DATA SHEET
CURRENT SENSOR - LOW TCR
PR/PF/PH series
5%, 2%, 1%
sizes 0805/1206/2512/0815
Product specification – November 01, 2011 V.0 Supersedes Date of Mar. 06, 2003
RoHS compliant & Halogen free
Downloaded from Arrow.com.
2
Chip Resistor Surface Mount
PR/PF/PH
SERIES
10
0805/1206/2512/0815
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC
This specification describes
PR/PF/PH series current sensor low TCR with lead-free terminations
made by metal substrate.
Both part numbers are identified by the series, size, tolerance, packing
type, temperature coefficient, taping reel and resistance value.
YAGEO BRAND ordering code
GLOBAL PART NUMBER (PREFERRED)
APPLICATIONS
Power Management Applications
Current detection for
Switching Power Supply
Computers, Consumer
DC-DC Converter, Battery
Pack, Charger, Adaptor
FEATURES
Halogen-free Epoxy
RoHS compliant
Products with lead-free
terminations meet RoHS
requirements
Pb-glass contained in electrodes,
resistor element and glass are
exempted by RoHS
Reduce environmentally
hazardous wastes
High component and equipment
reliability
None forbidden-materials used in
products/production
Low resistances applied to
current sensing
PR/PF/PH XXXX X X X XX XXXX L
(1)
(2) (3) (4)
(5)
(6)
(7)
(1) SIZE
0805 / 1206 / 2512 / 0815
(2) TOLERANCE
F = ±1%
G = ±2%
J = ±5%
(3) PACKAGING TYPE
K = Embossed taping reel
R = Paper taping reel
(4) TEMPERATURE COEFFICIENT OF RESISTANCE
M = ±75 ppm/°C
F = ±100 ppm/°C
G = ±200 ppm/°C
(5) TAPING REEL
07 = 7 inch dia. Reel and standard power
7W = 7 inch dia. Reel and 2 x standard power
7T = 7 inch dia. Reel and 3 x standard power
(6) RESISTANCE VALUE
1 mΩ to 50 mΩ
There are 4~5 digits indicated the resistance value. Letter R is decimal point.
Detailed coding rules of resistance are shown in the table of “Resistance rule of
global part number”.
(7) DEFAULT CODE
Letter L is the system default code for ordering only. (Note)
Resistance rule of global part
number
Resistance code rule
Example
0RXXX
(1 to 50 mΩ)
0R05 = 50 mΩ
ORDERING EXAMPLE
The ordering code of a PR2512
chip resistor, value 0.005 X with
±1% tolerance, supplied in 7-inch
tape reel is: PR2512FKF070R005L.
0R001 = 1 mΩ
NOTE
1. All our RSMD products are RoHS compliant. "LFP" of the internal 2D reel label mentions
"Lead-Free Process"
2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of
GLOBAL PART NUMBER / 12NC can be added (both are on customer request)
www.yageo.com
Nov 01, 2011 V.0
PR/PF/PH
SERIES
3
10
0805/1206/2512/0815
PHYCOMP BRAND ordering codes
Both GLOBAL PART NUMBER (preferred) and 12NC (traditional) codes are acceptable to order Phycomp
brand products.
GLOBAL PART NUMBER
( PREFERRED )
For detailed information of GLOBAL PART NUMBER and ordering example, please refer to page 2.
12NC
CODE
2322
XXX XXXXX L
(1)
SIZE TYPE
(2)
(3)
START TOL. RESISTANCE
IN (1) (%) RANGE
2512 MPRC221 2322
MPRC221 2322
Last digit of 12NC
(4)
Resistance decade (3)
EMBOSSED (2)
(units) (2)
PAPER
TAPE ON REEL TAPE ON REEL
4,000
Last digit
0.001 to 0.005 X
4,000
±5%
0.001 to 0.005 Ω
762 94xxx
±1%
0.001 to 0.005 Ω
763 95xxx
Example: 0.005 X = 050
(1) The resistors have a 12-digit ordering code starting with 2322.
ORDERING EXAMPLE
(2) The subsequent 4 or 5 digits indicate the resistor tolerance and
packaging.
The ordering code of a MPRC221
resistor, value 0.005 X with ±5%
tolerance, supplied in tape of
4,000 units per reel is:
232276294050L or
PR2512FKF070R005L.
(3) The remaining 4 or 3 digits represent the resistance value with the
last digit indicating the multiplier as shown in the table of
“Last digit of 12NC”.
(4) "L" is optional symbol (Note) .
