KTD500B105M32A0T00
KTD500B105M32A0T00
    NCC(贵弥功)
    插件
    1 µF ±20% 50V 陶瓷电容器 X7R 径向
KTD500B105M32A0T00 数据手册
DIPPED RADIAL LEAD MULTILAYER CERAMIC CAPACITORS NTD Series RoHS2 RoHS Compliant ◆FEATURES 1. Small in size and wide capacitance range. Max. 470µF is available. 2. Temperature characteristic is X7R in EIA code. 3. Superior humidity characteristic and long life. 4. Excellent high frequency characteristic due to low ESR. 5. High rated ripple current. 6. 500Vdc items are available. 7. Resin(UL94 V-0) used for coating. 8. Pb-free design(also ceramic dielectric) ◆APPLICATIONS 1. Smoothing circuit of switching mode AC-DC or DC-DC converter. 2. Noise suppressor for various kinds of equipments. 3. By-pass or decoupling circuits. 4. Automotive equipments. ◆CONSTRUCTION Coating Resin Ceramic Dielectric Termination Solder (Pb-free) Internal Electrode Lead Wire ◆RATINGS 1. 2. 3. 4. 5. 6. Category Temperature Range Rated Voltage Range Rated Capacitance Range Rated Capacitance Tolerance Temperature Characteristics Rated Ripple Current -55 to +125℃ 25, 35, 50, 100, 250, 500Vdc 0.1 to 470µF M(±20%), K(±10%) X7R See No.5 on the following table ◆SPECIFICATIONS No. 1 Items Withstand Voltage Between Terminals Specification No abnormality. Terminals to Coating Resin Test Condition Rated voltage Withstand voltage Less than 250V 250% of rated voltage More than 250V Less than 500V 100V + 150% of rated voltage More than 500V 130% of rated voltage Shall be applied for 5 seconds. 2 Insulation Resistance 100/CR(MΩ) or 4000(MΩ) whichever is less. 3 Rated Capacitance Within specified tolerance. Rated voltage shall be applied for 60±5 seconds at temperature 25±2℃. CR>10µF CR≦10µF Temperature 4 Dissipation Factor 5.0% maximum. 25±2℃ Frequency 1±0.1kHz 120±12Hz Voltage 1±0.2Vrms 0.5±0.2Vrms As customer requirement, Chemi-Con has submits the test results according to AEC-Q200 for Multilayer ceramic capacitors. Please contact us for more information. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 28 CAT. No. E1002C 2023 DIPPED RADIAL LEAD MULTILAYER CERAMIC CAPACITORS NTD Series ◆SPECIFICATIONS No. Items Specification Test Condition 5 Rated Ripple Current See STANDARD RATINGS 10kHz to 1MHz (sine curve) Ripple voltage Vp shall be less than the rated voltage. 6 Robustness Tension of Terminations No visible damage. The force applied shall be : Bending Lead φ (mm) 0.5 max. 0.6 min. Tensile(N) 5 10 Lead φ (mm) Bending(N) 0.5 max. 0.6 min. (sec.) 10±1 10±1 (kg) 2.5 5 0.25 0.51 Time : 2times. 7 Vibration Appearance : No abnormality. Capacitance : To meet the initial specification. D.F. : To meet the initial specification. 8 Solderability Min. 75% of surface of the termination shall be covered with new solder. 9 Resistance to Soldering Heat 10 Temperature Cycle 11 Humidity Load Life Appearance : No abnormality. ΔC/C :±20% D.F. : 10% maximum I.R. : 25/CR(MΩ) or 1000(MΩ) whichever is less. Temperature : 40±2℃ Humidity : 90 to 95%RH Voltage : Rated voltage Time : 500± 24 hours 0 12 Endurance Appearance : No abnormality. ΔC/C :±20% D.F. : 10% maximum I.R. : 50/CR(MΩ) or 1000(MΩ) whichever is less. Temperature : 125±3℃ Voltage : Rated voltage Time : 1000± 48 0 hours Amplitude : 1.5mm Frequency range : 10-55-10Hz (1 min) Direction and time : 2 hours each to X, Y, Z axis. Total 6 hours. Solder Solder Temperature Dipping Time Pb Free 245±5℃ 2±0.5sec. Appearance : No abnormality. ΔC/C :±15% D.F. : To meet the initial