SR1206FR-7W56KL
SR1206FR-7W56KL
    YAGEO(国巨)
    贴片电阻 1206 56KΩ ±1% 1/2W ±200ppm/℃
SR1206FR-7W56KL 数据手册
DATA SHEET SURGE CHIP RESISTORS SR series 1%, 0.5% sizes 0402/0603/0805/1206/1210/1218/2010/2512 Product specification – July 22, 2019 V.4 O RoHS compliant & Halogen free Product specification Chip Resistor Surface Mount SR 0402/0603/0805/1206/1210/1218/2010/2512 SERIES SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes SR0402 to SR2512 chip resistors with lead-free terminations made by thick film process. Part number is identified by the series name, size, tolerance, packaging type, temperature coefficient, taping reel and resistance value. APPLICATIONS  Telecommunications  Power supplies  Car electronics FEATURES  AEC-Q200 qualified  Superior to SR series in pulse withstanding voltage and surge withstanding voltage.  MSL class: MSL 1  Halogen free epoxy  RoHS compliant - Products with lead-free terminations meet RoHS requirements - Pb-glass contained in electrodes, resistor element and glass are exempted by RoHS  Reduce environmentally hazardous waste  High component and equipment reliability 2 9 GLOBAL PART NUMBER SR XXXX X X X XX XXXX L (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0402 / 0603 / 0805 / 1206 / 1210 / 1218 / 2010 / 2512 (2) TOLERANCE D = ± 0.5% F = ± 1% (3) PACKAGING TYPE R = Paper taping reel K = Embossed taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE – = Based on spec. (5) TAPING REEL & POWER 07 = 7 inch dia. Reel 7W = 7 inch dia. Reel & 2 x standard power 13 = 13 inch dia. Reel 7T = 7 inch dia. Reel & 3 x standard power 47 = 7 inch dia. Reel & 4 x standard power (6) RESISTANCE VALUE 1 Ω ≤ R ≤ 1M Ω There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point, no need to mention the last zero after R/K/M, e.g.1K2, not 1K20. Detailed coding rules of resistance are shown in the table of “Resistance rule of global part number”. (7) DEFAULT CODE Letter L is the system default code for ordering only. (Note) Resistance rule of global part number Resistance coding Example rule XRXX (1 to 9.76 Ω) 1R = 1 Ω 1R5 = 1.5 Ω 9R76 = 9.76 Ω XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω XXXR (100 to 976 Ω) 100R = 100 Ω XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω XXKX (10 to 97.6 KΩ) 10K = 10,000 Ω 97K6= 976,000 Ω XXXK (100 KΩ) 100K = 100,000 Ω O RDERING EXAMPLE The ordering code for an SR0805 chip resistor, value 10 KΩ with ± 5% tolerance, supplied in 7-inch tape reel is: SR0805JR-0710KL. www.yageo.com Jul. 22, 2019 V.4 Product specification Chip Resistor Surface Mount SR SERIES 0402/0603/0805/1206/1210/1218/2010/2512 3 9 MARKING SR0402 No Marking Fig. 1 SR1218 E-24 series: 3 digits First two digits for significant figure and 3rd digit for number of zeros Fig. 2 Value=10 KΩ SR0603 / SR0805 / SR1206 / SR1210 / SR2010 / SR2512 03 Fig. 3 E-24 series: 3 digits First two digits for significant figure and 3rd digit for number of zeros Value=10 KΩ NOTE For further marking information, please refer to data sheet “Chip resistors marking”. Table 1 TAPING REEL & POWER POWER, W (P70) TYPE CODING 07 7W 7T 47 0402 0603 1/16 1/8 1/5 - 1/10 1/5 1/4 - 0805 1/8 1/4 1/3 1/2 1206 1/4 1/2 3/4 1 1210 1218 1/2 1 - - 1 1.5 - - 2010 3/4 1.25 - - 2512 1 2 - - www.yageo.com Jul. 22, 2019 V.4 Product specification Chip Resistor Surface Mount SR SERIES 4 9 0402/0603/0805/1206/1210/1218/2010/2512 CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added at each end and connected by a resistive glaze. The resistive glaze is covered by a lead -free glass. The composition of the glaze is adjusted to give the approximately required