PSMN1R7-30YL,115
PSMN1R7-30YL,115
    NEXPERIA(安世)
    SOT669
    MOS管 N-channel Id=100A VDS=30V SOT669
PSMN1R7-30YL,115 数据手册
PSMN1R7-30YL N-channel 30 V 1.7 mΩ logic level MOSFET in LFPAK Rev. 1 — 30 May 2011 Product data sheet 1. Product profile 1.1 General description Logic level N-channel MOSFET in LFPAK package qualified to 175 °C. This product is designed and qualified for use in a wide range of industrial, communications and domestic equipment. 1.2 Features and benefits  Advanced TrenchMOS provides low RDSon and low gate charge  Improved mechanical and thermal characteristics  High efficiency gains in switching power convertors  LFPAK provides maximum power density in a Power SO8 package 1.3 Applications  DC-to-DC converters  Motor control  Lithium-ion battery protection  Server power supplies  Load switching 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C ID drain current Tmb = 25 °C; VGS = 10 V; see Figure 1 Ptot total power dissipation Tmb = 25 °C; see Figure 2 Tj junction temperature Min Typ Max Unit - - 30 V - - 100 A - - 109 W -55 - 175 °C VGS = 10 V; ID = 15 A; Tj = 100 °C; see Figure 13 - - 2.4 mΩ VGS = 10 V; ID = 15 A; Tj = 25 °C - 1.3 1.7 mΩ VGS = 4.5 V; ID = 10 A; VDS = 12 V; see Figure 14; see Figure 15 - 8.7 - nC [1] Static characteristics RDSon drain-source on-state resistance Dynamic characteristics QGD gate-drain charge PSMN1R7-30YL Nexperia N-channel 30 V 1.7 mΩ logic level MOSFET in LFPAK Table 1. Quick reference data …continued Symbol Parameter Conditions Min Typ QG(tot) total gate charge VGS = 4.5 V; ID = 10 A; VDS = 12 V; see Figure 14 - 36.2 - Max Unit nC VGS = 10 V; Tj(init) = 25 °C; ID = 100 A; Vsup ≤ 30 V; RGS = 50 Ω; unclamped - - mJ Avalanche ruggedness EDS(AL)S [1] non-repetitive drain-source avalanche energy 241 Continuous current is limited by package. 2. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 S source 2 S source 3 S source 4 G gate mb D mounting base; connected to drain Graphic symbol mb D G mbb076 S 1 2 3 4 SOT669 (LFPAK; Power-SO8) 3. Ordering information Table 3. Ordering information Type number PSMN1R7-30YL PSMN1R7-30YL Product data sheet Package Name Description Version LFPAK; Power-SO8 plastic single-ended surface-mounted package; 4 leads SOT669 All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 May 2011 © Nexperia B.V. 2017. All rights reserved 2 of 15 PSMN1R7-30YL Nexperia N-channel 30 V 1.7 mΩ logic level MOSFET in LFPAK 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 30 V VDSM peak drain-source voltage tp ≤ 25 ns; f ≤ 500 kHz; EDS(AL) ≤ 360 nJ; pulsed - 35 V VDGR drain-gate voltage Tj ≥ 25 °C; Tj ≤ 175 °C; RGS = 20 kΩ - 30 V VGS gate-source voltage drain current ID -20 20 V VGS = 10 V; Tmb = 100 °C; see Figure 1 [1] - 100 A VGS = 10 V; Tmb = 25 °C; see Figure 1 [1] - 100 A IDM peak drain current pulsed; tp ≤ 10 µs; Tmb = 25 °C; see Figure 3 - 790 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - 109 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C - 100 A Source-drain diode [1] IS source current Tmb = 25 °C ISM peak source current pulsed; tp ≤ 10 µs; Tmb = 25 °C - 790 A VGS = 10 V; Tj(init) = 25 °C; ID = 100 A; Vsup ≤ 30 V; RGS = 50 Ω; unclamped - 241 mJ Avalanche ruggedness non-repetitive drain-source avalanche energy EDS(AL)S [1] Continuous current is limited by package. 003aac446 120 ID (A) 100 03aa16 120 (1) Pder (%) 80 80 60 40 40 20 0 0 0 Fig 1. 