IS6607A
IS6607A
    CHANGGONG(长工微)
    DFN21_3X4MM
    DC-DC电源芯片 QFN21 2.4V~16V 可调
IS6607A 数据手册
IS6607A 3.5V to 16V Input, 20A Sync Step-Down Converter W/ Light Load Mode, Programmable Switching Frequency and Over Current Limit Rev2.6 05/2020 Part Number IS6607A Input Voltage 3.5V~16V Output Voltage 0.6V~5.5V Current Rating 20A Description The IS6607A is a high power density, fully integrated synchronous buck converter. It works with wide input voltage range and can support up to 20A continuous output current at defined conditions. LDO is integrated internally, which is very suitable for single input supply condition. External bias is optional for maximizing the efficiency. A differential sensing scheme and a 0.6V internal feedback reference voltage achieve ±1% output voltage tolerance over full temperature range. The IS6607A provides excellent line and load regulation. Switching frequency can be easily programmed among 600kHz, 800kHz and 1MHz. The IS6607A uses patented Turbo Constant On Time (TCOTTM) to control the algorithm with fast transient response. Pure MLCC output capacitors can be used to save space and cost. The IS6607A has fully integrated protection features including OCP, NOCP, OVP, UVP and over temperature protection (OTP). Features Turbo Constant On Time (TCOTTM) Control with Fast Transient Response. • VIN Input Voltage Range: 2.4 V to 16V with External Bias VCC voltage, or 3.5V to 16V with Internal Bias VCC. • Output Voltage Range: 0.6V to 5.5V, and 90% Max Duty Cycle. • 20A Continuous Output Current. • Excellent Load and Line Regulations with 1% Voltage Accuracy. • Up to 90% Efficiency at VIN=12V, VOUT=1.2V • Differential Remote Sense • Mode Selection between Pulse Skip and CCM at Light Load • Output Voltage Track and Discharge • Pre-bias Start-up • • The IS6607A is available in a QFN 3mm x 4mm package with 21-Pin. Junction Temperature Range from -40ºC to 125ºC • Programmable Soft-Start Time Moisture Sensitivity Leve 3. • 1.0µA Current into VIN Pin during Shutdown Programmable Valley Current Limit Programmable Switching Frequency: 600kHz, 800kHz and 1MHz OCP, NOCP, OVP, UVLO and OTP QFN 3mm x 4mm Package with 21-Pin Applications • • • Computers and Servers POLs Telecom/Datacom POLs Point of Load Module Production Datasheet • • • • Innovision Semiconductor 1 IS6607A Rev2.6 05/2020 Typical Application Circuit C4 R6 BST L1 VIN VIN C1 PHASE VO C2 VCC C8 FB C3 R1 C9 R4 PGOOD PGD IS6607A ON R5 RTN EN OFF C6 MODE R3 Production Datasheet PG ND CS R2 AG ND REF Innovision Semiconductor 2 IS6607A Rev2.6 05/2020 Order Information Part Number Package Shipping Method Package Marking IS6607A QFN-21(3mm x 4mm) 5000u Tape & Reel IS6607A TOP MARKING (IS6607A) IS6607A C12TC8 YYWW IS: Innovision Semiconductor prefix 6607A: First five digits of the part number C12TC8: Production site Y: Year code W: Week code Package Reference VIN 21 PHASE 20 BST 1 19 VCC AGND 2 18 PGND CS 3 17 PGND MODE 4 16 PGND REF 5 15 PGND RTN 6 14 PGND FB 7 13 PGND EN 8 12 PGND 11 PGND PGOOD 9 10 VIN Top View Production Datasheet Innovision Semiconductor 3 IS6607A Rev2.6 05/2020 Absolute Maximum Ratings Thermal Ratings Supply Voltage (Vin) …………………. -0.3V to 20V Vcc Voltage (Vcc)…………………………-0.3V to 5.5V Switch Node Voltage (VPH) DC…………-0.3V to 20V Switch Node Voltage (VPH) 25ns……...-5V to 25V BST Pin (Vbst-sw) DC………………… -0.3V to 5.5V All other pins……………………………-0.3V to 5.5V Junction Temperature (T j )………………….150°C Storage Temperature…………………-65°C to 150°C Θ JC Max…………………………………….17°C/W ΘJB Typ (Still Air, No Heat sink) …………….8°C/W Recommended Operating Conditions Supply Voltage (Vin)………………………2.4V to 16V V c c Voltage (V cc )…………………….3.0V to 5V Output Voltage (Vo)………………………0.6V to 5.5V Max Output Current (I o_max)…………………… 20A Junction Temperature (T j)……….. -40°C to 125°C Note 1. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only; functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ESD Ratings Electrostatic Discharge Standard Value Human Body Mode (HBM) Charge Device Mode (CDM) JEDEC EIA/JESD22-A114 JEDEC EIA/JESD22-C101F ±1500V ±2000V 1). JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. 2). JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. Production Datasheet Innovision Semiconductor 4 IS6607A Rev2.6 05/2020 Pin Out and Package IS6607A(QFN-21) Pin Number Name Description Bootstrap connection. Connect a capacitor between PHASE and BST, which is required to form a floating supply across the high-side switch driver. 1 BST 2 AGND 3 CS 4 MODE 5 REF Connect a capacitor to PGND to set soft start time or to an external reference for output voltage tracking. The capacitance of this capacitor determines the soft-start time. 6 RTN Output remote sense feedback. Connect the pin to the negative side of the voltage sense point. 7 FB Output remote sense return. An external resistor divider from the output to RTN (tapped to FB) sets the output voltage. 8 EN Enable pin. An input signal turns the regulator on or off. Connect EN to VIN through a pull-up resistor. Do not float this pin. 9 PGOOD Power good output with open drain. If the output voltage is within regulation, the pull-up resistor is required to indicate high. 10, 21 VIN Supply voltage. Input to the power stage and internal LDO. Make the connection with wide PCB traces. 11~18 PGND System ground. PGND is power ground of the power stage. Make the connection with wide PCB traces. 19 VCC Internal 5V LDO output. Supply power for the drive and control circuits. 20 PHASE Production Datasheet Signal logic ground. A Kelvin connection to PGND is required. Current limit and inductor current report. Connect a resistor to AGND to set the valley current limit trip point. A voltage indicating the inductor current during operating. Operation mode selection. Connect a resistor to AGND to set switching frequency and DCM/FCCM operation. Switch output. Switch node of power stage. Connect PH to the inductor and bootstrap capacitor. Make the connection with wide PCB traces. Innovision Semiconductor 5 IS6607A Rev2.6 05/2020 FUNCTIONAL BLOCK DIAGRAM VIN MODE VCC MODE Select LDO BST REG BST Off Timer EN Reference System Monitor HS Driver xS OV_TH UV_TH REF RTN + -Error Amplifier FB Q + PWM Comparator PHASE Logic Control On Timer Ramp HSG OV_TH + PGOOD PGOOD Comparator UV_TH LSG LS Driver + - HSG LSG xR OV Detect Comparator + ZCD UV Detect Comparator xLIM Valley Current Limit& ZCD PGND FAULT CS Production Datasheet Innovision Semiconductor 6 IS6607A Rev2.6 05/2020 ELECTRICAL CHARACTERISTICS Definition/Datasheet Parameters Min Typ Unit Max SUPPLY VOLTAGE & CURRENT VIN Supply Voltage (with internal LDO) 3.5 16 V VIN Supply Voltage (with external bias VCC voltage) 2.4 16 V VIN Supply Current (Quiescent) EN=2V ,VFB = 1V VIN Shutdown Current EN="Lo" 1950 0 µA 10 µA VCC Supply VCC Output Voltage (5.3V 2 × 8 × where • • COUT(min) is the minimum output capacitance needed to meet the stability requirement of the design tON is the on-time information based on the switching frequency and duty cycle (in this design, 100 ns) • τ is the ramp compensation time constant of the design based on the switching frequency and duty cycle (in this design, 1 sec) • LOUT is the output inductance (in the design, 0.39 µH) Production Datasheet Use the next equation to estimate the amount of capacitance needed for a given dynamic load release. _ = ×∆ 2×∆ _ × In general applications where the overall output voltage tolerance is +/-5%, the allowed transient voltage deviation during the worst case load release can be set at around 3% depending on how much output voltage setpoint accuracy (1% in this design) and the ripple voltage requirement (1% in this design). The minimum output capacitance to meet the overshoot requirement can be calculated using the above equation. This example uses a combination of POSCAP and MLCC capacitors to meet the overshoot requirement. • POSCAP bank #1: 2 x 470 µF, 2.5 V, 6 mΩ per capacitor Innovision Semiconductor 17 IS6607A Rev2.6 05/2020 • MLCC bank #2: 4 × 100 µF, 2.5 V, 1 mΩ per capacitor with DC+AC derating factor of 50% Recalculating the worst case overshoot using the described capacitor bank design, the overshoot needs to be 30 mV or less which meets the 3% overshoot transient specification requirement. Output Voltage Ripple The output voltage ripple is another important design consideration. The following equation calculates the minimum output capacitance required to meet the output voltage ripple