SS52 THRU SS5200
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Reverse Voltage - 20 to 200 Volts
FEATURES
DO-214AB/SMC
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Low reverse leakage
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
250 C/10 seconds at terminals
0.245(6.22)
0.220(5.59)
0.126 (3.20)
0.114 (2.90)
Forward Current - 5.0 Amperes
0.280(7.11)
0.260(6.60)
0.012(0.305)
0.006(0.152)
0.103(2.62)
0.079(2.06)
MECHANICAL DATA
0.060(1.52)
0.030(0.76)
Case: JEDEC DO-214AB molded plastic body
Terminals: Solder plated, solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.007 ounce, 0.25grams
0.008(0.203)MAX.
0.320(8.13)
0.305(7.75)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
MDD Catalog Number
SYMBOLS SS52 SS53
SS56
MDD MDD MDD MDD MDD
SS52 SS53 SS54 SS55 SS56
Marking code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL(see fig.1)
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 5.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
SS54 SS55
VRRM
VRMS
VDC
21
30
40
28
40
50
35
50
60
42
60
SS58 SS510 SS5150 SS5200 UNITS
MDD MDD
MDD
MDD
80
56
80
100
70
100
150
105
150
200 VOLTS
150 VOLTS
200 VOLTS
I(AV)
5.0
Amps
IFSM
150.0
Amps
VF
IR
CJ
RθJA
TJ,
TSTG
Note: 1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2 ”(5.0x5.0mm) copper pad areas
0.70
0.55
0.85
200
50.0
-50 to +125
-50 to +150
-50 to +150
0.95
0.2
2.0
0.5
Volts
mA
pF
C/W
C
C
FIG. 1- FORWARD CURRENT DERATING CURVE
5.0
4.0
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
3.0
2.0
SS52-SS56
SS58-SS5200
1.0
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
RATINGS AND CHARACTERISTIC CURVES SS52 THRU SS5200
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
150
120
90
60
30
175
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
AMBIENT TEMPERATURE, C
50
INSTANTANEOUS FORWARD
CURRENT,AMPERES
TJ=25 C
10.0
1
SS52-SS54
SS55-SS56
SS58-SS5150
SS5200
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
0.1
100
10
TJ=100 C
1
TJ=75 C
0.1
0.01
TJ=25 C
0.001
0.2
0.4
0.6
0.8
1.0
1.2
1.4
60
80
100
1.6
INSTANTANEOUS FORWARD VOLEAGE,
VOLTS
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
PERCENT OF PEAK REVERSE VOLTAGE,%
1000
TJ=25 C
100
TRANSIENT THERMAL IMPEDANCE,
C/W
0.01
100
NUMBER OF CYCLES AT 60 Hz
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
10
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
100
t,PULSE DURATION,sec.
The cruve graph is for reference only, can't be the basis for judgment(曲线图仅供参考)!
100
很抱歉,暂时无法提供与“SS510-SMC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.35040
- 50+0.32412
- 200+0.30222
- 600+0.28032
- 1500+0.26280
- 3000+0.25185