specification. I.R. : To meet the initial specification. Solder Temperature : 350±10℃ Dipping Time : 3±0.5 sec. Depth : 1.5 to 2mm Appearance : No abnormality. ΔC/C :±15% D.F. : To meet the initial specification. I.R. : To meet the initial specification. Temperature (℃) Step Min. Category temperature ±3 1 Room temperature 2 3 Max. Category temperature ±3 4 Room temperature For 5 cycles for above temperature cycle. (min.) 30±3 3 max. 30±3 3 max. *CR : Rated Capacitance(µF) Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 29 CAT. No. E1002C 2023 DIPPED RADIAL LEAD MULTILAYER CERAMIC CAPACITORS NTD Series ◆STANDARD RATINGS Rated voltage (Vdc) 25 35 50 100 Rated Capacitance (μF) 3.3 4.7 6.8 10 15 15 22 33 47 68 100 150 220 330 470 3.3 4.7 6.8 10 15 22 33 47 1.0 1.5 2.2 3.3 4.7 6.8 10 15 22 33 47 68 100 150 220 0.33 0.47 0.68 1.0 1.5 2.2 1.5 2.2 3.3 4.7 3.3 4.7 6.8 6.8 10 15 22 33 47 68 100 Electrostatic Capacitance Temperature Characteristics X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R L max. W max. T max. F±0.8 φd±0.05 Maximum ripple current (Arms) 5.0 5.0 6.5 6.5 6.5 7.5 7.5 7.5 10.0 13.5 13.5 22.5 22.5 28.5 28.5 5.0 5.0 6.5 6.5 7.5 7.5 10.0 10.0 5.0 5.0 5.0 5.0 6.5 6.5 7.5 7.5 10.0 13.5 22.5 22.5 22.5 28.5 28.5 5.0 5.0 5.0 5.0 5.0 5.0 6.5 6.5 6.5 6.5 7.5 7.5 7.5 10.0 13.5 13.5 22.5 22.5 28.5 28.5 28.5 6.0 6.0 6.5 6.5 6.5 9.0 9.0 9.0 11.5 15.0 15.0 20.0 20.0 20.0 20.0 6.0 6.0 6.5 6.5 9.0 9.0 11.5 11.5 6.0 6.0 6.0 6.0 6.5 6.5 9.0 9.0 11.5 15.0 20.0 20.0 20.0 20.0 20.0 6.0 6.0 6.0 6.0 6.0 6.0 6.5 6.5 6.5 6.5 9.0 9.0 9.0 11.5 15.0 15.0 20.0 20.0 20.0 20.0 20.0 3.5 3.5 4.0 4.0 4.0 4.5 4.5 4.5 5.5 6.0 8.0 6.0 8.0 8.0 11.5 3.5 3.5 4.0 4.0 4.5 4.5 5.0 5.5 3.5 3.5 3.5 3.5 4.0 4.0 4.5 4.5 5.0 5.5 6.0 6.0 6.0 7.5 10.0 3.5 3.5 3.5 3.5 3.5 3.5 4.0 4.0 4.0 4.0 4.5 4.5 4.7 5.0 5.0 6.0 6.0 6.0 7.5 7.5 9.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 10.0 10.0 20.0 20.0 25.0 25.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 10.0 20.0 20.0 20.0 25.0 25.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 10.0 10.0 20.0 20.0 25.0 25.0 25.0 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.6 0.6 0.8 0.8 0.8 0.8 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.6 0.8 0.8 0.8 0.8 0.8 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.6 0.6 0.8 0.8 0.8 0.8 0.8 0.3 0.3 0.8 0.8 0.8 1.0 1.0 1.0 1.5 2.0 2.0 3.0 3.0 4.0 4.0 0.3 0.3 0.8 0.8 1.0 1.0 1.5 1.5 0.3 0.3 0.3 0.3 0.8 0.8 1.0 1.0 1.5 2.0 3.0 3.0 3.0 4.0 4.0 0.3 0.3 0.3 0.3 0.3 0.3 0.8 0.8 0.8 0.8 1.0 1.0 1.0 1.5 2.0 2.0 3.0 3.0 4.0 4.0 4.0 Dimensions(mm) Part Number KTD250B335□32A0T00 KTD250B475□32A0T00 KTD250B685□43A0T00 KTD250B106□43A0T00 KTD250B156□43A0T00 KTD250B156□55A0T00 KTD250B226□55A0T00 KTD250B336□55A0T00 KTD250B476□76A0T00 KTD250B686M80A0B00 KTD250B107M80A0B00 KTD250B157M90A0B00 KTD250B227M90A0B00 KTD250B337M99A0B00 KTD250B477M99A0B00 KTD350B335□32A0T00 KTD350B475□32A0T00 KTD350B685□43A0T00 KTD350B106□43A0T00 KTD350B156□55A0T00 KTD350B226□55A0T00 KTD350B336□76A0T00 KTD350B476□76A0T00 KTD500B105□32A0T00 KTD500B155□32A0T00 KTD500B225□32A0T00 KTD500B335□32A0T00 KTD500B475□43A0T00 KTD500B685□43A0T00 KTD500B106□55A0T00 KTD500B156□55A0T00 KTD500B226□76A0T00 KTD500B336M80A0B00 KTD500B476M90A0B00 KTD500B686M90A0B00 KTD500B107M90A0B00 KTD500B157M99A0B00 KTD500B227M99A0B00 KTD101B334□32A0T00 KTD101B474□32A0T00 KTD101B684□32A0T00 KTD101B105□32A0T00 KTD101B155□32A0T00 KTD101B225□32A0T00 KTD101B155□43A0T00 KTD101B225□43A0T00 