HPCR
SERIES
HIGH POWER RESISTORS
FEATURES:
• Available Sizes 0402 to 1210
• Values from 1Ω to 1MΩ, plus 0Ω Jumper
• TCR as low as ±100PPM
• Good power dissipation capabilities
• 100% matte Tin over Nickel with wrap around termination
for excellent solderability
PART NUMBER STRUCTURE
HPCR
1210
Series
Size
0402
0603
0805
1206
1210
W
Power Rating
R = 1/8W (0.125W)
T = 1/4W ( 0.25W)
U = 1/3W (0.33W)
V = 1/2W (0.50W)
W = 3/4W (0.75)
103
J
T
Resistance Value
Tolerance
F = ± 1%
J = ± 5%
Packaging
T = Tape & Reel
3 DIGIT
(J TOL.)
2R2=2.2Ω
103=10KΩ
4 DIGIT
(F TOL.)
10R2=10.2Ω
1002=10KΩ
Optional Reel Identifier
Leave blank for
standard quantity.
Add “-13” if 13” Reel
is required
Example P/N: HPCR1210-W-103JT
Standard Termination is 100% matte Tin over Nickel.
DIMENSIONS
Unit: inches (mm)
L
W
C2
C1
T
C1
SIZE
L
W
T
C1
C2
0402
0.040 ± 0.002
(1.0 ± 0.05)
0.020 ± 0.002
(0.5 ± 0.05)
0.014 ± 0.002
(0.35 ± .05)
0.008 ± 0.004
(0.2 ± 0.1)
0.008 ± 0.004
(0.2 ± 0.1)
0603
0.063 ± 0.004
(1.6 ± 0.1)
0.031 ± 0.004
(0.8 ± 0.1)
0.018 ± 0.004
(0.45 ± 0.1)
0.012 ± 0.007
(0.30 ± 0.20)
0.012 ± 0.007
(0.30 ± 0.20)
0805
0.079 ± 0.006
(2.0 ± 0.10)
0.050 ± 0.003
(1.25 ± 0.10)
0.019 ± 0.003
(0.50 ± 0.10)
0.014 ± 0.007
(0.35 ± 0.20)
0.015 ± 0.007
(0.40 ± 0.20)
1206
0.122 ± 0.003
(3.10 ± 0.10)
0.061 ± 0.003
(1.55 ± 0.10)
0.021 ± 0.003
(0.55 ± 0.10)
0.020 ± 0.009
(0.50 ± 0.25)
0.020 ± 0.008
(0.50 ± 0.20)
1210
0.122 ± 0.003
(3.10 ± 0.10)
0.10 ± 0.006
(2.60 ± 0.15)
0.021 ± 0.003
(0.55 ± 0.10)
0.020 ± 0.009
(0.50 ± 0.25
0.020 ± 0.008
(0.50 ± 0.20)
C2
STRUCTURE
3
8
4
1
6
7
9
5
1
Alumina Substrate
6
Primary Coating
2
Backside Electrode
7
Protective Coating
3
Top Electrode
8
Barrier Layer (Ni)
4
Edge Electrode
9
Termination
100% matte Tin
5
Resistive layer
10
Marking
2
1
Email: sales@venkel.com
Phone: 512.794.0081 |
Toll Free: 800.950.8365 |
Web: www.venkel.com
Rev: 03/2021-A
1
HPCR
SERIES
ELECTRICAL SPECIFICATION & RANGE
SIZE
0402
0603
0805
1206
1210
Power Rating
at 70°C (W)
0.125W (1/8W)
0.25W (1/4W)
0.33W (1/3W)
0.50W (1/2W)
0.75W (3/4W)
Max. Working
Voltage
√ PR or 50V whichever
is less
√ PR or 75V whichever
is less
√ PR or 150V whichever
is less
√ PR or 200V whichever
is less
is less
Operating
Temp. Range
-55°C to +155°C
-55°C to +155°C
-55°C to +155°C
-55°C to +155°C
-55°C to +155°C
Zero Ohm
(Jumper)
Current Rating
1.5A
2A
2.5A
3.5A
4.5A
Zero Ohm
(Jumper)
Resistance
20 mΩ (max)
20 mΩ (max)
20 mΩ (max)
20 mΩ (max)
20 mΩ (max)
Tolerance
TCR
Resistance Range
Resistance Range
Resistance Range
Resistance Range
Resistance Range
±100ppm
10Ω - 1MΩ
10Ω - 1MΩ
10Ω - 1MΩ
10Ω - 1MΩ
10Ω - 1MΩ
±200ppm
1Ω - 9.76Ω
1Ω - 9.76Ω
1Ω - 9.76Ω
1Ω - 9.76Ω
1Ω - 9.76Ω
±100ppm
10Ω - 1MΩ
10Ω - 1MΩ
10Ω - 1MΩ
10Ω - 1MΩ
10Ω - 1MΩ
±200ppm
1Ω - 9.76Ω
1Ω - 9.76Ω
1Ω - 9.76Ω
1Ω - 9.76Ω
1Ω - 9.76Ω
±1 (F)
±5% (J)
NOTE: Overload Voltage=2.5*√(P*R).
