S-58LM20A-N4T1G
S-58LM20A-N4T1G
    ABLIC(艾普凌科)
    UFBGA4
    SENSOR ANALOG -55C-130C WLP-4B
S-58LM20A-N4T1G 数据手册
S-58LM20A Series CMOS TEMPERATURE SENSOR IC www.ablic.com www.ablicinc.com Rev.3.1_02 © ABLIC Inc., 2007-2015 The S-58LM20A Series is a high-accuracy temperature sensor IC on a single chip, provides output voltage which is linear against the temperature change. Each chip consists of a temperature sensor, a constant current circuit, and an operational amplifier. The operating ambient temperature is from –55C to 130C. This IC has much better linearity than other conventional temperature sensors such as thermistor, it is possible to achieve the extensive application for temperature control.  Features  Accuracy against temperature  Linear output voltage  Nonlinearity  Operation in wide range of power supply voltage     Low current consumption Built-in operational amplifier Output voltage referred to VSS *1 Lead-free, Sn 100%, halogen-free 2.5C (55C to 130C) 11.77 mV/C Typ. Ta = 30C: 2.205 V Typ. Ta = 30C: 1.515 V Typ. Ta = 130C: 0.303 V Typ. 0.4% Typ. (20 to 80C) VDD = 2.4 to 5.5 V (30C to 130C) VDD = 2.7 to 5.5 V (55C to 130C) 4.5 A Typ. (25C) 6.0 A Max. (55C to 130C) *1. Refer to “ Product Name Structure” for details.  Applications        Compensation of high-frequency circuits such as cellular phones and radio equipment Compensation of oscillation frequency in crystal oscillator LCD contrast compensation Compensation of amplifier gain Compensation of auto focus circuits Temperature detection in battery management Overheating prevention for charged batteries or halogen lights  Package  SC-82AB  SNT-4A  WLP-4B 1 CMOS TEMPERATURE SENSOR IC S-58LM20A Series Rev.3.1_02  Block Diagram VDD VOUT Temperature sensor VSS Figure 1 2 CMOS TEMPERATURE SENSOR IC S-58LM20A Series Rev.3.1_02  Product Name Structure Users can select the product type in the S-58LM20A Series. Refer to “1. Product name” regarding the contents of product name, “2. Package” regarding the package drawings and “3. Product name list” regarding the product type. 1. Product name (1) SC-82AB package S-58LM20A - N4T1 x Environmental code U: Lead-free (Sn 100%), halogen-free G: Lead-free (for details, please contact our sales office) Package name (abbreviation) and packing specifications N4T1 : SC-82AB, Tape *1 Product name *1. Refer to the tape drawing. (2) SNT-4A package S-58LM20A - I4T1 U Environmental code U: Lead-free (Sn 100%), halogen-free Package name (abbreviation) and packing specifications I4T1 : SNT-4A, Tape *1 Product name *1. Refer to the tape drawing. (3) WLP-4B package S-58LM20A - H4T1 S Environmental code S: Lead-free, halogen-free Package name (abbreviation) and packing specifications*1 H4T1 : WLP-4B, Tape Product name *1. Refer to the tape drawing. 3 CMOS TEMPERATURE SENSOR IC S-58LM20A Series Rev.3.1_02 2. Package Package Name SC-82AB SNT-4A WLP-4B Package NP004-A-P-SD PF004-A-P-SD HB004-C-P-SD Drawing Code Tape Reel NP004-A-C-SD NP004-A-R-SD PF004-A-C-SD PF004-A-R-SD HB004-C-C-SD HB004-C-R-SD 3. Product name list Table 1 Product Name Temperature Accuracy Package S-58LM20A-N4T1x 2.5C SC-82AB S-58LM20A-I4T1U 2.5C SNT-4A S-58LM20A-H4T1S 2.5C WLP-4B Remark 1. x: G or U 2. Please select products of environmental code = U for Sn 100%, halogen-free products. 