TS331
Low Power Low Offset Voltage Comparators
SOT-25
Pin Definition:
1. Input +
2. Ground
3. Input 4. Output
5. Vcc
General Description
The TS331 is single precision voltage comparators capable of single-supply or split-supply operation. The
specifications as low as 2.0 mV make this device an excellent ground level with single-supply operation. Input
offset-voltage selection for many applications in consumer automotive, and It is designed to permit a common
mode range-to- industrial electronics.
Features
Block Diagram
Output voltage compatible with DTL, ECL, TTL,
MOS and CMOS Logic levels
Low input bias current 25nA
Low input offset current ±0.5nA
Low input offset voltage ±2mV(typ)
Input common mode range to ground level
Differential input voltage range equal to power
supply voltage
Very low supply current drain (0.4mA) independent of supply voltage
Wide single-supply range 2V~36V
Split-supply range ±1V to ±18V
Ordering Information
Part No.
Package
Packing
TS331CX5 RFG
SOT-25
3Kpcs / 7” Reel
Note: “G” denotes Halogen Free Product.
Absolute Maximum Rating
Parameter
Symbol
Limit
Unit
Supply Voltage
VCC
+36 or ±18
V
Differential Input Voltage
VIDR
36
V
Input Common Mode Voltage Range
VICR
-0.3 to 36
V
Input Current
IIN
50
mA
Output Short Circuit to Ground
ISC
Continuous
Output Sink Current
ISINK
Operating Temperature Range
TOPR
-40 ~ +105
o
C
150
o
C
-65 ~ +150
o
C
260
o
C
Junction Temperature
TJ
Storage Temperature Range
TSTG
Lead Temperature 1.6mm(1/16”) from case for 10Sec.
1/5
TLEAD
mA
Version: B14
TS331
Electrical Characteristics (VCC=5V, TA=25oC; unless otherwise specified.)
Characteristics
Symbol
Min
Typ
Max
Unit
Input Offset Voltage (note 3)
VIO
2
5
mV
Input Offset Current, IIN(+) - IIN(-), VCM=0V
IIO
50
nA
Input Offset Current (note 4), IIN(+) - IIN(-), VCM=0V
IIB
250
nA
Input Common Mode Voltage Range, Vcc=30V
VICR
-0
VCC-1.5
V
Voltage Gain, RL ≥15K, Vcc=15V, Vo=1V~11V
AVOL
50
200
V/mV
300
nS
Response Time (note 6), VRL=5V. RL=5.1KΩ
tTLH
1.3
uS
Output Sink Current, VIN(-)=1V, VIN(+)=0V, Vo≤1.5V
ISINK
6.0
16
mA
VOL
250
400
mV
IOL
0.1
nA
Icc
0.4
1.0
mA
1.0
2.5
Large Signal Response Time
Vin=TTL Logic Swing. Vref = 1.4V, VRL=5V. RL=5.1KΩ
Output Saturation Voltage,
VIN(-)=1V, VIN(+)=0V, ISINK≤4mA
Output Leakage Current, VIN(-)=0V, VIN(+)=1V, Vo=5V
Supply Current
RL = ∞, VCC =5V
RL = ∞, VCC =36V
Note 1. The max. Output current may be as high as 20mA, independent of the magnitude of VCC, output short
circuits to VCC can cause excessive heating and eventual destruction.
Note 2. This magnitude of input current will only occur if the input leads are driven more negative than ground or
the negative supply voltage. This is due to the input PNP collector base junction becoming forward biased
acting as an input clamp diode. There is also a lateral PNP parasitic transistor action on the IC chip. This
phenomena can cause the output voltage of the comparators to go to the VCC voltage level (or ground if
overdrive is large) during the time the input is driven negative. This will not destroy the device and normal
output states will recover when the inputs become -0.3V of ground or negative supply.
Note 3. At output switch point, VO=1.4Vdc, RS=0Ω with VCC from 5Vdc to 30Vdc, and over the full input commonmode
Note 4. Due to the PNP transistor inputs, bias current will flow out of the inputs, this current is essentially constant
independent of the output state, therefore, no loading changes will exist on the input lines.
Note 5. Input common mode of either input should not be permitted to go more than 0.3V negative of ground or
minus supply. The upper limit of common mode range is VCC - 1.5V but either or both inputs can betaken
to as high as 30volts without damage.
Note 6. Response time is specified with a 100mV step and 5.0mV of overdrive. With larger magnitudes of
overdrive faster response times are obtainable.
Application information
This comparator feature high gain, wide bandwidth characteristics. This gives the device oscillation tendencies if
the outputs are capacitive coupled to the inputs via stray capacitance. This oscillation manifests itself during
output transitions (VOL to VOH). To alleviate this situation input resistors
很抱歉,暂时无法提供与“TS331CX5 RFG”相匹配的价格&库存,您可以联系我们找货
