PSMN9R8-30MLC
N-channel 30 V 9.8 mΩ logic level MOSFET in LFPAK33 using
NextPower Technology
Rev. 3 — 15 June 2012
Product data sheet
1. Product profile
1.1 General description
Logic level enhancement mode N-channel MOSFET in LFPAK33 package. This product is
designed and qualified for use in a wide range of industrial, communications and domestic
equipment.
1.2 Features and benefits
Low parasitic inductance and
resistance
Optimised for 4.5V Gate drive utilising
NextPower Superjunction technology
Ultra low QG, QGD, & QOSS for high
system efficiencies at low and high
loads
1.3 Applications
DC-to-DC converters
Synchronous buck regulator
Load switching
1.4 Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
Tj = 25 °C
30
V
ID
drain current
Tmb = 25 °C; VGS = 10 V; see Figure 1
50
A
Ptot
total power dissipation
Tmb = 25 °C; see Figure 2
Tj
junction temperature
45
W
-55
175
°C
VGS = 4.5 V; ID = 15 A; Tj = 25 °C;
see Figure 10
10.65
12.4
mΩ
VGS = 10 V; ID = 15 A; Tj = 25 °C;
see Figure 10
8.5
9.8
mΩ
Static characteristics
RDSon
drain-source on-state
resistance
Dynamic characteristics
QGD
gate-drain charge
VGS = 4.5 V; ID = 15 A; VDS = 15 V;
see Figure 12; see Figure 13
1.5
nC
QG(tot)
total gate charge
5
nC
PSMN9R8-30MLC
Nexperia
N-channel 30 V 9.8 mΩ logic level MOSFET in LFPAK33 using NextPower Technology
2. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
Simplified outline
1
S
source
2
S
source
3
S
source
4
G
gate
mb
D
mounting base; connected to
drain
Graphic symbol
D
G
mbb076
1
2
3
S
4
SOT1210 (LFPAK33)
3. Ordering information
Table 3.
Type number
Package
PSMN9R8-30MLC
Name
Description
Version
LFPAK33
Plastic single ended surface mounted package (LFPAK33);
4 leads
SOT1210
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
Tj = 25 °C
30
V
VGS
gate-source voltage
-20
V
ID
drain current
VGS = 10 V; Tmb = 25 °C; see Figure 1
50
A
VGS = 10 V; Tmb = 100 °C; see Figure 1
36
A
IDM
peak drain current
pulsed; tp ≤ 10 µs; Tmb = 25 °C; see Figure 4
202
A
Ptot
45
W
Tstg
storage temperature
-55
175
°C
Tj
-55
175
°C
Tsld(M)
peak soldering temperature
260
°C
VESD
electrostatic discharge voltage
MM (JEDEC JESD22-A115)
140
V
Source-drain diode
IS
source current
Tmb = 25 °C
41
A
ISM
peak source current
202
A
VGS = 10 V; Tj(init) = 25 °C; ID = 50 A;
Vsup ≤ 30 V; RGS = 50 Ω; unclamped;
see Figure 3
8
mJ
Avalanche ruggedness
EDS(AL)S
non-repetitive drain-source
avalanche energy
PSMN9R8-30MLC
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 14
PSMN9R8-30MLC
Nexperia
003aaj426
60
ID
(A)
Pder
40
80
Fig 1.
03na19
120
50
100
150
Tmb 200
(°C)
100
150
200
Tmb (°C)
Continuous drain current as a function of
mounting base temperature
Fig 2.
Normalized total power dissipation as a
function of mounting base temperature
003aaj427
102
IAL
(A)
10
(1)
(2)
1
10-1
10-3
Fig 3.
10-2
10-1
1
tAL 10
(ms)
Single pulse avalanche rating; avalanche current as a function of avalanche time
PSMN9R8-30MLC
Product data sheet
3 of 14
PSMN9R8-30MLC
Nexperia
003aaj428
103
ID
(A)
Limit RDSon = VDS / ID
102
tp =10 μ s
100 μ s
10
DC
1 ms
1
10 ms
100 ms
10-1
10-1
Fig 4.
1
10
102
VDS (V)
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
5. Thermal characteristics
Table 5.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance from
junction to mounting base
see Figure 5
3.1
3.32
K/W
003aaj429
10
Zth(j-mb)
(K/W)
δ = 0.5
1
0.2
0.1
0.05
10
δ=
P
-1
0.02
tp
T
single shot
t
tp
T
10-2
10-6
Fig 5.