50 100 150 Continuous drain current as a function of mounting base temperature PSMN1R7-30YL Product data sheet 0 200 Tmb (°C) 50 100 150 200 Tmb (°C) Fig 2. Normalized total power dissipation as a function of mounting base temperature All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 May 2011 © Nexperia B.V. 2017. All rights reserved 3 of 15 PSMN1R7-30YL Nexperia N-channel 30 V 1.7 mΩ logic level MOSFET in LFPAK 003aad111 104 ID (A) Limit RDSon = VDS / ID 103 10 μs 102 100 μs (1) 1 ms 10 DC 10 ms 100 ms 1 10-1 Fig 3. 1 10 102 VDS (V) Safe operating area; continuous and peak drain currents as a function of drain-source voltage PSMN1R7-30YL Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 May 2011 © Nexperia B.V. 2017. All rights reserved 4 of 15 PSMN1R7-30YL Nexperia N-channel 30 V 1.7 mΩ logic level MOSFET in LFPAK 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-mb) thermal resistance from junction to mounting base see Figure 4 - 0.5 1.1 K/W 003aac456 10 Zth(j-mb) (K/W) 1 δ = 0.5 10-1 0.2 0.1 0.05 δ= P 0.02 tp T 10-2 single shot t tp T 10-3 10-6 Fig 4. 10-5 10-4 10-3 10-2 tp (s) 10-1 1 Transient thermal impedance from junction to mounting base as a function of pulse duration PSMN1R7-30YL Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 May 2011 © Nexperia B.V. 2017. All rights reserved 5 of 15 PSMN1R7-30YL Nexperia N-channel 30 V 1.7 mΩ logic level MOSFET in LFPAK 6. Characteristics Table 6. Characteristics Tested to JEDEC standards where applicable. Symbol Parameter Conditions Min Typ Max Unit - - V Static characteristics V(BR)DSS drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = 25 °C 30 ID = 250 µA; VGS = 0 V; Tj = -55 °C 27 - - V VGS(th) gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 11; see Figure 12 1.3 1.7 2.15 V ID = 1 mA; VDS = VGS; Tj = 150 °C; see Figure 12 0.65 - - V ID = 1 mA; VDS = VGS; Tj = -55 °C; see Figure 12 - - 2.45 V - - 1 µA IDSS drain leakage current VDS = 30 V; VGS = 0 V; Tj = 25 °C VDS = 30 V; VGS = 0 V; Tj = 150 °C - - 100 µA IGSS gate leakage current VGS = 16 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = -16 V; VDS = 0 V; Tj = 25 °C - - 100 nA VGS = 4.5 V; ID = 15 A; Tj = 25 °C - 1.8 2.1 mΩ VGS = 10 V; ID = 15 A; Tj = 150 °C; see Figure 13 - - 2.8 mΩ VGS = 10 V; ID = 15 A; Tj = 100 °C; see Figure 13 - - 2.4 mΩ VGS = 10 V; ID = 15 A; Tj = 25 °C - 1.3 1.7 mΩ f = 1 MHz - 0.77 1.5 Ω ID = 10 A; VDS = 12 V; VGS = 10 V; see Figure 14; see Figure 15 - 77.9 - nC ID = 0 A; VDS = 0 V; VGS = 10 V - 70 - nC ID = 10 A; VDS = 12 V; VGS = 4.5 V; see Figure 14 - 36.2 - nC ID = 10 A; VDS = 12 V; VGS = 4.5 V; see Figure 14; see Figure 15 - 11.6 - nC - 8 - nC RDSon RG drain-source on-state resistance gate resistance Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGS(th) pre-threshold gate-source charge QGS(th-pl) post-threshold gate-source charge - 3.6 - nC QGD gate-drain charge - 8.7 - nC VGS(pl) gate-source plateau voltage VDS = 12 V; see Figure 14; see Figure 15 - 2.34 - V Ciss input capacitance Coss output capacitance VDS = 12 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; see Figure 16 Crss reverse transfer capacitance td(on) turn-on delay time VDS = 12 V; RL = 0.5 Ω; VGS = 4.5 V; RG(ext) = 4.7 Ω - 5057 - pF - 1082 - pF - 398 - pF - 46 - ns tr rise time - 72 - ns td(off) turn-off delay time - 76 - ns tf fall time - 34 - ns