74ALVCH16823DGG:11
74ALVCH16823DGG:11
    NEXPERIA(安世)
    TSSOP56
    IC FF D-TYPE DUAL 9BIT 56TSSOP
74ALVCH16823DGG:11 数据手册
74ALVCH16823 18-bit bus-interface D-type flip-flop with reset and enable; 3-state Rev. 3 — 1 February 2018 1 Product data sheet General description The 74ALVCH16823 is a 18-bit edge-triggered flip-flop featuring separate D-type inputs for each flip-flop and 3-state outputs for bus oriented applications. Incorporates bushold data inputs which eliminate the need for external pull-up resistors to hold unused inputs. The 74ALVCH16823 consists of two sections of nine edge-triggered flip-flops. A clock (nCP) input, an output-enable (nOE) input, a master reset (nMR) input and a clockenable (nCE) input are provided for each total 9-bit section. With the clock-enable (nCE) input LOW, the D-type flip-flops will store the state of their individual nDn-inputs that meet the set-up and hold time requirements on the LOW-to-HIGH nCP transition. Taking nCE HIGH disables the clock buffer, thus latching the outputs. Taking the master reset (nMR) input LOW causes all the nQn outputs to go LOW independently of the clock. When nOE is LOW, the contents of the flip-flops are available at the outputs. When the nOE is HIGH, the outputs go to the high impedance OFF-state. Operation of the nOE input does not affect the state of flip-flops. Active bus hold circuitry is provided to hold unused or floating data inputs at a valid logic level. 2 Features and benefits • • • • • • • • • • Wide supply voltage range from 1.2 V to 3.6 V CMOS low-power consumption Direct interface with TTL levels Current drive ± 24 mA at 3.0 V MULTIBYTE flow-through standard pin-out architecture Low inductance multiple VCC and GND pins for minimum noise and ground bounce Output drive capability 50 Ω transmission lines at 85°C All data inputs have bushold Complies with JEDEC standard no. 8-1A Complies with JEDEC standards: – JESD8-5 (2.3 V to 2.7 V) – JESD8B/JESD36 (2.7 V to 3.6 V) • ESD protection: – HBM ANSI/ESDA/JEDEC JS-001 exceeds 2000 V – CDM JESD22-C101E exceeds 1000 V 74ALVCH16823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable; 3-state 3 Ordering information Table 1. Ordering information Type number Package 74ALVCH16823DGG 4 Temperature range Name Description −40 °C to +85 °C plastic thin shrink small outline package; 56 leads; SOT364-1 body width 6.1 mm TSSOP56 Version Functional diagram 28 1 54 52 51 49 48 47 45 44 43 42 41 40 38 37 36 34 33 31 56 29 2MR 1OE 1MR 2OE 1D0 1Q0 1D1 1Q1 1D2 1Q2 1D3 1Q3 1D4 1Q4 1D5 1Q5 1D6 1Q6 1D7 1Q7 1D8 1Q8 2D0 2Q0 2D1 2Q1 2D2 2Q2 2D3 2Q3 2D4 2Q4 2D5 2Q5 2D6 2Q6 2D7 2Q7 2D8 2Q8 1CP 2CE 2CP 1CE 1OE 1MR 1CE 1CP 2OE 2MR 2CE 2CP 2 27 3 5 6 1D0 8 1D1 9 1D2 10 1D3 12 1D4 13 1D5 14 1D6 15 1D7 16 1D8 17 2D0 19 2D1 20 2D2 21 2D3 23 2D4 24 26 2D5 30 2D7 2D6 2D8 55 2 1 55 56 27 28 30 29 54 52 EN1 R2 G3 3C4 EN5 R6 G7 7C8 4D 1,2 3 5 51 6 49 8 48 9 47 10 45 12 44 13 43 14 42 41 8D 5,6 15 16 40 17 38 19 37 20 36 21 34 23 33 24 31 26 aaa-028141 1Q0 1Q1 1Q2 1Q3 1Q4 1Q5 1Q6 1Q7 1Q8 2Q0 2Q1 2Q2 2Q3 2Q4 2Q5 2Q6 2Q7 2Q8 001aad242 Figure 