UPTF0603-16W-N-1002BT 数据手册
UPTF
SERIES
ULTRA PRECISION THIN FILM RESISTORS
FEATURES:
• TCR as low as ±2ppm
• Excellent characteristics at higher frequencies
• Tolerance as low as ±0.01%
PART NUMBER STRUCTURE
UPTF
0805 -
10W
Series
Size
0402
0603
0805
1206
1210
2010
2512
Power Rating
16W = 0.063W
10W = 0.10W
8W = 0.125W
5W = 0.20W
4W = 0.25W
2W = 0.50W
P
TCR
2 = ±2ppm/˚C
3 = ±3ppm/˚C
P = ±5ppm/˚C
N = ±10ppm/˚C
E = ±25ppm/˚C
1001
A
T
Resistance Code
1001 = 1kΩ
39R9 = 39.9Ω
49R9 = 49.9Ω
Tolerance
U = ±0.01%
A =±0.05%
B = ±0.1%
C = ±0.25%
D = ±0.50%
Packaging
T = Tape & Reel
Optional Reel Identifier
Leave blank for standard quantity.
Add "-1K" if 1000 piece reel is required
Example P/N: UPTF0805-10W-P-1001AT
Standard Termination is 100% matte Tin over Nickel.
DIMENSIONS
Unit: inches (mm)
L
W
ι
ι
1
ι
2
L
W
T
ι1
ι2
0402
0.040 ± 0.002
(1.0 ± 0.05)
0.020 ± 0.002
(0.5 ± 0.05)
0.014 ± 0.002
(0.35 ± 0.05)
0.008 ± 0.004
(0.2 ± 0.10)
0.008 ± 0.004
(0.2 ± 0.10)
0603
0.063 ± 0.008
(1.6 ± 0.20)
0.031 ± 0.008
(0.8 ± 0.2)
0.017 ± 0.004
(0.45 ± 0.10)
0.010 ± 0.006
(0.25 ± 0.15)
0.010 ± 0.006
(0.25 ± 0.15)
0805
0.079 ± 0.008
(2.0 ± 0.20)
0.050 ± 0.008
(1.25 ± 0.20)
0.021 ± 0.004
(0.55 ± 0.10)
0.016 ± 0.008
(0.4 ± 0.20)
0.012 ± 0.008
(0.3 ± 0.20)
1206
0.126 ± 0.008
(3.2 ± 0.20)
0.063 ± 0.008
(1.6 ± 0.20)
0.021 ± 0.004
(0.55 ± 0.10)
0.018 ± 0.008
(0.45 ± 0.20)
0.012 ± 0.008
(0.3 ± 0.20)
1210
0.126 ± 0.008
(3.2 ± 0.20)
0.098 ± 0.006
(2.50 ± 0.15)
0.021 ± 0.004
(0.55 ± 0.10)
0.018 ± 0.008
(0.45 ± 0.20)
0.012 ± 0.008
(0.3 ± 0.20)
2010
0.197 ± 0.008
(5.0 ± 0.20)
0.098 ± 0.006
(2.50 ± 0.15)
0.021 ± 0.004
(0.55 ± 0.10)
0.236 ± 0.012
(0.60 ± 0.30)
0.02 ± 0.010
(0.50 ± 0.25)
2512
0.248 ± 0.008
(6.30 ± 0.20)
0.122 ± 0.006
(3.10 ± 0.15)
0.021 ± 0.004
(0.55 ± 0.10)
0.236 ± 0.012
(0.60 ± 0.30)
0.02 ± 0.010
(0.50 ± 0.25)
1
T
ι
SIZE
