FTC1210X7R202-103KNE 数据手册
FTC
SERIES
FLEX TERMINATION CAPACITORS
FEATURES:
• Utilize a conductive Polymer termination to allow the
capacitor to withstand high bending stresses
• 3mm minimum bending strength specification
• Capacitance range: 0.1pF to 47uF
• Voltage range: 6.3V to 3000V DC
• Terminations: 100% matte Tin (Sn)
• Ceramic monolithic structure provides excellent reliability
PART NUMBER STRUCTURE
FTC
1206
X7R
500
Series
Size
0402
0603
0805
1206
1210
1808
1812
2220
Temperature
Characteristic
(Dielectric)
C0G
X7R
X5R
Y5V
Rated Voltage
1st two digits
are significant
followed by
number
of zeroes.
6R3 = 6.3 VDC
100 = 10 VDC
160 = 16 VDC
250 = 25 VDC
500 = 50 VDC
101 = 100 VDC
201 = 200 VDC
251 = 250 VDC
401 = 400 VDC
451 = 450 VDC
501 = 500 VDC
631 = 630 VDC
102 = 1000 VDC
152 = 1500 VDC
202 = 2000 VDC
302 = 3000 VDC
106
K
N
E
Capacitance
(picofarads)
1st two digits are
significant, followed
by number of zeroes.
R denotes decimal
e.g:
101 = 10x101 = 100pF
104 = 10x104 = 100nF
6R8 = 6.8pF
Tolerance
* B = ±0.1pF
* C = ±0.25pF
* D = ±0.5pF
F ±1%
G = ±2%
J = ±5%
K = ±10%
M = ±20%
Z = -20/+80%
*F
or values
below 10pF
only.
Termination
N = 100% Matte Tin over
Nickel over a conductive
Polymer
Packaging
E = Embossed
Tape (7” reel)
Example P/N: FTC1206X7R500-106KNE
P = Paper
Tape (7” reel)
Standard termination finish is 100% matte Tin (Sn) over Nickel.
DIMENSIONS
Unit: inches (mm)
L
w
T
E/B
E/B
STRUCTURE
T
E/B
0.020 ± 0.002
(0.5 ± 0.05)
See Specific Value
0.004 (min.)
(0.10)
0.063 ± 0.006
(1.6 ± 0.15)
0.031 ± 0.0046
(0.8 ± 0.15)
See Specific Value
0.008 (min.)
(0.20)
0805
0.08 ± 0.008
(2.0 ± 0.20)
0.050 ± 0.008
(1.25 ± 0.20)
See Specific Value
0.020 ± 0.010
(0.508 ± 0.254)
1206
0.126 ± 0.008
(3.2 ± 0.20)
0.063 ± 0.008
(1.6 ± 0.20)
See Specific Value
0.020 ± 0.010
(0.508 ± 0.254)
1210
0.126 ± 0.008
(3.2 ± 0.20)
0.098 ± 0.008
(2.50 ± 0.20)
See Specific Value
0.020 ± 0.010
(0.508 ± 0.254)
1808
0.18 +0.024/-0.16
(4.50 +0.6/-0.4)
0.0812 ± 0.010
(2.03 ±0.25)
See Specific Value
0.020 ± 0.010
(0.50 ± 0.25)
1812
0.177 ± 0.012
(4.495 ± 0.30)
0.126 ± 0.012
(3.20 ± 0.30)
See Specific Value
0.024 ± 0.015
(0.6096 ± 0.381)
2220
0.225 ± 0.02
(5.70 ± 0.50)
0.200 ± 0.016
(5.00 ± 0.40)
See Specific Value
0.034 ± 0.014
(0.85 ± 0.35)
SIZE
L
W
0402
0.040 ± 0.002
(1.0 ± 0.05)
0603
6
2
4
3
5
1
Ceramic Body (dielectric)
4
2
Inner Electrode
5
Nickel Plating
3
Inner Termination
6
100% Matte Tin (Sn)
Silver Polymer
1
Email: sales@venkel.com
Phone: 512.794.0081 |
Toll Free: 800.950.8365 |
Web: www.venkel.com
Rev: 04/2021-A
1
FTC
SERIES
ELECTRICAL SPECIFICATION & RANGE
NP0/C0G
Typical Capacitance Change vs. Temperature
15%
10%
5%
-5%
-10%
-55˚C
-25˚C
0˚C
25˚C
50˚C
75˚C
100˚C
Ageing: None
Temperature Coefficient:
0 ±30PPM/°C
Withstanding Voltage: >2.5 times VDCW
Temperature Voltage Coefficient:
0 ±30PPM/°C
Insulation Resistance:
>1000Ω-F or 100GΩ, for values ≤ 0.047uF
(whichever is less at 25°C, WDCV).
For Capacitance values > 0.047uF, the 500 Ω-F rule applies.
(The IR at 125°C is 10% of the value at 25°C)
0%
-15%
Operating Temperature Range:
-55°C to +125°C
125˚C
Capacitance Tolerance: B,C,D,F,G,J,K
Dissipation Factor: 0.1% max
X7R
15%
-55°C to +125°C
10%
D.F.≤
≥100V
≤2.5%
0 ±15%∆°C MAX.
5%
X7R not applicable
0%
-5%
-10%
-15%
Rated
Voltage
-55˚C
-25˚C
0˚C
25˚C
50˚C
75˚C
100˚C
125˚C
>100Ω-F or 1GΩ, whichever is less
at 25°C, VDCW. (10,000Ω at 125°C)
50V
≤2.5%
35V
≤3.5%
J,K,M
25V
Rated Voltage
1206≥0.47μF
≤5%
0805›0.1μF; 0603≥0.068μF; 1206>1μF; 1210≥2.2μF
≤10%
0805›0.22μF; 1210≥3.3μF
≤5%
201≥0.01μF; 1210≥4.7μF
≤10%
0402≥0.012μF; 0603>0.1μF; 0805≥1μF; 1206≥2.2μF;
1210≥10μF
≤10%
0603≥1μF; 0805≥2.2μFF; 1206≥2.2μF; 1210≥10μF
≤5%
201≥0.01μF; 0805≥1μF; 1210≥10μF
≤7%
0603≥0.33μF
≤10%
201≥0.01μF; 0402≥0.10μF & (0402/X7R≥0.056μF);
0603≥0.47μF; 0805≥2.2μF;1206≥4.7μF;1210≥22μF
≤12.5%
0402≥0.47μF
≤5%
201≥0.01μF; 0402≥0.33μF; 0603≥0.15μF;
0805≥0.68μF; 1206≥2.2μF; 1210≥4.7μF
≤10%
201≥0.01μF; (201/X7R≥0.022μF); 0402≥0.22μF;
0603≥0.68μF; 0805≥2.2μF; 1206≥4.7μF; 1210≥22μF
≤10%
201≥0.012μF; 0402≥0.33μF(0402/X7R≥0.22μF);
0603≥0.33μF; 0805≥2.2μF; 1206≥2.2μF; 1210≥22μF; 01R5
≤3.5%
100V: All X7R; 1210≥3.3μF
50V: 0402>0.01μF; 0603≥1μF; 0805≥1μF; 1206≥4.7μF;
1210≥4.7μF
16V
≤3.5%
35V:0603≥1μF; 0805≥2.2μF; 1206≥2.2μF; 1210≥10μF
25V:0402≥0.22μF; 0603≥2.2μF; 0805≥2.2μF;
1206≥10μF;1210≥10μF
1GΩ or 100Ω-F
Whichever is smaller
16V: 0402≥0.22μF; 0603≥1μF; 0805≥2.2μF; 1206≥10μF;
1210≥47μF
10V: 0402≥0.47μF; 0603≥0.47μF; 0805≥2.2μF; 1206≥4.7μF;
1210≥47μF
6.3V ; 4V ; Size 1812
10V
6.3V
4V
≤3%
≤3% 0201(50V); 0603≥0.047μF; 0805≥0.18μF; 1206≥0.47μF
Ageing:
2.5% per decade hour, typical
>2.5 times VDCW
Exception of D.F.≤
≤5%
≤15%
201≥0.1μF; 0402≥1μF
≤15%
201≥0.1μF; 0402≥1μF(0402/X6S≥0.47μF); 0603≥10μF;
0805≥4.7μF; 1206≥47μF; 1210≥100μF
≤20%
0402≥2.2μF
≤10%
≤15%
Web: www.venkel.com
Rev: 04/2021-A
2
FTC
SERIES
X5R
15%
-55°C to +85°C
0 ±15%∆°C MAX.
