HCJ0402ZT0R00
HCJ0402ZT0R00
    SEI
    贴片电阻 0402 0Ω - 1/8W
HCJ0402ZT0R00 数据手册
HCJ Series Stackpole Electronics, Inc. Surface Mount High Current Jumper Chip Resistor Resistive Product Solutions Features: • • • • • • Chip size from 0201 to 2512 Max. resistance value less than 3 milliohm for 0201 and 0402, less than 0.5 milliohm for all other sizes Qualified to AEC-Q200 100% RoHS compliant and lead free without exemption Halogen free REACH compliant Applications: • • • • • Switching power supply Voltage regulation module DC-DC converter, adaptor, battery pack, charger PDA and cell phone Power and battery management applications Electrical Specifications Type/Code Power Rating (W) @ 70°C Current Rating (A) Max Overload Current (A) HCJ0201 HCJ0402 HCJ0603 HCJ0805 HCJ1206 HCJ2010 HCJ2512 0.1 0.125 0.25 0.5 0.75 1 2 5.8 6.5 22.4 31.6 38.7 70.7 63.2 14.5 16.25 56 79 96.7 112 158 Operating Temperature Range Ohmic Range (Ω) -55ºC to +155°C ≤ 0.003 ≤ 0.003 ≤ 0.0005 ≤ 0.0005 ≤ 0.0005 ≤ 0.0002 ≤ 0.0005 Power rating: P=I2*R Mechanical Specifications Type/Code 0.024 HCJ0201 0.60 0.039 HCJ0402 1.00 0.063 HCJ0603 1.60 0.079 HCJ0805 2.00 0.126 HCJ1206 3.20 0.200 HCJ2010 5.08 0.252 HCJ2512 6.40 Note: Size 0201 has no marking. L ± ± ± ± ± ± ± ± ± ± ± ± ± ± W 0.001 0.03 0.004 0.10 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.012 0.30 Rev Date: 6/29/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 0.012 0.30 0.020 0.50 0.031 0.80 0.047 1.20 0.063 1.60 0.100 2.54 0.126 3.20 ± ± ± ± ± ± ± ± ± ± ± ± ± ± H 0.001 0.03 0.002 0.05 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.012 0.30 1 0.010 0.26 0.016 0.40 0.020 0.50 0.026 0.65 0.026 0.65 0.026 0.65 0.026 0.65 ± ± ± ± ± ± ± ± ± ± ± ± ± ± a 0.002 0.05 0.002 0.05 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.006 0.15 0.012 0.30 0.016 0.40 0.022 0.55 0.031 0.80 0.083 2.10 0.037 0.95 ± ± ± ± ± ± ± ± ± ± ± ± ± ± Unit 0.002 0.05 0.004 0.10 0.008 0.20 0.008 0.20 0.008 0.20 0.012 0.30 0.014 0.35 inches mm inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com HCJ Series Stackpole Electronics, Inc. Surface Mount High Current Jumper Chip Resistor Resistive Product Solutions Performance Characteristics Test Short Time Overload High Temperature Exposure Low Temperature Storage Resistance to Solder Heat Moisture Load Life Temperature cycling Load Life Mechanical Shock Test Method Test Specification Test Condition JIS C-5201-1 clause 4.13 JIS C-5201-1 clause 4.23.2 JIS C 5201-1 clause 4.23.4 JIS C-5201-1 clause 4.18 2.5 times of rated current Rating power duration: 5 seconds 1000 hours at 155°C ± 2°C 1000 hours at -55°C ± 2°C The part shall be immersed into the flux specified in the solder bath 260°C ± 5°C for 10 ± 1 seconds Specimens shall be placed in a chamber and subject to a relative humidity of 90~95% and to a temperature of 40°C ± 2°C. Load with rated current 1.5 hours "ON", 0.5 hours "OFF", for the period of 1000 hours. JIS C-5201-1 clause 4.24 JIS C-5201-1 clause 4.19 JIS C-5201-1 clause 4.25 JIS C-5202 clause 6.7 -55°C to +155°C, 100 cycles For size 0402, max. 0.003 Ω All other sizes, max. 0.0005 Ω Apply rated power at 70°C ± 2°C for 1000 hours with 1.5 hours "ON" and 0.5 hour "OFF" a = 