N74F02D,623
N74F02D,623
    NEXPERIA(安世)
    SOIC14
    IC GATE NOR 4CH 2-INP 14SO
N74F02D,623 数据手册
INTEGRATED CIRCUITS 74F02 Quad 2-input NOR gate Product specification IC15 Data Handbook       1990 Oct 04 Philips Semiconductors Product specification Quad 2-input NOR gate 74F02 FEATURE PIN CONFIGURATION • Industrial temperature range available (–40°C to +85°C) TYPE TYPICAL PROPAGATION DELAY TYPICAL SUPPLY CURRENT (TOTAL) 74F02 3.4ns 4.4mA Q0 1 14 VCC D0a 2 13 Q3 D0b 3 12 D3b Q1 4 11 D3a D1a 5 10 Q2 D1b 6 9 D2a GND 7 8 D2b SF00007 ORDERING INFORMATION ORDER CODE DESCRIPTION COMMERCIAL RANGE VCC = 5V ±10%, Tamb = 0°C to +70°C INDUSTRIAL RANGE VCC = 5V ±10%, Tamb = –40°C to +85°C PKG DWG # 14-pin plastic DIP N74F02N I74F02N SOT27-1 14-pin plastic SO N74F02D I74F02D SOT108-1 INPUT AND OUTPUT LOADING AND FAN-OUT TABLE PINS DESCRIPTION 74F (U.L.) HIGH/LOW LOAD VALUE HIGH/LOW Dna, Dnb Data inputs 1.0/1.0 20µA/0.6mA Qn Data output 50/33 1.0mA/20mA NOTE: One (1.0) FAST unit load is defined as: 20µA in the high state and 0.6mA in the low state. LOGIC DIAGRAM FUNCTION TABLE 2 D0a D0b 5 6 D1a D1b VCC = Pin 14 GND = Pin 7 1 3 4 8 D2a D2b 9 D3a D3b 12 10 11 13 INPUTS Q0 Dna Q1 Q2 Q3 SF00008 LOGIC SYMBOL OUTPUT Dnb Qn L L H L H L H L L H H NOTES: 1 H = High voltage level 2 L = Low voltage level L IEC/IEEE SYMBOL 2 3 5 6 8 9 11 12 2 1 1 3 D0a D0bD1a D1b D2a D2b D3a D3b 5 4 6 Q0 Q1 Q2 Q3 8 VCC = Pin 14 GND = Pin 7 1 4 10 10 13 9 SF00009 11 13 12 SF00010 1990 Oct 04 2 853-0326 00622 Philips Semiconductors Product specification Quad 2-input NOR gate 74F02 ABSOLUTE MAXIMUM RATINGS (Operation beyond the limit set forth in this table may impair the useful life of the device. Unless otherwise noted these limits are over the operating free air temperature range.) SYMBOL PARAMETER RATING UNIT VCC Supply voltage –0.5 to +7.0 V VIN Input voltage –0.5 to +7.0 V IIN Input current –30 to +5 mA VOUT Voltage applied to output in high output state –0.5 to VCC V IOUT Current applied to output in low output state 40 mA Tamb Operating free air temperature range Commercial range 0 to +70 °C Industrial range –40 to +85 °C –65 to +150 °C Tstg Storage temperature range RECOMMENDED OPERATING CONDITIONS SYMBOL PARAMETER LIMITS UNIT MIN NOM MAX VCC Supply voltage 4.5 5.0 5.5 VIH High-level input voltage 2.0 VIL Low-level input voltage 0.8 V IIk Input clamp current –18 mA IOH High-level output current –1 mA IOL Low-level output current Tamb Operating free air temperature range V V 20 mA Commercial range 0 +70 °C Industrial range –40 +85 °C DC ELECTRICAL CHARACTERISTICS (Over recommended operating free-air temperature range unless otherwise noted.) SYMBOL TEST CONDITIONS1 PARAMETER LIMITS MIN VOH VOL High-level output voltage Low-level output voltage TYP2 UNIT MAX VCC = MIN, VIL = MAX ±10%VCC 2.5 VIH = MIN, IOH = MAX ±5%VCC 2.7 VCC = MIN, VIL = MAX ±10%VCC 0.30 0.50 V VIH = MIN, IOl = MAX ±5%VCC 0.30 0.50 V -0.73 V 3.4 V VIK Input clamp voltage VCC = MIN, II = IIK -1.2 V II Input current at maximum input voltage VCC = MAX, VI = 7.0V 100 µA IIH High-level input current VCC = MAX, VI = 2.7V 20 µA IIL Low-level input current VCC = MAX, VI = 0.5V IOS Short-circuit output current3 VCC = MAX ICC Supply current (total)4 -60 -0.6 mA -150 mA ICCH VCC = MAX 3.0 5.6 mA ICCL VCC = MAX 7.0 13.0 mA NOTES: 1 For conditions shown as MIN or MAX, use the appropriate value specified under recommended operating conditions for the applicable type. 2 All typical values are at VCC = 5V, Tamb = 25°C. 3 Not more than one output should be shorted at a time. For testing IOS, the use of high-speed test apparatus and/or sample-and-hold techniques are preferable in order to minimize internal heating and more accurately reflect operational values. Otherwise, prolonged shorting of a high output may raise the chip temperature well above normal and thereby cause invalid readings in other parameter tests. In any sequence of parameter tests, IOS tests should be performed last. 4 ICC is measured with outputs open. 1990 Oct 04 3 Philips Semiconductors Product specification Quad 2-input NOR gate 74F02 AC ELECTRICAL CHARACTERISTICS LIMITS SYMBOL tPLH tPHL PARAMETER Propagation delay Dna, Dnb to Qn VCC = +5.0V ± 10% Tamb = 0°C to +70°C CL = 50pF, RL = 500Ω VCC = +5.0V Tamb = +25°C CL = 50pF, RL = 500Ω TEST CONDITION Waveform 1 VCC = +5.0V ± 10% Tamb = –40°C to +85°C CL = 50pF, RL = 500Ω