1. Logic symbol Figure 2. IEC logic symbol VCC data input to internal circuit 001aad245 Figure 3. Bushold circuit (one data input) 74ALVCH16823 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 2 / 18 74ALVCH16823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable; 3-state nCE nD0 nD1 nD2 nD3 nD4 nD5 nD6 nD7 nD8 nCP CP nD R CP nD Q R CP nD Q R CP nD Q R CP nD Q R CP nD Q R CP nD Q R CP nD Q R CP nD Q R Q nMR nOE nQ0 nQ1 nQ2 nQ3 nQ4 nQ5 nQ6 nQ7 nQ8 001aad243 Figure 4. Logic diagram 74ALVCH16823 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 3 / 18 74ALVCH16823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable; 3-state 5 Pinning information 5.1 Pinning 74ALVCH16823 1MR 1 56 1CP 1OE 2 55 1CE 1Q0 3 54 1D0 GND 4 53 GND 1Q1 5 52 1D1 1Q2 6 51 1D2 VCC 7 50 VCC 1Q3 8 49 1D3 1Q4 9 48 1D4 1Q5 10 47 1D5 GND 11 46 GND 1Q6 12 45 1D6 1Q7 13 44 1D7 1Q8 14 43 1D8 2Q0 15 42 2D0 2Q1 16 41 2D1 2Q2 17 40 2D2 GND 18 39 GND 2Q3 19 38 2D3 2Q4 20 37 2D4 2Q5 21 36 2D5 VCC 22 35 VCC 2Q6 23 34 2D6 2Q7 24 33 2D7 GND 25 32 GND 2Q8 26 31 2D8 2OE 27 30 2CE 2MR 28 29 2CP aaa-028142 Figure 5. Pin configuration SOT364-1 (TSSOP56) 74ALVCH16823 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 4 / 18 74ALVCH16823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable; 3-state 5.2 Pin description Table 2. Pin description Symbol Pin Description 1D0, 1D1, 1D2, 1D3, 1D4, 1D5, 1D6, 1D7, 1D8 54, 52, 51, 49, 48, 47, 45, 44, 43 data inputs 1Q0, 1Q1, 1Q2, 1Q3, 1Q4, 1Q5, 1Q6, 1Q7, 1Q8 3, 5, 6, 8, 9, 10, 12, 13, 14 data outputs 2D0, 2D1, 2D2, 2D3, 2D4, 2D5, 2D6, 2D7, 2D8 42, 41, 40, 38, 37, 36, 34, 33, 31 data inputs 2Q0, 2Q1, 2Q2, 2Q3, 2Q4, 2Q5, 2Q6, 2Q7, 2Q8 15, 16, 17, 19, 20, 21, 23, 24, 26 data outputs 1MR, 2MR 1, 28 master reset inputs (active-LOW) 1OE, 2OE 2, 27 output enable inputs (active LOW) 1CP, 2CP 56, 29 clock pulse inputs (active rising edge) 1CE, 2CE 55, 30 clock enable inputs (active-LOW) GND 4, 11, 18, 25, 32, 39, 46, 53 ground (0 V) VCC 7, 22, 35, 50 supply voltage 6 Functional description Table 3. Function table Operating mode [1] Input Output nOE nMR nCE nCP nDn nQn clear L L X X X L load and read data L H L ↑ h H L H L ↑ l L L H L L X NC L H H X X NC H X X X X Z hold disable outputs [1] H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the LOW-to-HIGH clock transition; L = LOW voltage level; l = LOW voltage level one set-up time prior to the LOW-to-HIGH clock transition; NC = no change; X = don’t care; Z = high-impedance OFF-state; 74ALVCH16823 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 5 / 18 74ALVCH16823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable; 3-state 7 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI Conditions input voltage Min Max Unit −0.5 +4.6 V For control pins [1] −0.5 +5.5 V For data inputs [1] −0.5 VCC + 0.5 V [1] −0.5 VCC + 0.5 V −50 - mA VO output voltage IIK input clamping current VI < 0 V IOK output clamping current VO > VCC or VO < 0 V - ±50 mA VO = 0 V to VCC - ±50 mA IO(sink/source) output sink or source current ICC supply current - 100 mA IGND ground current −100 - mA Tstg