50 G, t = 11 ms, 5 times shock Span between fulcrums: 90mm Bend width: 2mm Substrate Bending JIS C-5201-1 clause 4.33 JIS C-5201-1 Solder shall cover 95% or more clause 4.17 of the electrode area Operating temperature range is -55°C to 155°C Solderability 245ºC ± 5°C for 3 ± 0.5 seconds Power Derating Curve: Percent Rated Power (%) 100 -55ºC 70ºC 80 60 40 20 0 -60 155ºC 0 20 40 60 80 100 120 140 160 180 Ambient Temperature (ºC) Rev Date: 6/29/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com HCJ Series Stackpole Electronics, Inc. Surface Mount High Current Jumper Chip Resistor Resistive Product Solutions Recommended Pad Layout Type/Code HCJ0201 HCJ0402 HCJ0603 HCJ0805 HCJ1206 HCJ2010 HCJ2512 a b c Unit 0.010 0.25 0.016 0.40 0.024 0.60 0.031 0.80 0.047 1.20 0.028 0.70 0.150 3.80 0.012 0.30 0.020 0.50 0.051 1.30 0.055 1.40 0.071 1.80 0.144 3.65 0.083 2.10 0.014 0.35 0.024 0.60 0.036 0.92 0.057 1.44 0.072 1.84 0.113 2.88 0.134 3.40 inches mm inches mm inches mm inches mm inches mm inches mm inches mm Wave Solder Temperature Condition Preheating Soldering Maximum Temperature Rev Date: 6/29/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 100°C ~ 130°C, max. 100 seconds 250°C ~ 265°C, max. 10 seconds 260°C ± 5°C, max. 10 seconds 3 www.seielect.com marketing@seielect.com HCJ Series Stackpole Electronics, Inc. Surface Mount High Current Jumper Chip Resistor Resistive Product Solutions Solder Reflow Temperature Condition Profile Feature Pb-Free Assembly Average Ramp-up Rate (Tsmax to Tp) 3°C / second max. Preheat - Temperature Min (Tsmin) - Temperature Max (Tsmax) 150°C 200°C - Time (tsmin to tsmax) 60 - 180 seconds Time maintained - Temperature (T L) - Time (tL) 217°C 60 - 150 seconds Peak Temperature (T p) 260 + 0°C Time within 5°C of actual peak Temperature (tp) Ramp-Down Rate Time 25°C to Peak Temperature 20 - 40 seconds 6°C / second max. 8 minutes max. Packaging Specifications Type/Code All sizes except 2010 and 2512 HCJ2010 and HCJ2512 ØD 2.362 60.00 2.362 60.00 ± ± ± ± W 0.079 2.00 0.079 2.00 Rev Date: 6/29/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 0.354 9.00 0.512 13.00 4 ± ± ± ± ØM 0.039 1.00 0.039 1.00 7.008 178.00 7.008 178.00 ± ± ± ± 0.197 5.00 0.197 5.00 Unit inches mm inches mm www.seielect.com marketing@seielect.com HCJ Series Stackpole Electronics, Inc. Surface Mount High Current Jumper Chip Resistor Resistive Product Solutions Taping Specifications – Paper Tape Type/Code HCJ0201 HCJ0402 HCJ0603 HCJ0805 HCJ1206 A 0.018 0.45 0.028 0.70 0.046 1.18 0.066 1.68 0.081 2.05 Type/Code HCJ0201 HCJ0402 HCJ0603 HCJ0805 HCJ1206 ± ± ± ± ± ± ± ± ± ± B 0.004 0.10 0.002 0.05 0.008 0.20 0.008 0.20 0.008 0.20 0.030 0.75 0.047 1.20 0.078 1.98 0.094 2.38 0.144 3.65 G 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± E 0.004 0.10 0.002 0.05 0.008 0.20 0.008 0.20 0.008 0.20 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 P 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.157 4.00 0.079 2.