TS19720
Taiwan Semiconductor
Single-Stage PFC Buck Current Control LED Driver
DESCRIPTION
FEATURES
The TS19720 is a high power factor and high accuracy
Low THD 0.9
optimization by an external resistor. TS19720 achieves
Low BOM Cost
high power factor and high efficiency by boundary
Boundary Conduction Mode Control
conduction mode (BCM). The line and load regulation of
Gate Output Voltage Clamp
LED current are within ±2.5%. TS19720 also provides
LED Open Protection
gate
LED Short Protection
Over Current Protection (OCP)
Over Thermal Protection (OTP)
Compliant to RoHS Directive 2011/65/EU and in
accordance to WEEE 2002/96/EC.
Halogen-free according to IEC 61249-2-21
harmonic
driving
protection,
distortion
voltage
and
(THD)
clamping,
system
output
and
VCC
over-voltage
open/short
circuit
protection to increase IC performance.
APPLICATION
SOT-26
LED lighting
Down lights, Tube lamps, PAR Lamps, Bulbs
Pin Definition:
1. VCC
2. GND
3. OUT
4. RT
5. COM
6. CS
Note: MSL 3 (Moisture Sensitivity Level) per J-STD-020
ABSOLUTE MAXIMUM RATINGS (Note 1)
PARAMETER
SYMBOL
LIMIT
UNIT
Power Supply Pin
VCC
40
V
RT Voltage to GND
VRT
-0.3 to 5.5
V
OUT Voltage to GND
VOUT
-0.3 to 40
V
CS Voltage to GND
VCS
-0.3 to 5.5
V
VCOM
-0.3 to 5.5
V
PD
0.3
W
HBM
2
kV
MM
200
V
TLEAD
260
°C
Junction Temperature Range
TJ
-40 to +150
°C
Storage Temperature Range
TSTG
-65 to +150
°C
COM Voltage to GND
Power Dissipation @ TA=25 °C
ESD Rating (Human Body Mode)
(Note 2)
ESD Rating (Machine Mode)
Lead Temperature (Soldering 10 sec)
1
Version: B15
TS19720
THERMAL PERFORMANCE
PARAMETER
SYMBOL
LIMIT
UNIT
Thermal Resistance - Junction to Case
RӨJC
106.6
°C/W
Thermal Resistance - Junction to Ambient
RӨJA
220
°C/W
Note: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The case thermal reference is defined at
the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is determined by the user’s board
design. RӨJA shown below for single device operation on FR-4 PCB in still air. Thermal Resistance is specified with the
component mounted on a low effective thermal conductivity test board in free air at TA=25°C.
RECOMMENDED OPERATING CONDITIONS
PARAMETER
(Note 3)
SYMBOL
CONDITIONS
UNIT
Power Supply Pin
VCC
33
V
RT Voltage to GND
VRT
-0.3 to 5
V
OUT Voltage to GND
VOUT
-0.3 to 19
V
CS Voltage to GND
VCS
-0.3 to 5
V
VCOM
-0.3 to 5
V
Operating Junction Temperature Range
TJ
-40 to +125
°C
Operating Ambient Temperature Range
TOPA
-40 to +85
°C
COM Voltage to GND
ELECTRICAL SPECIFICATIONS (VCC = 18V, TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
MIN
TYP
MAX
UNIT
VCC(ST)
45
µA
IOPA
2.1
2.6
mA
UVLO(off)
VUVLO(off)
7
8
9
V
UVLO(on)
VUVLO(on)
16
17.5
19
V
VOVP
29
31
33
V
Feedback Reference Voltage
VFB
0.196
0.2
0.204
V
Transconductance
GM
58
μS
IO-SINK
5.8
μA
IO-SOURCE
5.8
μA
VOCP
1.4
V
VOLP
5
V
LEBt
400
ns
100
ns
3
4.5
6
kHz
Supply Voltage
Start-up Current
VCC= VUVLO(on) -1V
Operating Current
With 1nF load on out pin
OVP Level on VCC Pin
Voltage Feedback
Output Sink Current
Output Source Current
Current Sensing
CS Limit Voltage
Open Loop Voltage
CS Pin Open
Leading-Edge Blanking Time
Delay to Output
Switching Frequency
Start Frequency
fSTR
2
Version: B15
TS19720
PARAMETER
CONDITIONS
SYMBOL
MIN
TYP
MAX
UNIT
Rising Time
Load Capacitance =1nF
tRISE
90
ns
Falling Time
tFALL
40
ns
VGATE
12.5
15
V
150
°C
120
°C
Gate Driver Output
VGATE-Clamp
Thermal Section
Thermal Shutdown
(Note 4)
Thermal Shutdown Release
(Note 5)
Notes:
1. Stresses listed as the above “Absolute Maximum Ratings” may cause permanent damage to the device. These are for
stress ratings. Functional operation of the device at these or any other conditions beyond those indicated in the operational
sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may
remain possibility to affect device reliability.