MIN TYP MAX MIN MAX MIN MAX 2.5 2.0 4.4 3.2 5.5 4.3 2.5 2.0 6.5 5.3 2.5 1.5 7.0 6.0 UNIT ns AC WAVEFORMS For all waveforms, VM = 1.5V. Dna, Dnb VM VM tPHL tPLH VM Qn VM SF00005 Waveform 1. Propagation delay for inverting outputs TEST CIRCUIT AND WAVEFORM VCC NEGATIVE PULSE VIN tw 90% VM D.U.T. RT CL RL AMP (V) VM 10% VOUT PULSE GENERATOR 90% 10% tTHL (tf ) tTLH (tr ) tTLH (tr ) tTHL (tf ) 0V AMP (V) 90% 90% POSITIVE PULSE DEFINITIONS: RL = Load resistor; see AC ELECTRICAL CHARACTERISTICS for value. CL = Load capacitance includes jig and probe capacitance; see AC ELECTRICAL CHARACTERISTICS for value. RT = Termination resistance should be equal to ZOUT of pulse generators. VM VM 10% Test Circuit for Totem-Pole Outputs 10% tw 0V Input Pulse Definition INPUT PULSE REQUIREMENTS family amplitude VM 74F 3.0V 1.5V rep. rate tw tTLH tTHL 1MHz 500ns 2.5ns 2.5ns SF00006 1990 Oct 04 4 Philips Semiconductors Product specification Quad 2-input NOR gate 74F02 DIP14: plastic dual in-line package; 14 leads (300 mil) 1990 Oct 04 5 SOT27-1 Philips Semiconductors Product specification Quad 2-input NOR gate 74F02 SO14: plastic small outline package; 14 leads; body width 3.9 mm 1990 Oct 04 6 SOT108-1 Philips Semiconductors Product specification Quad 2-input NOR gate 74F02 NOTES 1990 Oct 04 7 Philips Semiconductors Product specification Quad 2-input NOR gate 74F02 DIP14: plastic dual in-line package; 14 leads (300 mil) 1990 Oct 04 8 SOT27-1 Philips Semiconductors Product specification Quad 2-input NOR gate 74F02 SO14: plastic small outline package; 14 leads; body width 3.9 mm 1990 Oct 04 9 SOT108-1 Philips Semiconductors Product specification Quad 2-input NOR gate 74F02 NOTES 1990 Oct 04 10 Philips Semiconductors Product specification Quad 2-input NOR gate 74F02 DEFINITIONS Data Sheet Identification Product Status Definition Objective Specification Formative or in Design This data sheet contains the design target or goal specifications for product development. Specifications may change in any manner without notice. Preliminary Specification Preproduction Product This data sheet contains preliminary data, and supplementary data will be published at a later date. Philips Semiconductors reserves the right to make changes at any time without notice in order to improve design and supply the best possible product. Product Specification Full Production This data sheet contains Final Specifications. Philips Semiconductors reserves the right to make changes at any time without notice, in order to improve design and supply the best possible product. Philips Semiconductors and Philips Electronics North America Corporation reserve the right to make changes, without notice, in the products, including circuits, standard cells, and/or software, described or contained herein in order to improve design and/or performance. Philips Semiconductors assumes no responsibility or liability for the use of any of these products, conveys no license or title under any patent, copyright, or mask work right to these products, and makes no representations or warranties that these products are free from patent, copyright, or mask work right infringement, unless otherwise specified. Applications that are described herein for any of these products are for illustrative purposes only. Philips Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. LIFE SUPPORT APPLICATIONS Philips Semiconductors and Philips Electronics North America Corporation Products are not designed for use in life support appliances, devices, or systems where malfunction of a Philips Semiconductors and Philips Electronics North America Corporation Product can reasonably be expected to result in a personal injury. Philips Semiconductors and Philips Electronics North America Corporation customers using or selling Philips Semiconductors and Philips Electronics North America Corporation Products for use in such applications do so at their own risk and agree to fully indemnify Philips Semiconductors and Philips Electronics North America Corporation for any damages resulting from such improper use or sale.  Copyright Philips Electronics North America Corporation 1997 All rights reserved. Printed in U.S.A. Philips Semiconductors 811 East Arques Avenue P.O. Box 3409 Sunnyvale, California 94088–3409 Telephone 800-234-7381       1990 Oct 04 11
N74F02D,623 价格&库存
很抱歉,暂时无法提供与“N74F02D,623”相匹配的价格&库存,您可以联系我们找货
