DATA SHEET
SURFACE-MOUNT CERAMIC
MULTILAYER CAPACITORS
Mid-voltage
NP0/X7R
100 V TO 630 V
0.47 pF to 2.2 µF
Product Specification – March 7, 2017 V.19
RoHS compliant & Halogen Free
Product specification
Surface-Mount Ceramic Multilayer Capacitors
Mid-voltage
NP0/X7R
100 V to 630 V
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER, PHYCOMP
This specification describes Midvoltage NP0/X7R series chip
capacitors with lead-free
terminations.
CTC & 12NC
APPLICATIONS
PCs, Hard disk, Game PCs
Power supplies
LCD panel
ADSL, Modem
FEATURES
Supplied in tape on reel
Nickel-barrier end termination
RoHS compliant
Halogen Free compliant
2
18
All part numbers are identified by the series, size, tolerance, TC material,
packing style, voltage, process code, termination and capacitance value.
YAGEO BRAND ordering code
GLOBAL PART NUMBER (PREFERRED )
CC
XXXX X X XXX X
(1)
(2) (3) (4)
(5)
B
X XXX
(6) (7)
(1) SIZE – INCH BASED (METRIC)
0201 (0603) / 0402 (1005) / 0603 (1608) / 0805 (2012) / 1206 (3216) / 1210 (3225)
1808 (4520) / 1812 (4532)
(2) TOLERANCE
C = ± 0.25 pF
D = ± 0.5 pF
F = ± 1%
G = ± 2%
J = ± 5%
K = ± 10%
M = ± 20%
(3) PACKING STYLE
R = Paper/PE taping reel; Reel 7 inch
K = Blister taping reel; Reel 7 inch
P = Paper/PE taping reel; Reel 13 inch
F = Blister taping reel; Reel 13 inch
C = Bulk case
(4) TC MATERIAL
NPO
X7R
(5) RATED VOLTAGE
0 = 100 V
A = 200 V
Y = 250 V
B = 500 V
Z = 630 V
(6) PROCESS
N = NP0
B = Class 2 MLCC
(7) CAPACITANCE VALUE
2 significant digits+number of zeros
The 3rd digit signifies the multiplying factor, and letter R is decimal point
Example: 121 = 12 x 101 = 120 pF
www.yageo.com
Mar. 7, 2017 V.19
Mid-voltage
NP0/X7R
100 V to 630 V
3
18
CONSTRUCTION
The capacitor consists of a
rectangular block of ceramic
dielectric in which a number of
interleaved metal electrodes are
contained. This structure gives
rise to a high capacitance per
unit volume.
The inner electrodes are
connected to the two end
terminations and finally covered
with a layer of plated tin (NiSn).
The terminations are lead-free. A
cross section of the structure is
shown in Fig.1.
Fig. 1 Surface mounted multilayer ceramic capacitor construction
DIMENSION
Table 1 For outlines see fig. 2
OUTLINES
T (MM)
L2 / L3 (mm)
min.
max.
L4 (mm)
min.
TYPE
L1 (mm)
W (mm)
0201
0.6 ± 0.03
0.3± 0.03
0.10
0.20
0.20
0402
1.0 ± 0.05
0.5 ± 0.05
0.15
0.30
0.40
0603
1.6 ± 0.10
0.8 ± 0.10
0.20
0.60
0.40
0805
2.0 ± 0.20
1.25 ± 0.20
0.25
0.75
0.70
1206
3.2 ± 0.30
1.6 ± 0.20
0.25
0.75
1.40
1210
3.2 ± 0.30
2.5 ± 0.20
0.25
0.75
1.40
1808
4.5 ± 0.40
2.0 ± 0.30
0.25
0.75
2.20
1812
4.5 ± 0.40
3.2 ± 0.30
0.25
0.75
2.20
Refer to
table 2 to 13
For dimension see Table 1
Fig. 2 Surface mounted multilayer
ceramic capacitor dimension
www.yageo.com
Mar. 7, 2017 V.19
CAPACITANCE RANGE & THICKNESS FOR NP0
Table 2 Sizes from 0201 to 0805
0201
0402
0603
CAP.
