-
Fig. 8.
VT+
74AUP1G132
Product data sheet
VH
VT-
VO
VI
VH
VT+
mna208
VT+ and VT- limits at 70 % and 20 %.
mna207
Fig. 9.
Definition of VT+, VT- and VH
Rev. 6 — 1 May 2019
7 / 20
74AUP1G132
Nexperia
001aad691
240
001aad692
1200
ICC
(µA)
ICC
(µA)
160
800
80
400
0.8
1.2
1.6
VI (V)
Fig. 10. Typical transfer characteristics; VCC = 1.8 V
2.0
VI (V)
3.0
Fig. 11. Typical transfer characteristics; VCC = 3.0 V
12. Dynamic characteristics
Table 9. Dynamic characteristics
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C -40 °C to +125 °C Unit
Min
Typ [1]
Max
Min
Max
Min
Max
22.5
ns
VCC = 1.1 V to 1.3 V
2.6
6.3
13.4
2.4
15.1
2.4
16.6
ns
VCC = 1.4 V to 1.6 V
2.2
4.6
8.2
1.9
9.7
1.9
10.7
ns
VCC = 1.65 V to 1.95 V
1.9
3.9
6.6
1.7
7.9
1.7
8.7
ns
VCC = 2.3 V to 2.7 V
1.7
3.2
5.3
1.5
6.2
1.5
6.8
ns
VCC = 3.0 V to 3.6 V
1.6
2.9
4.7
1.4
5.6
1.4
6.2
ns
CL = 5 pF
tpd
propagation
delay
A or B to Y; see Fig. 12
[2]
VCC = 0.8 V
CL = 10 pF
tpd
propagation
delay
[2]
VCC = 0.8 V
26.1
ns
3.0
7.2
15.4
2.7
17.3
2.7
19.0
ns
2.5
5.2
9.3
2.2
11.0
2.2
12.1
ns
2.3
4.5
7.5
2.0
9.0
2.0
9.9
ns
2.1
3.8
6.1
1.8
7.2
1.8
7.9
ns
2.0
3.5
5.5
1.8
6.5
1.8
7.2
ns
29.6
ns
3.3
8.0
17.2
3.0
19.4
3.0
21.3
ns
2.8
5.8
10.4
2.5
12.3
2.5
13.5
ns
2.6
5.0
8.3
2.3
10.0
2.3
11.0
ns
2.3
4.2
6.7
2.1
7.9
2.1
8.7
ns
2.2
3.9
6.1
2.0
7.3
2.0
8.0
ns
CL = 15 pF
tpd
propagation
delay
74AUP1G132
Product data sheet
VCC = 0.8 V
[2]
Rev. 6 — 1 May 2019
8 / 20
74AUP1G132
Nexperia
Symbol Parameter
Conditions
25 °C
Min
Typ [1]
Max
Min
Max
Min
Max
39.9
ns
4.3
10.2
22.6
3.8
25.4
3.8
27.9
ns
3.6
7.3
13.3
3.2
15.8
3.2
17.4
ns
3.2
6.3
10.6
2.9
12.8
2.9
14.1
ns
3.0
5.3
8.5
2.7
10.1
2.7
11.1
ns
2.8
5.0
7.8
2.7
9.2
2.7
10.1
ns
VCC = 0.8 V
2.6
pF
2.9
pF
3.0
pF
3.2
pF
3.8
pF
4.4
pF
CL = 30 pF
tpd
propagation
delay
[2]
VCC = 0.8 V
CL = 5 pF, 10 pF, 15 pF and 30 pF
CPD
[1]
[2]
[3]
power
dissipation
capacitance
fi = 1 MHz;
VI = GND to VCC
[3]
All typical values are measured at nominal VCC.
tpd is the same as tPLH and tPHL.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL × VCC × fo) = sum of the outputs.
74AUP1G132
Product data sheet
Rev. 6 — 1 May 2019
9 / 20
74AUP1G132
Nexperia
12.1. Waveforms and test circuit
VI
VM
A, B input
GND
t PHL
t PLH
VOH
VM
Y output
mna612
VOL
Measurement points are given in Table 10.
VOL and VOH are typical output voltage drop that occur with the output load.