(INCHES)
2
STRUCTURE
3
5
4
1
6
87
1
Ceramic Substrate
5
Nickel Plating
2
Backside Electrode
6
Tin Plating
3
Top Electrode
7
Resistive layer
4
Edge Electrode
8
Overcoat
2
1
Email: sales@venkel.com
Phone: 512.794.0081 |
Toll Free: 800.950.8365 |
Web: www.venkel.com
Rev: 07/2020-A
1
UPTF
SERIES
ELECTRICAL SPECIFICATION & RANGE
Tolerance
0.01% (U)
0.05% (A)
0.10% (B)
0.25% (C)
0.50% (D)
SIZE
0402
0603
0805
1206
1210
2010
2512
Power Rating
at 70°C (W)
0.063W (1/16W)
0.063W (1/16W)
0.10W (1/10W)
0.125W (1/8W)
0.20W (1/5W)
0.25W (1/4W)
0.50W (1/2W)
Max. Working
Voltage
25V
50V
100V
150V
150V
150V
150V
Max. Overload
Voltage
50V
100V
200V
300V
300V
300V
300V
Operating
Temp. Range
-55°C to +155°C
-55°C to +155°C
-55°C to +155°C
-55°C to +155°C
-55°C to +155°C
-55°C to +155°C
-55°C to +155°C
TCR
Resistance
Range
Resistance
Range
Resistance
Range
Resistance
Range
Resistance
Range
Resistance
Range
Resistance
Range
±2ppm (2)
49.9Ω - 4.99KΩ
24.9Ω - 15KΩ
24.9Ω - 30KΩ
24.9Ω - 49.9KΩ
24.9Ω - 49.9KΩ
24.9Ω - 100KΩ
24.9Ω - 100KΩ
±3ppm (3)
49.9Ω - 4.99KΩ
24.9Ω - 15KΩ
24.9Ω - 30KΩ
24.9Ω - 49.9KΩ
24.9Ω - 49.9KΩ
24.9Ω - 100KΩ
24.9Ω - 100KΩ
±5ppm (P)
49.9Ω - 20KΩ
24.9Ω - 60KΩ
24.9Ω - 150KΩ
24.9Ω - 300KΩ
24.9Ω - 300KΩ
24.9Ω - 300KΩ
24.9Ω - 300KΩ
±10ppm (N)
49.9Ω - 20KΩ
24.9Ω - 100KΩ
24.9Ω - 200KΩ
24.9Ω - 499KΩ
24.9Ω - 499KΩ
24.9Ω - 499KΩ
24.9Ω - 499KΩ
±2ppm (2)
49.9Ω - 20KΩ
24.9Ω - 15KΩ
24.9Ω - 30KΩ
24.9Ω - 49.9KΩ
24.9Ω - 49.9KΩ
24.9Ω - 100KΩ
24.9Ω - 100KΩ
±3ppm (3)
49.9Ω - 4.99KΩ
24.9Ω - 15KΩ
24.9Ω - 30KΩ
24.9Ω - 49.9KΩ
24.9Ω - 49.9KΩ
24.9Ω - 100KΩ
24.9Ω - 100KΩ
±5ppm (P)
49.9Ω - 4.99KΩ
24.9Ω - 60KΩ
2.49Ω - 150KΩ
24.9 - 300KΩ
24.9Ω - 300KΩ
24.9Ω - 300KΩ
24.9Ω - 300KΩ
±10ppm (N)
49.9Ω - 20KΩ
4.7Ω - 332KΩ
4.7Ω - 1MΩ
4.7Ω - 1.5MΩ
4.7Ω - 1MΩ
4.7Ω - 1MΩ
4.7Ω - 1MΩ
±25ppm (E)
49.9Ω - 20KΩ
4.7Ω - 511KΩ
4.7Ω - 1MΩ
4.7Ω - 1.5MΩ