2. Devices are ESD sensitive. Handing precaution recommended..
3. The device is not guaranteed to function outside its operating conditions.
4. Guaranteed by design.
5. Auto Recovery Type.
3
Version: B15
TS19720
ORDERING INFORMATION
PART NO.
TS19720CX6 RFG
PACKAGE
PACKING
SOT-26
3,000pcs / 7” Reel
BLOCK DIAGRAM
PIN DESCRIPTION
PIN NO.
NAME
1
VCC
FUNCTION
2
GND
Ground return for all internal circuitry
3
OUT
Gate driver output
4
RT
Efficiency / THD option pin
5
COM
Output pin of error amplifier
6
CS
Power supply pin for all internal circuitry
Input current sense pin
4
Version: B15
TS19720
APPLICATION INFORMATION
Start-up Current
The typical start-up current is around 45μA. Very low start-up current allows the PWM controller to increase the
value of start-up resistor and then reduce the power dissipation.
Under Voltage Lockout (UVLO)
A hysteresis UVLO comparator is implemented in TS19720. The turn-on and turn-off thresholds level are fixed at
17.5V and 8V respectively. This hysteresis shown in Fig.3 ensures that the start-up capacitor will be adequate to
supply the chip during start-up. For quick start-up of the LED driver, the start-up resistor should be matched with
the start-up capacitor.
Fig.3
Leading-Edge Blanking (LEB)
Each time the power MOSFET is switched on, a turn-on spike will inevitably occur at the sense resistor. To avoid
fault trigger, a 400ns leading-edge blanking time is built in. Conventional RC filtering can therefore be omitted.
During this blanking period, the current-limit comparator is disabled and cannot switch off the gate driver.
Gate Clamp
Driver is clamped to 12.5V by an internal clamping circuit to avoid the Gate of MOSFET to get damaged.
The TS19720 has built-in cycle by cycle over current protection function on CS pin. As the CS pin voltage is larger
than VOCP (1.4V), the gate output will be turned off immediately to avoid the driver board to be burned out.
Over Voltage Protection (OVP) on VCC
To prevent the LED driver from being damaged, the TS19720 has an implemented OVP function on VCC. When the
VCC voltage is higher than the VOVP (31V), the output gate driver circuit will be shut down immediately to stop the
switching of power MOSFET. The VCC pin OVP function is an auto recovery type protection. If the OVP condition
happens, the pulses will be stopped until the VCC pin voltage is down to the UVLO off level. The TS19720 is
working in an auto-recovery mode as shown in Fig. 4.
Fig. 4
5
Version: B15
TS19720
PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters)
SOT-26
SUGGESTED PAD LAYOUT (Unit: Millimeters)
MARKING DIAGRAM
SC = Device Code
Y
W
L
= Year Code
D =2014 E =2015 F =2016 G =2017
H =2018 J =2019 K =2020
= Week Code
A~Z =wk1~wk26
A~Z = wk27~wk52
= Lot Code A~Z
6
Version: B15
TS19720
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: B15
很抱歉,暂时无法提供与“TS19720CX6 RFG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 224+5.06048224+0.61098
- 500+3.54899500+0.42849
- 3000+2.021533000+0.24407
- 24000+1.8967324000+0.22900