storage temperature −65 +150 °C - 600 mW Ptot total power dissipation Tamb = −40 °C to +125 °C [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] Above 55 °C the value of Ptot derates linearly with 8 mW/K. 8 Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Max Unit VCC supply voltage 2.5 V range for maximum speed performance at 30 pF output load 2.3 2.7 V 3.3 V range for maximum speed performance at 50 pF output load 3.0 3.6 V for low-voltage applications 1.2 3.6 V for data inputs 0 VCC V for control inputs 0 5.5 V 0 VCC V -40 +85 °C VI input voltage VO output voltage Tamb ambient temperature in free air Δt/ΔV input transition rise and fall rate VCC = 2.3 V to 3.0 V - 20 ns/V VCC = 3.0 V to 3.6 V - 10 ns/V 74ALVCH16823 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 6 / 18 74ALVCH16823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable; 3-state 9 Static characteristics Table 6. Static characteristics At recommended operating conditions; Tamb = −40 °C to +85 °C; voltages are referenced to GND (ground = 0 V). [1] Symbol Parameter Conditions Min Typ VIH VCC = 1.2 V VCC - - V VCC = 1.8 V 0.7VCC 0.9 - V VCC = 2.3 V to 2.7 V 1.7 1.2 - V VCC = 2.7 V to 3.6 V 2.0 1.5 - V VCC = 1.2 V - - GND V VCC = 1.8 V - 0.9 0.2VCC V VCC = 2.3 V to 2.7 V - 1.2 0.7 V VCC = 2.7 V to 3.6 V - 1.5 0.8 V IO = -100 μA; VCC = 1.8 V to 3.6 V VCC - 0.2 VCC - V IO = -6 mA; VCC = 1.8 V VCC - 0.4 VCC - 0.10 - V IO = -6 mA; VCC = 2.3 V VCC - 0.3 VCC - 0.08 - V IO = -12 mA; VCC = 2.3 V VCC - 0.5 VCC - 0.17 - V IO = -18 mA; VCC = 2.3 V VCC - 0.6 VCC - 0.26 - V IO = -12 mA; VCC = 2.7 V VCC - 0.5 VCC - 0.14 - V IO = -24 mA; VCC = 3.0 V VCC - 1.0 VCC - 0.28 - V IO = 100 μA; VCC = 1.8 V to 3.6 V - GND 0.20 V IO = 6 mA; VCC = 1.8 V - 0.09 0.30 V IO = 6 mA; VCC = 2.3 V - 0.07 0.20 V IO = 12 mA; VCC = 2.3 V - 0.15 0.40 V IO = 18 mA; VCC = 2.3 V - 0.23 0.60 V IO = 12 mA; VCC = 2.7 V - 0.14 0.40 V IO = 24 mA; VCC = 3.0 V - 0.27 0.55 V per control pin; VCC = 1.8 V to 3.6 V; VI = 5.5 V or GND - 0.1 5 μA per data pin; VCC = 1.8 V to 3.6 V; VI = VCC or GND - 0.1 5 μA VCC = 1.8 V to 2.7 V; VI = VIH or VIL; VO = VCC or GND - 0.1 5 μA VCC = 2.7 V to 3.6 V; VI = VIH or VIL; VO = VCC or GND - 0.1 10 μA VIL VOH VOL II IOZ HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage input leakage current OFF-state output current Max Unit VI = VIH or VIL VI = VIH or VIL ICC supply current VCC = 2.3 V to 3.6 V; VI = VCC or GND; IO = 0 A - 0.2 40 µA ΔICC additional supply current VCC = 2.7 V to 3.6 V; VI = VCC - 0.6 V; IO = 0 A - 150 750 μA 74ALVCH16823 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 7 / 18 74ALVCH16823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable; 3-state [1] Symbol Parameter Conditions IBHL bus hold LOW current VCC = 2.3 V; VI = 0.7 V 45 - - μA VCC = 3.0 V; VI = 0.8 V 75 150 - μA bus hold HIGH current VCC = 2.3 V; VI = 1.7 V -45 - - μA VCC = 3.0 V; VI = 2.0 V -75 -175 - μA bus hold LOW overdrive current VCC = 2.7 V 300 - - μA VCC = 3.0 V 450 - - μA bus hold HIGH overdrive current VCC = 2.7 V -300 - - μA VCC = 3.6 V -450 - - μA - 5.0 - pF