KTD101B105M32A0T00
KTD101B105M32A0T00
    NCC(贵弥功)
    插件
    贴片电容(MLCC) 径向 1µF ±20% 100V X7R
KTD101B105M32A0T00 数据手册
DIPPED RADIAL LEAD MULTILAYER CERAMIC CAPACITORS NTD Series RoHS2 RoHS Compliant ◆FEATURES 1. Small in size and wide capacitance range. Max. 470µF is available. 2. Temperature characteristic is X7R in EIA code. 3. Superior humidity characteristic and long life. 4. Excellent high frequency characteristic due to low ESR. 5. High rated ripple current. 6. 250Vdc items are available. 7. Resin(UL94 V-0) used for coating. 8. Pb-free design(also ceramic dielectric) ◆APPLICATIONS 1. Smoothing circuit of switching mode AC-DC or DC-DC converter. 2. Noise suppressor for various kinds of equipments. 3. By-pass or decoupling circuits. 4. Automotive equipments. ◆CONSTRUCTION Coating Resin Ceramic Dielectric Termination Solder (Pb-free) Internal Electrode Lead Wire ◆RATINGS 1. 2. 3. 4. 5. 6. Category Temperature Range Rated Voltage Range Rated Capacitance Range Rated Capacitance Tolerance Temperature Characteristics Rated Ripple Current -55 to +125℃ 25, 35, 50, 100, 250, 500Vdc 0.1 to 470µF M(±20%) X7R See No.5 on the following table ◆SPECIFICATIONS No. 1 Items Withstand Voltage Between Terminals Specification No abnormality. Terminals to Coating Resin Test Condition Rated voltage Withstand voltage Less than 250V 250% of rated voltage More than 250V Less than 500V 100V + 150% of rated voltage More than 500V 130% of rated voltage Shall be applied for 5 seconds. 2 Insulation Resistance 100/CR(MΩ) or 4000(MΩ) whichever is less. 3 Rated Capacitance Within specified tolerance. Rated voltage shall be applied for 60±5 seconds at temperature 25±2℃. Temperature 4 Dissipation Factor CR>10µF CR≦10µF 5.0% maximum. 25±2℃ Frequency 1±0.1kHz 120±12Hz Voltage 1±0.2Vrms 0.5±0.2Vrms As customer requirement, Chemi-Con has submits the test results according to AEC-Q200 for Multilayer ceramic capacitors. Please contact us for more information. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 28 CAT. No. E1002Z DIPPED RADIAL LEAD MULTILAYER CERAMIC CAPACITORS NTD Series ◆SPECIFICATIONS No. Items Specification Test Condition 5 Rated Ripple Current See STANDARD RATINGS 10kHz to 1MHz (sine curve) Ripple voltage Vp shall be less than the rated voltage. 6 Robustness Tension of Terminations No visible damage. The force applied shall be : Bending Lead φ (mm) 0.5 max. 0.6 min. Tensile(N) 5 10 Lead φ (mm) Bending(N) 0.5 max. 0.6 min. (sec.) 10±1 10±1 (kg) 2.5 5 0.25 0.51 Time : 2times. 7 Vibration Appearance : No abnormality. Capacitance : To meet the initial specification. D.F. : To meet the initial specification. 8 Solderability Min. 75% of surface of the termination shall be covered with new solder. 