Mid-voltage
NP0/X7R
100 V to 630 V
4
18
0805
100V
100V
100 V
200 V
250 V
100 V
200 V
250 V
500 V
630V
0.3± 0.03
0.5± 0.05
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.22 pF
0.47 pF
0.56 pF
0.68 pF
0.82 pF
1.0 pF
1.2 pF
1.5 pF
1.8 pF
2.2 pF
2.7 pF
3.3 pF
3.9 pF
4.7 pF
5.6 pF
6.8 pF
8.2 pF
10 pF
12 pF
15 pF
18 pF
22 pF
27 pF
33 pF
39 pF
47 pF
56 pF
68 pF
82 pF
100 pF
NOTE
1. Values in shaded cells indicate thickness class in mm
2. Capacitance value of non E-12 series is on request
www.yageo.com
Mar. 7, 2017 V.19
Table 4 Sizes from 0603 to 0805 (continued)
0603
CAP.
100 V
200 V
250 V
Mid-voltage
NP0/X7R
100 V to 630 V
5
18
0805
100 V
200 V
250 V
500 V
630 V
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.6± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
1.25± 0.2
120 pF
150 pF
180 pF
220 pF
270 pF
330 pF
390 pF
0.8± 0.1
0.8± 0.1
0.8± 0.1
0.6± 0.1
470 pF
0.85± 0.1
0.85± 0.1
560 pF
680 pF
820 pF
1.0 nF
1.2 nF
1.5 nF
0.85± 0.1
1.8 nF
2.2 nF
1.25± 0.2
2.7 nF
1.25± 0.2
3.3 nF
3.9 nF
4.7 nF
1.25± 0.2
5.6 nF
6.8 nF
8.2 nF
10 nF
12 nF
15 nF
18 nF
22 nF
NOTE
www.yageo.com
Mar. 7, 2017 V.19
Table 5 Sizes from 1206 to 1210
1206
CAP.
100 V
200 V
250 V
0.6± 0.1
0.6± 0.1
0.6± 0.1
Mid-voltage
NP0/X7R
100 V to 630 V
6
18
1210
500 V
630 V
0.6± 0.1
1.25± 0.2
100 V
200 V
250 V
500 V
630 V
0.47 pF
0.56 pF
0.68 pF
0.82 pF
1.0 pF
1.2 pF
1.5 pF
1.8 pF
2.2 pF
2.7 pF
3.3 pF
3.9 pF
4.7 pF
5.6 pF
6.8 pF
8.2 pF
10 pF
12 pF
15 pF
18 pF
22 pF
27 pF
33 pF
39 pF
47 pF
56 pF
68 pF
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
82 pF
NOTE
www.yageo.com
Mar. 7, 2017 V.19
Table 7 Sizes from 1206 to 1210 (continued)
1206
CAP.
100 V
200 V
250 V
500 V
0.6± 0.1
0.6± 0.1
0.6± 0.1
Mid-voltage
NP0/X7R
100 V to 630 V
7
18
1210
630 V
100 V
200 V
250 V
500 V
630 V
100 pF
120 pF
150 pF
180 pF
220 pF
270 pF
330 pF
1.25± 0.2
390 pF
470 pF
560 pF
1.25± 0.2
0.6± 0.1
680 pF
1.25± 0.2
1.25± 0.2
1.25± 0.2
820 pF
1.0 nF
1.2 nF
0.85± 0.1
0.85± 0.1
1.25± 0.2
1.25± 0.2
0.85± 0.1
1.25± 0.2
1.5 nF
1.8 nF
2.2 nF
1.25± 0.2
2.7 nF
3.3 nF
3.9 nF
4.7 nF
0.85± 0.1
5.6 nF
6.8 nF
8.2 nF
10 nF
1.25± 0.2
12 nF
15 nF
18 nF
22 nF
NOTE
www.yageo.com
Mar. 7, 2017 V.19
Mid-voltage
NP0/X7R
8
18
100 V to 630 V
Table 8 Sizes 1812
1812
CAP.
