HCJ Series
Stackpole Electronics, Inc.
Surface Mount High Current Jumper Chip Resistor
Resistive Product Solutions
Features:
Chip size from 0201 to 2512
Max. resistance value less than 3 milliohm for 0201 and 0402,
less than 0.5 milliohm for all other sizes
Qualified to AEC-Q200
100% RoHS compliant and lead free without exemption
Halogen free
REACH compliant
Applications:
Switching power supply
Voltage regulation module
DC-DC converter, adaptor, battery pack, charger
PDA and cell phone
Power and battery management applications
Electrical Specifications
Type/Code
Power Rating (W)
@ 70°C
Current Rating (A)
Max Overload
Current (A)
HCJ0201
HCJ0402
HCJ0603
HCJ0805
HCJ1206
HCJ2010
HCJ2512
0.1
0.125
0.25
0.5
0.75
1
2
5.8
6.5
22.4
31.6
38.7
70.7
63.2
14.5
16.25
56
79
96.7
112
158
Operating Temperature
Range
Ohmic Range (Ω)
-55ºC to +155°C
≤ 0.003
≤ 0.003
≤ 0.0005
≤ 0.0005
≤ 0.0005
≤ 0.0002
≤ 0.0005
Power rating: P=I2*R
Mechanical Specifications
Type/Code
0.024
HCJ0201
0.60
0.039
HCJ0402
1.00
0.063
HCJ0603
1.60
0.079
HCJ0805
2.00
0.126
HCJ1206
3.20
0.200
HCJ2010
5.08
0.252
HCJ2512
6.40
Note: Size 0201 has no marking.
L
W
0.001
0.03
0.004
0.10
0.010
0.25
0.010
0.25
0.010
0.25
0.010
0.25
0.012
0.30
Rev Date: 6/29/2021
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
0.012
0.30
0.020
0.50
0.031
0.80
0.047
1.20
0.063
1.60
0.100
2.54
0.126
3.20
H
0.001
0.03
0.002
0.05
0.010
0.25
0.010
0.25
0.010
0.25
0.010
0.25
0.012
0.30
1
0.010
0.26
0.016
0.40
0.020
0.50
0.026
0.65
0.026
0.65
0.026
0.65
0.026
0.65
a
0.002
0.05
0.002
0.05
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.006
0.15
0.012
0.30
0.016
0.40
0.022
0.55
0.031
0.80
0.083
2.10
0.037
0.95
Unit
0.002
0.05
0.004
0.10
0.008
0.20
0.008
0.20
0.008
0.20
0.012
0.30
0.014
0.35
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
marketing@seielect.com
HCJ Series
Performance Characteristics
Test
Short Time Overload
High Temperature
Exposure
Low Temperature
Storage
Resistance to
Solder Heat
Moisture Load Life
Temperature cycling
Load Life
Mechanical Shock
Test Method
Test Specification
Test Condition
JIS C-5201-1
clause 4.13
JIS C-5201-1
clause 4.23.2
JIS C 5201-1
clause 4.23.4
JIS C-5201-1
clause 4.18
2.5 times of rated current
Rating power duration: 5 seconds
1000 hours at 155°C ± 2°C
1000 hours at -55°C ± 2°C
The part shall be immersed into the flux specified in the
solder bath 260°C ± 5°C for 10 ± 1 seconds
Specimens shall be placed in a chamber and subject to
a relative humidity of 90~95% and to a temperature of
40°C ± 2°C. Load with rated current 1.5 hours "ON", 0.5
hours "OFF", for the period of 1000 hours.
JIS C-5201-1
clause 4.24
JIS C-5201-1
clause 4.19
JIS C-5201-1
clause 4.25
JIS C-5202
clause 6.7
-55°C to +155°C, 100 cycles
For size 0402, max. 0.003 Ω
All other sizes, max. 0.0005 Ω
Apply rated power at 70°C ± 2°C for 1000 hours
with 1.5 hours "ON" and 0.5 hour "OFF"
a = 50 G, t = 11 ms, 5 times shock
Span between fulcrums: 90mm
Bend width: 2mm
Substrate Bending
JIS C-5201-1
clause 4.33
JIS C-5201-1 Solder shall cover 95% or more
clause 4.17
of the electrode area
Operating temperature range is -55°C to 155°C
Solderability
245ºC ± 5°C for 3 ± 0.5 seconds
Power Derating Curve:
Percent Rated Power (%)
100
-55ºC
70ºC
80
60
40
155ºC
60
80
100
120
140
160
180
Ambient Temperature (ºC)
Rev Date: 6/29/2021
2
www.seielect.com
HCJ Series
Recommended Pad Layout
Type/Code
HCJ0201
HCJ0402
HCJ0603
HCJ0805
HCJ1206
HCJ2010
HCJ2512
a
b
c
Unit
0.010
0.25
0.016
0.40
0.024
0.60
0.031
0.80
0.047
1.20
0.028
0.70
0.150
3.80
0.012
0.30
0.020
0.50
0.051
1.30
0.055
1.40
0.071
1.80
0.144
3.65
0.083
2.10
0.014
0.35
0.024
0.60
0.036
0.92
0.057
1.44
0.072
1.84
0.113
2.88
0.134
3.40
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Wave Solder Temperature Condition
Preheating
Soldering
Maximum Temperature
Rev Date: 6/29/2021
100°C ~ 130°C, max. 100 seconds
250°C ~ 265°C, max. 10 seconds
260°C ± 5°C, max. 10 seconds
3
www.seielect.com
HCJ Series
Solder Reflow Temperature Condition
Profile Feature
Pb-Free Assembly
Average Ramp-up Rate (Tsmax to Tp)
3°C / second max.