IBHH IBHLO IBHHO CI Min input capacitance Typ Max Unit [1] All typical values are measured at Tamb = 25 °C. 10 Dynamic characteristics Table 7. Dynamic characteristics At recommended operating conditions; Tamb = −40 °C to +85 °C; voltages are referenced to GND (ground = 0 V); for test circuit see Figure 10 Symbol tpd Parameter propagation delay Conditions Min nCP to nQn; see Figure 6 Typ [1] Max Unit [2] VCC = 1.2 V - 10.6 - ns VCC = 1.8 V 1.5 4.5 7.5 ns VCC = 2.3 V to 2.7 V 1.0 2.8 4.9 ns VCC = 2.7 V 1.0 2.7 4.3 ns VCC = 3.0 V to 3.6 V 1.0 2.5 3.7 ns VCC = 1.2 V - 9.9 - ns VCC = 1.8 V 1.5 4.6 7.4 ns VCC = 2.3 V to 2.7 V 1.0 2.9 5.0 ns VCC = 2.7 V 1.0 3.1 4.6 ns 1.0 2.6 4.0 ns VCC = 1.2 V - 10.4 - ns VCC = 1.8 V 1.5 4.4 7.7 ns VCC = 2.3 V to 2.7 V 1.0 2.8 5.3 ns VCC = 2.7 V 1.0 3.1 5.2 ns VCC = 3.0 V to 3.6 V 1.0 2.5 4.3 ns nMR to nQn; see Figure 8 VCC = 3.0 V to 3.6 V ten enable time 74ALVCH16823 Product data sheet nOE to nQn; see Figure 9 [3] All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 8 / 18 74ALVCH16823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable; 3-state Symbol tdis tsu Parameter disable time set-up time Conditions Min nOE to nQn; see Figure 9 Typ [1] Max Unit [4] VCC = 1.2 V - 6.7 - ns VCC = 1.8 V 1.5 3.3 5.5 ns VCC = 2.3 V to 2.7 V 1.0 2.2 4.1 ns VCC = 2.7 V 1.0 3.1 4.3 ns VCC = 3.0 V to 3.6 V 1.0 2.8 3.9 ns VCC = 1.8 V 1.5 0.2 - ns VCC = 2.3 V to 2.7 V 1.2 0.2 - ns VCC = 2.7 V 1.5 0.4 - ns VCC = 3.0 V to 3.6 V 1.2 0.2 - ns VCC = 1.8 V 2.0 -0.2 - ns VCC = 2.3 V to 2.7 V 1.8 -0.2 - ns VCC = 2.7 V 1.9 -0.1 - ns VCC = 3.0 V to 3.6 V 1.5 -0.1 - ns VCC = 1.8 V 0.6 -0.2 - ns VCC = 2.3 V to 2.7 V 0.8 -0.1 - ns VCC = 2.7 V 0.6 -0.2 - ns VCC = 3.0 V to 3.6 V 0.8 0.0 - ns VCC = 1.8 V 0.3 0.2 - ns VCC = 2.3 V to 2.7 V 0.3 0.2 - ns VCC = 2.7 V 0.4 0.1 - ns VCC = 3.0 V to 3.6 V 0.5 0.1 - ns VCC = 1.8 V 4.0 2.0 - ns VCC = 2.3 V to 2.7 V 3.0 1.6 - ns VCC = 2.7 V 3.0 1.6 - ns VCC = 3.0 V to 3.6 V 2.5 1.4 - ns VCC = 1.8 V 4.0 0.8 - ns VCC = 2.3 V to 2.7 V 3.0 0.4 - ns VCC = 2.7 V 3.0 0.6 - ns VCC = 3.0 V to 3.6 V 2.5 0.3 - ns nDn to nCP; see Figure 7 nCE to nCP; see Figure 7 th hold time nDn to nCP; see Figure 7 nCE to nCP; see Figure 7 tW pulse width nCP HIGH or LOW; see Figure 6 nMR HIGH or LOW; see Figure 8 74ALVCH16823 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 9 / 18 74ALVCH16823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable; 3-state Symbol Parameter Conditions trec recovery time nMR to nCP; see Figure 8 fmax maximum frequency Typ VCC = 1.8 V 0.8 0.2 - ns VCC = 2.3 V to 2.7 V 1.0 0.3 - ns VCC = 2.7 V 0.8 0.1 - ns VCC = 3.0 V to 3.6 V 1.0 0.2 - ns power dissipation capacitance Max Unit VCC = 1.8 V 125 250 - MHz VCC = 2.3 V to 2.7 V 150 300 - MHz VCC = 2.7 V 150 300 - MHz 200 350 - MHz outputs enabled - 16 - pF outputs disabled - 10 - pF nCP; see Figure 6 VCC = 3.0 V to 3.6 V CPD [1] Min per latch; VI = GND to VCC [5] [1] Typical values are measured at Tamb = 25 °C Typical values for VCC = 2.3 V to 2.7 V are measured at VCC = 2.5 V. Typical values for VCC = 3.0 V to 3.6 V are measured at VCC = 3.3 V. [2] tpd is the same as tPLH and tPHL. [3] ten is the same as tPZL and tPZH. [4] tdis is the same as tPLZ and tPHZ. [5] CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + ∑ (CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in Volts; N = total load switching outputs; 2 ∑(CL × VCC × fo) = sum of outputs. 