4 Land  PF004-A-L-SD  CMOS TEMPERATURE SENSOR IC S-58LM20A Series Rev.3.1_02  Pin Configuration Table 2 SC-82AB Top view 4 3 Pin No. Pin Name 1 2 3 4 VDD VSS NC*1 VOUT Description Power supply pin GND pin No connection Output voltage pin *1. The NC pin is electrically open. The NC pin can be connected to VDD or VSS. 1 2 Figure 2 SNT-4A Top view Table 3 1 4 2 3 Pin No. Pin Name 1 2 3 4 VSS VDD VOUT NC*1 Description GND pin Power supply pin Output voltage pin No connection *1. The NC pin is electrically open. The NC pin can be connected to VDD or VSS. Figure 3 Table 4 WLP-4B Top view Pin No. Pin Name 1 2 3 4 VDD VSS*1 VSS*1 VOUT Description Power supply pin GND pin GND pin Output voltage pin *1. Connect both VSS pins to GND. Figure 4 WLP-4B Bottom view 1 2 4 3 Figure 5 5 CMOS TEMPERATURE SENSOR IC S-58LM20A Series Rev.3.1_02  Absolute Maximum Ratings Table 5 Item Symbol (Ta = 25C unless otherwise specified) Absolute Maximum Rating Unit Power supply pin voltage VDD VSS – 0.3 to VSS  6.5 Output voltage VOUT VSS – 0.3 to VDD  0.3 SC-82AB Power dissipation SNT-4A PD V 350 *1 mW 300*1 mW *1 mW 290 WLP-4B V Operating ambient temperature Topr –55 to 130 C Storage temperature Tstg –65 to 150 C *1. When mounted on board [Mounted board] (1) Board size: 114.3 mm  76.2 mm  t1.6 mm (2) Board name: JEDEC STANDARD51-7 Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. 6 CMOS TEMPERATURE SENSOR IC S-58LM20A Series Rev.3.1_02  Electrical Characteristics Table 6 (Ta = 25C, VDD = 2.7 V, IOUT = 0 A unless otherwise specified) Item Symbol Range of power supply voltage VDD Output voltage VOUT = (3.88  10-6  T2) -2 +(1.15  10  T) +1.8639 V VOUT Conditions Min. Typ. Max. Unit Test Circuit 30C  Ta  130C 55C  Ta  130C Ta = 30C Ta = 30C Ta = 130C 30C  Ta  130C 20C  Ta  80C  55C  Ta  130C 2.4 2.7 2.177 1.486 0.272 12.20  55    2.205 1.515 0.303 11.77 0.4  4.5 5.5 5.5 2.234 1.545 0.335 11.40  130 6.0 V V V V V mV/C % C A 1 1 1 1 1    1  0.1  A 1  -11  nA/C 1     3.3 0.156 mV/V mV/A 2 2 Temperature sensitivity VSE Nonlinearity NL Operating temperature range Topr Current consumption IDD Current consumption  IDD1 VDD = 2.4 V to 5.5 V Power supply voltage Current consumption  IDD2  Temperature Line regulation VOUT1 VDD = 2.4 V to 5.5 V Load regulation*1 IOUT = 0 A to 16 A VOUT2 *1. Do not flow current into the output voltage pin. 7 CMOS TEMPERATURE SENSOR IC S-58LM20A Series Rev.3.1_02  Test Circuit 1. A VDD S-58LM20A Series VOUT VSS V V CIN Figure 6 2. VDD S-58LM20A VOUT A Series V CIN VSS V Figure 7 8 IOUT CMOS TEMPERATURE SENSOR IC S-58LM20A Series Rev.3.1_02  Explanation of Terms 1. Output voltage (VOUT) VOUT indicates the output voltage at Ta = 30C, Ta = 30C, and Ta = 130C. Output voltage Max. Min. 30C 0C 30C Temperature [Ta] 130C Figure 8 9 CMOS TEMPERATURE SENSOR IC S-58LM20A Series Rev.3.1_02 2. Temperature Sensitivity (VSE) VSE is the temperature coefficient of output voltage which is calculated from an output voltage when Ta = 30C and Ta = 130C. VSE is calculated from the following formula. VSE  V  VOUT *2 160 *3 OUT *1  