PA1206FRF470R003L
PA1206FRF470R003L
    YAGEO(国巨)
    电流采样电阻 1206 3mΩ ±1% ±100ppm/℃ 1W
PA1206FRF470R003L 数据手册
DATA SHEET CURRENT SENSOR - LOW TCR AUTOMOTIVE GRADE PA series 5%, 1%, 0.5% sizes 0201/0402/0603/0805/1206/2010 Product specification – May 15, 2020 V.0 RoHS compliant & Halogen free Product specification Chip Resistor Surface Mount SCOPE This specification describes PA0201/0402/0603/0805/1206/2010 series current sensor - low TCR with lead-free terminations metal substrate. FEATURES  AEC-Q200 qualified  Halogen-free Epoxy  RoHS compliant  Reduce environmentally hazardous wastes  High component and equipment reliability  Non-forbidden materials used in products/production  Low resistances applied to current sensing  Moisture sensitivity level: MSL 1 2 11 0201/0402/0603/0805/1206/2010 ORDERING INFORMATION - GLOBAL PART NUMBER Global part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. GLOBAL PART NUMBER PA XXXX X X X XX XXXX X (1) APPLICATIONS  Smart Phone  Batteries  Computer  Telecom / Datacom  Industrial / Power supply  Car electronics SERIES PA (2) (3) (4) (5) (6) (7) (1) SIZE 0201/0402/0603/0805/1206/2010 (2) TOLERANCE D = ± 0.5% ( for 5mΩ ~ 20mΩ) F = ± 1% J = ± 5% (3) PACKAGING TYPE R = Paper taping reel (PA0201~PA1206) K = Embossed taping reel (PA2010) (4) TEMPERATURE COEFFICIENT OF RESISTANCE E = ± 50ppm/°C M = ± 75ppm/°C F = ± 100ppm/°C L = ± 150ppm/°C G = ± 200ppm/°C (5) TAPING REEL 07 / 7W / 7T / 47 / 57 / 87 inch dia. Reel and specific rated power Detailed power rating are shown in the Table 2. (6) RESISTANCE VALUE 1 mΩ to 20 mΩ (7) DEFAULT CODE Letter L / Z is the system default code for ordering only. (Note) L is for 0201/0402/0603/0805 Z is for only 1206/2010 Resistance rule of global part number Resistance code rule Example 0RXXX (1 to 20 mΩ) 0R001 = 1 mΩ 0R02 = 20 mΩ ORDERING EXAMPLE The ordering code for a PA0805 0.125W chip resistor,TC50 value 0.01Ω (10mR) with ±1% tolerance, supplied in 7-inch tape reel with 5Kpcs quantify is: PA0805FRE070R01L. NOTE 1. All our RChip products are RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead-Free Process" www.yageo.com May. 15, 2020 V0 Product specification Chip Resistor Surface Mount PA SERIES 3 11 0201/0402/0603/0805/1206/2010 MARKING PA0201/0402/0603/0805/1206/2010 Fig. 1 Value = 10 mΩ No Marking CONSTRUCTION The resistors are constructed using outstanding TCR level material, which makes Yageo PA resistors excellent for current sensing application in battery charger circuit & DC -DC converter. The composition of the resistive material is adjusted to give the app roximate required resistance. Finally, the three external terminations (Cu / Ni / matte Tin) are added, as shown in Fig. 2. Outlines L W H I1 I1 Fig. 2 Chip resistor outlines www.yageo.com May. 15, 2020 V0 Product specification Chip Resistor Surface Mount PA SERIES 4 11 0201/0402/0603/0805/1206/2010 DIMENSION Table 1 For outlines, please refer to Fig. 2 TYPE RESISTANCE RANGE L (mm) W (mm) H (mm) I1 (mm) PA0201 5mΩ ≤ R ≤ 20mΩ 0.60± 0.03 0.31± 0.04 