Fig. 12. The data input (A or B) to output (Y) propagation delays
Table 10. Measurement points
Supply voltage
Output
Input
VCC
VM
VM
VI
tr = tf
0.8 V to 3.6 V
0.5 × VCC
0.5 × VCC
VCC
≤ 3.0 ns
VCC
G
VI
DUT
VEXT
5 kΩ
VO
RT
CL
RL
001aac521
Test data is given in Table 11.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 13. Test circuit for measuring switching times
Table 11. Test data
Supply voltage
Load
VCC
CL
RL [1]
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ
0.8 V to 3.6 V
5 kΩ or 1 MΩ
open
GND
2 × VCC
[1]
VEXT
For measuring enable and disable times RL = 5 kΩ.
For measuring propagation delays, setup and hold times and pulse width RL = 1 MΩ.
74AUP1G132
Product data sheet
Rev. 6 — 1 May 2019
10 / 20
74AUP1G132
Nexperia
13. Application information
The slow input rise and fall times cause additional power dissipation, this can be calculated using
the following formula:
Padd = fi × (tr × ΔICC(AV) + tf × ΔICC(AV)) × VCC where:
Padd = additional power dissipation (μW);
fi = input frequency (MHz);
tr = input rise time (ns); 10 % to 90 %;
tf = input fall time (ns); 90 % to 10 %;
ΔICC(AV) = average additional supply current (μA).
Average ΔICC(AV) differs with positive or negative input transitions, as shown in Fig. 14.
001aad027
0.3
ΔICC(AV)
(mA)
(1)
0.2
(2)
0.1
1.8
2.8
VCC (V)
3.8
(1) Positive-going edge.
(2) Negative-going edge.
Linear change of VI between 0.8 V and 2.0 V. All values given are typical, unless otherwise specified.
Fig. 14. Average ICC as a function of VCC
74AUP1G132
Product data sheet
Rev. 6 — 1 May 2019
11 / 20
74AUP1G132
Nexperia
14. Package outline
TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm
D
E
SOT353-1
A
X
c
y
HE
v M A
Z
5
4
A2
A
(A3)
A1
θ
1
Lp
3
e
e1
L
w M
bp
detail X
3 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
e1
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.1
0.8
0.15
0.30
0.15
0.25
0.08
2.25
1.85
1.35
1.15
0.65
1.3
2.25
2.0
0.425
0.46
0.21
0.3
0.1
0.1
0.60
0.15
7°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT353-1
REFERENCES
IEC
JEDEC
JEITA
MO-203
SC-88A
EUROPEAN
PROJECTION
ISSUE DATE
00-09-01
03-02-19
Fig. 15. Package outline SOT353-1 (TSSOP5)
74AUP1G132
Product data sheet
Rev. 6 — 1 May 2019
12 / 20
74AUP1G132
Nexperia
SOT886
XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm
b
1
2
3
4x
(2)
L
L1
e
6
5
e1
4
e1
6x
A
(2)
A1
D
E
terminal 1
index area
2 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
max
nom
min
A(1)
0.5
A1
b
D
E
0.04 0.25 1.50 1.05
0.20 1.45 1.00
0.17 1.40 0.95
e
e1
0.6
0.5
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Notes
1. Including plating thickness.
2. Can be visible in some manufacturing processes.
Outline
version
SOT886
sot886_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
04-07-22
12-01-05
MO-252
Fig. 16. Package outline SOT886 (XSON6)
74AUP1G132
Product data sheet
Rev. 6 — 1 May 2019
13 / 20
74AUP1G132
Nexperia
XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1 x 0.5 mm
1
SOT891
b
3
2
4×
(1)
L
L1
e
6
5
e1
4
e1
6×
A
(1)
A1
D
E
terminal 1
index area
2 mm
scale
UNIT
A
max
A1
max
b
D
E
e
e1
L
L1
mm
0.5
0.04
0.20
0.12
1.05
0.95
1.05
0.95
0.55
0.35
0.35
0.27
0.40
0.32
Note
1. Can be visible in some manufacturing processes.
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
05-04-06
07-05-15
SOT891
Fig. 17. Package outline SOT891 (XSON6)
74AUP1G132
Product data sheet
Rev. 6 — 1 May 2019
14 / 20
74AUP1G132
Nexperia
XSON6: extremely thin small outline package; no leads;
6 terminals; body 0.9 x 1.0 x 0.35 mm
1
SOT1115
b
3
2
(4×)(2)
