74HC237D,652
74HC237D,652
    NEXPERIA(安世)
    SOIC16_150MIL
    3到8线解码器,带地址锁存器的多路分解器 SOIC16_150MIL 2~6V
74HC237D,652 数据手册
74HC237 3-to-8 line decoder, demultiplexer with address latches Rev. 7 — 29 January 2016 Product data sheet 1. General description The 74HC237 is a high-speed Si-gate CMOS device and is pin compatible with low-power Schottky TTL (LSTTL). The 74HC237 is specified in compliance with JEDEC standard no. 7A. The 74HC237 is a 3-to-8 line decoder, demultiplexer with latches at the three address inputs (An). The 74HC237 essentially combines the 3-to-8 decoder function with a 3-bit storage latch. When the latch is enabled (LE = LOW), the 74HC237 acts as a 3-to-8 active LOW decoder. When the latch enable (LE) goes from LOW-to-HIGH, the last data present at the inputs before this transition, is stored in the latches. Further address changes are ignored as long as LE remains HIGH. The output enable input (E1 and E2) controls the state of the outputs independent of the address inputs or latch operation. All outputs are HIGH unless E1 is LOW and E2 is HIGH. The 74HC237 is ideally suited for implementing non-overlapping decoders in 3-state systems and strobes (stored address) applications in bus-oriented systems. 2. Features and benefits      Combines 3-to-8 decoder with 3-bit latch Multiple input enable for easy expansion or independent controls Active HIGH mutually exclusive outputs Low-power dissipation ESD protection:  HBM JESD22-A114F exceeds 2 000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and from 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74HC237D 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74HC237DB 40 C to +125 C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 74HC237 Nexperia 3-to-8 line decoder, demultiplexer with address latches 4. Functional diagram  /(
74HC237D,652 价格&库存
很抱歉,暂时无法提供与“74HC237D,652”相匹配的价格&库存,您可以联系我们找货