4.7 -1MΩ
4.7Ω - 1MΩ
4.7Ω - 1MΩ
±2ppm (2)
49.9Ω - 4.99KΩ
24.9Ω - 15KΩ
24.9Ω - 30KΩ
24.9Ω - 49.9KΩ
24.9Ω - 49.9KΩ
24.9Ω - 100KΩ
24.9Ω - 100KΩ
±3ppm (3)
49.9Ω - 4.99KΩ
24.9Ω - 15KΩ
24.9Ω - 30KΩ
24.9Ω - 49.9KΩ
24.9Ω - 49.9KΩ
24.9Ω - 100KΩ
24.9Ω - 100KΩ
±5ppm (P)
49.9Ω - 20KΩ
24.9Ω - 60KΩ
24.9Ω - 150KΩ
24.9 - 300KΩ
24.9Ω - 300KΩ
24.9Ω - 300KΩ
24.9Ω - 300KΩ
±10ppm (N)
49.9Ω - 100KΩ
4.7Ω - 511KΩ
4.7Ω - 1MΩ
4.7Ω - 1.5MΩ
4.7Ω - 1MΩ
4.7Ω - 1MΩ
4.7Ω - 1MΩ
24.9Ω - 300KΩ
±5ppm (P)
49.9Ω - 20KΩ
24.9Ω - 60KΩ
24.9Ω - 150KΩ
24.9 - 300KΩ
24.9Ω - 300KΩ
24.9Ω - 300KΩ
±10ppm (N)
49.9Ω - 100KΩ
4.7Ω - 511KΩ
4.7Ω - 1MΩ
4.7Ω - 1.5MΩ
4.7Ω - 1MΩ
4.7Ω - 1MΩ
4.7Ω - 1MΩ
±5ppm (P)
49.9Ω - 20KΩ
24.9Ω - 60KΩ
24.9Ω - 150KΩ
24.9 - 300KΩ
24.9Ω - 300KΩ
24.9Ω - 300KΩ
24.9Ω - 300KΩ
±10ppm (N)
49.9Ω - 100KΩ
4.7Ω - 511KΩ
4.7Ω - 1MΩ
4.7Ω - 1.5MΩ
4.7Ω - 1MΩ
4.7Ω - 1MΩ
4.7Ω - 1MΩ
NOTE: Overload Voltage=2.5*√(P*R).
MARKING CODE
E-24 values for 0603 size maybe marked with the standard 3 digit marking code.
E-96 values for 0805 size and larger, will be marked with standard 4 digit
marking code.
E-24 values for 0603 size and larger, will be marked with standard 3 digit
marking code.
0603 - E-96 values will be marked with a standard 3 digit alpha numeric code
Please see 0603 marking codes PDF.
Note: 0402 cannot be marked.
DERATING CURVE
Rated power (%)
120
100
80
60
40
-55
-25
50
75
70
100
125
150
175
Ambient temperature (˚C)
Web: www.venkel.com
Rev: 07/2020-A
2
UPTF
SERIES
REEL SPECIFICATIONS
F
Label
Unit: mm (inch)
H
M C
E
C
E
F
G
H
M
13.0 ± 0.2
(0.51 ± 0.008)
60.0 ± 1.0
(2.36 ± 0.03)
11.4 ± 1.0
(0.45 ± 0.04)
9.0 ± .3
(0.35 ± 0.012)
1.5 ± .3
(0.06 ± 0.012)
180 ± 2.0
(7.09 ± 0.08)
Minimum of 30 empty pockets at the beginning of reel, 65 minimum empty pockets at the end.
G
TAPE SPECIFICATIONS
T
G
B
A
W
F
T
J
Dø
Embossed
H
Paper
E
Units: mm (inches).