KTD101B335□43A0T00 KTD101B475□43A0T00 KTD101B335□55A0T00 KTD101B475□55A0T00 KTD101B685□55A0T00 KTD101B685□76A0T00 KTD101B106M80A0B00 KTD101B156M80A0B00 KTD101B226M90A0B00 KTD101B336M90A0B00 KTD101B476M99A0B00 KTD101B686M99A0B00 KTD101B107M99A0B00 Taping Quantity per reel (pcs. / reel) 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 1,000 - - - - - - 2,000 2,000 2,000 2,000 2,000 2,000 1,000 1,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 1,500 - - - - - - 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 1,500 - - - - - - - Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 30 CAT. No. E1002C 2023 DIPPED RADIAL LEAD MULTILAYER CERAMIC CAPACITORS NTD Series ◆STANDARD RATINGS Rated voltage (Vdc) Electrostatic Capacitance Temperature Characteristics X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R X7R Rated Capacitance (μF) 0.1 0.15 0.22 0.33 0.47 0.68 1.0 1.5 2.2 2.2 3.3 4.7 6.8 10 15 0.47 0.56 0.68 1.0 1.2 250 500 L max. W max. T max. F±0.8 φd±0.05 Maximum ripple current (Arms) 5.0 5.0 5.0 5.0 6.5 6.5 7.5 7.5 10.0 13.5 22.5 22.5 28.5 28.5 28.5 7.5 7.5 10.0 10.0 10.0 6.0 6.0 6.0 6.0 6.5 6.5 9.0 9.0 11.5 15.0 20.0 20.0 20.0 20.0 20.0 9.0 9.0 11.5 11.5 11.5 3.5 3.5 3.5 3.5 4.0 4.0 4.5 4.5 6.0 5.0 6.0 6.0 7.5 7.5 7.5 3.5 3.5 3.4 3.8 4.2 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 10.0 20.0 20.0 25.0 25.0 25.0 5.0 5.0 5.0 5.0 5.0 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.6 0.8 0.8 0.8 0.8 0.8 0.5 0.5 0.5 0.5 0.5 0.3 0.3 0.3 0.3 0.8 0.8 1.0 1.0 1.5 2.0 3.0 3.0 4.0 4.0 4.0 0.8 0.8 1.0 1.0 1.0 Dimensions(mm) Taping Quantity per reel (pcs. / reel) Part Number KTD251B104□32A0T00 KTD251B154□32A0T00 KTD251B224□32A0T00 KTD251B334□32A0T00 KTD251B474□43A0T00 KTD251B684□43A0T00 KTD251B105□55A0T00 KTD251B155□55A0T00 KTD251B225□76A0T00 KTD251B225M80A0B00 KTD251B335M90A0B00 KTD251B475M90A0B00 KTD251B685M99A0B00 KTD251B106M99A0B00 KTD251B156M99A0B00 KTD501B474□55A0T00 KTD501B564□55A0T00 KTD501B684□76A0T00 KTD501B105□76A0T00 KTD501B125□76A0T00 2,000 2,000 2,000 2,000 2,000 2,000 2,000 2,000 1,000 - - - - - - 2,000 2,000 1,500 1,500 1,500 ※ The square (□) in part numbers is replaced by a capacitance tolerance code: ‘K’ when ±10%, or ‘M’ when ±20% ※ Please consult with us when you consider the rating other than a standard table. 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ◆DIMENSIONS 16 Crimped lead 32 to 76 Size 17 18 K TD 5 0 0 B 1 0 6 M 5 5 A0 T 0 0 L T W L F 15min. Supplement code Taping code Terminal code Size code Capacitance tolerance code Nominal Capacitance code Temperature characteristics code Rated voltage code Series code Category Straight lead For all size T W 1 F d 15min. ◆PART NUMBERING SYSTEM d Please refer to"Part Numbering System" of the beginning of a catalog for the details. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. 31 CAT. No. E1002C 2023 MULTILAYER CERAMIC CAPACITORS Product Guide ■ Always read "Notes on Use" before using the product in order to enable you to use the product correctly and prevent any faults and accidents from occurring. ■ Request the Product Specification on the product of NIPPON CHEMI-CON CORPORATION to refer to it as well as this brochure prior to the order of the products. Some specific notes on use of the ordered product may be described in the specifications. ■ The products listed in this catalog are designed and manufactured for general electronics equipment use and are not intended for use