MARKING CODE
• 1% E-24 values for 0603 size and larger are typically marked with the
standard 3 digit marking code.
• 1% E-96 values for 0805 size and larger, will be marked with standard 4 digit
marking code.
• 5% E-24 values for 0603 size and larger, will be marked with standard 3 digit
marking code.
• 0603 - 1% E-96 values will be marked with a standard 3 digit alpha numeric
code (Please see alpha numeric marking codes for resistors).
• 0402 size cannot be marked
DERATING CURVE
Rated power (%)
120
100
80
60
40
-55
-25
50
75
100
70
Ambient temperature (˚C)
125
150
175
Web: www.venkel.com
Rev: 03/2021-A
2
HPCR
SERIES
REEL SPECIFICATIONS
F
Label
Unit: mm (inch)
H
M C
E
C
E
F
G
H
M
13.0 ± 0.2
(0.51 ± 0.008)
60.0 ± 1.0
(2.36 ± 0.03)
11.4 ± 1.0
(0.45 ± 0.04)
9.0 ± .3
(0.35 ± 0.012)
1.5 ± .3
(0.06 ± 0.012)
180 ± 2.0
(7.09 ± 0.08)
Minimum of 30 empty pockets at the beginning of reel, 65 minimum empty pockets at the end.
G
TAPE SPECIFICATIONS
T
G
B
A
F
W
T
J
Dø
Embossed
H
Paper
E
Units: mm (inches).
TAPE
Paper
SIZE (in)
A
B
W
E
F
T
G
H
J
Dø
0402
1.15 ±0.10
0.65 ±0.10
8.0 ±0.20
1.75 ±0.10
3.50 ±0.05
0.45 ±0.10
2.00 ±0.05
4.00 ±0.10
2.00 ±0.05
1.50 ±0.10
0603
1.90 ±0.10
1.10 ±0.10
8.0 ±0.20
1.75 ±0.10
3.50 ±0.05
0.70 ±0.10
4.00 ±0.10
4.00 ±0.10
2.00 ±0.05
1.50 ±0.10
0805
2.40 ±0.10
1.65 ±0.10
8.0 ±0.20
1.75 ±0.10
3.50 ±0.05
0.85 ±0.10
4.00 ±0.10
4.00 ±0.10
2.00 ±0.05
1.50 ±0.10
1206
3.50 ±0.10
1.90 ±0.10
8.0 ±0.20
1.75 ±0.10
3.50 ±0.05
0.85 ±0.10
4.00 ±0.10
4.00 ±0.10
2.00 ±0.05
1.50 ±0.10
1210
3.50 ±0.10
2.80 ±0.10
8.0 ±0.20
1.75 ±0.10
3.50 ±0.05
0.85 ±0.10
4.00 ±0.10
4.00 ±0.05
2.00 ±0.05
1.50 ±0.10
PEEL BACK FORCE AND DIRECTION DIAGRAM
Direction of pull
Top cover tape
Carrier tape
Peel back force and direction of peel back angle should follow
EIA481-1-A. Peel back force should be between 0.1N – 1.3N
and peel back angle of 165˚ – 180˚.
165 ~ 180˚
Direction of unreeling
Bottom cover tape
Web: www.venkel.com
Rev: 03/2021-A
3
HPCR
SERIES
ENVIRONMENTAL CHARACTERISTICS
REQUIREMENT
TEST
±1% and below
±5%
Temperature Coefficient of
Resistance (T.C.R.)
Short Time Overload
TEST METHOD
Jumper
JIS-C-5201-1 4.8
IEC-60115-1 4.8
At 25°C/-55°C and 25°C/+125°C, 25°C is the reference temperature
As Spec.
±(1.0%+0.05Ω)
Insulation Resistance
±(2.0%+0.05Ω)
很抱歉,暂时无法提供与“HPCR0402-R-6490FT”相匹配的价格&库存,您可以联系我们找货