X5R not applicable
at 25°C, VDCW. (10,000 Ω at 125°C)
Ageing:
>2.5 times VDCW
K,M
10%
5%
0%
-5%
-10%
-15%
-55°C
-25°C
0°C
25°C
50°C
75°C
100°C
125°C
Rated
Voltage
≥100V
50V
35V
25V
Rated Voltage
D.F.≤
≤2.5%
≤2.5%
≤3.5%
Exception of D.F.≤
≤3%
1206≥0.47μF
≤5%
≤10%
≤3%
≤5%
≤10%
1210≥10μF
≤10%
≤5%
≤7%
0603≥0.33μF
≤10%
≤3.5%
≤12.5%
0402≥0.47μF
≤5%
≤10%
≤10%
16V
1210≥4.7μF
≤3.5%
1206≥10μF;1210≥10μF
1GΩ or 100Ω-F
10V
≤5%
1210≥47μF
1210≥47μF
6.3V
≤10%
4V
≤15%
≤15%
201≥0.1μF; 0402≥1μF
≤15%
≤20%
0402≥2.2μF
Y5V
40%
-30°C to +85°C
+22% - 82%∆°C MAX.
at 25°C, WDCV. (The IR at 125°C
20%
0%
-20%
-40%
-60%
-80%
-100%
-55˚C
-25˚C
0˚C
25˚C
50C
75˚C
100˚C
125˚C
Ageing:
7% per decade hour, typical
>2.5 times VDCW
M,Z
Rated
Voltage
≥50V
Rated Voltage
1210≥4.7μF
35V
25V
D.F.≤
1GΩ or 100Ω-F
1210≥47μF
1210≥47μF
16V
(C 1000pF, 25°C
Note: To ensure proper capacitance readings, the voltage level must be held constant. The HP4284 and Agilent E4980 has
a “ALC” (Automatic Level Control) function and should be switched to the “ON” position for accurate capacitance readings.
VOLTAGE AND CAPACITANCE RANGE
C0G (NP0) DIELECTRIC (0402 - 0603)
Size (inches)
0.1pF
0603
10V
16V
25V
50V
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
100V
10V
16V
50V
100V
200V
250V
0R2
0.2pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0R3
0.3pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0R4
0.4pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0R5
0.5pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0R6
0.6pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0R7
0.7pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0R8
0.8pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0R9
0.9pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
1.0pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
1.2pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
1R0
1R2
1R5
1R8
2R2
2R7
3R3
3R9
4R7
471
5R6
8R2
100
120
150
180
220
270
330
390
470
Values that are typically available. (Thickness in mm).
0402
VDCW (MAX)
0R1
1.5pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
1.8pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
2.2pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
2.7pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
3.3pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
3.9pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
4.7pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
5.6pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
6.8pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
8.2pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
10pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
12pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
15pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
18pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
22pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
27pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
33pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
39pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
47pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
560
56pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
680
68pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
820
82pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
101
100pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
121
120pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
151
150pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
181
180pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
221
220pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
271
270pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30
0.80±0.30
Note: Additional values may be available. Please contact us for more information. Due to demand and raw material fluctuations, specific values may not be available.
Web: www.venkel.com
Rev: 04/2021-A
4
FTC
SERIES
0603
10V
16V
25V
50V
330pF
0.50±0.20
0.50±0.20
0.50±0.20
390pF
0.50±0.20
0.50±0.20
470pF
0.50±0.20
0.50±0.20
560pF
0.50±0.20
680pF
331
391
471
561
681
821
102
122
152
182
222
272
332
100V
10V
16V
25V
50V
100V
200V
250V
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30
0.80±0.30
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30
0.80±0.30
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30
0.80±0.30
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30
0.80±0.30
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
820pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
1000pF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
1200pF
0.80±0.30
0.80±0.30
0.80±0.30
1500pF
0.80±0.30
0.80±0.30
1800pF
0.80±0.30
0.80±0.30
0.80±0.30
0.80±0.30
2200pF
0.80±0.30
0.80±0.30
0.80±0.30
0.80±0.30
2700pF
0.80±0.30
0.80±0.30
0.80±0.30
0.80±0.30
3300pF
0.80±0.30
0.80±0.30
0.80±0.30
0.80±0.30
0.80±0.30
C0G (NP0) DIELECTRIC (0805)
SIZE (INCHES)
0R6
0R7
0R8
0R9
1R0
1R2
1R5
1R8
2R2
2R7
3R3
3R9
4R7
471
5R6
8R2
100
120
150
180
220
270
330
390
470
560
680
820
101
121
151
VDCW (MAX)
0R5
0402
VDCW (MAX)
SIZE (INCHES)
0805
10V
16V
25V
50V
100V
200V
250V
500V
630V
1000V
0.5pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
0.6pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
0.7pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
0.8pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
0.9pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
1.0pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
1.2pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
1.5pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
1.8pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
2.2pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
2.7pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
3.3pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
3.9pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
4.7pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
5.6pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
6.8pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
8.2pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
10pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
12pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
15pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
18pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
22pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
27pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
33pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
39pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
47pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
56pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
68pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
82pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.80±0.10
0.80±0.10
1.25±0.10
100pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.25±0.10
120pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.80±0.10
1.25±0.10
1.25±0.10
1.25±0.10
150pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.80±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
Web: www.venkel.com
Rev: 04/2021-A
5
FTC
SERIES
SIZE (INCHES)
181
221
271
331
391
471
561
681
821
102
122
152
182
222
272
332
392
472
562
682
822
103
VDCW (MAX)
0805
10V
16V
25V
50V
100V
200V
250V
500V
630V
1000V
180pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.80±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
220pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
270pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
330pF
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
0.60±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
390pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
470pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.25±0.10
1.25±0.10
1.25±0.30
1.25±0.30
1.25±0.30
560pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.25±0.10
1.25±0.10
1.25±0.30
680pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.25±0.10
1.25±0.10
1.25±0.30
1.25±0.30
820pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.25±0.10
1.25±0.10
1.25±0.30
1.25±0.30
1000pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.25±0.10
1.25±0.10
1.25±0.30
1.25±0.30
1200pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.25±0.10
1.25±0.10
1500pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.25±0.10
1.25±0.10
1800pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.25±0.10
1.25±0.10
2200pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.25±0.10
1.25±0.10
2700pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
3300pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