100 V
200 V
250 V
500 V
630V
10 pF
12 pF
15 pF
18 pF
22 pF
27 pF
33 pF
39 pF
47 pF
56 pF
68 pF
82 pF
100 pF
120 pF
150 pF
180 pF
220 pF
270 pF
1.25± 0.2
330 pF
390 pF
470 pF
1.25± 0.2
560 pF
680 pF
820 pF
1 nF
1.2 nF
1.25± 0.2
1.5 nF
1.25± 0.2
1.8 nF
2.2 nF
2.7 nF
1.25± 0.2
3.3 nF
3.9 nF
4.7 nF
5.6 nF
6.8 nF
8.2 nF
10 nF
12 nF
15 nF
18 nF
22 nF
NOTE
www.yageo.com
Mar. 7, 2017 V.19
CAPACITANCE RANGE & THICKNESS FOR X7R
Table 10 Sizes from 0402 to 0805
0402
0603
CAP.
100 V
100 V
250 V
Mid-voltage
NP0/X7R
9
18
100 V to 630 V
0805
100 V
200 V
250 V
500 V
630 V
0.85± 0.1
0.85± 0.1
0.85± 0.1
0.85± 0.1
1.25± 0.2
1.25± 0.2
100 pF
150 pF
220 pF
330 pF
470 pF
680 pF
1.0 nF
0.5± 0.05
1.5 nF
0.6± 0.1
2.2 nF
3.3 nF
0.8± 0.1
0.8± 0.1
4.7 nF
6.8 nF
10 nF
15 nF
22 nF
0.85± 0.1
1.25± 0.2
1.25± 0.2
33 nF
47 nF
68 nF
100 nF
1.25± 0.2
150 nF
220 nF
330 nF
470 nF
NOTE
2. Capacitance value of non E-6 series is on request
3. For special ordering code, please contact local sales force before order
4. For product with 5% tolerance, please contact local sales force before order
www.yageo.com
Mar. 7, 2017 V.19
Table 11 Sizes from 1206 to 1210
1206
CAP.
100 V
200 V
250 V
0.85± 0.1
0.85± 0.1
500 V
Mid-voltage
NP0/X7R
100 V to 630 V
10
18
1210
630 V
100 V
200 V
250 V
0.85± 0.1
0.85± 0.1
500 V
630V
100 pF
150 pF
220 pF
330 pF
470 pF
680 pF
1.0 nF
1.5 nF
2.2 nF
3.3 nF
1.25± 0.2
1.25± 0.2
0.85± 0.1
4.7 nF
6.8 nF
1.25± 0.2
10 nF
15 nF
22 nF
33 nF
1.25± 0.2
47 nF
1.25± 0.2
1.6± 0.2
1.6± 0.2
68 nF
100 nF
150 nF
1.25± 0.2
1.25± 0.2
1.6± 0.2
470 nF
1.25± 0.2
1.6± 0.2
220 nF
330 nF
1.25± 0.2
0.85± 0.1
1.25± 0.2
1.6± 0.2
680 nF
1 µF
2.2 µF
1.6± 0.2
2.0± 0.2
NOTE
3. For product with 5% tolerance, please contact local sales force before order
www.yageo.com
Mar. 7, 2017 V.19
Table 12 Sizes from 1808 to 1812
1808
CAP.