NOTE
1. All our RSMD products are RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead-Free Process"
2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART NUMBER / 12NC can be added
www.yageo.com
Nov 01, 2011 V.0
PR/PF/PH
SERIES
0805/1206/2512/0815
4
10
MARKING
PF0805 / PH0805
ynsc107
No marking
Fig. 1
PF1206 / PH1206 / PR2512:
PF2512:
Full range
R < 20 mΩ & R ≥ 20 mΩ with 2W
4 digits with top bar
ynsc016
Fig. 2
Value = 5 mΩ
The “R” is used as a decimal point; the other 3 digits are significant
PF2512: R ≥ 20 mΩ with 1W
4 digits
020
YNSC005
Fig. 3
Value = 20 mΩ
PF0815
4 digits: E24 series
YNSC106
Fig. 4
Value = 10 mΩ
For further marking information, please refer to data sheet “Chip resistors marking”.
www.yageo.com
Nov 01, 2011 V.0
PR/PF/PH
5
10
0805/1206/2512/0815
SERIES
CONSTRUCTION
The resistors are constructed using outstanding TCR level material, which makes Yageo PR/PF/PH resistors
excellent for current sensing application in battery charger circuit & DC-DC converter.
The composition of the resistive material is adjusted to give the approximate required resistance and is
covered with a protective coating, which printed with the resistance value.
Finally, the three external terminations (Cu / Ni / matte Tin) are added, as shown in Fig. 4.
Outlines
For dimensions, please refer to Table 1
marking layer
H
end termination
I2
marking layer
protective coat
protective coat
metal substrate
end termination
inner electrode
H
I2
protective coat
H
I1
resistive layer
(metal foil)
protective coat
marking
I1
001
W
L
PR series
W
00
00
end termination
W
protective coat
ceramic substrate
resistive layer (metal foil)
protective coat
ceramic substrate
I1
inner electrode
I2
YNSC105
L
L
PF / PH series
PF 0815 series
Note: construction will be adjusted to
resistance value (only for PF series).
Fig. 5 Chip resistor outlines
DIMENSION
Table 1 For outlines, please refer to Fig. 5
TYPE
RESISTANCE RANGE
L (mm)
W (mm)
H (mm)
I1 (mm)
PF/PH0805
0.01 to 0.05 Ω
2.03 ±0.25
1.27 ±0.25
0.33 ±0.12
0.38 ±0.25
0.38 ±0.25
PF/PH1206
0.01 to 0.05 Ω
3.20 ±0.25
1.60 ±0.25
0.60 ±0.25
0.50 ±0.25
0.65 ±0.25
PF0815
0.01 to 0.02 Ω
2.15 ±0.20
3.75 ±0.25
0.65 ±0.25
0.65 ±0.25
0.70 ±0.25
0.006 Ω
6.45 ±0.25
3.25 ±0.25
0.70 ±0.25
0.75 ±0.25
1.85 ±0.25
0.007 to 0.015 Ω
6.45 ±0.25
3.25 ±0.25
0.70 ±0.25
0.75 ±0.25
1.55 ±0.25
0.02 to 0.05 Ω (1W)
6.45 ±0.25
3.25 ±0.25
0.70 ±0.25
1.30 ±0.25
0.75 ±0.25
0.02 to 0.05 Ω (2W)
6.45 ±0.25
3.25 ±0.25
0.70 ±0.25
0.75 ±0.25
1.30 ±0.25
0.001 to 0.002 Ω
6.40 ±0.20
3.20 ±0.20
0.75 ±0.15
1.20 ±0.20
1.20 ±0.20
0.003 to 0.005 Ω
6.40 ±0.20
3.20 ±0.20
0.55 ±0.15
0.60 ±0.20
0.60 ±0.20
PF2512
PR2512
I2 (mm)
www.yageo.com
Nov 01, 2011 V.0
PR/PF/PH
SERIES
6
10
0805/1206/2512/0815
ELECTRICAL CHARACTERISTICS
Table 2
TYPE
POWER
RESISTANCE RANGE
TOLERANCE
PF0805
1/8 W, 1/4 W, 1/3 W
10 / 20 / 25 / 50 mΩ
PH0805
1/2 W
PF1206
1/4 W, 1/2 W
10 / 15 / 20 / 25 / 30 / 40 / 50 mΩ
PH1206
1W
PF0815
1/2W, 1W
10 /15 / 20 mΩ
PF2512
1 W, 2W
6 / 7 / 8 / 10 / 15 / 20 / 25 / 33 / 50 mΩ
PR2512
1 W, 2W
1 / 2 / 3 / 4 / 5 mΩ
±1%, ±2%, ±5%
RESISTANCE
±100 ppm/°C, ±75 ppm/°C
1 mΩ ≤ R ≤ 2 mΩ
±200 ppm/°C
3 mΩ ≤ R ≤ 5 mΩ
±100 ppm/°C
FOOTPRINT AND SOLDERING PROFILES
For recommended footprint and soldering profiles, please refer to data sheet “Chip resistors mounting”.
