UHV Series
Stackpole Electronics, Inc.
Ultra-High Voltage Chip Resistor
Resistive Product Solutions
Features:
Voltage ratings to 20000 Volts
Resistance values to 10 Gohms
Ultra-high stability
Very low noise
Tolerances to 1%
Tolerances 10% and wider are typically untrimmed
TCR to 100 ppm/ºC
RoHS compliant and halogen free
REACH compliant
Electrical Specifications
Ohmic Range (Ω) and Tolerance
1%, 2%, 5%, 10%, 20%
3000
100 M - 158 M
100
UHV2010
4000
162 M - 357 M
200
6000
365 M - 10 G
4000
121 M - 249 M
100
6000
255 M - 442 M
UHV2512
200
8000
453 M - 698 M
10000
715 M - 10 G
4000
100 M - 196 M
6000
200 M - 324 M
100
8000
332 M - 523 M
UHV3512
200
10000
536 M - 732 M
12000
750 M - 976 M
14000
1 G - 10 G
6000
150 M - 249 M
8000
255 M - 392 M
100
10000
402 M - 562 M
UHV4020
200
12000
576 M - 768 M
14000
787 M - 976 M
16000
1 G - 10 G
6000
100 M - 158 M
8000
162 M - 249 M
10000
255 M - 357 M
100
UHV5020
12000
365 M - 487 M
200
14000
499 M - 634 M
16000
649 M - 976 M
20000
1 G - 10 G
Due to the high resistance values offered, the power rating for a given size and resistance value should be calculated by V2/R.
Because of the high voltage ratings, these resistors should be potted to ensure terminal isolation.
Type / Code
TCR (ppm/ºC)
Maximum Working Voltage (V)
Mechanical Specifications
Type / Code
UHV2010
UHV2512
L
Body Length
0.200 ± 0.010
5.08 ± 0.25
W
Body Width
0.100 ± 0.005
2.54 ± 0.13
Thickness
(Max.)
0.030
0.76
DT
Top Termination
0.018 ± 0.010
0.46 ± 0.25
DB
Bottom Termination
0.020 ± 0.010
0.51 ± 0.25
inches
mm
0.250 ± 0.010
6.35 ± 0.25
0.125 ± 0.005
3.18 ± 0.13
0.030
0.76
0.020 ± 0.010
0.51 ± 0.25
0.024 ± 0.010
0.61 ± 0.25
inches
mm
Rev Date: 11/18/2020
This specification may be changed at any time without prior notice
Please confirm technical specifications before you order and/or use.
1
Unit
www.seielect.com
marketing@seielect.com
UHV Series
Mechanical Specifications (cont.)
Type / Code
UHV3512
UHV4020
UHV5020
L
Body Length
0.350 ± 0.010
8.89 ± 0.25
0.400 ± 0.010
10.16 ± 0.25
W
Body Width
0.125 ± 0.005
3.18 ± 0.13
0.200 ± 0.005
5.08 ± 0.13
Thickness
(Max.)
0.030
0.76
0.030
0.76
DT
Top Termination
0.020 ± 0.010
0.51 ± 0.25
0.025 ± 0.010
0.64 ± 0.25
DB
Bottom Termination
0.024 ± 0.010
0.61 ± 0.25
0.030 ± 0.010
0.76 ± 0.25
inches
mm
inches
mm
0.500 ± 0.010
12.70 ± 0.25
0.200 ± 0.005
5.08 ± 0.13
0.030
0.76
0.030 ± 0.010
0.76 ± 0.25
0.030 ± 0.010
0.76 ± 0.25
inches
mm
Unit
Performance Characteristics
Test
Typical Performance
Short Time Overload
Load Life
Temperature Cycle
Moisture Resistance
Shock
Vibration
Dielectric Withstanding Voltage
Resistance to Soldering Heat
Parameter
0.5%
0.5%
0.5%
0.5%
0.25%
0.25%
0.25%
0.25%
Typical
TCR
Pulse Capability
Measured from 25°C to 75°C
Consult Stackpole for pulse applications
Measured at 100V
Consult Stackpole for custom test voltages
Resistance Value
Operating temperature range is -55ºC to +150ºC
Load Life
2
www.seielect.com
UHV Series
VCR Curves
Recommended Solder Profile
This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should
be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board
density, geometry, packages used, etc., especially those cells labeled with “*”.
100% Matte Tin / RoHS Compliant Terminations
Soldering iron recommended temperatures: 330°C to 350°C with minimum duration.
Maximum number of reflow cycles: 3.
Wave Soldering
Description
Maximum
Recommended
Preheat Time
80 seconds
70 seconds
Temperature Diff.
140°C
120°C
Solder Temp.
260°C
250°C
Dwell Time at Max.
10 seconds
5 seconds
Ramp DN (°C/sec)
N/A
N/A
Temperature Diff. = Defference between final preheat stage and soldering stage.
3
Minimum
60 seconds
100°C
240°C
N/A
www.seielect.com
UHV Series
Convection IR Reflow
Description
Maximum
Recommended
Minimum
Ramp Up (°C/sec)
Dwell Time > 217°C
Solder Temp.
Dwell Time at Max.
Ramp DN (°C/sec)
3°C/sec
150 seconds
260°C
30 seconds
6°C/sec
2°C/sec
90 seconds
245°C
15 seconds
3°C/sec
60 seconds
10 seconds
Recommended Lead Free Resistor Reflow Profile
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
Description
Package /
Standard
Termination Series RoHS
Type
Compliant
UHV
SMD
Note (1): RoHS compliant by means of exemption 7c-I.
YES(1)
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
100% Matte Sn over Ni
Always
Always
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
4
www.seielect.com
UHV Series
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
U
H
V
B
3
5
1
2
F
K
D
5
M
Product Series
Solderable wraparound
(matte tin Sn99.9
UHVB
on nickel barrier)
RoHS Compliant
(Sn63Pb37 solder over
UHVS
nickel barrier)
Not RoHS Compliant
Size
Tolerance
2010 Code Tol
2512
F
1%
3512
G
2%
4020
J
5%
5020
K
10%
M
20%
Code
T
K
D
C
Packaging
TCR
Description
Size Quantity Code ppm
Tape and Reel
2010
4000
D
100
Plastic Tape
2512
2000
L
200
Tape and Reel
All Sizes 1000
Plastic Tape
Tape and Reel
All Sizes 500
Plastic Tape
Tape and Reel
All Sizes 250
Plastic Tape
5
Resistance Value
Four characters with the
multiplier used as the
decimal holder.
90 Mohm = 90M0
250 Mohm = 250M
1 Gohm = 1G00
www.seielect.com
很抱歉,暂时无法提供与“UHVB3512FCD2G00”相匹配的价格&库存,您可以联系我们找货