10-5
10-4
10-3
10-2
10-1
tp (s)
1
Transient thermal impedance from junction to mounting base as a function of pulse duration
PSMN9R8-30MLC
Product data sheet
4 of 14
PSMN9R8-30MLC
Nexperia
6. Characteristics
Table 6.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V
V(BR)DSS
drain-source
breakdown voltage
ID = 250 µA; VGS = 0 V; Tj = 25 °C
30
ID = 250 µA; VGS = 0 V; Tj = -55 °C
27
V
VGS(th)
gate-source threshold
voltage
ID = 1 mA; VDS = VGS; Tj = 25 °C
1.3
1.64
1.95
V
∆VGS(th)/∆T
voltage variation with
temperature
-4
mV/K
IDSS
drain leakage current
VDS = 30 V; VGS = 0 V; Tj = 25 °C
1
µA
VDS = 30 V; VGS = 0 V; Tj = 150 °C
100
µA
VGS = 16 V; VDS = 0 V; Tj = 25 °C
100
nA
VGS = -16 V; VDS = 0 V; Tj = 25 °C
100
nA
see Figure 10
10.65
12.4
mΩ
VGS = 4.5 V; ID = 15 A; Tj = 150 °C;
see Figure 11; see Figure 10
21.1
mΩ
see Figure 10
8.5
9.8
mΩ
VGS = 10 V; ID = 15 A; Tj = 150 °C;
16.75
mΩ
f = 1 MHz
0.9
1.8
3.6
Ω
ID = 15 A; VDS = 15 V; VGS = 10 V;
10.9
nC
ID = 15 A; VDS = 15 V; VGS = 4.5 V;
5
nC
ID = 0 A; VDS = 0 V; VGS = 10 V
10
nC
2
nC
1.2
nC
IGSS
RDSon
RG
gate leakage current
resistance
gate resistance
QG(tot)
total gate charge
QGS
gate-source charge
QGS(th)
pre-threshold
gate-source charge
QGS(th-pl)
post-threshold
gate-source charge
0.8
nC
QGD
gate-drain charge
1.5
nC
VGS(pl)
gate-source plateau
voltage
3.1
V
Ciss
input capacitance
690
pF
Coss
output capacitance
VDS = 15 V; VGS = 0 V; f = 1 MHz;
Tj = 25 °C; see Figure 14
170
pF
Crss
reverse transfer
capacitance
52
pF
PSMN9R8-30MLC
Product data sheet
5 of 14
PSMN9R8-30MLC
Nexperia
Table 6.
Characteristics …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
td(on)
turn-on delay time
7.4
ns
tr
rise time
VDS = 15 V; RL = 1 Ω; VGS = 4.5 V;
RG(ext) = 5 Ω
7.7
ns
td(off)
turn-off delay time
11.7
ns
tf
fall time
Qoss
output charge
5.3
ns
VGS = 0 V; VDS = 15 V; f = 1 MHz;
Tj = 25 °C
4.9
nC
Source-drain diode
VSD
source-drain voltage
IS = 15 A; VGS = 0 V; Tj = 25 °C;
see Figure 15
0.84
1.1
V
trr
reverse recovery time
12.9
ns
Qr
recovered charge
IS = 15 A; dIS/dt = -100 A/µs; VGS = 0 V;
VDS = 15 V
5.3
nC
ta
reverse recovery rise
time
VGS = 0 V; IS = 15 A; dIS/dt = -100 A/µs;
VDS = 15 V; see Figure 16
7.9
ns
tb
reverse recovery fall
time
5
ns
ID
(A)
003aaj430
50
10
4.5
003aaj431
30
3.5
RDSon
(mΩ)
40
3
10
2.6
10
VGS (V) = 2.4
2.2
Fig 6.
1
2
3
VDS(V)
Output characteristics; drain current as a
function of drain-source voltage; typical values
PSMN9R8-30MLC
Product data sheet
Fig 7.
4
8
12
VGS (V)
16
Drain-source on-state resistance as a function
of gate-source voltage; typical values
6 of 14
PSMN9R8-30MLC
Nexperia
003aaj432
60
003aaj433
50
ID
(A)
gfs
(S)
40
40
30
Tj = 150 °C
10
Tj = 25 °C
Fig 8.
