REVISION H
NOTES:
1. NOT AVAILABLE AS STANDARD.
2. C REPRESENTS A CRITICAL DIMENSION.
3. PARTS TO BE PACKAGED IN TAPE & REEL.
4. QUANTITIES UNDER 5000 PCS WILL BE SHIPPED IN POCKETS
WITH COVER TAPE BUT NOT ON A REEL.
5. ROHS COMPLIANT.
6. MINIMUM CONTACT RETENTION FORCE : 0.4 N
SPECIFICATIONS:
ELECTRICAL RATINGS
J
"A"
0.05 .002
0.60 .024
GROUND
0.90 .035
0.15 .006
3.00 .118
0.03 .001
GAP
1.80±0.015 .071±.001
(TYP)
0.45 .018
0.50 .020
+.000
0.50-0.00
0.03 .020 - .001
BY SIGNING THIS DOCUMENT
YOU ARE ACCEPTING THE
CONDITIONS SET WITHIN.
YOUR REQUIREMENTS MUST BE
LISTED WITHIN THIS DRAWING.
WHERE NO DIRECTION FROM THE
CUSTOMER IS IDENTIFIED
SAMTEC'S PROCESS
REQUIREMENTS WILL BE USED.
1.80 .071
0.44 .017
SIGNAL
0.40±0.05 .016±.002
2.60 .102
SECTION "A"-"A"
"A"
RECOMMENDED P.C.B LAYOUT
2.00 .079
1.28 .050
1.34 .053
0.10[.004] C
(FOR ALL SOLDER TAILS)
0.06 .002
(TYP)
1.90 .075
1.05 .041 REF
(TYP)
ORIENTATION OF
CONNECTOR
AS SHOWN
CUTOUT PROHIBITION
AREA
2.20 .087
1.00±0.10 .039±.004
EXCEPTIONS:
PHONE No:
PRINTED NAME:
CUSTOMER SIGNATURE:
COMPANY:
DATE:
0.40 .016 (TYP)
SIGNAL
PAD FOR GROUND
PAD FOR SIGNAL
1.05 .041
0.40 .016
(TYP)
1.00 .039
4.00 .157
2.60 .102
3.00 .118
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN MILLIMETERS.
TOLERANCES ARE:
DECIMALS
0.80 .031
GROUND
.XX: .10
.XXX: .05
ANGLES
5
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 10:1
MATERIAL:
SHELL & CENTER CONTACT: PHOS BRONZE C5191
HOUSING: LCP, UL 94 V-0
F:\DWG\MISC\MKTG\RSP-122811-01-MKT.SLDDRW
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
I-PEX MHF I CONNECTOR RECEPTACLE
DWG. NO.
BY: TIM P.
RSP-122811-01
03/17/2006
SHEET 1 OF 1
很抱歉,暂时无法提供与“RSP-122811-01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+14.582611+1.76174
- 10+14.3571110+1.73450
- 25+14.1327425+1.70740
- 100+13.90725100+1.68015
- 250+10.31478250+1.24614
- 500+10.14479500+1.22561
- 1000+9.975661000+1.20517
- 国内价格
- 1+14.05467
- 10+11.12954
- 25+10.95561
- 100+10.78081
- 250+10.60688
- 500+10.43208
- 1000+10.25815