Max. 0.30 0.15± 0.06 PA0402 2mΩ ≤ R ≤ 20mΩ 1.00± 0.10 0.55± 0.10 Max. 0.40 0.25± 0.10 1 mΩ 1.60± 0.20 0.80± 0.20 0.55± 0.15 0.38± 0.12 2mΩ ≤ R ≤ 20mΩ 1.60± 0.20 0.80± 0.20 0.45± 0.15 0.38± 0.12 1mΩ 2.03± 0.20 1.27± 0.20 0.55± 0.15 0.60± 0.15 1.5/ 2mΩ 2.03± 0.20 1.27± 0.20 0.45± 0.15 0.50± 0.15 2.5mΩ ≤ R ≤ 20mΩ 2.03± 0.20 1.27± 0.20 0.30± 0.15 0.35± 0.20 1mΩ 3.20± 0.25 1.60± 0.25 0.65± 0.25 0.51± 0.25 2mΩ 3.20± 0.25 1.60± 0.25 0.55± 0.25 0.60± 0.25 2.5/ 3mΩ 3.20± 0.25 1.60± 0.25 0.40± 0.25 0.80± 0.30 4mΩ ≤ R ≤ 20mΩ 3.20± 0.25 1.60± 0.25 0.40± 0.25 0.60± 0.30 1mΩ ≤ R ≤ 3mΩ 5.08± 0.25 2.54± 0.25 0.50± 0.25 1.40± 0.25 4mΩ ≤ R ≤ 20mΩ 5.08± 0.25 2.54± 0.25 0.40± 0.25 0.70± 0.25 PA0603 PA0805 PA1206 PA2010 Note: 1. For relevant physical dimensions, please refer to construction outlines. 2. Please contact with sales offices, distributors and representatives in your region before ordering. ELECTRICAL CHARACTERISTICS Table 2 POWER RATING (1) SIZE TOLERANCE RESISTANCE RANGE 07 7W 7T 0201 1/20W 1/10W 3/20W Fig. 4 Chip resistor outlines 0402 1/16W 1/8W 1/6W 47 57 87 1/4W -- -- 1/4W 1/3W -- 0603 1/10W 1/5W 1/3W 2/5W 1/2W -- 0805 1/8W 1/4W -- 1/2W -- 1W 1/4W 1/2W -- 1W -- -- 1206 0.5W 1W 1.5W - - - 0.5W 1W 1.5W 2W - - 2010 ± 1% ± 5% 5mΩ ≤ R ≤ 20mΩ ± 150 ppm/°C 2mΩ ≤ R ≤ 20mΩ ± 150 ppm/°C 1mΩ ≤ R ≤ 20mΩ ± 0.5% 10mΩ ± 1% ± 5% 1mΩ≤ R ≤ 20mΩ ± 0.5% 5mΩ ≤ R ≤ 20mΩ ± 1% ± 5% 1mΩ ≤ R ≤ 20mΩ ± 1% ± 5% TEMPERATURE COEFFICIENT OF RESISTANCE 1mΩ 2/ 2.5mΩ 3mΩ ≤ R ≤ 10mΩ ± 200 ppm/°C ± 150 ppm/°C ± 50 ppm/°C, ± 75 ppm/°C 1/ 1.5mΩ 2mΩ ≤ R ≤ 20mΩ ± 150 ppm/°C ± 50 ppm/°C 1/ 2mΩ 3mΩ ≤ R ≤ 20mΩ ± 100 ppm/°C ± 50 ppm/°C 1mΩ ≤ R ≤ 20mΩ ± 50 ppm/°C 1mΩ ≤ R ≤ 10mΩ Note: Please contact with sales offices, distributors and representatives in your region before ordering. www.yageo.com May. 15, 2020 V0 Product specification Chip Resistor Surface Mount SERIES PA FUNCTIONAL DESCRIPTION OPERATING TEMPERATURE RANGE MLB206_14 PA0201/ 0402 Range: –55°C to +125°C PA0603/ 0805 Range: –55°C to +155°C PA1206/ 2010 Range: –55°C to +170°C 70 Standard rated power at 70°C: For detail power value, please refer to Table 2. Rated Power (%) 100 POWER RATING 80 1206/ 2010 60 0603/ 0805 40 0201/ 0402 20 RATED VOLTAGE -55 The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V= 5 11 0201/0402/0603/0805/1206/2010 -40 -20 0 20 40 60 80 100 155 125 170 120 140 160 180 Ambient Temperature Fig. 3 Maximum dissipation (P max ) in percentage of rated power as a function of the operating ambient temperature (T amb) (PxR ) Where V = Continuous rated DC or AC (rms) working voltage (V) P = Rated power (W) R = Resistance value (Ω) PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity PACKING STYLE REEL DIMENSION PA0201 PA0402 PA0603 PA0805 PA1206 PA2010 Paper Taping Reel (R) 7" (178 mm) 10,000 10,000 5,000 5,000 4,000 - Embossed Taping Reel (K) 7" (178 mm) - - - - - 4,000 PAPER TAPE P0 T D0 P2 E F cover tape W B0 Fig. 4 Paper Tape A0 P1 MBG251 www.yageo.com May. 15, 2020 V0 Product specification Chip Resistor Surface Mount SERIES PA 6 11 