specification. This criterion is the requirement when the impedance of the output capacitance is dominated by ESR. _ = 8× × _ In this example, the maximum output voltage ripple is 5.5 mV. Because this capacitance value is significantly lower compared to that of transient load release, determining the output capacitance bank using the worst case load release requirement is generally adequate. Because the output capacitor bank consists of both POSCAP and MLCC type capacitors, it is important to consider the ripple effect at the switching frequency due to effective ESR. For detailed calculations, please contact the factory to obtain a user-friendly Excel based design tool. 4. Input Capacitor Selection The IS6607A devices require a high-quality, ceramic, type X5R or X7R, input decoupling capacitor with a value of at least 1 μF of effective capacitance on the VCC pin, relative to AGND. The power stage input decoupling capacitance (effective capacitance at the VIN and PGND pins) must be sufficient to supply the high switching currents demanded when the high-side MOSFET switches on, while providing minimal input voltage ripple as a result. This effective capacitance includes any DC bias effects. The voltage rating of the input capacitor must be greater than the maximum input voltage. The capacitor must also have a ripple current rating greater than the maximum input current ripple to the device during full load. The input ripple current can be calculated using the equation below. Production Datasheet The value of a ceramic capacitor varies significantly over temperature and the amount of DC bias applied to the capacitor. The capacitance variations due to temperature can be minimized by selecting a dielectric material that is stable over temperature. X5R and X7R ceramic dielectrics are usually selected for power regulator capacitors because they have a high capacitance to volume ratio and are fairly stable over temperature. The input capacitor must also be selected with the DC bias taken into consideration. For this design example, a ceramic capacitor with at least a 25 V voltage rating is required to support the maximum input voltage. For this design, allow 0.1 V input ripple for VRIPPLE(cap), and 0.3 V input ripple for VRIPPLE(esr). the minimum input capacitance for this design is 38.5 µF, and the maximum ESR is 9.4 mΩ. For this example, four 22 μF, 25 V low-ESR polymer capacitors in parallel were selected for the power stage. Bootstrap Capacitor Selection A ceramic capacitor with a value of 0.1 μF must be connected between the BOOT and SW pins for proper operation. It is recommended to use a ceramic capacitor with X5R or better grade dielectric. Use a capacitor with a voltage rating of 25 V or higher. 5. R-C Snubber and VIN Pin HighFrequency Bypass Though it is possible to operate the IS6607A within absolute maximum ratings without ringing reduction techniques, some designs may require external components to further reduce ringing levels. This example uses two approaches: a high frequency power stage bypass capacitor on the VIN pins, and an R-C snubber between the PHASE area and GND. The high-frequency VIN bypass capacitor is a lossless ringing reduction technique which helps minimizes the outboard parasitic inductances in the power stage, which store energy during the low-side MOSFET on-time, and discharge once the high-side MOSFET is turned on. For this design twin 2.2 nF, 25 V, 0603 sized high-frequency capacitors are used. The placement of these capacitors is critical to its effectiveness. Its ideal placement is shown in PCB layout guidelines. Innovision Semiconductor 18 IS6607A Rev2.6 05/2020 PCB Layout Guidelines Efficient PCB layout is crucial to the stable operation of the circuit. For best performance, refer to the figure in the PCB layout column and follow the PCB layout recommendations below. 1.The input MLCC capacitor shall be as close as possible to the VIN and PGND pins and the main MLCC capacitor shall be placed on the same wiring layer as IS6607A. The copper plane of VIN and PGND can be maximized to minimize the parasitic impedance. 