9 Resistance to Soldering Heat 10 Temperature Cycle 11 Humidity Load Life Appearance : No abnormality. ΔC/C :±20% D.F. : 10% maximum I.R. : 25/CR(MΩ) or 1000(MΩ) whichever is less. Temperature : 40±2℃ Humidity : 90 to 95%RH Voltage : Rated voltage Time : 500± 24 hours 0 12 Endurance Appearance : No abnormality. ΔC/C :±20% D.F. : 10% maximum I.R. : 50/CR(MΩ) or 1000(MΩ) whichever is less. Temperature : 125±3℃ Voltage : Rated voltage Time : 1000± 48 0 hours Amplitude : 1.5mm Frequency range : 10-55-10Hz (1 min) Direction and time : 2 hours each to X, Y, Z axis. Total 6 hours. Solder Solder Temperature Dipping Time Pb Free 245±5℃ 2±0.5sec. Appearance : No abnormality. ΔC/C :±15% D.F. : To meet the initial specification. I.R. : To meet the initial specification. Solder Temperature : 350±10℃ Dipping Time : 3±0.5 sec. Depth : 1.5 to 2mm Appearance : No abnormality. ΔC/C :±15% D.F. : To meet the initial specification. I.R. : To meet the initial specification. Temperature (℃) Step Min. Category temperature ±3 1 Room temperature 2 3 Max. Category temperature ±3 4 Room temperature For 5 cycles for above temperature cycle. (min.) 30±3 3 max. 30±3 3 max. *CR : Rated Capacitance(µF) Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 29 CAT. No. E1002Z DIPPED RADIAL LEAD MULTILAYER CERAMIC CAPACITORS NTD Series ◆STANDARD RATINGS Rated voltage Rated Capacitance (Vdc) (µF) 25 35 50 100 3.3 4.7 6.8 10 15 15 22 33 47 68 100 150 220 330 470 3.3 4.7 6.8 10 15 22 33 47 1.0 1.5 2.2 3.3 4.7 6.8 10 15 22 33 47 68 100 150 220 0.33 0.47 0.68 1.0 1.5 2.2 1.5 2.2 3.3 4.7 3.3 4.7 6.8 6.8 10 15 22 33 47 68 100 Lmax. Wmax. Tmax. F±0.8 φd±0.05 Maximum ripple current (Arms) 5.0 6.0 3.5 5.0 0.5 0.3 6.5 6.5 4.0 5.0 0.5 0.8 7.5 9.0 4.5 5.0 0.5 1.0 10.0 11.5 13.5 15.0 22.5 20.0 28.5 20.0 5.5 6.0 8.0 6.0 8.0 8.0 11.5 5.0 6.0 6.5 7.5 Dimensions (mm) 5.0 0.5 1.5 10.0 0.6 2.0 20.0 0.8 3.0 25.0 0.8 4.0 3.5 5.0 0.5 0.3 6.5 4.0 5.0 0.5 0.8 9.0 4.5 5.0 0.5 1.0 10.0 11.5 5.0 5.5 5.0 0.5 1.5 5.0 6.0 3.5 5.0 0.5 0.3 6.5 6.5 4.0 5.0 0.5 0.8 7.5 9.0 4.5 5.0 0.5 1.0 10.0 13.5 11.5 15.0 5.0 5.5 5.0 10.0 0.5 0.6 1.5 2.0 22.5 20.0 20.0 0.8 3.0 28.5 20.0 25.0 0.8 4.0 5.0 6.0 3.5 5.0 0.5 0.3 6.5 6.5 4.0 5.0 0.5 0.8 7.5 9.0 5.0 0.5 1.0 10.0 11.5 5.0 0.5 1.5 13.5 15.0 10.0 0.6 2.0 22.5 20.0 20.0 0.8 3.0 28.5 20.0 25.0 0.8 4.0 6.0 7.0 7.5 10.0 4.5 4.7 5.0 5.0 6.0 6.0 7.5 9.0 Part Number Taping Quantity per reel (pcs. / box) KTD250B335M32A0T00 KTD250B475M32A0T00 KTD250B685M43A0T00 KTD250B106M43A0T00 KTD250B156M43A0T00 KTD250B156M55A0T00 KTD250B226M55A0T00 KTD250B336M55A0T00 KTD250B476M76A0T00 KTD250B686M80A0B00 KTD250B107M80A0B00 KTD250B157M90A0B00 KTD250B227M90A0B00 KTD250B337M99A0B00 KTD250B477M99A0B00 KTD350B335M32A0T00 KTD350B475M32A0T00 KTD350B685M43A0T00 KTD350B106M43A0T00 KTD350B156M55A0T00 KTD350B226M55A0T00 KTD350B336M76A0T00 KTD350B476M76A0T00 KTD500B105M32A0T00 KTD500B155M32A0T00 KTD500B225M32A0T00 KTD500B335M32A0T00 KTD500B475M43A0T00 KTD500B685M43A0T00 KTD500B106M55A0T00 KTD500B156M55A0T00 KTD500B226M76A0T00 KTD500B336M80A0B00 KTD500B476M90A0B00 KTD500B686M90A0B00 KTD500B107M90A0B00 KTD500B157M99A0B00 KTD500B227M99A0B00 