DSP56F801/D
Rev. 13.0, 02/2004
56F801
Technical Data
56F801 16-bit Hybrid Controller
Up to 30 MIPS operation at 60MHz core
frequency
8K × 16-bit words Program Flash
1K × 16-bit words Program RAM
Up to 40 MIPS operation at 80MHz core
frequency
2K × 16-bit words Data Flash
DSP and MCU functionality in a unified,
C-efficient architecture
1K × 16-bit words Data RAM
2K × 16-bit words Boot Flash
MCU-friendly instruction set supports both
DSP and controller functions: MAC, bit
manipulation unit, 14 addressing modes
Serial Peripheral Interface (SPI)
General Purpose Quad Timer
JTAG/OnCETM port for debugging
On-chip relaxation oscillator
11 shared GPIO
48-pin LQFP Package
Hardware DO and REP loops
6-channel PWM Module
Two 4-channel, 12-bit ADCs
Serial Communications Interface (SCI)
6
PWM Outputs
PWMA
RESET
Fault Input
IRQA
6
VCAPC VDD
VSS
2
5*
4
JTAG/
OnCE
Port
4
4
A/D1
A/D2
VREF
3
Quad Timer C
Program Memory
8188 x 16 Flash
1024 x 16 SRAM
Quad Timer D
or GPIO
Boot Flash
2048 x 16 Flash
Data Memory
2048 x 16 Flash
1024 x 16 SRAM
2
4
Digital Reg
SCI0
or
GPIO
SPI
or
GPIO
Program Controller
and
Hardware Looping Unit
16-Bit
56800
Core
CGDB
XAB1
XAB2
INTERRUPT
CONTROLS
16
COP/
Watchdog
ApplicationSpecific
Memory &
Peripherals
IPBB
CONTROLS
16
COP RESET
MODULE CONTROLS
ADDRESS BUS [8:0]
IPBus Bridge
(IPBB)
DATA BUS [15:0]
*includes TCS pin which is reserved for factory use and is tied to VSS
Figure 1. 56F801 Block Diagram
© Motorola, Inc., 2004. All rights reserved.
Bit
Manipulation
Unit
PLL
XDB2
Analog Reg
Data ALU
16 x 16 + 36 → 36-Bit MAC
Three 16-bit Input Registers
Two 36-bit Accumulators
Address
Generation
Unit
PAB
PDB
VSSA
Low Voltage
Supervisor
ADC
Interrupt
Controller
VDDA
Clock Gen
or Optional
Internal
Relaxation Osc.
GPIOB3/XTAL
GPIOB2/EXTAL
Part 1 Overview
1.1 56F801 Features
1.1.1
Digital Signal Processing Core
Efficient 16-bit 56800 family hybrid controller engine with dual Harvard architecture
As many as 40 Million Instructions Per Second (MIPS) at 80MHz core frequency
Single-cycle 16 × 16-bit parallel Multiplier-Accumulator (MAC)
Two 36-bit accumulators including extension bits
16-bit bidirectional barrel shifter
Parallel instruction set with unique DSP addressing modes
Three internal address buses and one external address bus
Four internal data buses and one external data bus
Instruction set supports both DSP and controller functions
Controller style addressing modes and instructions for compact code
Efficient C compiler and local variable support
Software subroutine and interrupt stack with depth limited only by memory
JTAG/OnCE debug programming interface
1.1.2
Memory
Harvard architecture permits as many as three simultaneous accesses to Program and Data memory
On-chip memory including a low-cost, high-volume Flash solution
— 8K × 16 bit words of Program Flash
— 1K × 16-bit words of Program RAM
— 2K × 16-bit words of Data Flash
— 1K × 16-bit words of Data RAM
— 2K × 16-bit words of Boot Flash
1.1.3
2
Programmable Boot Flash supports customized boot code and field upgrades of stored code
through a variety of interfaces (JTAG, SPI)
Peripheral Circuits for 56F801
Pulse Width Modulator (PWM) with six PWM outputs, two Fault inputs, fault-tolerant design with
deadtime insertion; supports both center- and edge-aligned modes
Two 12-bit, Analog-to-Digital Converters (ADCs), which support two simultaneous conversions
with two 4-multiplexed inputs; ADC and PWM modules can be synchronized
General Purpose Quad Timer: Timer D with three pins (or three additional GPIO lines)
Serial Communication Interface (SCI) with two pins (or two additional GPIO lines)
Serial Peripheral Interface (SPI) with configurable four-pin port (or four additional GPIO lines)
56F801 Technical Data
56F801 Description
Eleven multiplexed General Purpose I/O (GPIO) pins
Computer-Operating Properly (COP) watchdog timer
One dedicated external interrupt pin
External reset pin for hardware reset
JTAG/On-Chip Emulation (OnCE™) for unobtrusive, processor speed-independent debugging
Software-programmable, Phase Locked Loop-based frequency synthesizer for the hybrid controller
core clock
Oscillator flexibility between either an external crystal oscillator or an on-chip relaxation oscillator
for lower system cost and two additional GPIO lines
1.1.4
Energy Information
Fabricated in high-density CMOS with 5V-tolerant, TTL-compatible digital inputs
Uses a single 3.3V power supply
On-chip regulators for digital and analog circuitry to lower cost and reduce noise
Wait and Stop modes available
1.2 56F801 Description
The 56F801 is a member of the 56800 core-based family of hybrid controllers. It combines, on a single
chip, the processing power of a DSP and the functionality of a microcontroller with a flexible set of
peripherals to create an extremely cost-effective solution. Because of its low cost, configuration flexibility,
and compact program code, the 56F801 is well-suited for many applications. The 56F801 includes many
peripherals that are especially useful for applications such as motion control, smart appliances, steppers,
encoders, tachometers, limit switches, power supply and control, automotive control, engine management,
noise suppression, remote utility metering, and industrial control for power, lighting, and automation.