resistance value. The whole element is covered by a protective overcoat. The top of overcoat is marked with the resistance value. Finally, the two external terminations (Ni/matte tin) are added, as shown in Fig.5. OUTLINES SR0402/0603/0805/1206/1210/1218/2010 SR2512 Fig. 5-1 Fig. 5-2 Chip resistor outlines Chip resistor outlines DIMENSIONS Table 2 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) SR0402 1.00± 0.05 0.50± 0.05 0.35± 0.05 0.20± 0.10 0.25± 0.10 SR0603 1.60± 0.10 0.80± 0.10 0.45± 0.10 0.25± 0.15 0.25± 0.15 SR0805 2.00± 0.10 1.25± 0.10 0.50± 0.10 0.35± 0.20 0.35± 0.20 SR1206 3.10± 0.10 1.60± 0.10 0.55± 0.10 0.45± 0.20 0.40± 0.20 SR1210 3.10± 0.10 2.60± 0.15 0.55± 0.10 0.45± 0.15 0.50± 0.20 SR1218 3.10± 0.10 4.60± 0.10 0.55± 0.10 0.45± 0.20 0.40± 0.20 SR2010 5.00± 0.10 2.50± 0.15 0.55± 0.10 0.55± 0.15 0.50± 0.20 SR2512 6.35± 0.10 3.10± 0.15 0.55± 0.10 0.60± 0.20 0.50± 0.20 For dimension, please refer to Table 1 SR0402 SR0603/0805/1206/ 1210/2010/2512 SR1218 Side view for all type Fig. 5 Chip resistor dimensions www.yageo.com Jul. 22, 2019 V.4 Product specification Chip Resistor Surface Mount SR SERIES 0402/0603/0805/1206/1210/1218/2010/2512 5 9 ELECTRICAL CHARACTERISTICS Table 3 TYPE POWER RESISTANCE RANGE Operating Temperature Range CHARACTERISTICS Max. Max. Dielectric Working Overload Withstanding Voltage Voltage Voltage Temperature Coefficient of Resistance 1/16W SR0402 1/8W 50 V 100 V 100 V 75V 150V 150V 150V 300V 300V 1/5W 1/10W SR0603 1/5W 1/4W 1/8 W SR0805 1/4W 1/3W 10Ω < R ≤ 1MΩ 1/2W 1/4 W SR1206 1/2W ± 100 ppm/°C E24/E96 0.5%, 1% 1 Ω ≤ R ≤ 1M Ω –55 °C to +155 °C 200 V 3/4W 400 V 500 V ± 200 ppm/°C 1W SR1210 1/2W 1W 1W SR1218 SR2010 1.5W 3/4W 1.25W 1W SR2512 1Ω ≤ R ≤ 10Ω 2W 200 V 400 V 500 V 200 V 400 V 500 V 200 V 400 V 500 V 200 V 400 V 500 V FOOTPRINT AND SOLDERING PROFILES Recommended footprint and soldering profiles, please refer to data sheet “Chip resistors mounting”. PACKING STYLE AND PACKAGING QUANTITY Table 4 Packing style and packaging quantity PACKING STYLE Paper taping reel (R) Embossed taping reel (K) REEL DIMENSION SR0402 SR0603/0805/1206 SR1210 SR1218/2010/2512 7" (178 mm) 10,000 5,000 5,000 --- 13" (330 mm) 50,000 20,000 20,000 --- 7" (178 mm) --- --- --- 4,000 NOTE 1. For paper/embossed tape and reel specification/dimensions, please refer to data sheet “Chip resistors packing”. TEMPERATURE COEFFICIENT OF RESISTANCE RESISTANCE RANGE PT040 2 100 mΩ to 910 mΩ ± 200 ppm/°C Jul. 22, 2019 V.4 PT060 ± 200 ppm/°C www.yageo.com Product specification Chip Resistor Surface Mount SR SERIES 0402/0603/0805/1206/1210/1218/2010/2512 6 9 FUNCTIONAL DESCRIPTION OPERATING TEMPERATURE RANGE Range: –55 °C to +155 °C POWER RATING Each type rated power at 70 °C: SR0402: 1/16W, 1/8W, 1/5W SR0603: 1/10W, 1/5W, 1/4W SR0805: 1/8W, 1/4W, 1/3W, 1/2W SR1206: 1/4W, 1/2W, 3/4W, 1W SR1210: 1/2W, 1W SR1218: 1W, 1.5W SR2010: 3/4W, 1.25W SR2512: 1W, 2W R ATED VOLTAGE The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V= Fig. 6 Maximum dissipation (P max ) in percentage of rated power as a function of the operating ambient temperature (T amb) (P X R) Where V = Continuous rated DC or AC (rms) working voltage (V) P = Rated power (W) R = Resistance value (Ω) PULSE LOAD BEHAVIOR Fig. 7 Pulse-Load behavior www.yageo.com Jul. 22, 2019 V.4 Product specification Chip Resistor Surface Mount SR SERIES 0402/0603/0805/1206/1210/1218/2010/2512 7 9 TESTS AND REQUIREMENTS Table 5 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE REQUIREMENTS Temperature Coefficient of Resistance (T.C.R.) MIL-STD-202 Method 304 At +25/–55 °C and +25/+125 °C Refer to table 