2. A capacitor with a minimum capacitance of 0.1μF must be close to pin 10(VIN pin). At least two 20/10 mil vias are required to connect the grounding end of the capacitor to the ground plane of the PCB board. Production Datasheet 3. Place as many PGND holes as possible nearest to the PGND pin to minimize parasitic impedance and thermal resistance. 4. VCC capacitor should be placed as close to the IS6607A as possible. Connect AGND and PGND at VCC capacitor's grounding point. 5. Place the BST capacitor as close as possible to BST and PH. Routing widths should be greater than 20mil. It is recommended to use a 0.1µF to 1µF bootstrap capacitor. Place the BST resistance between the IC and the BST capacitor to achieve Damping effect. It is recommended to use a 3.3Ω resistance. 6. Place the REF capacitor close to REF and connected to the RTN. It is recommended to use a 22nF capacitor. Innovision Semiconductor 19 IS6607A Rev2.6 05/2020 Typical Application Circuits VIN C4 0.1uF C5 PHASE R1 1 1.0V @ 20A 12 9 EN 8 PGND MODE 4 CS 3 BST C7 VCC U1 PGOOD EN FB R3 3k MODE R6 4k FB RTN 6 RTN CS R2 2k NC 7 IS6607A 2 R5 0 VOUT 13 PHASE PGND R4 10k VIN 5 REF C11 0.22uF C12 NC REF 11 PGOOD 10,14 C6 1uF L1 390nH AGND VCC PGND PGND AGND AGND AGND PGND BST VIN C4 0.1uF C5 PHASE 1 R1 12 9 EN 8 PGND MODE 4 CS 3 R6 4k PHASE VOUT 13 C7 VCC U1 PGOOD EN FB MODE CS NC 7 R2 8.2k R3 1.1k IS6607A RTN 2 R5 0 VIN PGND R4 10k C6 1uF 5V @ 10A L1 3.3uH BST 10,14 REF FB RTN 6 5 C11 0.22uF C12 NC REF 11 PGOOD PGND AGND VCC PGND AGND AGND AGND Production Datasheet PGND Innovision Semiconductor 20 IS6607A Rev2.6 05/2020 PCB layout TOP Layer Layer 2 Production Datasheet Innovision Semiconductor 21 IS6607A Rev2.6 05/2020 Layer 3 Bottom Layer Production Datasheet Innovision Semiconductor 22 IS6607A Rev2.6 05/2020 Package Dimension Production Datasheet Innovision Semiconductor 23 IS6607A Rev2.6 05/2020 RECOMMENDED LAND PATTERN 2.80 0.30 0.15×45 2.30 0.90 0.80 0.30 0.50 0.30 0.00 0.20 0.30 0.40 0.40 0.20 0.50 0.35 2.30 0.80 0.30 0.80 0.60 Production Datasheet Innovision Semiconductor 24 IS6607A Rev2.6 05/2020 Reflow Specification Qualification Reflow: The IS6606 was qualified in accordance with IPC/JEDEC J-STD-020D.01. This standard classifies proper packaging, storage and handling in order to avoid subsequent thermal and mechanical damage during the solder reflow attachment phase of PCB assembly. The qualification preconditioning process specifies a sequence consisting of a bake cycle, moisture soak cycle (in a temperature humidity oven), and three consecutive solder reflow cycles, followed by functional device testing. SUPPLIER TP≥TC USER TP≤TC TC TC -5℃ SUPPLIER tp USER tp TP tp MAXIMUM RAMP UP RATE = 3℃/s MAXIMUM RAMP DOWM RATE = 6℃/s TL TSMAX PREHEAT AREA TC -5℃ tL TMEPERATURE[℃] TSMIN ts 25 TIME 25℃ TO PEAK TIME Production Reflow: PROFILE FEATURE SN - PB EUTECTIC ASSEMBLY PB-FREE ASSEMBLY Peak package body temperature (TP) For users, TP must not exceed For users, TP must not exceed TC(235℃).For suppliers, TP must TC(260℃).For suppliers, TP must equal or exceed TC(235℃). equal or exceed TC(260℃). Storage Specifications The storage specification of the IS6606 conforms to IPC/JEDEC J-STD-020D.01 Moisture Sensitivity Level (MSL) 3. After opening moisture-sealed bag Production Datasheet 168 hours -- Storage conditions: ambient ≤30°C at 60%RH Innovision Semiconductor 25 IS6607A Rev2.6 05/2020 TAPE AND REEL INFORMATION REEL DIMENSIONS TAPE DIMENSIONS E Discharging direction P1 P0 D0 P2 B0 T Reel Diameter K0 1 . . . . . W F Pin1 Discharging direction A0 Reel Width NOTE: KEY PARAMETER LIST OF TAPE AND REEL Reel Diameter (inch) Package Type QFN-21(3 x 4) 1). The cumulative error of any 10 ratchet holes shall not exceed ±0.2mm 2). The non-parallelism of 100mm long carrier band in the carrier band length direction shall not exceed 1mm. Reel Width (mm) 3). All dimensions are in accordance with EIA-481-3 4). Material: black, PS material, thickness 0.3±0.05mm. 5). The picture is only for reference. Please make the object as the standard. 13″ Unit(mm) ITEM W A0 B0 K0 P0 P1 P2 F S E D0 T DIM 12 ±0.30 3.20 ±0.1 4.20 ±0.1 0.85 4.00 ±0.1 8.00 ±0.1 2.00 ±0.1 5.5 ±0.1 0.0 ±0.1 1.75 ±0.1 1.5 0.3 ±0.05 Production Datasheet +0.1 -0.05 Innovision Semiconductor +0.10 -0.00 26
IS6607A 价格&库存
很抱歉,暂时无法提供与“IS6607A”相匹配的价格&库存,您可以联系我们找货