L
L1
e
6
5
4
e1
e1
(6×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
max 0.35 0.04 0.20 0.95 1.05
nom
0.15 0.90 1.00 0.55
min
0.12 0.85 0.95
e1
0.3
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Note
2. Visible depending upon used manufacturing technology.
Outline
version
sot1115_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-07
SOT1115
Fig. 18. Package outline SOT1115 (XSON6)
74AUP1G132
Product data sheet
Rev. 6 — 1 May 2019
15 / 20
74AUP1G132
Nexperia
6 terminals; body 1.0 x 1.0 x 0.35 mm
1
SOT1202
b
3
2
(4×)(2)
L
L1
e
6
5
4
e1
e1
(6×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
e1
L
L1
max 0.35 0.04 0.20 1.05 1.05
0.35 0.40
nom
0.15 1.00 1.00 0.55 0.35 0.30 0.35
min
0.12 0.95 0.95
0.27 0.32
Note
Outline
version
sot1202_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-06
SOT1202
Fig. 19. Package outline SOT1202 (XSON6)
74AUP1G132
Product data sheet
Rev. 6 — 1 May 2019
16 / 20
74AUP1G132
Nexperia
X2SON5: plastic thermal enhanced extremely thin small outline package; no leads;
5 terminals; body 0.8 x 0.8 x 0.35 mm
D
A
B
SOT1226
X
A
E
A1
A3
detail X
terminal 1
index area
e
v
w
b
1
2
terminal 1
index area
C
C A B
C
y1 C
y
k
D
h
3
L
5
4
1 mm
scale
Dimensions
Unit
mm
A(1)
A1
A3
D
Dh
E
b
e
k
L
max 0.35 0.04 0.128 0.85 0.30 0.85 0.27
0.27
nom
0.80 0.25 0.80 0.22 0.48
0.22
min
0.040 0.75 0.20 0.75 0.17
0.20 0.17
v
0.1
w
y
y1
0.05 0.05 0.05
Note
1. Dimension A is including plating thickness.
2. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
Outline
version
References
IEC
JEDEC
EIAJ
sot1226_po
European
projection
Issue date
12-04-10
12-04-25
SOT1226
Fig. 20. Package outline SOT1226 (X2SON5)
74AUP1G132
Product data sheet
Rev. 6 — 1 May 2019
17 / 20
74AUP1G132
Nexperia
15. Abbreviations
Table 12. Abbreviations
Acronym
Description
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
16. Revision history
Table 13. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74AUP1G132 v.6
20190501
Product data sheet
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines
of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Fig. 7: Pin configuration drawing SOT1226 (X2SON5) updated.
74AUP1G132 v.5
20120629
Modifications:
74AUP1G132 v.4
20111124
Modifications:
74AUP1G132 v.3
20101029
74AUP1G132 v.2
74AUP1G132 v.1
74AUP1G132
Product data sheet
74AUP1G132 v.5
Product data sheet
74AUP1G132 v.4
Added type number 74AUP1G132GX (SOT1226)
Package outline drawing of SOT886 (Fig. 16) modified.
Product data sheet
74AUP1G132 v.3
Product data sheet
74AUP1G132 v.2
20090615
Product data sheet
74AUP1G132 v.1
20061020
Product data sheet
Legal pages updated.
Rev. 6 — 1 May 2019
18 / 20
74AUP1G132
Nexperia
17. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74AUP1G132
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Rev. 6 — 1 May 2019
19 / 20
74AUP1G132
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Ordering information....................................................2
5. Marking.......................................................................... 2
6. Functional diagram.......................................................2
7. Pinning information......................................................3
7.1. Pinning.........................................................................3
7.2. Pin description............................................................. 3
8. Functional description................................................. 4
9. Limiting values............................................................. 4
10. Recommended operating conditions........................4
11. Static characteristics..................................................5
11.1. Transfer characteristics..............................................7
11.2. Waveforms transfer characteristics............................ 7
12. Dynamic characteristics............................................ 8
12.1. Waveforms and test circuit...................................... 10
13. Application information........................................... 11
14. Package outline........................................................ 12
15. Abbreviations............................................................ 18
16. Revision history........................................................18
17. Legal information......................................................19
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 1 May 2019
74AUP1G132
Product data sheet
Rev. 6 — 1 May 2019
20 / 20
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74AUP1G132GF,132 74AUP1G132GM,115 74AUP1G132GM,132 74AUP1G132GW,125 74AUP1G132GN,132
74AUP1G132GS,132 74AUP1G132GX,125
