PBV CONNECTOR
2.0
2.0 mm
mm pitch/Disconnectable
pitch/Disconnectable Crimp
Crimp style
style connectors
connectors
●S
ecure locking structure
● Sucking area on header
● High reliability contact
PBV
PBV CONNECTOR
CONNECTOR
Specifications
• Current rating: 3 A AC/DC (AWG #22)
• Voltage rating: 100 V AC/DC
• Temperature range: -25℃ to +85℃
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 10 mΩ max.
After environmental tests/ 20 mΩ max.
• Insulation resistance: lnitial/ 1,000 MΩ min.
• Withstanding voltage: 800 VAC/minute
• Applicable wire: Conductor size/ AWG#28 to #22
Insulation O.D./ 0.9 to 1.5 mm
* In using the products,refer to "Handling Precautions for Terminals
and Connectors" described on our website (Technical documents
of Product information page).
* RoHS2 compliance
* Dimensional unit: mm
* Contact JST for details.
This PBV connector, which is mainly used for
connecting PCB of flat television, is a crimping
type connector and is designed to have a secure
locking structure and a sucking area.
Standards
Recognized E 60389
PC board layout and Assembly layout
Side entry type
Top entry type
< 2 circuits >
< 2 circuits >
Circuit No.1
1 min.
< 3 to 15 circuits >
6.8
2.7 min.
±0.05
1.45 ±0.1
1.8 ±0.1
3.8 ±0.1 2.8
1.8 ±0.1
5 ±0.1
3.6
1.85
1
+0.1
±0.1
5 ±0.1
Circuit No.1
2.9 min.
A
±0.1
1 min.
2
(12.1)
8.9
1.45 ±0.1
Pattern prohibition area,
excluding product
with applicable circuit-number
(1.1)
A±0.1
Circuit No.1
1 min.
2 ±0.05
A±0.1
Note: 1
. The above figure is the figure viewed from the connector mounting side.
2. Tolerances are non-cumulative: ± 0.03 mm for all centers. The dimensions above should serve as a guideline. Contact JST for details.
1
(6.8)
1.8±0.1
3.8±0.1 2.8
5 ±0.1
(1.4)
2.7 min.
(6.8)
1.8±0.1
(12.1)
1.45±0.1
1.45±0.1
2.9 min.
Circuit No.1
1
1.85 +0.1
1 min.
3.6±0.1
excluding product
5±0.1
A±0.1
PBV CONNECTOR
Contact
Applicable wire
AWG #
mm2
Model No.
SPHD-001T-P0.5
SPHD-002T-P0.5
Insulation O.D.
(mm)
Q'ty/reel
0.13~0.33
26~22
1.0~1.5
8,000
0.08~0.21
28~24
0.9~1.5
8,000
PBV CONNECTOR
1.5
Material and Finish
Phosphor bronze, tin-plated (reflow treatment)
RoHS2 compliance
6.5
2.85
Contact
1.3
SPHD-001T-P0.5
SPHD-002T-P0.5
Crimping
machine Crimp applicator
MKS-L-10
AP-K2N
Applicator
Dies
Crimp applicator with dies
MK/SPHD-001-05
APLMK SPHD001-05
MK/SPHD-002-05
APLMK SPHD002-05
Note: Contact JST for fully automatic crimping applicator.
Housing
No. of
circuits
< 3 (2 circuits in common use) to 8 circuits >
B
A
*3
(3)
2
4
6.4
6
8
5.8
9
10
12
15
Circuit No.1
Model No.
PBVP-03V-S
PBVP-04V-S
PBVP-06V-S
PBVP-08V-S
PBVP-10V-S
PBVP-12V-S
PBVP-15V-S
Dimensions (mm)
A
B
Q'ty/
bag
4.0
10.0
2,000
6.0
12.0
2,000
10.0
16.0
1,000
14.0
20.0
1,000
18.0
24.0
1,000
22.0
28.0
500
28.0
34.0
500
Material and Finish
< 9 to 12 circuits >
PA 66, UL94V-0, natural (white)
B
A
RoHS2 compliance
Note*: 2 circuits in common use.
(3)
6.4
5.8
9
2
Circuit No.1
< 13 to 15 circuits >
B
(3)
6.4
5.8
2
9
A
Circuit No.1
2
PBV CONNECTOR
Shrouded header
No. of
circuits
Top entry type
< 2 circuits >
B
< 3 to 8 circuits >
B
4
8.9
6.8
8.9
6.8
Circuit No.1
Circuit No.1
2
A
B
8.9
B
8.9
6.8
Circuit No.1
A
< 2 circuits >
B
< 3 to 8 circuits >
B
6.8
8.9
8.9
6.8
4
Circuit No.1
Circuit No.1
2
A
B
6.8
8.9
2
Circuit No.1
A
B
8.9
6.8
Circuit No.1
2
A
3
BM02(4.0)B-PBVSS-TF SM02(4.0)B-PBVSS-TB
4.0
10.0
700
800
3
BM03B-PBVSS-TF SM03B-PBVSS-TB
4.0
10.0
700
800
4
BM04B-PBVSS-TF SM04B-PBVSS-TB
6.0
12.0
700
800
6
BM06B-PBVSS-TF SM06B-PBVSS-TB
10.0
16.0
700
800
8
BM08B-PBVSS-TF SM08B-PBVSS-TB
14.0
20.0
700
800
10
BM10B-PBVSS-TF SM10B-PBVSS-TB
18.0
24.0
700
800
12
BM12B-PBVSS-TF SM12B-PBVSS-TB
22.0
28.0
700
800
15
BM15B-PBVSS-TF SM15B-PBVSS-TB
28.0
34.0
700
800
RoHS2 compliance This product displays (LF)(SN) on a label.
Note: 1. These products listed above are supplied on embossed-tape.
2. *2 circuits product: Removing center pin from 3 circuits product
Side entry type
*2
Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment)
Wafer: Polyamide resin, UL94V-0, natural (ivory)
Reinforcement: Copper alloy, copper-undercoated, tin-plated (reflow treatment)
A
2
Dimensions (mm) Q'ty/reel
A
B Top type Side type
Material and Finish
6.8
Circuit No.1
2
Model No.
Side entry type
Top entry type
很抱歉,暂时无法提供与“PBVP-03V-S”相匹配的价格&库存,您可以联系我们找货