Output voltage VOUT (when Ta = 30C) VSE VOUT (when Ta = 130C) 30C 0C 30C Temperature [Ta] Figure 9 *1. VOUT value at Ta = 130C [V] *2. VOUT value at Ta = 30C [V] *3. The difference of the temperature between Ta = 130C and Ta = 30C [C] 10 130C CMOS TEMPERATURE SENSOR IC S-58LM20A Series Rev.3.1_02 3. Nonlinearity (NL) NL is the nonlinearity of output voltage. Its deviation with the approximation line is shown below. NL is calculated from the following formula. ∆NL  a *1  100 b*2 Output voltage a VOUT (when 20C) (B) Actual measured value a b a VOUT (when 80C) 20C (A) Approximation line 80C 0C Temperature [Ta] *1. The maximum deviation of the actual measurement of output voltage (B) and an approximation line (A) in temperature 20C to 80C. The approximation line is the one to be drawn so that “a” should be the minimum value. *2. The difference of the actual measured value of output voltage when 20C and 80C. Figure 10 4. Line regulation (VOUT1) VOUT1 indicates the dependency of output voltage against input voltage. This indicates how much the output voltage varies when changing the input voltage after fixing the output current constant. 5. Load regulation (VOUT2) VOUT2 indicates the dependency of output voltage against output current. This indicates how much the output voltage varies when changing output current after fixing the input voltage constant. 6. Current consumption – Power supply voltage (IDD1) IDD1 indicates the dependency of current consumption against power supply voltage. This indicates how much current consumption varies when changing the temperature after fixing an output current constant. 7. Current consumption - Temperature (IDD2) IDD2 indicates the dependency of current consumption against temperature. This indicates how much current consumption varies when changing the temperature after fixing an output current constant. 11 CMOS TEMPERATURE SENSOR IC S-58LM20A Series Rev.3.1_02  Precautions  Wire each pin of VDD, VSS and VOUT carefully in order to set them in low impedance when wiring an IC on a patterned board.  In this IC, if load capacitance of the VOUT pin is large, VOUT pin voltage may oscillate. It is recommended not to use an external capacitor between the VOUT and VSS pin. When using an external capacitor, set near the VOUT pin. When connecting an A/D converter etc. to the VOUT pin, the input pin capacitance of the A/D converter and the parasitic capacitance component between wires are included as load capacitance. To prevent oscillation, it is recommended to use the following output load condition. Load capacitance of VOUT pin (CL1) : 300 pF or less VDD S-58LM20A VOUT Series VSS CL1 CIN VOUT Figure 11 Caution The above connection diagram and constant will not guarantee successful operation. Perform through evaluation using the actual application to set the constant. 