P-3000S
PRESSURE TRANSDUCERS
P-3000S 構造図
INTERNAL STRUCTURE (Gauge type)
1
4
2
3
6
5
Part name
■ FEATURES
● For non-corrosive gases
● Built-in temp. compensation function (0 〜 50 °C)
● Three pressure reference to choose from Gauge,
Differential and Absolute pressure
● Compact and light weight
● PC board mountable
Material
1
Pressure port
2
Housing
3
Resin compound
4
Sensor chip
Silicone
5
Resistor board for temp. compensation
Ceramic
6
Terminal pin
Iron/Nickel alloy + Nickel-plated
PBT (Polybutyleneterephthalate)
Silicone gel
Copper + solder-plated
■ MODEL NUMBER DESIGNATION
P-3000S - 501 G - 02
Series name
Thermal error
Rated pressure range
02:± 0.02 % F.S./°C
04:± 0.04 % F.S./°C
500:0 ~ 4.9 kPa {0 ~ 0.05 kgf/cm2} 102:0 ~ 98.1 kPa {0 ~
1 kgf/cm2}
101:0 ~ 9.81 kPa {0 ~ 0.1 kgf/cm2} *502:0 ~ 490 kPa {0 ~ 5.0 kgf/cm2}
351:0 ~ 34.3 kPa {0 ~ 0.35 kgf/cm2} *702:0 ~ 686 kPa {0 ~ 7.0 kgf/cm2}
501:0 ~ 49.0 kPa {0 ~ 0.5 kgf/cm2}
*… Built-to-order
10:± 0.10 % F.S./°C
Pressure reference
G:Gauge
D:Differential
A:Absolute
■ LIST OF MODEL NUMBERS
Pressure reference
Thermal error
Gauge
Differential
Absolute
kPa {kgf/cm2} 0 ~ 4.9 0 ~ 9.81 0 ~ 49.0 0 ~ 98.1 0 ~ 490 0 ~ 686 0 ~ ± 9.81 0 ~ ± 49.0 0 ~ ± 98.1 0 ~ 34.3 0 ~ 98.1
Rated pressure range {0 ~ 0.05} {0 ~ 0.1} {0 ~ 0.5} {0 ~ 1} {0 ~ 5.0} {0 ~ 7.0} {0 ~ ± 0.1} {0 ~ ± 0.5} {0 ~ ± 1} {0 ~ 0.35} {0 ~ 1}
± 0.02 % F.S./°C
± 0.04 % F.S./°C
± 0.1 % F.S./°C
P-3000S P-3000S
-501G-02 -102G-02
P-3000S P-3000S
-501D-02 -102D-02
P-3000S P-3000S P-3000S P-3000S → P-3000S → P-3000S P-3000S P-3000S P-3000S P-3000S P-3000S
-500G-04 -101G-04 -501G-04 -102G-04 -502G-04 -702G-04 -101D-04 -501D-04 -102D-04 -351A-04 -102A-04
-101G-10 -501G-10 -102G-10
-101D-10 -501D-10 -102D-10 -351A-10 -102A-10
:Not available
※ Verify the above model numbers when placing orders.
→ The products marked → are built-to-order items. Please contact us separately to buy these products.
P-3000S
■標準仕様 STANDARD SPECIFICATIONS
● 特記ない場合、周囲温度 25 ± 5℃、駆動電流 1.5 mA DC で規定します。
Unless otherwise specified, the specs are defined at an ambient temperature of 25±5 °C and excitation current of 1.5 mA DC.