2 Formula: R2–R1 T.C.R= ------------------------- × 106 (ppm/°C) R1(t2–t1) Where t1= +25 °C or specified room temperature t2= –55 °C or +125 °C test temperature R1=resistance at reference temperature in ohms R2=resistance at test temperature in ohms Short Time Overload IEC60115-1 4.13 2.5 times of rated voltage or maximum overload voltage whichever is less for 5 sec at room temperature ± (2.0%+0.05 Ω) High Temperature Exposure IEC 60068-2-2 1,000 hours at TA = 155 °C ± 5 °C, unpowered ± (2.0%+0.05 Ω) Humidity IEC 60115-1 4.24.2 Steady state for 1,000 hours at 40 °C / 95% R.H. ± (3.0%+0.05 Ω) RCWV applied for 1.5 hours on and 0.5 hour off Life Resistance to Soldering Heat IEC 60115-1 4.25.1 ± (2.0%+0.05 Ω) MIL-STD-202 Method 108 1,000 hours at 70± 2 °C, RCWV applied for 1.5 hours on, 0.5 hour off, still-air required IEC 60115-1 4.18 Condition B, no pre-heat of samples ± (1.0%+0.05 Ω) MIL-STD- 202 Method 210 Lead-free solder, 260± 5 °C, 10± 1 seconds immersion time No visible damage Procedure 2 for SMD: devices fluxed and cleaned with isopropanol Temperature Cycling JESD22-A104C -55/+125 °C for 1 cycle per hour, with 1,000 cycles. ± (1.0%+0.05 Ω) Devices mounted www.yageo.com Jul. 22, 2019 V.4 Product specification Chip Resistor Surface Mount TEST Solderability - Wetting SR SERIES 0402/0603/0805/1206/1210/1218/2010/2512 TEST METHOD PROCEDURE REQUIREMENTS J-STD-002 Electrical Test not required Magnification 50X Well tinned (≥95% covered) SMD conditions: No visible damage 8 9 Immerse the specimen into the solder pot at 245± 3°C for 2± 0.5 seconds. Board Flex IEC 60115-1 4.33 Chips mounted on a 90mm glass epoxy resin PCB (FR4) Bending for 0402: 5mm 0603 & 0805: 3mm 1206 and above: 2mm ± (1.0%+0.05 Ω) Holding time: minimum 60 seconds www.yageo.com Jul. 22, 2019 V.4 Product specification Chip Resistor Surface Mount SR SERIES 0402/0603/0805/1206/1210/1218/2010/2512 9 9 REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 4 Jul. 22, 2019 - - Update power rating - Extend resistance range of 0402 ~ 2512 to 1Mohm Version 3 Sep. 27, 2018 - - Tighten TCR of all sizes for for 10Ω < R ≤ 1MΩ from ± 200 ppm/°C to ± 100 ppm/°C - Add SR1210, SR1218, SR2010 7W (double power) - Add SR0402 7T (triple power), SR0805 47 (quadruple power), SR2512 7W (double power) Version 2 Oct. 02, 2017 - Version 1 Nov. 11, 2016 - - Update 7T power for 1206 Version 0 Dec. 01, 2015 - - New product datasheet “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products are unchanged. Any product change will be announced by PCN.” "The reimbursement is limited to the value of the products." www.yageo.com Jul. 22, 2019 V.4
SR1206FR-7W56KL AI解析
物料型号:YAGEO Phicomp SR系列,尺寸包括0402/0603/0805/1206/1210/1218/2010/2512。
器件简介:这些电阻采用无铅端接,通过厚膜工艺制造,符合RoHS标准,无卤素环氧树脂。
引脚分配:文档中没有提供具体的引脚分配图,但通常贴片电阻为两个端点。
参数特性: - 公差:±0.5%和±1% - 温度系数:基于规格书 - 额定功率:根据尺寸不同,从1/16W到2W不等 - 最大工作电压和过载电压:根据尺寸和功率不同而变化
功能详解: - 符合AEC-Q200标准 - 在脉冲电压和浪涌电压方面优于SR系列 - 湿度敏感等级:MSL 1
应用信息: - 适用于通信、电源、汽车电子等领域
封装信息: - 提供纸带卷装和压花卷装 - 包装尺寸和数量根据尺寸不同而有所变化
电气特性包括工作温度范围、最大工作电压、最大过载电压、介质耐压、电阻温度系数等。
测试和要求包括温度系数、短时间过载、高温暴露、湿度、寿命、耐焊接热、温度循环、润湿性、板弯曲等测试。
*介绍内容由AI识别生成
SR1206FR-7W56KL 价格&库存
很抱歉,暂时无法提供与“SR1206FR-7W56KL”相匹配的价格&库存,您可以联系我们找货
SR1206FR-7W56KL
  • 1+5.196431+0.62657
  • 10+2.9799110+0.35931
  • 50+2.1408150+0.25814
  • 100+1.87850100+0.22651
  • 500+1.43959500+0.17359
  • 1000+1.300801000+0.15685
库存:1902
SR1206FR-7W56KL
    • 5000+0.145795000+0.01758
    • 15000+0.1451115000+0.01750
    • 50000+0.1451050000+0.01750
    • 100000+0.14510100000+0.01750
    • 200000+0.14510200000+0.01750
    库存:5000
    SR1206FR-7W56KL
    • 5000+1.286565000+0.15513
    库存:1902