12 CMOS TEMPERATURE SENSOR IC S-58LM20A Series Rev.3.1_02 In this IC, it is necessary to add a capacitor from an output pin to GND with a series resistor in the ambience having excessive noise, as seen in Figure 12 and Figure 13. In the combination shown in Table 7, a time constant against heat of this IC is much later than the time constant composed of RC, therefore it does not affect on the response time of this IC. Table 7 RL2 () CL2 (F) 200 1 470 0.1 680 0.01 1k 0.001 VDD S-58LM20A VOUT Series RL2 VSS VOUT CIN CL2 Figure 12 VDD S-58LM20A Series VSS VOUT RL2 CL2 VOUT CIN Figure 13 Caution The above connection diagram and constant will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constant. 13 CMOS TEMPERATURE SENSOR IC S-58LM20A Series Rev.3.1_02  For stabilization, set a capacitor (CIN) of approx. 0.1 F between VDD and VSS pin.  Do not connect a pull-up resistor to the output pin.  The application condition for input voltage, output voltage and load voltage must not exceed the package power dissipation.  Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit.  Regarding the current at the output pin, refer to load regulation and footnote *1 in Table 6 “ Electrical Characteristics”.  ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 14 CMOS TEMPERATURE SENSOR IC S-58LM20A Series Rev.3.1_02  Characteristics (Typical Data) 1. Output voltage (VOUT) vs. Temperature (Ta) 2. Current consumption (IDD) vs. Temperature (Ta) 3.0 5.0 4.8 4.6 4.4 4.2 4.0 3.8 3.6 3.4 3.2 3.0 2.0 IDD [μA] VOUT [V] 2.5 1.5 1.0 0.5 0 −55 −40 −20 0 20 40 60 Ta [°C] 100 80 4 5 2 IDD [μA] Difference between the temperature converted into approximation line and actual temperature [C] 6 0 −2 1 0 20 40 60 Ta [°C] 20 40 60 Ta [°C] 80 100 120 130 100 80 Ta = −30°C Ta = −55°C Ta = 30°C Ta = 130°C 2 −4 0 0 4 3 −6 −20 −20 4. Current consumption (IDD) vs. Power supply voltage (VDD) 6 −55 −40 VDD = 2.7 V VDD = 2.4 V −55 −40 120 130 3. Error range of each temperature VDD = 5.5 V 2.4 120 130 3.0 3.5 4.0 4.5 VDD [V] 5.0 5.5 Ta = 30C 2.210 2.209 2.208 2.207 2.206 2.205 2.204 2.203 2.202 2.201 2.200 VOUT [V] VOUT [V] 5. Output voltage (VOUT) vs. Power supply voltage (VDD) VOUT [V] 2.4 3.0 3.5 4.0 4.5 VDD [V] 5.0 5.5 Ta = 30C 1.520 1.519 1.518 1.517 1.516 1.515 1.514 1.513 1.512 1.511 1.510 2.4 3.0 3.5 4.0 4.5 VDD [V] 5.0 5.5 Ta = 130C 0.310 0.309 0.308 0.307 0.306 0.305 0.304 0.303 0.302 0.301 0.300 2.4 3.0 3.5 4.0 4.5 VDD [V] 5.0 5.5 15 CMOS TEMPERATURE SENSOR IC S-58LM20A Series Rev.3.1_02 6. Output voltage (VOUT) vs. Load current (IOUT) VDD = 2.4 V 3.0 2.5 Ta = 30°C Ta = 30°C Ta = 130°C 2.0 1.5 VOUT [V] VOUT [V] 2.5 1.0 0.5 Ta = 55°C Ta = 30°C Ta = 130°C 2.0 1.5 1.0 0.5 0 0 0 0.5 1.0 IOUT [mA] 1.5 0 2.0 0.5 1.0 1.5 2.0 IOUT [mA] 2.5 3.0 VDD = 5.5 V 3.0 Ta = −55°C Ta = 30°C Ta = 130°C 2.5 VOUT [V] VDD = 2.7 V 3.0 2.0 1.5 1.0 0.5 0 0 2.0 4.0 6.0 IOUT [mA] 8.0 10.0 7. Heat response Output voltage (VOUT) vs. Time (t) When packages are put into the liquid of 130C from the air of 25C 1.8 1.6 1.4 WLP-4B 1.2 1.0 SC-82AB 0.8 SNT-4A 0.6 0.4 0.2 0 0 5 10 15 20 25 30 35 40 45 t [s] VOUT [V] VOUT [V] When packages are put into the air of 130C from the air of 25C 1.8 1.6 1.4 1.2 SC-82AB 1.0 SNT-4A 0.8 WLP-4B 0.6 0.4 0.2 0 0 20 40 60 80 100 120 140 160 160 200 220 240 t [s] 8. Start up response Ta = 25C, CL = 100pF, RL = 10 M Ta = 25C, CL = 100pF, RL = 10 M VDD (= 5.5 V) 1 V / div. GND VOUT 1 V / div. GND t (50s / div.) 16 VDD (= 2.4 V) 1 V / div. GND VOUT 1 V / div. GND t (50s / div.) CMOS TEMPERATURE SENSOR IC S-58LM20A Series Rev.3.1_02  Marking Specifications 1. SC-82AB Top view 4 (1) to (3) 3 : Product code (refer to Product name vs. Product code) (1) (2) (3) 1 2 Product name vs. Product code Product name (1) D S-58LM20A-N4T1x Product code (2) (3) R E Remark 1. x: G or U 2. Please select products of environmental code = U for Sn 100%, halogen-free products. 