3900pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
4700pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
5600pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
6800pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
8200pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.010μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
C0G (NP0) DIELECTRIC (1206)
SIZE (INCHES)
1R2
1R5
1R8
2R2
2R7
3R3
3R9
4R7
471
5R6
8R2
100
120
150
180
220
270
330
390
470
560
680
820
101
VDCW (MAX)
1R0
1206
10V
16V
25V
50V
100V
200V
250V
500V
630V
1000V
1500V
2000V
1.0pF
1.2pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.5pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.8pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
2.2pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
2.7pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
3.3pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
3.9pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
4.7pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
5.6pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
6.8pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
8.2pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
10pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
12pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
15pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
18pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
22pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
27pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
33pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.95±0.10
0.95±0.10
39pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.95±0.10
0.95±0.10
47pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.95±0.10
0.95±0.10
0.95±0.10
56pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.95±0.10
1.25±0.10
1.25±0.10
68pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.95±0.10
1.25±0.10
1.25±0.10
82pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.25±0.10
1.25±0.10
1.25±0.10
100pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.25±0.10
1.25±0.10
1.25±0.10
Web: www.venkel.com
Rev: 04/2021-A
6
FTC
SERIES
SIZE (INCHES)
121
151
181
221
271
331
391
471
561
681
821
102
122
152
182
222
272
332
392
472
562
682
822
103
123
153
183
223
273
333
393
VDCW (MAX)
1206
10V
16V
25V
50V
100V
200V
250V
500V
630V
1000V
1500V
2000V
120pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.25±0.10
1.60±0.20
1.60±0.20
150pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.25±0.10
1.60±0.20
1.60±0.20
180pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.60±0.20
1.60±0.20
1.60±0.20
220pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.60±0.20
1.60±0.20
1.60±0.20
270pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.60±0.20
1.60±0.50
1.60±0.50
330pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.60±0.20
1.60±0.50
1.60±0.50
390pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.60±0.20
1.60±0.50
1.60±0.50
470pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.60±0.20
560pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.95±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.60±0.20
680pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.95±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.60±0.20
820pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.95±0.10
1.60±0.20
1.60±0.20
1.60±0.20
1.60±0.20
1000pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.95±0.10
1.60±0.20
1.60±0.20
1.60±0.20
1.60±0.20
1200pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.95±0.10
1.60±0.20
1.60±0.20
1.60±0.20
1500pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.25±0.10
1.60±0.20
1.60±0.20
1.60±0.20
1800pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.25±0.10
1.60±0.20
1.60±0.20
1.60±0.20
2200pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.25±0.10
1.60±0.20
1.60±0.20
1.60±0.20
2700pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.25±0.10
1.60±0.20
1.60±0.20
1.60±0.20
3300pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.25±0.10
1.60±0.20
1.60±0.20
1.60±0.20
3900pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.25±0.10
1.60±0.20
1.60±0.20
1.60±0.20
4700pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1.25±0.10
1.60±0.20
1.60±0.20
1.60±0.20
5600pF
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
0.80±0.10
6800pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
8200pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.010μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.012μF
1.60±0.50
1.60±0.50
1.60±0.50
1.60±0.50
1.60±0.50
0.015μF
1.60±0.50
1.60±0.50
1.60±0.50
1.60±0.50
1.60±0.50
0.018μF
1.60±0.50
1.60±0.50
1.60±0.50
1.60±0.50
1.60±0.50
0.022μF
1.60±0.50
1.60±0.50
1.60±0.50
1.60±0.50
1.60±0.50
0.027μF
1.60±0.50
1.60±0.50
1.60±0.50
1.60±0.50
0.033μF
1.60±0.50
1.60±0.50
1.60±0.50
1.60±0.50
0.039μF
1.60±0.50
1.60±0.50
1.60±0.50
1.60±0.50
C0G (NP0) DIELECTRIC (1210)
SIZE (INCHES)
120
150
180
220
270
330
390
470
560
680
820
101
121
151
181
VDCW (MAX)
100
1210
10V
16V
25V
50V
100V
200V
250V
500V
630V
1000V
1500V
2000V
10pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
12pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
15pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
18pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
22pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
27pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
33pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
39pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
47pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
56pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.25±0.10
1.25±0.10
68pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.25±0.10
1.25±0.10
82pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.25±0.10
1.25±0.10
100pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.25±0.10
1.25±0.10
1.25±0.10
120pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.25±0.10
1.25±0.10
1.25±0.10
150pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.25±0.10
1.60±0.20
1.60±0.20
180pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.25±0.10
1.60±0.20
1.60±0.20
Web: www.venkel.com
Rev: 04/2021-A
7
FTC
SERIES
SIZE (INCHES)
221
271
331
391
471
561
681
821
102
122
152
182
222
272
332
392
472
562
682
822
103
123
153
183
223
273
333
393
473
VDCW (MAX)
1210
10V
16V
25V
50V
100V
200V
250V
500V
630V
1000V
1500V
2000V
220pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.60±0.20
1.60±0.20
1.60±0.20
270pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.60±0.20
2.00±0.20 2.00±0.20
330pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.60±0.20
2.00±0.20 2.00±0.20
390pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.60±0.20
2.50±0.50
2.50±0.50
470pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.60±0.20
2.50±0.50
2.50±0.50
560pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.60±0.20
680pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.60±0.20
820pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.60±0.20
1000pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.60±0.20
1200pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.60±0.20
1500pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
1800pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.50±0.50
2200pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.50±0.50
2700pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.50±0.50
3300pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.50±0.50
3900pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.50±0.50
4700pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.60±0.20
1.60±0.20
1.60±0.20
5600pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.60±0.20
1.60±0.20
1.60±0.20
6800pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.60±0.20
1.60±0.20
1.60±0.20
8200pF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.60±0.20
1.60±0.20
1.60±0.20
0.010μF
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
0.95±0.10
1.60±0.20
1.60±0.20
1.60±0.20
0.012μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.015μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.018μF
0.022μF
0.027μF
0.033μF
0.039μF
0.047μF
C0G (NP0) DIELECTRIC (1808)
SIZE (INCHES)
2R2
2R7
3R3
3R9
4R7
471
5R6
8R2
100
120
150
180
220
270
330
390
470
VDCW (MAX)
2R0
1808
500V
630V
1000V
1500V
2000V
3000V
2.0pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.2pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.7pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
3.3pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