74ALVCH16823 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 10 / 18 74ALVCH16823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable; 3-state 10.1 Waveforms and test circuit 1/fmax VI nCP input VM VM GND tW t PHL t PLH VOH VM nQn output VOL 001aaa256 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 6. Propagation delay clock input (nCP) to output (nQn), clock pulse (nCP) width and maximum clock (nCP) frequency VI input nDn, nCE VM GND VM t su(H) VM t h(H) VM t su(L) t h(L) VI input nCP VM VM GND 001aad401 Measurement points are given in Table 8. The shaded areas indicate when the input is permitted to change for predictable output performance. Figure 7. Data set-up and hold times for the nDn or nCE input to the nCP input VI VM input nMR VM GND t WL t rec VI input nCP VM GND t PHL VOH VM output nQn VOL 001aad400 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 8. Master reset (nMR) pulse width, master reset (nMR) to output (nQn) propagation delay and master reset (nMR) to clock (nCP) recovery time 74ALVCH16823 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 11 / 18 74ALVCH16823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable; 3-state VI nOE input VM VM GND tPLZ nQn output LOW-to-OFF OFF-to-LOW tPZL VCC VM VX VOL tPZH tPHZ nQn output HIGH-to-OFF OFF-to-HIGH VOH VY VM GND outputs enabled outputs disabled outputs enabled 001aal795 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 9. OFF-state to HIGH and LOW propagation delays and LOW and HIGH to OFF-state propagation delays Table 8. Measurement points VCC Input Output VI VM VM VX VY < 2.7 V VCC 0.5 x VCC 0.5 x VCC VOL + 0.15 V VOH - 0.15 V ≥ 2.7 V 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V 74ALVCH16823 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 12 / 18 74ALVCH16823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable; 3-state VI negative pulse tW 90 % VM 0V VI tf tr tr tf 90 % positive pulse 0V VM 10 % VM VM 10 % tW VEXT VCC PULSE GENERATOR VI RL VO DUT RT CL RL 001aae235 Test data is given in Table 9. Definitions test circuit: RL = Load resistance; CL = Load capacitance including jig and probe capacitance; RT = Termination resistance should be equal to output impedance Zo of the pulse generator; VEXT = External voltage for measuring switching times. Figure 10. Test circuit for measuring switching times Table 9. Test data Input Load VEXT VCC VI tr, tf RL CL tPHZ, tPZH tPLZ, tPZL tPLH, tPHL < 2.7 V VCC ≤ 2.0 ns 500 Ω 30 pF GND 2 × VCC open ≥ 2.7 V 2.7 V ≤ 2.5 ns 500 Ω 50 pF GND 2 × VCC open 74ALVCH16823 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 13 / 18 74ALVCH16823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable; 3-state 11 Package outline TSSOP56: plastic thin shrink small outline package; 