Item
Model number
Pressure reference
P-3000S
500G 101G 501G 102G 502G 702G 101D 501D 102D 351A 102A
Gauge
Differential Absolute
General specifications
4.9
9.81
49.0
98.1
490
686
± 9.81 ± 49.0 ± 98.1 34.3 (abs) 98.1 (abs)
Rated pressure range kPa {kgf/cm2} {0.05} {0.1}
{0.5}
{1.0}
{5.0}
{7.0} {± 0.1} {± 0.5} {± 1.0} {0.35} {1.0}
9.8
19.6
98.1
196
981
1372
19.6
98.1
196 103 (abs) 196 (abs)
kPa {kgf/cm2}
Maximum pressure
{0.1} {0.2} {1.0} {2.0} {10} {14} {0.2} {1.0} {2.0} {1.05} {2.0}
24.5
49.0
245
490
1471
2058
49.0
245
490 147 (abs) 490 (abs)
Break-down pressure kPa {kgf/cm2}
{0.25} {0.5} {2.5} {5.0} {15} {21} {0.5} {2.5} {5.0} {1.5} {5.0}
Operating temp. range
°C
− 20 ~ 100
Compensated temp. range
°C
0 ~ 50
Operating humidity
35 ~ 85(No condensation)
%RH
Storage temp.
°C
− 40 ~ 120(Atmospheric pressure, humidity 65 %RH maximum)
Bridge resistance
Ω
4700 ± 30 %
Pressure medium
Insulation resistance
Non-corrosive gases
MΩ
minimum
100 (50 V DC)
50 V AC, 60 s(Leakage current 1 mA maximum)
Dielectric strength
Pressure port
Power
Net weight
Analog output
φ 3.5
mm
g
Excitation current
Approx. 5
mV
Span voltage
mV 70 ± 30 50 ± 20
%F.S. ± 0.5
ZERO
%F.S./°C
Thermal error
(Reference temp.: 25 °C) SPAN
%F.S./°C
Response
Approx. 5
1.5(Constant current)
mA DC
Offset voltage
Linearity/Hysteresis
Approx. 7
± 3
±5
100 ± 30
± 0.3
± 0.25
50 ± 20
± 0.5
100 ± 30
± 0.3
80 ± 40
± 0.5
± 0.04 ± 0.04/0.1 ± 0.02/0.04/0.1
± 0.04
± 0.04/0.1
± 0.04
± 0.04/0.1
Approx. 1
ms
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Test conditions (At 25 ± 5 °C)
Permissible change
Vibration
10 ~ 500 Hz, 1.5 mm maximum/98.1 m/s ,
3 directions for 2 hours each
Shock
981 m/s2, 3 directions for 3 times each
Pressure cycling
0 ~ Rated pressure, 10 cycles
Moisture resistance
40 °C, 90 ~ 95 %RH, 240 hrs.
2
6
Offset voltage/Span voltage:
±1 %F.S. maximum each
※ P-3000S series can be operated at the vacuum pressure.
P-3000S
00S外形図
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance : ± 0.5 (Unit: mm)
● Gauge
Absolute type
9.52
17
10±1
10±1
21.5
2
3
10.2
15
3
Terminal pin No.
Φ 3.5±0.1
2
4
5 .1 5 .1
15
10.2
G
Vent hole
1
1
4
ゲージ圧タイプ
Pressure port
Terminal pin 5 –Φ 0.7
COPAL
JAPAN
10±1
B
17
差圧タイプ
A
+1
10.5 0
1
Φ 3.5±0.1
COPAL
Φ 3.5±0.1
● Differential type
JAPAN
Pressure port B
Terminal pin No.
81±
Pressure port A
G 4 3 2 1
Aux. pin
4×2.54
2 –Φ 0.75
■ INTERNAL ELECTRICAL SCHEMATICS
Thick film resistors for temp. compensation
Metal housing
Input
4 (+)
G
3 (–)
2 (–)
1 (+)
Output
7.62
Terminal pin
5 – Φ 0.75
■ TERMINAL NUMBER
Pin Connection
1
Output ⊕
2
Output ⊖
3
Input ⊖
4
Input ⊕
G
Housing
很抱歉,暂时无法提供与“P-3000S-102G-04”相匹配的价格&库存,您可以联系我们找货