PACKING STYLE AND PACKAGING QUANTITY
Table 3 Packing style and packaging quantity
PACKING STYLE
REEL DIMENSION
PF / PH0805
PF / PH1206
PF0815
PF / PR2512
Paper taping reel (R)
7" (178 mm)
4,000
4,000
Embossed taping reel (K)
7" (178 mm)
4,000
4,000
NOTE
1. For paper/embossed tape and reel specification/dimensions, please refer to data sheet “Chip resistors packing”.
www.yageo.com
Nov 01, 2011 V.0
PR/PF/PH
SERIES
7
10
0805/1206/2512/0815
FUNCTIONAL DESCRIPTION
OPERATING TEMPERATURE RANGE
Range: –55°C to +155°C
POWER RATING
MRA632
Pmax
(%Prated)
100
Standard rated power at 70°C:
PF0805 = 1/8W
PH0805 = 1/2W
PF1206 = 1/4W
PH1206 = 1W
PF0815 = 1/2W
PF2512 = 1W
PR2512 = 1W
For detail power value, please refer to Table 2.
50
−55
155
100
Tamb (°C)
Fig. 6 Maximum dissipation (Pmax) in percentage of rated power
as a function of the operating ambient temperature (Tamb )
RATED VOLTAGE
The DC or AC (rms) continuous working voltage
corresponding to the rated power is determined by
the following formula:
V = √(P X R)
Where
V = Continuous rated DC or
AC (rms) working voltage (V)
P = Rated power (W)
R = Resistance value (X)
www.yageo.com
Nov 01, 2011 V.0
PR/PF/PH
SERIES
8
10
0805/1206/2512/0815
TESTS AND REQUIREMENTS
Table 4 Test condition, procedure and requirements
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Life/
Operational Life/
Endurance
MIL-STD-202G-method 108A
1,000 hours at 70±5 °C applied RCWV
1.5 hours on, 0.5 hour off, still air required
±(1%+0.0005 Ω)
High
Temperature
Exposure/
Endurance at
Upper Category
Temperature
1,000 hours at maximum operating temperature
depending on specification, unpowered
±(1%+0.0005 Ω)
IEC 60115-1 4.25.3
JIS C 5202-7.11
No direct impingement of forced air to the parts
Moisture
Resistance
MIL-STD-202G-method 106F
IEC 60115-1 4.24.2
IEC 60115-1 4.25.1
JIS C 5202-7.10
Tolerances: 155±3 °C
Each temperature / humidity cycle is defined at 8
hours (method 106F), 3 cycles / 24 hours for 10d
with 25 °C / 65 °C 95% R.H, without steps 7a &
7b, unpowered
±(0.5%+0.0005 Ω)
Parts mounted on test-boards, without
condensation on parts
Measurement at 24±2 hours after
test conclusion
Thermal Shock
MIL-STD-202G-method 107G
-55/+155 °C
±(0.5%+0.0005 Ω)
Note: Number of cycles required is 300. Devices
unmounted
Maximum transfer time is 20 seconds. Dwell time
is 15 minutes. Air – Air
Short Time
Overload
MIL-R-55342D-para 4.7.5
Board Flex/
Bending
IEC60115-1 4.33
IEC60115-1 4.13
5 times of rated power for 5 seconds at room
temperature
±(0.5%+0.0005 Ω)
Device mounted on PCB test board as described,
only 1 board bending required
±(1%+0.05 Ω)
No visible damage
No visible damage
Bending for 0805: 3 mm
1206/2512/other: 2 mm
Holding time: minimum 60 seconds
www.yageo.com
Nov 01, 2011 V.0
PR/PF/PH
SERIES
9
10
0805/1206/2512/0815
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Solderability
- Wetting
IPC/JEDECJ-STD-002B test B
Electrical Test not required
Well tinned (≥95% covered)
IEC 60068-2-58
Magnification 50X
No visible damage
SMD conditions:
1st step: method B, aging 4 hours at 155 °C
dry heat
2nd step: leadfree solder bath at 245±3 °C
Dipping time: 3±0.5 seconds
- Leaching
- Resistance to
Soldering Heat
IPC/JEDECJ-STD-002B test D
No visible damage
IEC 60068-2-58
Leadfree solder, 260 °C, 30 seconds
immersion time
MIL-STD-202G-method 210F
Condition B, no pre-heat of samples
±(0.5%+0.0005 Ω)
IEC 60068-2-58
Leadfree solder, 260 °C, 10 seconds
immersion time
No visible damage
Procedure 2 for SMD: devices fluxed and
cleaned with isopropanol
www.yageo.com
Nov 01, 2011 V.0
PR/PF/PH
SERIES
10
10
0805/1206/2512/0815
REVISION HISTORY
REVISION
DATE
CHANGE NOTIFICATION
DESCRIPTION
Version 0
Nov 01, 2011
- New datasheet for current sensor - low TCR PR/PF/PH series sizes of
0805/1206/2512, 1%, 2% and 5% with lead-free terminations
- Replace the pdf files: Pu-PRPF_PE_51_PbFree_L_1.pdf & PYuPR_521_RoHS_L_2.pdf
“ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itself are unchanged. Any
product change will be announced by PCN.”
www.yageo.com
Nov 01, 2011 V.0