KTD101B334M32A0T00 KTD101B474M32A0T00 KTD101B684M32A0T00 KTD101B105M32A0T00 KTD101B155M32A0T00 KTD101B225M32A0T00 KTD101B155M43A0T00 KTD101B225M43A0T00 KTD101B335M43A0T00 KTD101B475M43A0T00 KTD101B335M55A0T00 KTD101B475M55A0T00 KTD101B685M55A0T00 KTD101B685M76A0T00 KTD101B106M80A0B00 KTD101B156M80A0B00 KTD101B226M90A0B00 KTD101B336M90A0B00 KTD101B476M99A0B00 KTD101B686M99A0B00 KTD101B107M99A0B00 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 1,000 - - - - - - 2,000 2,000 2,000 2,000 2,000 2,000 1,000 1,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 1,000 - - - - - - 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 1,000 - - - - - - - Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 30 CAT. No. E1002Z 1.5 2.2 1.5 2.2 3.3 4.7 3.3 4.7 6.8 6.8 10 15 22 Series 33 47 68 100 0.1 0.15 0.22 0.33 0.47 0.68 1.0 1.5 2.2 2.2 3.3 4.7 6.8 10 15 0.47 0.56 0.68 1.0 1.2 DIPPED RADIAL LEAD4.5 MULTILAYER CERAMIC CAPACITORS 7.5 9.0 5.0 1.0 0.5 NTD 250 500 10.0 11.5 13.5 15.0 22.5 20.0 28.5 20.0 5.0 6.0 6.5 6.5 4.7 5.0 5.0 6.0 5.0 0.5 1.5 10.0 0.6 2.0 20.0 0.8 3.0 25.0 0.8 4.0 3.5 5.0 0.5 0.3 4.0 5.0 0.5 0.8 6.0 7.5 9.0 7.5 9.0 4.5 5.0 0.5 1.0 10.0 13.5 11.5 15.0 6.0 5.0 5.0 10.0 0.5 0.6 1.5 2.0 22.5 20.0 6.0 20.0 0.8 3.0 28.5 20.0 7.5 25.0 0.8 4.0 7.5 9.0 3.5 5.0 0.5 0.8 11.5 3.4 3.8 4.2 5.0 0.5 1.0 10.0 ※Please consult with us when you consider the rating other than a standard table. 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ◆DIMENSIONS 16 Crimped lead 32 to 76 Size 17 18 K TD 5 0 0 B 1 0 6 M 5 5 A0 T 0 0 L T W L F 15min. Supplement code Taping code Terminal code Size code Capacitance tolerance code Nominal Capacitance code Temperature characteristics code Rated voltage code Series code Category Straight lead For all size 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 1,000 - - - - - - - 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 1,000 - - - - - - 2,000 2,000 1,500 1,500 1,500 T W ◆PART NUMBERING SYSTEM F d 15min. 100 1 KTD101B155M32A0T00 KTD101B225M32A0T00 KTD101B155M43A0T00 KTD101B225M43A0T00 KTD101B335M43A0T00 KTD101B475M43A0T00 KTD101B335M55A0T00 KTD101B475M55A0T00 KTD101B685M55A0T00 KTD101B685M76A0T00 KTD101B106M80A0B00 KTD101B156M80A0B00 KTD101B226M90A0B00 KTD101B336M90A0B00 KTD101B476M99A0B00 KTD101B686M99A0B00 KTD101B107M99A0B00 KTD251B104M32A0T00 KTD251B154M32A0T00 KTD251B224M32A0T00 KTD251B334M32A0T00 KTD251B474M43A0T00 KTD251B684M43A0T00 KTD251B105M55A0T00 KTD251B155M55A0T00 KTD251B225M76A0T00 KTD251B225M80A0B00 KTD251B335M90A0B00 KTD251B475M90A0B00 KTD251B685M99A0B00 KTD251B106M99A0B00 KTD251B156M99A0B00 KTD501B474M55A0T00 KTD501B564M55A0T00 KTD501B684M76A0T00 KTD501B105M76A0T00 KTD501B125M76A0T00 d Please refer to"Part Numbering System" of the beginning of a catalog for the details. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 31 CAT. No. E1002Z
KTD101B105M32A0T00 价格&库存
很抱歉,暂时无法提供与“KTD101B105M32A0T00”相匹配的价格&库存,您可以联系我们找货