100 V
200 V
250 V
500 V
Mid-voltage
NP0/X7R
100 V to 630 V
11
18
1812
100 V
200 V
250 V
0.85± 0.1
0.85± 0.1
500 V
630 V
100 pF
150 pF
220 pF
330 pF
470 pF
680 pF
1.0 nF
1.5 nF
2.2 nF
3.3 nF
4.7 nF
6.8 nF
0.85± 0.1
10 nF
15 nF
22 nF
1.35± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
1.25± 0.2
33 nF
1.6± 0.2
47 nF
68 nF
100 nF
150 nF
220 nF
1.25± 0.2
1.25± 0.2
1.6± 0.2
1.6± 0.2
1.6± 0.2
1.25± 0.2
330 nF
470 nF
680 nF
1.6± 0.2
1 µF
NOTE
www.yageo.com
Mar. 7, 2017 V.19
Mid-voltage
NP0/X7R
100 V to 630 V
12
18
THICKNESS CLASSES AND PACKING QUANTITY
Table 13
SIZE
CODE
Ø 180 MM / 7 INCH
Paper
Blister
Ø 330 MM / 13 INCH
Paper
Blister
THICKNESS
CLASSIFICATION
TAPE WIDTH
QUANTITY PER REEL
0201
0.3 ± 0.03 mm
8 mm
15,000
50,000
0402
0.5 ± 0.05 mm
8 mm
10,000
50,000
50,000
0603
0.8 ± 0.1 mm
8 mm
4,000
15,000
15,000
0.6 ± 0.1 mm
8 mm
4,000
20,000
10,000
0.8 / 0.85 ± 0.1 mm
8 mm
4,000
15,000
8,000
1.25 ± 0.2 mm
8 mm
3,000
10,000
5,000
0805
1206
QUANTITY
PER BULK CASE
0.6 ± 0.1 mm
8 mm
4,000
20,000
0.8 / 0.85 ± 0.1 mm
8 mm
4,000
15,000
1.00 / 1.15 ± 0.1 mm
8 mm
3,000
10,000
1.25 ± 0.2 mm
8 mm
3,000
10,000
1.6 ± 0.15 mm
8 mm
2,500
10,000
1.6 ± 0.2 mm
8 mm
2,000
8,000
0.6 / 0.7 ± 0.1 mm
8 mm
4,000
15,000
0.85 ± 0.1 mm
8 mm
4,000
10,000
1.15 ± 0.1 mm
8 mm
3,000
10,000
1.15 ± 0.15 mm
8 mm
3,000
10,000
1.25 ± 0.2 mm
8 mm
3,000
1.5 ± 0.1 mm
8 mm
2,000
1.6 / 1.9 ± 0.2 mm
8 mm
2,000
2.0 ± 0.2 mm
8 mm
2,000
1,000
2.5 ± 0.2 mm
8 mm
1,000
500
1.15 ± 0.15 mm
12 mm
3,000
1210
1.25 ± 0.2 mm
12 mm
3,000
1.35 ± 0.15 mm
12 mm
2,000
1.5 ± 0.1 mm
12 mm
2,000
1.6 ± 0.2 mm
12 mm
2,000
8,000
2.0 ± 0.2 mm
12 mm
2,000
0.6 / 0.85 ± 0.1 mm
12 mm
2,000
1.15 ± 0.1 mm
12 mm
1,000
1.15 ± 0.15 mm
12 mm
1,000
1.25 ± 0.2 mm
12 mm
1,000
1.35 ± 0.15 mm
12 mm
1,000
1.5 ± 0.1 mm
12 mm
1,000
1.6 ± 0.2 mm
12 mm
1,000
2.0 ± 0.2 mm
12 mm
1,000
2.5 ± 0.2 mm
12 mm
500
1808
1812
www.yageo.com
Mar. 7, 2017 V.19
Mid-voltage
NP0/X7R
13
18
100 V to 630 V
ELECTRICAL CHARACTERISTICS
NP0/X7R DIELECTRIC CAPACITORS; NISN TERMINATIONS
Unless otherwise specified, all test and measurements shall be made under standard atmospheric conditions
for testing as given in 5.3 of IEC 60068-1:
Temperature: 15 °C to 35 °C
Relative humidity: 25% to 75%
Air pressure: 86 kPa to 106 kPa
Before the measurements are made, the capacitor shall be stored at the measuring temperature for a time
sufficient to allow the entire capacitor to reach this temperature.