The 56800 core is based on a Harvard-style architecture consisting of three execution units operating in
parallel, allowing as many as six operations per instruction cycle. The microprocessor-style programming
model and optimized instruction set allow straightforward generation of efficient, compact code for both
DSP and MCU applications. The instruction set is also highly efficient for C compilers to enable rapid
development of optimized control applications.
The 56F801 supports program execution from either internal or external memories. Two data operands can
be accessed from the on-chip Data RAM per instruction cycle. The 56F801 also provides one external
dedicated interrupt lines and up to 11 General Purpose Input/Output (GPIO) lines, depending on peripheral
configuration.
The 56F801 controller includes 8K words (16-bit) of Program Flash and 2K words of Data Flash (each
programmable through the JTAG port) with 1K words of both Program and Data RAM. A total of 2K words
of Boot Flash is incorporated for easy customer-inclusion of field-programmable software routines that can
be used to program the main Program and Data Flash memory areas. Both Program and Data Flash
memories can be independently bulk erased or erased in page sizes of 256 words. The Boot Flash memory
can also be either bulk or page erased.
A key application-specific feature of the 56F801 is the inclusion of a Pulse Width Modulator (PWM)
module. This modules incorporates six complementary, individually programmable PWM signal outputs to
enhance motor control functionality. Complementary operation permits programmable dead-time insertion,
3
and separate top and bottom output polarity control. The up-counter value is programmable to support a
continuously variable PWM frequency. Both edge- and center-aligned synchronous pulse width control (0%
to 100% modulation) are supported. The device is capable of controlling most motor types: ACIM (AC
Induction Motors), both BDC and BLDC (Brush and Brushless DC motors), SRM and VRM (Switched and
Variable Reluctance Motors), and stepper motors. The PWMs incorporate fault protection and cycle-bycycle current limiting with sufficient output drive capability to directly drive standard opto-isolators. A
“smoke-inhibit”, write-once protection feature for key parameters is also included. The PWM is doublebuffered and includes interrupt control to permit integral reload rates to be programmable from 1 to 16. The
PWM modules provide a reference output to synchronize the Analog-to-Digital Converters.
The 56F801 incorporates an 8 input, 12-bit Analog-to-Digital Converter (ADC). A full set of standard
programmable peripherals is provided that include a Serial Communications Interface (SCI), a Serial
Peripheral Interface (SPI), and two Quad Timers. Any of these interfaces can be used as General-Purpose
Input/Outputs (GPIO) if that function is not required. An on-chip relaxation oscillator provides flexibility
in the choice of either on-chip or externally supplied frequency reference for chip timing operations.
Application code is used to select which source is to be used.
1.3 State of the Art Development Environment
Processor ExpertTM (PE) provides a Rapid Application Design (RAD) tool that combines easy-touse component-based software application creation with an expert knowledge system.
The Code Warrior Integrated Development Environment is a sophisticated tool for code navigation,
compiling, and debugging. A complete set of evaluation modules (EVMs) and development system
cards will support concurrent engineering. Together, PE, Code Warrior and EVMs create a
complete, scalable tools solution for easy, fast, and efficient development.
1.4 Product Documentation
The four documents listed in Table 1 are required for a complete description and proper design with the
56F801. Documentation is available from local Motorola distributors, Motorola semiconductor sales
offices, Motorola Literature Distribution Centers, or online at www.motorola.com/semiconductors.