3.9pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
4.7pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
5.6pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
6.8pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
8.2pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
10pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
12pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
15pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
18pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
22pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
27pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
33pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
39pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
47pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
Web: www.venkel.com
Rev: 04/2021-A
8
FTC
SERIES
SIZE (INCHES)
1808
680
820
101
121
151
181
221
271
331
391
471
561
681
821
102
122
152
182
222
272
332
VDCW (MAX)
560
500V
630V
1000V
1500V
2000V
3000V
56pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
68pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
82pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
100pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
120pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
150pF
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
2.00±0.20
2.00±0.20
180pF
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
2.00±0.20
2.00±0.20
220pF
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
2.00±0.20
2.00±0.20
270pF
2.00±0.20
2.00±0.20
2.00±0.20
2.00±0.20
2.00±0.20
2.00±0.20
330pF
2.00±0.20
2.00±0.20
2.00±0.20
2.00±0.20
2.00±0.20
2.00±0.20
390pF
2.00±0.20
2.00±0.20
2.00±0.20
2.00±0.20
2.00±0.20
470pF
2.00±0.20
2.00±0.20
2.00±0.20
2.00±0.20
2.00±0.20
560pF
2.00±0.20
2.00±0.20
2.00±0.20
2.00±0.20
2.00±0.20
680pF
2.00±0.20
2.00±0.20
2.00±0.20
2.00±0.20
2.00±0.20
820pF
2.00±0.20
2.00±0.20
2.00±0.20
1.25±0.10
1.25±0.10
1000pF
2.00±0.20
2.00±0.20
2.00±0.20
1.60±0.20
1.60±0.20
1.60±0.20
1200pF
2.00±0.20
2.00±0.20
1500pF
2.00±0.20
2.00±0.20
1.60±0.20
1800pF
2.00±0.20
2.00±0.20
2.00±0.20
2200pF
2.00±0.20
2.00±0.20
2.00±0.20
2700pF
2.00±0.20
2.00±0.20
3300pF
2.00±0.20
2.00±0.20
C0G (NP0) DIELECTRIC (2220)
SIZE (INCHES)
120
150
180
220
270
330
390
470
560
680
820
101
121
151
181
221
271
331
391
471
561
681
821
102
VDCW (MAX)
100
2220
25V
50V
100V
200V
250V
500V
630V
1000V
1500V
2000V
3000V
10pF
2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20
2.00±0.20 2.00±0.20
2.00±0.20 2.00±0.20
12pF
15pF
2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20
4000V
18pF
22pF
27pF
2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20
33pF
39pF
47pF
56pF
68pF
82pF
100pF
120pF
150pF
180pF
220pF
270pF
2.50±0.30
330pF
2.50±0.30
390pF
470pF
560pF
680pF
820pF
1000pF
Web: www.venkel.com
Rev: 04/2021-A
9
FTC
SERIES
SIZE (INCHES)
122
152
182
222
272
332
392
472
562
682
822
103
123
153
183
223
273
333
393
473
563
683
823
104
VDCW (MAX)
2220
25V
50V
100V
200V
250V
500V
630V
1000V
221
271
331
391
471
561
681
821
102
122
152
182
222
272
332
392
472
562
682
181
3000V
4000V
1500pF
1800pF
2200pF
2700pF
3300pF
3900pF
4700pF
5600pF
6800pF
8200pF
2.50±0.30
10000pF
2.50±0.30
12000pF
15000pF
18000pF
22000pF
27000pF
33000pF
39000pF
47000pF
2.50±0.30
2.50±0.30
56000pF
2.50±0.30
2.50±0.30
68000pF
2.50±0.30
2.50±0.30
82000pF
2.00±0.20 2.00±0.20
2.50±0.30
100000pF
2.50±0.30
2.50±0.30
VDCW (MAX)
121
2000V
2.50±0.30
SIZE (INCHES)
151
1500V
1200pF
2.50±0.30
X7R DIELECTRIC (0402, 0603)
101
0402
10V
16V
25V
0603
50V
100V
10V
16V
25V
50V
100V
100pF
0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
200V
250V
120pF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
150pF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
180pF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
220pF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
270pF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
330pF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
390pF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
470pF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
560pF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
680pF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
820pF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
1000pF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
1200pF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
1500pF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
1800pF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
2200pF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
2700pF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
3300pF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
3900pF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
4700pF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
5600pF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
6800pF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
Web: www.venkel.com
Rev: 04/2021-A
10
FTC
SERIES
SIZE (INCHES)
822
103
123
153
183
223
273
333
393
473
563
683
823
104
124
154
184
224
274
334
394
474
564
684
824
105
VDCW (MAX)
0402
10V
16V
0603
25V
50V
100V
10V
16V
25V
50V
100V
8200pF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
0.010μF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
0.012μF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30
0.015μF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30
0.022μF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30
0.027μF
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30
0.033μF
0.50±0.20 0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
0.039μF
0.50±0.20 0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
0.047μF
0.50±0.20 0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
0.056μF
0.50±0.20 0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
0.068μF
0.50±0.20 0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
0.082μF
0.50±0.20 0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
0.10μF
0.50±0.20 0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
0.80±0.07
0.80±0.07
0.80±0.30
0.12μF
0.15μF
0.80±0.07
0.80±0.07
0.80±0.30
0.18μF
0.80±0.07
0.80±0.07
0.80±0.30
0.22μF
0.80±0.07
0.80±0.07
0.80±0.30 0.80±0.30
0.27μF
0.80±0.30 0.80±0.30 0.80±0.30
0.33μF
0.39μF
0.47μF
0.56μF
0.80±0.30 0.80±0.30
0.68μF
0.80±0.30 0.80±0.30
0.82μF
0.80±0.30 0.80±0.30
1.0μF
181
221
271
331
391
471
561
681
821
102
122
152
182
222
272
332
392
472
121
250V
Size (inches)
0805
VDCW (MAX)
151
200V
0.018μF
X7R DIELECTRIC (0805)
101
10V
16V
25V
50V
100V
200V
250V
500V
630V
1000V
100pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.80±0.10
0.80±0.10
0.80±0.10
120pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.80±0.10
0.80±0.10
0.80±0.10
150pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.80±0.10
0.80±0.10
0.80±0.10
180pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.80±0.10
0.80±0.10
0.80±0.10
220pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.80±0.10
0.80±0.10
0.80±0.10
270pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.80±0.10
0.80±0.10
0.80±0.10
330pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.80±0.10
0.80±0.10
0.80±0.10
390pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.80±0.10
0.80±0.10
0.80±0.10
470pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.80±0.10
0.80±0.10
0.80±0.10
560pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.80±0.10
0.80±0.10
0.80±0.10
680pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.80±0.10
0.80±0.10
0.80±0.10
820pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1000pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1200pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.80±0.10
0.80±0.10
0.80±0.10
1500pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.80±0.10
0.80±0.10
1.25±0.10
1800pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.80±0.10
0.80±0.10
1.25±0.10
2200pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.80±0.10
0.80±0.10
1.25±0.10
2700pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.80±0.10
0.80±0.10
3300pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.80±0.10
0.80±0.10
3900pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.80±0.10
0.80±0.10
4700pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
Web: www.venkel.com
Rev: 04/2021-A
11
FTC
SERIES
SIZE (INCHES)
562
682
822
103
123
153
183
223
273
333
393
473
563
683
823
104
124
154
184
224
274
334
394
474
564
684
824
105
155
225
475
155
225
475
VDCW (MAX)
0805
10V
16V
25V
50V
100V
200V
250V
500V
630V
5600pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