The period as prescribed for recovery at the end of a test is normally sufficient for this purpose.
Table 14
VALUE
DESCRIPTION
Capacitance range
0.47 pF to 2.2 µF
Capacitance tolerance
NP0
C < 10 pF
± 0.25 pF, ± 0.5 pF
C ≥ 10 pF
±2%, ± 5%, ± 10%
X7R
± 5% (1), ± 10%, ± 20%
Dissipation factor (D.F.)
NP0
C < 30 pF
≤ 1 / ( 400 + 20C )
C ≥ 30 pF
≤ 0.1 %
X7R
Exception
≤ 2.5 %
X7R/0603/100V, 12nF ≤ C ≤ 100nF, X7R/1206/2.2uF/100V
≤ 5%
X7R/1206/100V/1uF;
X7R/1210/100V/1uF and 2.2uF;
≤ 3.5%
Insulation resistance after 1 minute at Ur (DC)
Rins ≥ 10 GΩ or Rins × C ≥ 500 seconds whichever is less
Maximum capacitance change as a function of temperature
(temperature characteristic/coefficient):
NP0
± 30 ppm/°C
X7R
± 15%
Operating temperature range:
NP0/X7R
–55 °C to +125 °C
NOTE
1. Capacitance tolerance ±5% doesn't available for X7R full product range, please contact local sales force before order
www.yageo.com
Mar. 7, 2017 V.19
SOLDERING RECOMMENDATION
Table 15
SIZE
SOLDERING
0201
METHOD
Reflow
Reflow only
Reflow/Wave
Mid-voltage
NP0/X7R
14
18
100 V to 630 V
0402
0603
0805
1206
≥ 1210
> 100 nF
> 1.0 µF
> 2.2 µF
> 2.2 µF
Reflow only
≤ 100 nF
≤ 1.0 µF
≤ 2.2 µF
≤ 2.2 µF
TESTS AND REQUIREMENTS
Table 16 Test procedures and requirements
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Mounting
IEC 60384- 4.3
21/22
The capacitors may be mounted on printed-circuit boards or
ceramic substrates
No visible damage
Visual
Inspection and
Dimension
Check
4.4
Any applicable method using × 10 magnification
In accordance with specification
Capacitance
4.5.1
Class 1:
f = 1 MHz for C ≤ 1 nF, measuring at voltage 1 Vrms at 20 °C
Within specified tolerance
f = 1 KHz for C > 1 nF, measuring at voltage 1 Vrms at 20 °C
Class 2:
f = 1 KHz for C ≤ 10 µF, measuring at voltage 1 Vrms at 20 °C
Dissipation
Factor (D.F.)
4.5.2
Class 1:
f = 1 MHz for C ≤ 1 nF , measuring at voltage 1 Vrms at 20 °C
Class 2:
Insulation
Resistance
4.5.3
Ur ≤ 500 V: At Ur for 1 minute
Ur > 500 V: At 500 V for 1 minute
www.yageo.com
Mar. 7, 2017 V.19
TEST
TEST METHOD
Temperature
coefficient
4.6
Mid-voltage
NP0/X7R
100 V to 630 V
PROCEDURE
REQUIREMENTS
Capacitance shall be measured by the steps shown
in the following table.
Class1:
∆ C/C: ± 30ppm
The capacitance change should be measured after
5 min at each specified temperature stage.