56 leads; body width 6.1 mm SOT364-1 E D A X c HE y v M A Z 56 29 Q A2 (A 3 ) A1 pin 1 index A θ Lp L 1 28 w M bp e detail X 2.5 0 5 mm scale DIMENSIONS (mm are the original dimensions). UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z θ mm 1.2 0.15 0.05 1.05 0.85 0.25 0.28 0.17 0.2 0.1 14.1 13.9 6.2 6.0 0.5 8.3 7.9 1 0.8 0.4 0.50 0.35 0.25 0.08 0.1 0.5 0.1 8 o 0 o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT364-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Figure 11. Package outline SOT364-1 (TSSOP56) 74ALVCH16823 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 14 / 18 74ALVCH16823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable; 3-state 12 Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test TTL Transistor-Transistor Logic 13 Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74ALVCH16823 v.3 20180201 Product data sheet - 74ALVCH16823 v.2 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. • Type number 74ALVCH16823DL (SOT371-1 / SSOP56) removed 74ALVCH16823 v.2 19980729 Product specification - 74ALVCH16823 v.1 74ALVCH16823 v.1 19980729 Product specification - - 74ALVCH16823 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 15 / 18 74ALVCH16823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable; 3-state 14 Legal information 14.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74ALVCH16823 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 16 / 18 74ALVCH16823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable; 3-state Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74ALVCH16823 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 February 2018 © Nexperia B.V. 2018. All rights reserved. 17 / 18 74ALVCH16823 Nexperia 18-bit bus-interface D-type flip-flop with reset and enable; 3-state Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 10.1 11 12 13 14 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 2 Functional diagram ............................................. 2 Pinning information ............................................ 4 Pinning ............................................................... 4 Pin description ................................................... 5 Functional description ........................................5 Limiting values .................................................... 6 Recommended operating conditions ................ 6 Static characteristics .......................................... 7 Dynamic characteristics .....................................8 Waveforms and test circuit .............................. 11 Package outline .................................................14 Abbreviations .................................................... 15 Revision history ................................................ 15 Legal information .............................................. 16 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2018. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 1 February 2018 Document identifier: 74ALVCH16823
74ALVCH16823DGG:11 价格&库存
很抱歉,暂时无法提供与“74ALVCH16823DGG:11”相匹配的价格&库存,您可以联系我们找货