6800pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
8200pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.010μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.012μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.015μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.018μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.022μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.027μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.033μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.039μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.047μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.056μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.068μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.082μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.10μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.12μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.30
0.15μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.30
0.18μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.30
0.22μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.30
0.27μF
1.25±0.30
1.25±0.30
1.25±0.30
1.25±0.30
0.33μF
1.25±0.30
1.25±0.30
1.25±0.30
1.25±0.30
0.39μF
1.25±0.30
1.25±0.30
1.25±0.30
1.25±0.30
0.47μF
1.25±0.30
1.25±0.30
1.25±0.30
1.25±0.30
0.56μF
1.25±0.30
1.25±0.30
1.25±0.30
0.68μF
1.25±0.30
1.25±0.30
1.25±0.30
0.82μF
1.25±0.30
1.25±0.30
1.25±0.30
1.0μF
1.25±0.30
1.25±0.30
1.25±0.30
1.5μF
1.25±0.30
1.25±0.30
1.25±0.30
2.2μF
1.25±0.30
1.25±0.30
1.25±0.30
4.7μF
1.25±0.30
1.25±0.30
1.5μF
1.25±0.30
1.25±0.30
1.25±0.30
2.2μF
1.25±0.30
1.25±0.30
1.25±0.30
1.25±0.30
1.25±0.30
4.7μF
SIZE (INCHES)
121
151
181
221
271
331
391
471
561
681
821
102
VDCW (MAX)
1000V
1.25±0.30
X7R DIELECTRIC (1206)
101
1206
10V
16V
25V
100pF
50V
100V
1000V
1500V
2000V
1.25±0.10 1.25±0.10
200V
250V
400V
450V
1.25±0.10 1.25±0.10
500V
630V
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
150pF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
180pF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
220pF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
270pF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
330pF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
390pF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
470pF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
560pF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
680pF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
820pF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
1.25±0.10 1.60±0.20 1.60±0.20
1000pF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
120pF
Web: www.venkel.com
Rev: 04/2021-A
12
FTC
SERIES
SIZE (INCHES)
122
152
182
222
272
332
392
472
562
682
822
103
123
153
183
223
273
333
393
473
563
683
823
104
124
154
184
224
274
334
394
474
564
684
824
105
155
225
475
106
226
VDCW (MAX)
1206
10V
16V
25V
50V
100V
200V
250V
400V
450V
500V
630V
1000V
1500V
2000V
1200pF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
1500pF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
1800pF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
2200pF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
2700pF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
3300pF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
3900pF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
1.25±0.10 1.60±0.20
4700pF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
1.25±0.10 1.60±0.20
5600pF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
1.25±0.10 1.60±0.20
6800pF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
1.25±0.10 1.60±0.20
8200pF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
1.25±0.10 1.60±0.20
0.010μF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
1.25±0.10 1.60±0.20
0.012μF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10 1.60±0.20
0.015μF
1.25±0.10 1.25±0.10
0.018μF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10
0.022μF
1.25±0.10 1.25±0.10
1.60±0.20 1.60±0.20
0.027μF
1.25±0.10 1.25±0.10
1.60±0.20 1.60±0.20
0.033μF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1.60±0.20
1.60±0.20 1.60±0.20
0.039μF
1.25±0.10 1.25±0.10
1.60±0.20 1.60±0.20
0.047μF
1.25±0.10 1.25±0.10
1.60±0.20 1.60±0.20
0.056μF
1.25±0.10 1.25±0.10
1.60±0.20 1.60±0.20
0.068μF
1.25±0.10 1.25±0.10
1.25±0.10 1.25±0.10 1.25±0.10 1.60±0.20 1.60±0.20 1.60±0.20 1.60±0.20
0.082μF
1.25±0.10 1.25±0.10
0.10μF
1.25±0.10 1.25±0.10
0.12μF
1.25±0.10 1.25±0.10
0.15μF
0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20
0.18μF
0.22μF
0.27μF
0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.60±0.20
0.33μF
0.39μF
0.95±0.10 0.95±0.10 1.15±0.15 1.60±0.50 1.60±0.20
0.47μF
1.15±0.15
1.15±0.15
0.56μF
1.15±0.15
1.15±0.15
1.15±0.15 1.60±0.50 1.60±0.50
0.68μF
1.15±0.15
1.15±0.15
0.82μF
1.15±0.15
1.15±0.15
1.0μF
1.15±0.15
1.15±0.15
1.5μF
1.15±0.15
1.15±0.15 1.60±0.50
1.15±0.15
2.2μF
4.7μF
1.60±0.50 1.60±0.50 1.60±0.50
10μF
22μF
1.60±0.50
Web: www.venkel.com
Rev: 04/2021-A
13
FTC
SERIES
X7R DIELECTRIC (1210)
SIZE (INCHES)
101
121
151
181
221
271
331
391
471
561
681
821
102
122
152
182
222
272
332
392
472
562
682
822
103
123
153
183
223
273
333
393
473
563
683
823
104
124
154
184
224
274
334
394
474
564
684
824
105
155
VDCW (MAX)
1210
6.3V
10V
16V
25V
50V
100V
200V
250V
400V
450V
100pF
500V
630V
1000V
1500V
2000V
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
120pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
150pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
180pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
220pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
270pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
330pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
390pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
470pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
560pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
680pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
820pF
1000pF
0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10 2.50±0.50 2.50±0.50
1200pF
1.25±0.10
1.25±0.10
1500pF
1.25±0.10
1.25±0.10
1800pF
1.25±0.10
1.25±0.10
2200pF
1.25±0.10
1.25±0.10
2700pF
1.25±0.10
1.25±0.10
3300pF
1.25±0.10
1.25±0.10
3900pF
1.25±0.10
1.25±0.10 1.60±0.20 2.50±0.50 2.50±0.50
4700pF
1.25±0.10
5600pF
1.25±0.10
6800pF
1.25±0.10
8200pF
1.25±0.10
0.010μF
1.25±0.10
1.25±0.10 1.60±0.20
0.012μF
1.25±0.10
1.25±0.10 1.60±0.20
0.015μF
1.25±0.10
1.25±0.10 1.60±0.20
0.018μF
1.25±0.10
1.25±0.10 1.60±0.20
0.022μF
1.25±0.10
1.25±0.10 1.60±0.20
0.027μF
0.033μF
0.039μF
1.60±0.20 1.60±0.20
0.047μF
0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10
1.25±0.10
1.60±0.20 1.60±0.20 2.50±0.50
0.056μF
1.25±0.10
1.60±0.20 1.60±0.20
0.068μF
0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 1.60±0.20
2.00±0.20 2.00±0.20
0.082μF
2.00±0.20 2.00±0.20
0.10μF
2.00±0.20 2.00±0.20
0.12v
0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 1.60±0.20 2.50±0.50 2.50±0.50
0.15μF
0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 2.50±0.50 2.50±0.50 2.50±0.50 2.50±0.50
0.18μF
0.22μF
0.27μF
0.95±0.10 0.95±0.10 0.95±0.10 0.95±0.10 1.60±0.20 2.50±0.50 2.50±0.50 2.50±0.50 2.50±0.50
0.33μF
0.95±0.10 0.95±0.10 0.95±0.10 1.25±0.10 1.60±0.20 2.50±0.50 2.50±0.50 2.50±0.50 2.50±0.50
0.39μF
0.47μF
0.56μF
1.25±0.10
1.25±0.10
1.25±0.10
0.68μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10 2.00±0.20 2.50±0.50 2.50±0.50
0.82μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10 2.00±0.20
1.0μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10 2.00±0.20
1.5μF
2.00±0.20 1.60±0.20 2.50±0.50 2.50±0.50
Web: www.venkel.com
Rev: 04/2021-A
14
FTC
SERIES
SIZE (INCHES)
225
335
475
106
226
476
VDCW (MAX)
1210
6.3V
10V
2.2μF
16V
25V
50V
100V
200V
250V
400V
450V
3.3μF
4.7μF
10μF
2.00±0.20 2.00±0.20 2.50±0.50 2.50±0.50
22μF
391
471
561
681
821
102
122
152
182
222
272
332
392
472
562
682
822
103
123
153
183
223
273
333
393
473
563
683
823
271
331
1000V
1500V
2000V
2.50±0.50
1808
VDCW (MAX)
181
630V
47μF 2.50±0.50
SIZE (INCHES)
221
500V
X7R DIELECTRIC (1808)
151
150pF
500V
630V
1000V
1500V
2000V
3000V
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
180pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
220pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
270pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
330pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
390pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
470pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
560pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
680pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
820pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
1000pF
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
2.00±0.20
2.00±0.20
1200pF
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
2.00±0.20
2.00±0.20
1500pF
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
2.00±0.20
2.00±0.20
2.00±0.20
1800pF
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
2.00±0.20
2200pF
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
2.00±0.20
2700pF
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
2.00±0.20
3300pF
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
2.00±0.20
3900pF
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
2.00±0.20
4700pF
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
2.00±0.20
5600pF
2.00±0.20
2.00±0.20
2.00±0.20
2.00±0.20
2.00±0.20
6800pF
2.00±0.20
2.00±0.20
2.00±0.20
2.00±0.20
2.00±0.20
8200pF
2.00±0.20
2.00±0.20
2.00±0.20
0.010μF
2.00±0.20
2.00±0.20
2.00±0.20
0.012μF
2.00±0.20
2.00±0.20
2.00±0.20
0.015μF
2.00±0.20
2.00±0.20
2.00±0.20
0.018μF
2.00±0.20
2.00±0.20
2.00±0.20
0.022μF
2.00±0.20
2.00±0.20
2.00±0.20
0.027μF
2.00±0.20
2.00±0.20
2.00±0.20
0.033μF
2.00±0.20
2.00±0.20
2.00±0.20
0.039μF
2.00±0.20
2.00±0.20
2.00±0.20
0.047μF
2.00±0.20
2.00±0.20
2.00±0.20
0.056μF
2.00±0.20
2.00±0.20
2.00±0.20
0.068μF
2.00±0.20
2.00±0.20
0.082μF
2.00±0.20
2.00±0.20
Web: www.venkel.com
Rev: 04/2021-A
15
FTC
SERIES
X7R DIELECTRIC (1812)
SIZE (INCHES)
1812
VDCW (MAX)
271
10V
16V
25V
50V
100V
270pF
200V
250V
500V
630V
1000V
1500V
2000V
3000V
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
331
330pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
391
390pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
2.00±0.20
471
470pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
561
560pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
681
680pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
821
820pF
102
1000pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
122
1200pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
152
1500pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
182
1800pF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
222
2200pF 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
332
392
472
562
682
822
103
123
153
183
223
273
333
393
473
563
683
823
104
124
154
272
2700pF 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
3300pF 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
3900pF 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
4700pF 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
5600pF 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
6800pF 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
8200pF 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.50±0.50 2.50±0.50
0.010μF 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.50±0.50 2.50±0.50
0.012μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
0.015μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20
0.018μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.50±0.50
0.022μF 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.50±0.50
0.027μF 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.50±0.50
0.033μF 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.50±0.50
0.039μF 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.50±0.50
0.047μF 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.50±0.50
0.056μF 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.068μF 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.082μF 1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.50±0.50 2.50±0.50
0.10μF
1.25±0.10
0.12μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
0.15μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
184
0.18μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
224
0.22μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
274
0.27μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
334
0.33μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
394
0.39μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
474
0.47μF
1.25±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.50
1.25±0.10
564
0.56μF
1.25±0.10
1.25±0.10
1.25±0.10
684
0.68μF
1.25±0.10
1.25±0.10
1.25±0.10
824
0.82μF
1.25±0.10
1.25±0.10
1.25±0.10
105
1.0μF
1.25±0.10
1.25±0.10
1.25±0.10
155
1.5μF
2.00±0.20
225
2.2μF
2.50±0.50 2.50±0.50
Web: www.venkel.com
Rev: 04/2021-A
16
FTC
SERIES
X7R DIELECTRIC (2220)
SIZE (INCHES)
VDCW (MAX)
2220
25V
50V
100V
200V
250V
400V
500V
630V
1000V
1500V
2000V
3000V
4000V
100pF
121
120pF
151
150pF
181
180pF
221
220pF
271
270pF
2.00±0.20*
331
330pF
2.00±0.20*
391
390pF
2.00±0.20*
471
470pF
2.00±0.20*
561
560pF
2.00±0.20*
681
680pF
2.00±0.20*
821
820pF
2.00±0.20*
102
1000pF
2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20*
122
152
182
222
272
332
392
472
562
682
822
103
123
153
183
223
273
333
393
473
101
1200pF
2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30*
1500pF
1800pF
2200pF
2700pF
3300pF
3900pF
4700pF
5600pF
6800pF
2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30 2.50±0.30 2.50±0.30*
8200pF
10000pF
12000pF
2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30 2.50±0.30 2.80±0.30*
15000pF
2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.80±0.30 2.80±0.30 2.80±0.30*
18000pF
22000pF
27000pF
33000pF
39000pF
47000pF
563
56000pF
683
68000pF
823
82000pF
104
100000pF
124
120000pF
154
150000pF
184
180000pF
224
220000pF
274
270000pF
334
330000pF
394
390000pF
474
470000pF
564
560000pF
684
680000pF
824
820000pF
105
1000000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20 2.00±0.20
125
1200000pF
Note: A
*Provided with surface coating.
Web: www.venkel.com
Rev: 04/2021-A
17
FTC
SERIES
SIZE (INCHES)
2220
185
225
275
335
395
475
565
685
825
106
126
156
186
226
VDCW (MAX)
155
25V
50V
100V
200V
250V
400V
1500000pF
1800000pF
500V
630V
563
683
823
104
154
224
274
334
394
474
684
824
105
155
225
335
475
473
2000V
3000V
4000V
2700000pF 2.00±0.20 2.00±0.20 2.00±0.20
3900000pF 2.00±0.20 2.00±0.20 2.00±0.20
4700000pF 2.00±0.20 2.00±0.20 2.00±0.20
5600000pF 2.00±0.20 2.00±0.20 2.00±0.20
680000pF
8200000pF 2.50±0.30 2.50±0.30 2.50±0.30
10000000pF 2.50±0.30 2.50±0.30 2.50±0.30
12000000pF 2.80±0.30 2.80±0.30
15000000pF 2.80±0.30 2.80±0.30
18000000pF 2.80±0.30 2.80±0.30
22000000pF 2.80±0.30 2.80±0.30
0402
VDCW (MAX)
333
1500V
3300000pF 2.00±0.20 2.00±0.20 2.00±0.20
SIZE (INCHES)
393
1000V
2200000pF 2.00±0.20 2.00±0.20 2.00±0.20 2.50±0.30 2.50±0.30
X5R DIELECTRIC (0402, 0603, 0805)
273
6.3V
10V
0603
16V
25V
0.027μF
0.50±0.20
0.033μF
0.50±0.20
0.039μF
0.50±0.20
0.047μF
0.50±0.20
0.056μF
0.50±0.20 0.50±0.20
0.068μF
0.50±0.20 0.50±0.20
6.3V
10V
16V
0805
25V
50V
6.3V
10V
16V
25V
50V
0.082μF 0.50±0.20 0.50±0.20 0.50±0.20
0.10μF
0.15μF
0.22μF 0.50±0.20 0.50±0.20 0.50±0.20 0.50±0.20
0.80±0.30 0.80±0.30
0.27μF
0.80±0.30 0.80±0.30 0.80±0.30 0.80±0.30
0.33μF 0.50±0.20 0.50±0.20
0.39μF
0.47μF 0.50±0.20 0.50±0.20
0.68μF 0.50±0.20 0.50±0.20
0.82μF
1.0μF
1.5μF
0.80±0.30
1.25±0.30 1.25±0.30 1.25±0.30 1.25±0.30
2.2μF
3.3μF
0.80±0.30
4.7μF
0.80±0.30
1.25±0.30 1.25±0.30
Web: www.venkel.com
Rev: 04/2021-A
18
FTC
SERIES
X5R DIELECTRIC (1206, 1210)
SIZE (INCHES)
1206
274
334
394
474
684
824
105
155
225
335
475
685
106
VDCW (MAX)
224
6.3V
10V
16V
1210
25V
50V
6.3V
10V
16V
2.00±0.20
2.00±0.20
2.00±0.20
2.00±0.20
2.00±0.20
2.00±0.20
2.00±0.20
2.00±0.20
0.27μF
0.39μF
0.47μF
0.68μF
0.82μF
1.0μF
1.5μF
1.15±0.15
1.15±0.15
2.2μF
1.15±0.15
1.15±0.15
1.60±0.60
3.3μF
1.60±0.60
1.60±0.60
1.60±0.60
1.60±0.60
1.60±0.60
1.60±0.60
1.60±0.60
4.7μF
1.60±0.60
1.60±0.60
6.8μF
1.60±0.60
1.60±0.60
10μF
1.60±0.60
1.60±0.60
2.00±0.20
473
683
104
154
224
334
474
684
105
225
475
333
6.3V
2.00±0.20
0402
VDCW (MAX)
153
50V
0.33μF
SIZE (INCHES)
223
25V
0.22μF
Y5V DIELECTRIC (0402, 0603)
103
0603
10V
16V
25V
50V
10V
16V
25V
50V
0.010μF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.015μF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.022μF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.033μF
0.50±0.20
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.047μF
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.068μF
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.10μF
0.50±0.20
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.15μF
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.80±0.07
0.22μF
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.33μF
0.50±0.20
0.50±0.20
0.80±0.07
0.80±0.07
0.80±0.07
0.47μF
0.80±0.07
0.80±0.07
0.68μF
0.80±0.07
0.80±0.30
1.0μF
0.80±0.07
0.80±0.30
2.2μF
0.80±0.07
4.7μF
Web: www.venkel.com
Rev: 04/2021-A
19
FTC
SERIES
RELIABILITY TEST CONDITIONS & REQUIREMENTS
ITEM
1.