0201/0402/0603/0805/1206/2010 EMBOSSED TAPE P0 D0 P2 E F cover tape W B0 MBG516_b A0 D1 T P1 direction of unreeling Fig. 5 Embossed Tape Table 4 Dimensions of paper tape for relevant chip resistors size SIZE SYMBOL Unit: mm A0 B0 W E F P0 P1 P2 ΦD0 T PA0201 0.39± 0.10 0.70± 0.10 8.0± 0.30 1.75± 0.10 3.50± 0.10 4.00± 0.10 2.00± 0.10 2.00± 0.10 1.55± 0.05 0.43± 0.10 PA0402 0.59± 0.10 1.10± 0.10 8.0± 0.30 1.75± 0.10 3.50± 0.10 4.00± 0.10 2.00± 0.10 2.00± 0.10 1.55± 0.05 0.53± 0.10 PA0603 1.08± 0.10 1.90± 0.10 8.0± 0.30 1.75± 0.10 3.50± 0.10 4.00± 0.10 4.00± 0.10 2.00± 0.10 1.55± 0.05 0.60± 0.10 1.60± 0.10 2.35± 0.10 8.0± 0.30 1.75± 0.10 3.50± 0.10 4.00± 0.10 4.00± 0.10 2.00± 0.10 1.55± 0.05 0.60± 0.10* 1.60± 0.10 2.35± 0.10 8.0± 0.30 1.75± 0.10 3.50± 0.10 4.00± 0.10 4.00± 0.10 2.00± 0.10 1.55± 0.05 0.53± 0.10** 1.90± 0.10 3.50± 0.10 8.0± 0.30 1.75± 0.10 3.50± 0.10 4.00± 0.10 4.00± 0.10 2.00± 0.10 1.55± 0.05 PA0805 PA1206 0.85± 0.15 Note: * 1~2mΩ ** 2.5~20mΩ Table 5 Dimensions of embossed tape for relevant chip resistors size SIZE PA2010 SYMBOL Unit: mm A0 B0 W E F P0 P1 P2 ΦD0 T 3.40± 0.15 6.70± 0.15 12.0± 0.30 1.75± 0.10 5.50± 0.10 4.00± 0.10 4.00± 0.10 2.00± 0.10 1.55± 0.10 0.85± 0.15 www.yageo.com May. 15, 2020 V0 Product specification Chip Resistor Surface Mount PA SERIES 7 11 0201/0402/0603/0805/1206/2010 REEL SPECIFICATION W2 D C Fig. 6 Reel N A HBK039_a W1 Table 6 Dimensions of reel specification for relevant chip resistors size SIZE QUANTITY PER REEL PA0201 10,000 PA0402 10,000 PA0603 5,000 PA0805 5,000 PA1206 4,000 PA2010 4,000 REEL SIZE 8mm TAPE WIDE 7" (Φ178mm) 7" (Φ178mm) 7" (Φ178mm) 7" (Φ178mm) 7" (Φ178mm) - REEL SIZE 12mm TAPE WIDE SYMBOL Unit: mm A N C D W1 W2 MAX. - 178.0± 1.0 60.0+1/-0 13.50± 0.5 21.0± 0.8 9.0± 0.5 12.0± 0.2 - 178.0± 1.0 60.0+1/-0 13.50± 0.5 21.0± 0.8 9.0± 0.5 12.0± 0.2 - 178.0± 1.0 60.0+1/-0 13.50± 0.5 21.0± 0.8 9.0± 0.5 12.0± 0.2 - 178.0± 1.0 60.0+1/-0 13.50± 0.5 21.0± 0.8 9.0± 0.5 12.0± 0.2 - 178.0± 1.0 60.0+1/-0 13.50± 0.5 21.0± 0.8 9.0± 0.5 12.0± 0.2 7" (Φ178mm) 178.0± 1.0 60.0+1/-0 13.50± 0.5 21.0± 0.8 13.6± 0.5 16.5± 0.5 www.yageo.com May. 15, 2020 V0 Product specification Chip Resistor Surface Mount SERIES PA 8 11 0201/0402/0603/0805/1206/2010 LEADER/TRAILER TAPE SPECIFICATION leader end empty compartments with cover tape (min. 240 mm) trailer end cover tape only trailer (max. 260 mm) Fig. 7 Leader/Trailer Tape CCB325 FOOTPRINT AND SOLDERING PROFILES For recommended soldering profiles, please refer to data sheet “Chip resistors mounting”. FOOTPRINT Fig. 8 Single resistor chips recommended dimensions of footprints Table 7 Footprint dimensions Unit: mm TYPE RESISTANCE RANGE A B C D PA0201 5mΩ ≤ R ≤ 20mΩ 1.00 0.30 0.35 0.40 PA0402 2mΩ ≤ R ≤ 20mΩ 2.00 0.40 0.80 0.60 1mΩ 2.20 0.50 0.70 0.90 1mΩ < R ≤ 20mΩ 2.20 0.80 0.70 0.90 1mΩ 4.10 0.50 1.80 2.18 1.5mΩ ≤ R ≤ 20mΩ 4.60 1.00 1.80 2.18 1mΩ / 2mΩ 4.20 1.00 1.60 1.84 2.5mΩ / 3mΩ 4.80 1.00 1.90 1.84 4mΩ ≤ R ≤ 20mΩ 4.80 1.20 1.80 1.84 1mΩ ≤ R ≤ 3mΩ 6.00 1.40 2.30 3.00 4mΩ ≤ R ≤ 20mΩ 6.00 3.50 1.25 3.00 PA0603 PA0805 PA1206 