TAPE
Paper
SIZE
A
B
W
E
F
T
G
H
J
DØ
0402
1.16 ±0.10
0.70 ±0.10
8.0 ±0.10
1.75 ±0.05
3.50 ±0.05
0.40 ±0.03
2.00 ±0.05
4.00 ±0.10
2.00 ±0.05
1.55 ±0.05
0603
1.90 ±0.10
1.10 ±0.05
8.0 ±0.10
1.75 ±0.05
3.50 ±0.05
0.60 ±0.03
4.00 ±0.10
4.00 ±0.10
2.00 ±0.05
1.55 ±0.05
0805
2.37 ±0.20
1.60 ±0.05
8.0 ±0.10
1.75 ±0.05
3.50 ±0.05
0.75 ±0.05
4.00 ±0.10
4.00 ±0.10
2.00 ±0.05
1.55 ±0.05
1206
3.55 ±0.05
2.00 ±0.05
8.0 ±0.10
1.75 ±0.05
3.50 ±0.05
0.75 ±0.05
4.00 ±0.10
4.00 ±0.10
2.00 ±0.05
1.55 ±0.05
1210
3.40 ±0.05
2.75 ±0.05
8.0 ±0.10
1.75 ±0.05
3.50 ±0.05
0.75 ±0.05
4.00 ±0.10
4.00 ±0.05
2.00 ±0.05
1.60 ±0.10
2010
5.45 ±0.10
2.85 ±0.10
12.00 ±0.10
1.75 ±0.10
5.50 ±0.05
1.00
+0.20, -0
4.00 ±0.10
4.00 ±0.05
2.00 ±0.05
1.50
+0.1, -0
2512
6.65 ±0.10
3.40 ±0.10
12.00 ±0.10
1.75 ±0.10
5.50 ±0.05
1.00
+.02.0, -0
4.00 ±0.10
4.00 ±0.05
2.00 ±0.05
1.50
+0.1, -0
Embossed
PEEL BACK FORCE AND DIRECTION DIAGRAM
Direction of pull
Top cover tape
Carrier tape
Peel back force and direction of peel back angle should follow
EIA481-1-A. Peel back force should be between 0.1N – 1.3N
and peel back angle of 165˚ – 180˚.
165 ~ 180˚
Direction of unreeling
Bottom cover tape
Web: www.venkel.com
Rev: 07/2020-A
3
UPTF
SERIES
ENVIRONMENTAL CHARACTERISTICS
REQUIREMENT
TEST
Tol. ≤0.05%
Temperature Coefficient of
Resistance (T.C.R.)
Short Time Overload
TEST METHOD
Tol. >0.05%
MIL-STD-202 Method 304
+25/-55/+125/+25°C
As Spec.
ΔR±0.05%
ΔR±0.2%
JIS-C-5201-1 4.13
RCWV*2.5 or Max. Overload Voltage whichever is lower for 5 seconds
ΔR±0.2% for high power rating
Insulation Resistance
MIL-STD-202 Method 302
Apply 100VDC for 1 minute
>9999MΩ
ΔR±0.05%
ΔR±0.2%
ΔR±0.5% for high power rating
MIL-STD-202 Method 108A
70±2°C RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hrs “OFF”
Endurance
0201:>7kΩ→ ΔR±0.5%
≤7kΩ→ ΔR±0.2%
Damp Heat with Load
Bending Strength
Solderability
Resistance to Soldering Heat
ΔR±0.05%
ΔR±0.3%
ΔR±0.05%
JIS-C-5201-1 4.33
Bending amplitude 3mm for 10 seconds
2010 / 2512 sizes: 2mm Other sizes: 3mm
ΔR±0.1%
MIL-STD-202 Method 208H
245±5°C for 3 seconds
95% min. coverage
ΔR±0.05%
MIL-STD-202 Method 210E
260±5°C for 10 seconds
ΔR±0.1%
Dielectric Withstanding
Voltage
Low Temperature Operation
MIL-STD-202 Method 103B
40±2°C 90~95% R.H. RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hrs “OFF”
MIL-STD-202 Method 301
Max. Overload Voltage for 1 minute
By Type
ΔR±0.05%
ΔR±0.2%
JIS-C-5201-1 4.36
1 hour, -65°C, followed by 45 minutes of RCWV
High Temperature Exposure
at +155°C for 1000 hrs
ΔR±0.5%
RCWV (Rated Continuous Working Voltage)=√(P*R) or Max. Operating Voltage whichever is lower.
Storage Temperature: 15~28°C; Humidity: < 80%RH
Web: www.venkel.com
Rev: 07/2020-A
4
UPTF0603-16W-N-1002BT 价格&库存
很抱歉,暂时无法提供与“UPTF0603-16W-N-1002BT”相匹配的价格&库存,您可以联系我们找货