Visual and
Mechanical
2.
Capacitance
3.
Q/ D.F.
(Dissipation Factor)
TEST CONDITION
REQUIREMENTS
* No remarkable defect.
* Dimensions to conform to individual specification sheet.
Class I: (NP0)
C≤1000pF, 1.0±0.2Vrms, 1MHz±10%
C>1000pF, 1.0±0.2Vrms, 1KHz±10%
Class II: (X7R, X6S, X5R,X7S,Y5V)
C≤10μF, 1.0±0.2Vrms, 1KHz±10% **
C>10µF, 0.5±0.2Vrms, 120Hz±20%
** Test condition: 0.5±0.2Vrms, 1KHz±10%
X7R:
0805=106(6.3V), 0603/475(6.3V)
* Shall not exceed the limits given in the detailed spec.
NP0: Cap30pF, Q1000; Cap0.1µF;0603≥0.068µF;1206>1µF;1210≥2.2µF
≤10%
0805>0.22µF;1210≥3.3µF
≤3%
0201(50V);0603≥0.047µF;0805≥0.18µF;1206≥0.47µF
≤5%
0201≥0.01uF;1210≥4.7µF
≤10%
0402≥0.012µF;0603>0.1µF;0805≥1µF;1206≥2.2µF;
1210≥10µF
≤10%
0603≥1µF;0805≥2.2µF;1206≥2.2µF;1210≥10µF
≤5%
0201≥0.01µF;0805≥1µF;1210≥10µF
≤7%
0603≥0.33µF
≤10%
0201≥0.1µF;0402≥0.10µF&(0402/X7R≥0.056µF)
0603≥0.47µF;0805≥2.2µF;1206≥4.7µF;1210≥22µF
≤12.5%
16V
10V
≤5%
0201≥0.01µF;0402≥0.033µF;0603≥0.15µF;
0805≥0.68µF;1206≥2.2µF;1210≥4.7µF
≤10%
0201≥0.1uF(0201/X7R≥0.022µF);0402≥0.22uF
0603≥0.68µF;0805≥2.2µF;1206≥4.7µF;1210≥22µF
≤10%
0201≥0.012µF;0402≥0.33µF(0402/X7R≥0.22µF)
0603≥0.33µF;0805≥2.2µF;1206≥2.2µF;1210≥22µF;01R5
≤15%
0201≥0.1µF; 0402≥1µF
≤15%
0201≥0.1µF;0402≥1µF(0402/X6S≥0.47µF);0603≥10µF;
0805≥4.7µF;1206≥47µF;1210≥100µF
≤20%
0402≥2.2µF
≤3.5%
≤5%
6.3V
≤10%
4V
≤15%
0402≥0.47µF
_
X7R,X5R,X6S,X7S:
Rated
vol.
D.F.≤
≥50V
≤5%
35V
≤7%
25V
≤5%
16V
(C0.01µF;06031µF;08051µF;12064
.7µF;12104.7µF
35V:0805≥2.2µF;1206≥2.2µF;1210≥10µF
25V:0402≥1µF;0603≥2.2µF;0805≥2.2µF;
1206≥10µF; 1210≥10µF
10Gor 100Ω-F
whichever is smaller.
16V: 0201≥0.1µF,0402≥0.22µF;0603≥1µF;
0805≥2.2µF;1206≥10µF;1210≥47µF
10V:0201≥47nF;0402≥0.47µF;0603≥0.47µF;
0805≥2.2µF;1206≥4.7µF;1210≥47µF
6.3V ; 4V ; Size≥1812
RATED VOLTAGE
INSULATION RESISTANCE
All X6S items, All X7S items
100V: 1210≥3.3µF
50V: 0402≥0.1µF; 0603≥2.2µF;
0805≥10µF;1206≥10µF
35V: 0603≥1µF;
25V: 0201≥0.1µF; 0402≥2.2µF;0603≥10µF;
0805≥10µF;1206≥22µF
≥50Ω-F.
16V: 0603≥10µF; 0402≥1µF; 0201≥0.22µF
10V: 0201>0.1µF; 0402≥1µF; 0603≥10µF;
0805≥47µF
6.3V: 0201≥0.1µF; 0603>4.7µF;
0805≥47µF;1206≥10µF
4V:0603≥22µF; 0805≥47µF; 1206≥100µF
Rated voltage:
200~630V
To apply rated voltage (500V max.) for
60 sec.
Rated voltage:
>630V
To apply 500V for
60 sec.
10GΩ or 100Ω-F whichever is smaller
Web: www.venkel.com
Rev: 04/2021-A
21
FTC
SERIES
FLEX TERMINATION CAPACITORS
ITEM
6.
TEST CONDITION
Temperature
Coefficient
REQUIREMENTS
With no electrical load.
T.C.
T.C.
Capacitance Change
NP0
-55~125°C at 25°C
NP0
Within ±30ppm/°C
X7R
-55~125°C at 25°C
X7R
Within ±15%
X7S
-55~125°C at 25°C
X7S
Within ±22%
X5R
-55~85°C at 25°C
X5R
Within ±15%
X6S
-55~105°C at 25°C
X6S
Within ±22%
Y5V
-55~85°C at 25°C
Y5V
Within +30%/-80%
*Before initial measurement (Class II only):
To apply de-aging at 150°C for 1hr then set
for 24± 2 hrs at room temp.
* Measurement voltage for Class II:
01005
0201
Cap≤0.01µF: 0.5V
Cap0.01µF: 0.2V
0.1µF*≤Cap0.22µF;1210≥3.3µF
≤6%
0201(50V);0603≥0.047µF; 0805≥0.18µF; 1206≥0.47µF
≤10%
≤20%
0402≥0.012µF; 0603>0.1µF; 0805≥1µF; 1206≥2.2µF;
1210≥10µF
≤20%
0603≥1µF;0805 2.2F;1206≥2.2µF;1210≥10µF
≤10%
0201≥0.01µF;0805≥1µF; 1210≥10µF
≤14%
0603≥0.33µF
≤15%
X7R≥0.056µF);0603≥0.47µF;
≤20%
0402µ0.47µF
≤10%
0603≥0.15µF;0805≥0.68µF;1206≥2.2µF;1210≥4.7µF
≤15%
0201≥0.01µF(0201/X7R≥0.022µF);0402≥0.033µF;
0603≥0.68µF;0805≥2.2µF;1206≥4.7µF; 1210≥22µF
≤15%
0201≥0.012µF; 0402≥0.33µF(0402/X7R≥0.22µF);
0603≥0.33µF;0805≥2.2µF;1206≥2.2µF; 1210≥22µF
≤20%
0201≥0.1µF ;0402≥1µF; 01R5
0201≥0.1µF;0402≥1µF(0402/X6S≥0.47µF);0603V10µF;
6.3V
≤15%
≤30%
4V
≤20%
RATED
VOL.