PA2010 www.yageo.com May. 15, 2020 V0 Product specification Chip Resistor Surface Mount PA SERIES 9 11 0201/0402/0603/0805/1206/2010 TESTS AND REQUIREMENTS Table 8 Test condition, procedure and requirements TEST PROCEDURE REQUIREMENT Short time overload TEST METHOD IEC60115-1 4.13 5 times of rated power for 5 seconds at room temperature ± (1.0%+0.0005Ω) High Temperature Exposure/ Endurance at Upper Category Temperature MIL-STD-202G-Method 108A 1,000 hours at maximum operating temperature depending on specification, unpowered ± (1.0%+0.0005Ω) No visible damage No direct impingement of forced air to the par ts Tolerances: 0201/0402: 125± 3ºC 0603/0805: 155± 3ºC 1206/2010: 170± 3ºC Temperature Cycling JESD22-A104C 1,000 cycles, -55/+125ºC for 1 cycle per hour ± (1.0%+0.0005Ω) Moisture Resistance MIL-STD-202G-Method 106F Each temperature / humidity cycle is defined at 8 hours (method 106F), 3 cycles / 24 hours for 10d with 25ºC / 65ºC 95% R.H, without steps 7a & 7b, unpowered ± (0.5%+0.0005Ω) Biased Humidity MIL-STD-202 Method 103 1,000 hours; 85ºC / 85% RH ± (1.0%+0.0005Ω) Operational Life/ Endurance MIL-STD-202G-Method 108A IEC 60115-1 4.25.1 10% of operating power 1,000 hours at 125± 3ºC, de-rated power applied for 1.5 hours on, 0.5 hour off, still-air required ± (1.0%+0.0005Ω) 1,000 hours at 70± 2ºC applied rated power 1.5 hours on, 0.5 hour off, still air required ± (1.0%+0.0005Ω) Resistance to Solvents MIL-STD-202 Method 215 Immerse in isopropyl alcohol for 5 min with ultrasonic at room temperature No visible damage Mechanical Shock MIL-STD-202 Method 213 Three shocks in each direction shall be applied along the three mutually perpendicular axes of the test specimen. Peak value: 100 g’s Duration: 6 ms Velocity change: 12.3 ft/s Waveform: Half sine ± (0.5%+0.0005Ω) Vibration MIL-STD-202 Method 204 5 g’s for 20 min., 12 cycles each of 3 orientations Test from 10-2000 Hz. ± (0.5%+0.0005Ω) Resistance to Soldering Heat MIL-STD-202G-method 210F Condition B, no pre-heat of samples Leadfree solder, 260ºC, 10 seconds immersion time Procedure 2 for SMD: devices fluxed and cleaned with isopropanol ± (0.5%+0.0005Ω) No visible damage www.yageo.com May. 15, 2020 V0 Product specification Chip Resistor Surface Mount TEST Thermal Shock Electrostatic Discharge TEST METHOD MIL-STD-202 Method 107 AEC-Q200-002 SERIES PA PROCEDURE REQUIREMENT -55/+125ºC, Number of cycles is 300. Maximum transfer time is 20 seconds. Dwell time is 15 minutes. Air -Air ± (1.0%+0.0005Ω) Human Body Model, 1 pos + 1 neg. 0805/ 1206/ 2010 : 2KV ± (1.0%+0.0005Ω) 0402/ 0603 : 1KV 10 11 0201/0402/0603/0805/1206/2010 No visible damage No visible damage 0201: 500V Solderability - Wetting J-STD-002 (a) Method B, aging 4 hours at 155ºC dr y heat, dipping at 235± 3ºC for 5± 0.5 seconds. Well tinned (>95% covered) (b) Method B, steam aging 8 hours, dipping at 215± 3ºC for 5± 0.5 seconds. No visible damage (c) Method D, steam aging 8 hours, dipping at 260± 3 ºC for 30± 0.5 seconds. Flammability UL94 Tr y to inflame a specimen by a