Preheat
- Temperature Min (Tsmin)
- Temperature Max (Tsmax)
150°C
200°C
- Time (tsmin to tsmax)
60 - 180 seconds
Time maintained
- Temperature (T L)
- Time (tL)
217°C
60 - 150 seconds
Peak Temperature (T p)
260 + 0°C
Time within 5°C of actual peak
Temperature (tp)
Ramp-Down Rate
Time 25°C to Peak Temperature
20 - 40 seconds
6°C / second max.
8 minutes max.
Packaging Specifications
Type/Code
All sizes except 2010 and 2512
HCJ2010 and HCJ2512
ØD
2.362
60.00
2.362
60.00
W
0.079
2.00
0.079
2.00
Rev Date: 6/29/2021
0.354
9.00
0.512
13.00
4
ØM
0.039
1.00
0.039
1.00
7.008
178.00
7.008
178.00
0.197
5.00
0.197
5.00
Unit
inches
mm
inches
mm
www.seielect.com
HCJ Series
Taping Specifications – Paper Tape
Type/Code
HCJ0201
HCJ0402
HCJ0603
HCJ0805
HCJ1206
A
0.018
0.45
0.028
0.70
0.046
1.18
0.066
1.68
0.081
2.05
Type/Code
HCJ0201
HCJ0402
HCJ0603
HCJ0805
HCJ1206
B
0.004
0.10
0.002
0.05
0.008
0.20
0.008
0.20
0.008
0.20
0.030
0.75
0.047
1.20
0.078
1.98
0.094
2.38
0.144
3.65
G
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
E
0.004
0.10
0.002
0.05
0.008
0.20
0.008
0.20
0.008
0.20
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
P
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.157
4.00
0.079
2.00
0.157
4.00
0.157
4.00
0.157
4.00
F
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
H
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
W
0.002
0.05
0.002
0.05
0.004
0.10
0.004
0.10
0.004
0.10
0.315
8.00
0.315
8.00
0.315
8.00
0.315
8.00
0.315
8.00
D
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.059
1.50
0.059
1.50
0.059
1.50
0.059
1.50
0.059
1.50
+0.004/-0.00
+0.10/-0.00
+0.004/-0.00
+0.10/-0.00
+0.004/-0.00
+0.10/-0.00
+0.004/-0.00
+0.10/-0.00
+0.004/-0.00
+0.10/-0.00
Unit
0.008
0.20
0.008
0.20
0.012
0.30
0.012
0.30
0.012
0.30
T
0.014
0.35
0.018
0.45
0.030
0.75
0.034
0.87
0.034
0.87
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Unit
0.004
0.10
0.004
0.10
0.008
0.20
0.008
0.20
0.008
0.20
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
0.012
0.30
0.012
0.30
inches
mm
inches
mm
Taping Specifications – Embossed Plastic Tape
Type/Code
HCJ2010
HCJ2512
A
0.112
2.85
0.134
3.40
Type/Code
HCJ2010
HCJ2512
B
0.008
0.20
0.008
0.20
0.215
5.45
0.266
6.75
P0
0.157
4.00
0.157
4.00
E
0.008
0.20
0.008
0.20
0.069
1.75
0.069
1.75
P1
0.004
0.10
0.004
0.10
0.157
4.00
0.157
4.00
F
0.004
0.10
0.004
0.10
0.217
5.50
0.217
5.50
P2
0.004
0.10
0.004
0.10
Rev Date: 6/29/2021
0.079
2.00
0.079
2.00
5
W
0.002
0.05
0.002
0.05
0.472
12.00
0.472
12.00
D0
0.004
0.10
0.004
0.10
0.059
1.50
0.059
1.50
+0.004/-0.00
+0.10/-0.00
+0.004/-0.00
+0.10/-0.00
Unit
T
0.031
0.80
0.031
0.80
Unit
0.008
0.20
0.008
0.20
inches
mm
inches
mm
www.seielect.com
HCJ Series
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
Description
Package /
Termination
Type
HCJ
Molded Metal Plate Sensing Resistor
SMD
Standard
Series
RoHS
Compliant
YES
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
100% Matte Sn over Ni
Always
Lead-Free
Effective Date
Code
(YY/WW)
Always
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region”
of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals
used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible
that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in
compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High
Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation,
Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH
Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We
continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the
protection of our environment and all requests related to the environment to which we have agreed. We are committed
to the prevention of all forms of pollution.
How to Order
1
2
3
4
5
6
7
8
9
10
11
12
13
H
C
J
Z
T
R
Product Series
Size
SM High Current Size
A
HCJ
Jumper Chip
0201 5.8
0402 6.5
0603 22.4
0805 31.6
1206 38.7
2010 70.7
2512 63.2
Code
Z
Tolerance
Tol
Size Value (Ω)
0402 ≤ 0.003
0603
Zero
0805
Ohm
≤ 0.0005
1206
2512
Rev Date: 6/29/2021
6
Code
T
Packaging
Description
Size
Quantity
0201, 0402
10000
Paper Tape
0603, 0805, 1206 5000
Embossed Plastic
2010, 2512
4000
Resistance Value
Four characters with
the multiplier used as
the decimal holder.
0 ohm = 0R00
www.seielect.com
很抱歉,暂时无法提供与“HCJ1206ZT0R00”相匹配的价格&库存,您可以联系我们找货