PSMN1R7-30YL Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 May 2011 © Nexperia B.V. 2017. All rights reserved 6 of 15 PSMN1R7-30YL Nexperia N-channel 30 V 1.7 mΩ logic level MOSFET in LFPAK Table 6. Characteristics …continued Tested to JEDEC standards where applicable. Symbol Parameter Conditions Min Typ Max Unit - 0.78 1.2 V Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; see Figure 17 trr reverse recovery time Qr recovered charge IS = 20 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 20 V 003aac449 300 ID 4 (A) 10 3.6 250 - 45 - ns - 56 - nC 003aac450 5 RDSon (mΩ) VGS (V) = 3.2 3.4 4 VGS (V) = 3.4 200 3 150 3.6 3 4 2.8 100 2 2.6 7 50 2.4 2.2 0 0 Fig 5. 2 4 6 10 1 8 VDS (V) 10 Output characteristics: drain current as a function of drain-source voltage; typical values 003aac452 200 0 Fig 6. 50 100 150 200 ID (A) 250 Drain-source on-state resistance as a function of drain current; typical values 003aac455 8000 Ciss gfs (S) C (pF) 150 6000 100 4000 Crss 50 2000 0 0 Fig 7. 20 40 60 Forward transconductance as a function of drain current; typical values PSMN1R7-30YL Product data sheet 0 ID (A) 80 2 Fig 8. 4 6 8 VGS (V) 10 Input and reverse transfer capacitances as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 May 2011 © Nexperia B.V. 2017. All rights reserved 7 of 15 PSMN1R7-30YL Nexperia N-channel 30 V 1.7 mΩ logic level MOSFET in LFPAK 003aac451 3.0 003aac453 80 ID (A) RDSon (mΩ) 2.5 60 2.0 40 1.5 20 Tj = 150 °C 0 1.0 2 Fig 9. 25 °C 4 6 8 VGS (V) Drain-source on-state resistance as a function of gate-source voltage; typical values 003aab271 10-1 0 10 1 Fig 10. Transfer characteristics: drain current as a function of gate-source voltage; typical values 003a a c982 VGS (th) (V) typ 3 V (V) 4 GS 3 ID (A) 10-2 min 2 max max 2 10-3 typ min 10-4 1 10-5 10-6 0 1 2 VGS (V) 0 -60 3 Fig 11. Sub-threshold drain current as a function of gate-source voltage PSMN1R7-30YL Product data sheet 0 60 120 Tj (°C) 180 Fig 12. Gate-source threshold voltage as a function of junction temperature All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 May 2011 © Nexperia B.V. 2017. All rights reserved 8 of 15 PSMN1R7-30YL Nexperia N-channel 30 V 1.7 mΩ logic level MOSFET in LFPAK 03aa27 2 VDS a ID 1.5 VGS(pl) VGS(th) 1 VGS QGS1 0.5 QGS2 QGS QGD QG(tot) 003aaa508 0 −60 0 60 120 Tj (°C) 180 Fig 13. Normalized drain-source on-state resistance factor as a function of junction temperature 003aac448 10 VGS (V) Fig 14. Gate charge waveform definitions 003aac454 6000 Ciss C (pF) 8 Coss 4000 6 VDS = 12 (V) VDS = 19 (V) 4 2000 Crss 2 0 0 20 40 60 QG (nC) 80 Fig 15. Gate-source voltage as a function of gate charge; typical values PSMN1R7-30YL Product data sheet 0 10-1 1 10 VDS (V) 102 Fig 16. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 May 2011 © Nexperia B.V. 2017. All rights reserved 9 of 15 PSMN1R7-30YL Nexperia N-channel 30 V 1.7 mΩ logic level MOSFET in LFPAK 003aac447 100 IS (A) 80 60 40 Tj = 150 °C 20 25 °C 0 0.0 0.2 0.4 0.6 0.8 1.0 VSD (V) Fig 17. Source (diode forward) current as a function of source-drain (diode forward) voltage; typical values PSMN1R7-30YL Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 May 2011 © Nexperia B.V. 2017. All rights reserved 10 of 15 PSMN1R7-30YL Nexperia N-channel 30 V 1.7 mΩ logic level MOSFET in LFPAK 7. Package outline Plastic single-ended surface-mounted package (LFPAK; Power-SO8); 