in applications that can adversely affect human life; where the malfunction of equipment may cause damage to life or property. In addition, our products are not intended to be used in specific applications that may cause a major social impact. Please consult with us in advance of usage of our products in the following listed applications. ① Aerospace equipment ② Power generation equipment such as thermal power, nuclear power etc. ③ Medical equipment ④ Transport equipment (automobiles, trains, ships, etc.) ⑤ Transportation control equipment ⑥ Disaster prevention / crime prevention equipment ⑦ Highly publicized information processing equipment ⑧ Submarine equipment ⑨ Other applications that are not considered general-purpose applications. ■ The circuits described as examples in this catalog and the "delivery specifications" are featured in order to show the operations and usage of our products, however, this fact does not guarantee that the circuits are available to function in your equipment systems. We are not in any case responsible for any failures or damage caused by the use of information contained herein. You should examine our products, of which the characteristics are described in the "delivery specifications" and other documents, and determine whether or not our products suit your requirements according to the specifications of your equipment systems. Therefore, you bear final responsibility regarding the use of our products. Please make sure that you take appropriate safety measures such as use of redundant design and malfunction prevention measures in order to prevent fatal accidents and/or fires in the event any of our products malfunction. ■ We strongly recommend our customers to purchase Nippon Chemi-Con products only through our official sales channels. We assume no responsibility for any defects or damages caused by using products purchased from outside our official sales channel or of counterfeit goods. In addition, we will ask the customer to pay the investigation cost for products purchased outside our official sales channel. ■ We reserve the right to discontinue production and delivery of products. We do not guarantee that all the products included in this catalog will be available in the future. The aforementioned does not apply in the case of individual agreements deviating from the foregoing for customer-specific products ■ We continually strive to improve the quality and reliability of our products, but in any case that our product does not meet our published specifications, please stop using it promptly and contact us immediately. As for compensation for non-conforming goods delivered by Chemi-Con, we will limit it only to goods found in non-compliance of our published specifications. This may be accomplished by a no cost replacement of non-conforming individual products, a credit of the piece price paid per each individual non-conforming product, or in other ways deemed necessary. In addition, we have an established system with enhanced traceability, therefore we will limit the applicable lot items for any potential compensation. Precautions and Guidelines・Recommended Soldering Conditions Part Numbering System List of Standardization and Obsoleted Products TAPING SPECIFICATION Characteristics Data Minimum Packaging Quantity Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1002C 2023
KTD500B105M32A0T00 价格&库存
很抱歉,暂时无法提供与“KTD500B105M32A0T00”相匹配的价格&库存,您可以联系我们找货