Step
Temperature(℃)
a
25± 2
b
Lower temperature± 3℃
c
25± 2
d
Upper Temperature± 2℃
e
25± 2
15
18
Class2:
X7R: ∆ C/C: ±15%
Y5V: ∆ C/C: 22~-82%
Class2:
X7R/X5R: ∆ C/C: ±15%
Y5V: ∆ C/C: 22~-82%
(1) Class I
Temperature Coefficient shall be calculated from
the formula as below
C2 - C1
106 [ppm/℃]
Temp, Coefficient =
C1 xΔT
C1: Capacitance at step c
C2: Capacitance at 125℃
∆T: 100℃(=125℃-25℃)
(2) Class II
Capacitance Change shall be calculated from the
formula as below
C2 - C1
∆C =
x 100%
C1
C2: Capacitance at step b or d
Adhesion
Bending
Strength
IEC 6038421/22
4.7
A force applied for 10 seconds to the line joining
the terminations and in a plane parallel to the
substrate
Force
size ≥ 0603: 5N
4.8
Mounting in accordance with IEC 60384-22
paragraph 4.3
No visible damage
Conditions: bending 1 mm at a rate of 1 mm/s,
radius jig 5 mm
∆C/C
Class 1:
NP0: within ± 1% or 0.5 pF, whichever is greater
Class2:
X7R: ± 10%
www.yageo.com
Mar. 7, 2017 V.19
TEST
TEST METHOD
Resistance to
Soldering
Heat
4.9
Mid-voltage
NP0/X7R
100 V to 630 V
16
18
PROCEDURE
REQUIREMENTS
Precondition: 150 +0/–10 °C for 1 hour,
then keep for 24 ± 1 hours at room
temperature
Dissolution of the end face plating shall not exceed
25% of the length of the edge concerned
Preheating: for size ≤ 1206: 120 °C to 150
°C for 1 minute
Class 1:
NP0: within ± 0.5% or 0.5 pF, whichever is greater
∆C/C
Preheating: for size >1206: 100 °C to 120
Class2:
°C for 1 minute and 170 °C to 200 °C for 1
X7R: ± 10%
minute
D.F. within initial specified value
Solder bath temperature: 260 ± 5 °C
Dipping time: 10 ± 0.5 seconds
Rins within initial specified value
Recovery time: 24 ± 2 hours
Solderability
4.10
Preheated the temperature of 80 °C to 140
°C and maintained for 30 seconds to 60
seconds.
The solder should cover over 95% of the critical area
of each termination
1. Temperature: 235± 5°C
/ Dipping time: 2 ± 0.5 s
2. Temperature: 245± 5°C
/ Dipping time: 3 ± 0.5 s (lead free)
Depth of immersion: 10mm
Rapid Change
of
Temperature
IEC 6038421/22
4.11
Preconditioning;
150 +0/–10 °C for 1 hour, then keep for
24 ± 1 hours at room temperature
5 cycles with following detail:
30 minutes at lower category temperature
30 minutes at upper category temperature
Recovery time 24 ± 2 hours
No visual damage
∆C/C
Class 1:
NP0: within ± 1% or 1 pF, whichever is greater
Class2:
X7R: ± 15%
D.F. meet initial specified value
Rins meet initial specified value
www.yageo.com
Mar. 7, 2017 V.19
TEST
TEST METHOD
Damp Heat
4.13
Mid-voltage
REQUIREMENTS
3. Preconditioning, class 2 only:
No visual damage after recovery
4. Initial measure:
Spec: refer initial spec C, D, IR
5. Damp heat test:
500 ± 12 hours at 40 ± 2 °C;
90 to 95% R.H.
6. Recovery:
Class 1: 6 to 24 hours
Class 2: 24 ± 2 hours
7. Final measure: C, D, IR
P.S. If the capacitance value is less than the
minimum value permitted, then after the other
measurements have been made the capacitor shall
be precondition according to “IEC 60384 4.1” and
then the requirement shall be met.
IEC 6038421/22
4.14
1. Preconditioning, class 2 only:
2.