D.F.≤
≥50V
≤7.5%
35V
≤10%
Y5V:
25V
≤7.5%
EXCEPTION OF D.F.≤
≤10%
0603≥0.1µF; 0805≥0.47µF;1206≥4.7µF
≤20%
1210≥6.8µF
≤10%
0402≥0.047µF;0603≥0.1µF;
0805≥0.33µF;1206≥1µF; 1210≥4.7µF
≤15%
0402≥0.068µF;0603≥0.47µF;1206≥4.7µF; 1210≥22µF
≤12.5%
0402≥0.068µF; 0603≥0.68µF
≤20%
0402≥0.22µF
16V
(C0.01µF;0603≥1µF;0805≥1µF;1206≥4.7µF;12
10≥4.7µF
35V:0603≥1µF;0805≥2.2µF; 1206≥2.2µF;1210≥10µF
25V:0201≥0.1uF; 0402≥0.22µF;
1206≥10µF;1210≥10µF
1GΩ OR 100Ω-F
16V: 0201≥0.1uF;0402≥0.22µF;0603≥1µF;0805≥2.2µF;
1206≥10µF;1210≥47µF
10V:0201≥47nF;0402≥0.47µF;0603≥0.47µF;0805≥2.
2µF;
6.3V ; 4V ; All X6S/X7S items; Size1812
14.
Humidity (Damp
Heat) Load
* Test temp.: 40±2°C
* No remarkable damage.
* Humidity: 90~95%RH
Cap change:
* Test time: 500+24/-0 hrs.
NP0: ±7.5% or 0.75pF whichever is larger.
*T
o apply voltage:
Rated voltage (MAX. 500V)
X7R, X5R, X6S, X7S: ≥10V**,within ±12.5%; ≤6.3V within ±25%;
C≥1uF,within ±25%
*B
for 24±2 hrs at room temp.
**10V: 0603≥4.7µF;0402≥1µF;0201≥0.1µF, within ±25%;
*C
ap. / DF(Q) / I.R. Measurement to be
made after de-aging at 150°C for 1hr then
set for 24±2 hrs at room temp.
NP0: C≥30pF,Q≥200;C0.1µF, 0603≥0.068µF, 1206>1µF;1210≥2.2µF
≤20%
≤6%
≤10%
≤20%
1210≥10µF
≤20%
0603≥1µF;08052.2F;1206≥2.2µF;1210≥10µF
≤10%
≤14%
0603≥0.33µF
≤15%
0201≥0.1µF;0402≥0.10µF&(0402/X7R≥0.056µF);
0603≥0.47µF;
≤20%
0402≥0.47µF
≤10%
≤15%
≤15%
≤20%
6.3V
≤15%
≤30%
4V
≤20%
Email: sales@venkel.com
Phone: 512.794.0081 |
Toll Free: 800.950.8365 |
Web: www.venkel.com
Rev: 04/2021-A
25
FTC
SERIES
ITEM
14.
TEST CONDITION
Humidity (Damp
Heat) Load
(continued)
REQUIREMENTS
Y5V:
*T
o apply voltage:
*B
RATED
VOL.
D.F.≤
≥50V
≤7.5%
35V
≤10%
25V
≤7.5%
*C
EXCEPTION OF D.F.≤
≤10%
≤20%
1210≥6.8µF
≤10%
≤15%
≤12.5%
≤20%
0402≥0.22µF
16V
10≥4.7µF
1206≥10µF;1210≥10µF
500MΩ or 100Ω-F
1206≥10µF;1210≥47µF
2µF;
6.3V ; 4V ; All X6S/X7S items; Size≥1812
Web: www.venkel.com
Rev: 04/2021-A
26
FTC
SERIES
ITEM
15.
High Temperature
Load (Endurance)
TEST CONDITION
REQUIREMENTS
*T
est temp.:
NP0, X7R/X7S: 125±3°C
X6S: 105±3°C
X5R, Y5V: 85±3°C
* Test time: 1000+24/-0 hrs.
X7R, X5R, X6S, X7S: 10V**,within ±12.5%; ≤6.3V within ±25%;
*T
o apply voltage:
(1) ≤6.3V or C≥10µF: 150% of rated voltage.
(2) 10V~250V: 200% of rated voltage.
(3) 400V~450V: 120% of rated voltage.
(4) 500V: 150% of rated voltage.
(5) 630V~3000V: 120% of rated voltage.
(6) 4000V: 110% of rated voltage
(7) 100% of rated voltage for below range.
**For life test items, using 1.0x working
or rated voltage, must follow de-rating
guidelines.
Cap change:
NP0: ±3.0% or ±0.3pF whichever is larger
C≥1uF,within ±25%
Y5V: 10V, within ±30%; ≤6.3V, within +30/-40%
Q/D.F. value:
NP0: More than 30pF, Q350
10pFC0.1µF,0603≥0.068µF,1206>1µF;1210≥2.2µF
≤20%
≤6%
≤10%
≤20%
1210≥10µF;
≤20%
≤10%
≤14%
0603≥0.33µF
≤15%
≤20%
402≥0.47µF
≤10%
≤15%
0603≥0.68µF;0805≥2.2µF;1206≥4.7µF; 1210≥22µF;
≤15%
≤20%
6.3V
≤15%
≤30%
4V
≤20%
Web: www.venkel.com
Rev: 04/2021-A
27
FTC
SERIES
ITEM
15.
TEST CONDITION
High Temperature
Load (Endurance)
(continued)
REQUIREMENTS
*T
est temp.:
X6S: 105±3°C
X5R, Y5V: 85±3°C
Y5V:
RATED
VOL.
D.F.≤
≥50V
≤7.5%
35V
≤10%
*T
o apply voltage:
(8)150% of rated voltage for below range.
Size
Dielectric
0201
0402
0603
Rated
voltage
Capacitance
range
X5R/X6S
16V,25V
C=0.1µF
X7R
16V
C≥0.022µF
X7R/X5R/
X6S
50V
C>0.1µF
10~25V
C≥0.22µF
Y5V
16V
C≥0.47µF
≤10%
≤20%
1210≥6.8µF
≤15%
≤12.5%
≤20%
0402≥0.22µF
≤7.5%
16V
10≥4.7µF
1206≥10µF;1210≥10µF
1GΩ or 50Ω-F
Whichever is smaller
1206≥10µF;1210≥47µF
2µF;
*B
efore initial measurement (Class II only): To
apply de-aging at 150°C for 1hr then set for
*C
ap. / DF(Q) / I.R. Measurement to be made
after de-aging at 150°C for 1hr then set for
Ratio [Operating Voltage / Rated Voltage (%)]
** De-rating conditions:
120
100
80
60
40
0 25 50 75 100 125
Temperature at Product (˚C)
Product for 125˚C
Product for 105˚C
Product for 85˚C
Web: www.venkel.com
Rev: 04/2021-A
28
FTC
SERIES
TAPE AND REEL SPECIFICATIONS
T
P0
P0
T
E
D0
E
A0
P2
P2
D0
F
F
W
5˚
B0
W
B0
D1
5˚
P1
A0
K0
P1
PAPER TAPE DIMENSIONS
SIZE
0402
0603
0805
Thickness
0.80±0.07
0.50±0.20
(mm)
0.80±0.30
PLASTIC TAPE DIMENSIONS
1206
1210
1.25±0.30
1.15±0.15
1.60±0.20
1.60±0.50
1808
1812
2220
0.95±0.10
1.25±0.10
1.25±0.10
1.25±0.10
2.50±0.50 1.60±0.20 1.60±0.20 2.50±0.50
1.60±0.20
2.00±0.20 2.00±0.20
2.00±0.20
1.40±0.15
1.60±0.20
2.00±0.20
2.50±0.50
A0
0.70±0.20
1.05±0.30