4 leads A2 A E SOT669 C c2 b2 E1 b3 L1 mounting base b4 D1 D H L2 1 2 3 e 4 w M A b 1/2 X c e A (A 3) C A1 θ L detail X y C 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 A2 A3 b b2 1.20 0.15 1.10 0.50 4.41 0.25 1.01 0.00 0.95 0.35 3.62 mm b3 b4 2.2 2.0 0.9 0.7 c D (1) c2 D1(1) E(1) E1(1) max 0.25 0.30 4.10 4.20 0.19 0.24 3.80 5.0 4.8 3.3 3.1 e H L L1 L2 w y θ 1.27 6.2 5.8 0.85 0.40 1.3 0.8 1.3 0.8 0.25 0.1 8° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT669 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 06-03-16 11-03-25 MO-235 Fig 18. Package outline SOT669 (LFPAK; Power-SO8) PSMN1R7-30YL Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 May 2011 © Nexperia B.V. 2017. All rights reserved 11 of 15 PSMN1R7-30YL Nexperia N-channel 30 V 1.7 mΩ logic level MOSFET in LFPAK 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes PSMN1R7-30YL v.5 20110530 Product data sheet - PSMN1R7-30YL v.4 - PSMN1R7-30YL v.3 Modifications: PSMN1R7-30YL v.4 PSMN1R7-30YL Product data sheet • Various changes to content. 20100420 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 May 2011 © Nexperia B.V. 2017. All rights reserved 12 of 15 PSMN1R7-30YL Nexperia N-channel 30 V 1.7 mΩ logic level MOSFET in LFPAK 9. Legal information 9.1 Data sheet status Document status [1] [2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 9.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. PSMN1R7-30YL Product data sheet Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 May 2011 © Nexperia B.V. 2017. All rights reserved 13 of 15 PSMN1R7-30YL Nexperia N-channel 30 V 1.7 mΩ logic level MOSFET in LFPAK Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. 10. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PSMN1R7-30YL Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 30 May 2011 © Nexperia B.V. 2017. All rights reserved 14 of 15 Nexperia PSMN1R7-30YL N-channel 30 V 1.7 mΩ logic level MOSFET in LFPAK 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3 Thermal characteristics . . . . . . . . . . . . . . . . . . .5 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . .12 Legal information. . . . . . . . . . . . . . . . . . . . . . . .13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . .13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .14 Contact information. . . . . . . . . . . . . . . . . . . . . .14 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 30 May 2011
PSMN1R7-30YL,115
物料型号:PSMN1R7-30YL
器件简介:这是一个逻辑电平N沟道MOSFET,封装在LFPAK中,适用于工业、通信和家用电器的广泛应用。
引脚分配:文档中提供了引脚信息表,包括源极(S)、栅极(G)和安装底座(D),共4个引脚。
参数特性: - 漏源电压(Vps):30V - 漏电流(ID):最大100A - 总功耗(Ptot):最大109W - 结温(Tj):范围-55℃至175℃ - 导通电阻(RDSon):在特定条件下,最小值为1.3mΩ,典型值为1.7mΩ,最大值为2.4mΩ - 栅极电荷(QGD):8.7nC
功能详解: - 该MOSFET具有低导通电阻和低栅极电荷,适合用于开关电源转换器,可提高效率。 - 提供了机械和热特性的改进。 - 适用于DC-DC转换器、电机控制、锂离子电池保护、服务器电源和负载开关等应用。
应用信息:适用于DC-DC转换器、电机控制、锂离子电池保护、服务器电源和负载开关等。
封装信息:LFPAK; Power-SO8塑料单端表面贴装封装,共4个引脚。封装型号为SOT669。
PSMN1R7-30YL,115 价格&库存
很抱歉,暂时无法提供与“PSMN1R7-30YL,115”相匹配的价格&库存,您可以联系我们找货
PSMN1R7-30YL,115
  • 1500+7.097731500+0.91861
  • 3000+6.608593000+0.85530
  • 4500+6.359484500+0.82306
  • 7500+6.079667500+0.78685
  • 10500+6.0566410500+0.78387
库存:1606
PSMN1R7-30YL,115
  • 1+22.970511+2.97290
  • 10+14.7545510+1.90957
  • 100+10.07305100+1.30368
  • 500+8.06972500+1.04441
库存:1606
PSMN1R7-30YL,115
    • 1+22.77720
    • 10+19.91520
    • 30+18.12240
    库存:39
    PSMN1R7-30YL,115