needle flame No ignition of specimen; V-0 Board Flex / Bending AEC-Q200-005 Chips mounted on a 90mm glass epoxy resin PCB (FR4), Bending for ± (1.0%+0.0005Ω) 0201: 3mm 0402 and above: 2mm Holding time: Min.60 seconds Terminal Strength (SMD) AEC-Q200-006 Applied ± (1.0%+0.0005Ω) 0201: 3N No visible damage 0402: 5N 0603/ 0805/ 1206/ 2010: 17.7N for 60± 1 seconds. Flame Retardance Temperature Coefficient of Resistance (T.C.R.) AEC-Q200-001 IEC 60115-1 4.8 Apply voltage from 9V to 32V to increase the surface temp to 350ºC No flame, At +25/+125ºC Refer to table 2 no explosion Formula: R2–R1 6 T.C.R= ------------------------- × 10 (ppm/ºC) R1(t2–t1) Where t1 =+25ºC or specified room temperature t2 =+125ºC test temperature R1=resistance at reference temperature in ohms R2=resistance at test temperature in ohms www.yageo.com May. 15, 2020 V0 Product specification Chip Resistor Surface Mount PA SERIES 0201/0402/0603/0805/1206/2010 11 11 REVISION HISTORY REVISION DATE Version 0TYPE May 07, 2020 CHANGE NOTIFICATION - POWER DESCRIPTION TEMPERATURE COEFFICIENT RESISTANCE RANGE - New datasheet for automotive grade current sensor – TOLERANCE OF RESISTANCE PA0201/0402/0603/0805/1206/2010 series. 0603 0805 1206 1/10W, 1/5W, 3/10W, 2/5W, 1/2W 5 mΩ≦ R < 100 mΩ 1/8W, 1/4W, 1/3W, 1/2W 4 mΩ ≦ R < 100 mΩ 1/4W, 1/2W 3 mΩ ≦ R < 100 mΩ 1/2W, 1W PF The resistors are constructed using outstanding TCR level material, which makes Yageo PF resistors excellent for current sensing application in battery charger circuit & DC-DC converter. The composition of the resistive 2010 material is adjusted to give the approximate required resistance and is covered with a protective coating, which printed with the resistance value. Finally, the three external terminations (Ni / matte Tin) are added, as shown in Fig. 4. 2512 4527 ± 1% ± 2% 5 mΩ ≦ R < 100 mΩ ±75 ppm/°C ± 5% 1W, 2W 1 mΩ ≦ R < 100 mΩ 3W 1 mΩ ≦ R ≦ 50 mΩ 2W, 3W, 5W 6 mΩ ≦ R < 1Ω NOTE: 1. PLEASE CONTACT WITH SALES OFFICES, DISTRIBUTORS AND REPRESENTATIVES IN YOUR REGION BEFORE ORDERING “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itself are unchanged. Any product change will be announced by PCN.” www.yageo.com May. 15, 2020 V0 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Yageo: PA0805JR-470RL PA1206FRF470R025L PA1206FRF470R006L PA1206FRF070R001L PA1206FRE470R005L PA1206FRE470R004L PA1206FRF7W0R033L PA1206FRM7W0R05L PA1206FRF7W0R03L PA1206FRF070R006L PA1206FRF470R05L PA1206FRF470R007L PA1206DRE7W0R01L PA1206FRF7W0R05L PA1206FRE470R003L PA1206FRM470R001L PA0805FRL471U5L PA1206FRM7W0R025L PA1206FRM470R004L PA1206FRE7W0R004L PA1206FRF470R01L PA1206FRF470R03L PA1206FRF470R004L PA1206FRF070R008L PA1206JRF070R005L PA1206FRE7W0R006L YAGEO: PA0805FRF470R008L
PA1206FRF470R003L 价格&库存
很抱歉,暂时无法提供与“PA1206FRF470R003L”相匹配的价格&库存,您可以联系我们找货
PA1206FRF470R003L
  • 1+2.83785
  • 100+2.65237
  • 300+2.46689
  • 500+2.28141
  • 2000+2.18867
  • 5000+2.13303
PA1206FRF470R003L
    • 1+1.12900
    • 100+0.84110
    • 1000+0.62670
    • 2000+0.44620
    • 4000+0.31770
    库存:20560