3.
4.
5.
6.
150 +0/-10 °C /1 hour, then keep for
24 ± 1 hour at room temp
Initial measure:
Endurance test:
Temperature: NP0/X7R: 125 °C
Specified stress voltage applied for 1,000 hours:
High voltage series follows with below stress
condition:
Applied 2.0 x Ur for 100 V series
Applied 1.5 x Ur for 200/250 V series
Applied 1.3 x Ur for 500 V, 630 V series
Applied 1.2 x Ur for 1 KV, 2 KV, 3 KV series
Voltage Proof
4.6
100 V to 630 V
PROCEDURE
Endurance
NP0/X7R
Specified stress voltage applied for 1~5 seconds
Ur ≤ 100 V: series applied 2.5 Ur
17
18
∆C/C
Class 1:
NP0: within ± 2% or 1 pF, whichever is greater
Class2:
X7R: ± 15%
D.F.
Class 1:
NP0: ≤ 2 x specified value
Class2:
X7R: ≥ 25 V: ≤ 5%
Rins
Class 1:
NP0: ≥ 2,500 MΩ or Rins x Cr ≥ 25s whichever
is less
Class2:
X7R: ≥ 500 MΩ or Rins x Cr ≥ 25s whichever is
less
No visual damage
∆C/C
Class1:
Class2:
X7R: ± 15%
D.F.
Class1:
Class2:
X7R: ≥ 25 V: ≤ 5%
Rins
Class1:
NP0: ≥ 4,000 MΩ or
Rins x Cr ≥ 40s whichever is less
Class2:
X7R: ≥ 1,000 MΩ or
Rins x Cr ≥ 50s whichever is less
No breakdown or flashover
100 V < Ur ≤ 200 V series applied
(1.5 Ur + 100)
200 V < Ur ≤ 500 V series applied
(1.3 Ur + 100)
Ur > 500 V: 1.3 Ur
Ur ≧ 1000 V: 1.2 Ur
Charge/Discharge current is less than 50 mA
www.yageo.com
Mar. 7, 2017 V.19
Mid-voltage
NP0/X7R
100 V to 630 V
18
18
REVISION HISTORY
REVISION DATE
CHANGE NOTIFICATION
DESCRIPTION
Version 19
Mar 7, 2017
- 0805 L4 spec updated
Version 18
Dec 9, 2016
- Soldering recommendation update
Version 17
Aug 16, 2016
- Capacitance range & thickness update
Version 16
Apr. 16, 2015
Version 15
Apr. 16, 2015
- Electrical characteristics update
Version 14
Sep. 25, 2014
Version 13
Apr. 21, 2014
Version 12
Dec. 12, 2013
Version 11
Jun. 17, 2013
- Test method and procedure updated
Version 10
Nov 22, 2012
Version 9
Feb 02, 2012
Version 8
Apr 22, 2011
- NP0 0402 100V added
Version 7
Mar 01, 2011
- Dimension updated
Version 6
Sep 30, 2010
- Update the thickness of 0805 100V
Version 5
Sep 28, 2010
- Product range updated
- Thickness classes and packing quantity table updated
Version 4
Jun 17, 2010
- Update the dimension of 0805, 1206 and 1812
Version 3
Mar 25, 2010
Version 2
Mar 15, 2010
Version 1
Oct 30, 2009
- Change to dual brand datasheet that describe Mid-voltage NP0/X7R
series with RoHS compliant
- Replace the "100V to 630V" part of pdf files: UP-NP0X7R_MV_100-to500V_0, UY-NP0X7R_MV_100-to-500V_0, NP0_16V-to-100V_6,
NP0_50-to-500V_10, X7R_16-to-500V_9 and X7R_16V-to-100V_9
- Define global part number
- Description of "Halogen Free compliant" added
Version 0
Sep 08, 2005
- New
www.yageo.com
Mar. 7, 2017 V.19