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± F 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 H 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± W 0.002 0.05 0.002 0.05 0.004 0.10 0.004 0.10 0.004 0.10 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 D 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 +0.004/-0.00 +0.10/-0.00 +0.004/-0.00 +0.10/-0.00 +0.004/-0.00 +0.10/-0.00 +0.004/-0.00 +0.10/-0.00 +0.004/-0.00 +0.10/-0.00 ± ± ± ± ± ± ± ± ± ± Unit 0.008 0.20 0.008 0.20 0.012 0.30 0.012 0.30 0.012 0.30 T 0.014 0.35 0.018 0.45 0.030 0.75 0.034 0.87 0.034 0.87 ± ± ± ± ± ± ± ± ± ± inches mm inches mm inches mm inches mm inches mm Unit 0.004 0.10 0.004 0.10 0.008 0.20 0.008 0.20 0.008 0.20 inches mm inches mm inches mm inches mm inches mm 0.012 0.30 0.012 0.30 inches mm inches mm Taping Specifications – Embossed Plastic Tape Type/Code HCJ2010 HCJ2512 A 0.112 2.85 0.134 3.40 Type/Code HCJ2010 HCJ2512 ± ± ± ± B 0.008 0.20 0.008 0.20 0.215 5.45 0.266 6.75 P0 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± E 0.008 0.20 0.008 0.20 0.069 1.75 0.069 1.75 P1 0.004 0.10 0.004 0.10 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± F 0.004 0.10 0.004 0.10 0.217 5.50 0.217 5.50 P2 0.004 0.10 0.004 0.10 Rev Date: 6/29/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 0.079 2.00 0.079 2.00 5 ± ± ± ± ± ± ± ± W 0.002 0.05 0.002 0.05 0.472 12.00 0.472 12.00 D0 0.004 0.10 0.004 0.10 0.059 1.50 0.059 1.50 +0.004/-0.00 +0.10/-0.00 +0.004/-0.00 +0.10/-0.00 ± ± ± ± Unit T 0.031 0.80 0.031 0.80 ± ± ± ± Unit 0.008 0.20 0.008 0.20 inches mm inches mm www.seielect.com marketing@seielect.com HCJ Series Stackpole Electronics, Inc. Surface Mount High Current Jumper Chip Resistor Resistive Product Solutions RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description Package / Termination Type HCJ Molded Metal Plate Sensing Resistor SMD Standard Series RoHS Compliant YES Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) 100% Matte Sn over Ni Always Lead-Free Effective Date Code (YY/WW) Always “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order 1 2 3 4 5 6 7 8 9 10 11 12 13 H C J 0 6 0 3 Z T 0 R 0 0 Product Series Size SM High Current Size A HCJ Jumper Chip 0201 5.8 0402 6.5 0603 22.4 0805 31.6 1206 38.7 2010 70.7 2512 63.2 Code Z Tolerance Tol Size Value (Ω) 0402 ≤ 0.003 0603 Zero 0805 Ohm ≤ 0.0005 1206 2512 Rev Date: 6/29/2021 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 6 Code T Packaging Description Size Quantity 0201, 0402 10000 Paper Tape 0603, 0805, 1206 5000 Embossed Plastic 2010, 2512 4000 Resistance Value Four characters with the multiplier used as the decimal holder. 0 ohm = 0R00 www.seielect.com marketing@seielect.com
HCJ0402ZT0R00 价格&库存
很抱歉,暂时无法提供与“HCJ0402ZT0R00”相匹配的价格&库存,您可以联系我们找货
HCJ0402ZT0R00
    • 5+1.44882
    • 50+1.14923
    • 150+1.02093
    • 500+0.86076
    • 2500+0.78938
    • 5000+0.74661
    库存:9389
    HCJ0402ZT0R00
    • 1+3.262761+0.42166
    • 10+2.0717510+0.26774
    • 25+1.7529325+0.22654
    • 50+1.5520550+0.20058
    • 100+1.38177100+0.17857
    • 250+1.19464250+0.15439
    • 500+1.07774500+0.13928
    • 1000+0.978181000+0.12642
    • 5000+0.800885000+0.10350
    库存:41431
    HCJ0402ZT0R00
    • 10000+0.7429310000+0.09601
    • 20000+0.6937020000+0.08965
    • 30000+0.6684230000+0.08638
    • 50000+0.6398250000+0.08269
    • 70000+0.6228070000+0.08049
    • 100000+0.60624100000+0.07835
    库存:41431