2. SNT-4A Top view (1) to (3) 1 : Product code (refer to Product name vs. Product code) 4 (1) (2) (3) 2 3 Product name vs. Product code Product name S-58LM20A-I4T1U (1) D Product code (2) (3) R E 3. WLP-4B Top view 4 3 (1) to (2) : Lot number (1) (2) 1 2 17 2.0±0.2 1.3±0.2 4 3 0.05 0.3 +0.1 -0.05 +0.1 0.16 -0.06 2 1 +0.1 0.4 -0.05 No. NP004-A-P-SD-2.0 TITLE SC82AB-A-PKG Dimensions NP004-A-P-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. +0.1 ø1.5 -0 4.0±0.1 2.0±0.05 1.1±0.1 4.0±0.1 0.2±0.05 ø1.05±0.1 (0.7) 2.2±0.2 2 1 3 4 Feed direction No. NP004-A-C-SD-3.0 TITLE SC82AB-A-Carrier Tape No. NP004-A-C-SD-3.0 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. NP004-A-R-SD-1.1 TITLE SC82AB-A-Reel No. NP004-A-R-SD-1.1 QTY. ANGLE UNIT mm ABLIC Inc. 3,000 1.2±0.04 3 4 +0.05 0.08 -0.02 2 1 0.65 0.48±0.02 0.2±0.05 No. PF004-A-P-SD-6.0 TITLE SNT-4A-A-PKG Dimensions No. PF004-A-P-SD-6.0 ANGLE UNIT mm ABLIC Inc. +0.1 ø1.5 -0 4.0±0.1 2.0±0.05 0.25±0.05 +0.1 1.45±0.1 2 1 3 4 ø0.5 -0 4.0±0.1 0.65±0.05 Feed direction No. PF004-A-C-SD-2.0 TITLE SNT-4A-A-Carrier Tape No. PF004-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PF004-A-R-SD-1.0 TITLE SNT-4A-A-Reel No. PF004-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 5,000 0.52 1.16 2 0.52 0.35 1. 2. 0.3 1 (0.25 mm min. / 0.30 mm typ.) (1.10 mm ~ 1.20 mm) 0.03 mm 1. Pay attention to the land pattern width (0.25 mm min. / 0.30 mm typ.). 2. Do not widen the land pattern to the center of the package (1.10 mm to 1.20 mm). Caution 1. Do not do silkscreen printing and solder printing under the mold resin of the package. 2. The thickness of the solder resist on the wire pattern under the package should be 0.03 mm or less from the land pattern surface. 3. Match the mask aperture size and aperture position with the land pattern. 4. Refer to "SNT Package User's Guide" for details. 1. 2. (0.25 mm min. / 0.30 mm typ.) (1.10 mm ~ 1.20 mm) TITLE SNT-4A-A -Land Recommendation PF004-A-L-SD-4.1 No. No. PF004-A-L-SD-4.1 ANGLE UNIT mm ABLIC Inc. 0.84±0.02 4 (0.5) 3 3 B 4 A 1 2 2 4-(ø0.20) 0.58max. 1 ø0.05 M S AB S ø0.20±0.02 Pin No. 0.06 S 1 2 3 4 Symbol VDD VSS VSS VOUT No. HB004-C-P-SD-2.0 TITLE No. WLP-4B-C-PKG Dimensions (S-58LM20A) HB004-C-P-SD-2.0 ANGLE UNIT ABLIC Inc. +0.1 ø1.5 -0 4.0±0.1 2.0±0.05 ø0.35±0.05 0.18±0.05 0.73±0.05 4.0±0.1 Count mark(R0.3,Depth 0.2) (Every 10 pockets) 1.1 1.16 0.7 0.93±0.05 0.95 2 1 3 4 Feed direction No. HB004-C-C-SD-1.1 TITLE No. WLP-4B-C-Carrier Tape (S-58LM20A) HB004-C-C-SD-1.1 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 No. HB004-C-R-SD-1.0 TITLE WLP-4B-C-Reel (S-58LM20A) No. HB004-C-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 3,000 Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-58LM20A-N4T1G 价格&库存
很抱歉,暂时无法提供与“S-58LM20A-N4T1G”相匹配的价格&库存,您可以联系我们找货