10
40
ID (A)
Forward transconductance as a function of
drain current; typical values
Fig 9.
2.8
RDSon
(mΩ)
2
3
4
VGS (V)
Transfer characteristics; drain current as a
function of gate-source voltage; typical values
003aaj436
50
1
003aaj437
2
3
a
10V
40
1.5
VGS=4.5V
30
3.5
1
4.5
0.5
VGS (V) = 10
15
25
35
45
ID (A)
55
Fig 10. Drain-source on-state resistance as a function
of drain current; typical values
PSMN9R8-30MLC
Product data sheet
120
Tj (°C)
180
Fig 11. Normalized drain-source on-state resistance
factor as a function of junction temperature
7 of 14
PSMN9R8-30MLC
Nexperia
003aaj438
10
VGS
(V)
VDS
8
ID
6V
6
24 V
VGS(pl)
VGS(th)
4
VDS = 15 V
VGS
QGS1
QGS2
QGS
2
QGD
QG(tot)
003aaa508
Fig 12. Gate charge waveform definitions
5
10
QG (nC)
15
003aaj440
50
IS
(A)
Ciss
C
(pF)
Fig 13. Gate-source voltage as a function of gate
charge; typical values
003aaj439
103
Coss
30
Crss
Tj = 150°C
10
10
10-1
1
10
VDS (V)
102
Fig 14. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
PSMN9R8-30MLC
Product data sheet
Tj = 25 °C
0.6
0.9
VSD(V)
1.2
Fig 15. Source current as a function of source-drain
8 of 14
PSMN9R8-30MLC
Nexperia
003a a f 444
ID
(A)
trr
ta
tb
0.25 IRM
I RM
t (s )
Fig 16. Reverse recovery timing definition
PSMN9R8-30MLC
Product data sheet
9 of 14
PSMN9R8-30MLC
Nexperia
7. Package outline
Plastic single ended surface mounted package (LFPAK33); 8 leads
E
A
A
e1
c1
b1
L
SOT1210
E1
mounting
base
D1
D
H
1
4
e
b
w
X
A
A1
c
C
θ
Lp
y C
detail X
Dimensions
Unit(1)
mm
5 mm
scale
A
A1
b
b1
c
c1
D(1)
D1
E(1)
E1
e
e1
H
L
Lp
w
y
3.40 0.25 0.50
max 0.90 0.10 0.35 0.35 0.20 0.30 2.70 2.35 3.40 2.45
nom
0.65 0.65
0.20 0.10
3.20 0.13 0.30
min 0.80 0.00 0.25 0.25 0.10 0.20 2.50 1.90 3.20 2.00
θ
8°
0°
Note
1. Plastic or metal protrusions of 0.15 mm per side are not included.
Outline
version
sot1210_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
11-12-19
12-03-12
SOT1210
Fig 17. Package outline SOT1210 (LFPAK33)
PSMN9R8-30MLC
Product data sheet
10 of 14
PSMN9R8-30MLC
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PSMN9R8-30MLC v.3
20120615
Product data sheet
PSMN9R8-30MLC v.2
PSMN9R8-30MLC v.1
Modifications:
PSMN9R8-30MLC v.2
PSMN9R8-30MLC
Product data sheet
Status changed from objective to product.
Various changes to content.
20120607
Objective data sheet
11 of 14
PSMN9R8-30MLC
Nexperia
9. Legal information
9.1
Data sheet status
Document status[1] [2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
9.3
Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with theTerms and conditions of commercial sale of Nexperia.
PSMN9R8-30MLC
Product data sheet
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
12 of 14
PSMN9R8-30MLC
Nexperia
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from competent authorities.
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
10. Contact information
For more information, please visit:http://www.nexperia.com
For sales office addresses, please send an email to:salesaddresses@nexperia.com
PSMN9R8-30MLC
Product data sheet
13 of 14
PSMN9R8-30MLC
Nexperia
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2
Thermal characteristics . . . . . . . . . . . . . . . . . . .4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . .10
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 11
Legal information. . . . . . . . . . . . . . . . . . . . . . . .12
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .12
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .12
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .12
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .13
Contact information. . . . . . . . . . . . . . . . . . . . . .13
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 15 June 2012