Table 1. 56F801 Chip Documentation
Topic
4
Description
Order Number
DSP56800
Family Manual
Detailed description of the 56800 family architecture, and
16-bit core processor and the instruction set
DSP56800FM/D
DSP56F801/803/805/807
User’s Manual
Detailed description of memory, peripherals, and interfaces
of the 56F801, 56F803, 56F805, and 56F807
DSP56F801-7UM/D
56F801
Technical Data Sheet
Electrical and timing specifications, pin descriptions, and
package descriptions (this document)
DSP56F801/D
56F801
Product Brief
Summary description and block diagram of the 56F801 core,
memory, peripherals and interfaces
DSP56F801PB/D
DSP56F801
Errata
Details any chip issues that might be present
DSP56F801E/D
Data Sheet Conventions
1.5 Data Sheet Conventions
This data sheet uses the following conventions:
OVERBAR
This is used to indicate a signal that is active when pulled low. For example, the RESET pin is
active when low.
“asserted”
A high true (active high) signal is high or a low true (active low) signal is low.
“deasserted”
A high true (active high) signal is low or a low true (active low) signal is high.
Examples:
1.
Signal/Symbol
Logic State
Signal State
Voltage1
PIN
True
Asserted
VIL/VOL
PIN
False
Deasserted
VIH/VOH
PIN
True
Asserted
VIH/VOH
PIN
False
Deasserted
VIL/VOL
Values for VIL, VOL, VIH, and VOH are defined by individual product specifications.
Part 2 Signal/Connection Descriptions
2.1 Introduction
The input and output signals of the 56F801 are organized into functional groups, as shown in Table 2 and
as illustrated in Figure 2. In Table 3 through Table 13, each table row describes the signal or signals
present on a pin.
Table 2. Functional Group Pin Allocations
Number of
Pins
Detailed
Description
Power (VDD or VDDA)
5
Table 3
Ground (VSS or VSSA)
6
Table 4
Supply Capacitors
2
Table 5
PLL and Clock
2
Table 6
Interrupt and Program Control
2
Table 7
Pulse Width Modulator (PWM) Port
7
Table 8
Serial Peripheral Interface (SPI) Port1
4
Table 9
Serial Communications Interface (SCI) Port1
2
Table 10
Analog-to-Digital Converter (ADC) Port
9
Table 11
Quad Timer Module Port
3
Table 12
JTAG/On-Chip Emulation (OnCE)
6
Table 13
Functional Group
1.
Alternately, GPIO pins
5
Power Port
Ground Port
Power Port
Ground Port
VDD
4
VSS
5*
VDDA
1
VSSA
1
Other
Supply
Port
VCAPC
PLL and Clock
or GPIO
EXTAL (GPIOB2)
XTAL (GPIOB3)
PWMA0-5
6
2
1
FAULTA0
1
SCLK (GPIOB4)
1
MOSI (GPIOB5)
1
MISO (GPIOB6)
1
SS (GPIOB7)
1
TXD0 (GPIOB0)
1
RXD0 (GPIOB1)
SCI0 Port
or GPIO
8
ANA0-7
ADCA Port
1
VREF
3
TD0-2 (GPIOA0-2)
1
IRQA
1
1
56F801
TCK
TMS
JTAG/OnCE
Port
TDI
TDO
TRST
DE
SPI Port
or GPIO
1
1
1
1
1
Quad
Timer D
or GPIO
Interrupt/
Program
Control
RESET
1
1
Figure 2. 56F801 Signals Identified by Functional Group1
1. Alternate pin functionality is shown in parenthesis.
6
Power and Ground Signals
2.2 Power and Ground Signals
Table 3. Power Inputs
No. of Pins
Signal Name
Signal Description
4
VDD
Power—These pins provide power to the internal structures of the chip, and should
all be attached to VDD.
1
VDDA
Analog Power—This pin is a dedicated power pin for the analog portion of the chip
and should be connected to a low noise 3.3V supply.
Table 4. Grounds
No. of Pins
Signal Name
Signal Description
4
VSS
GND—These pins provide grounding for the internal structures of the chip,
and should all be attached to VSS.
1
VSSA
Analog Ground—This pin supplies an analog ground.
1
TCS
TCS—This Schmitt pin is reserved for factory use and must be tied to VSS for
normal use. In block diagrams, this pin is considered an additional VSS.
Table 5. Supply Capacitors and VPP
No. of
Pins
Signal
Name
Signal
Type
State
During Reset
2
VCAPC
Supply
Supply
Signal Description
VCAPC—Connect each pin to a 2.2 µFor greater bypass capacitor
in order to bypass the core logic voltage regulator (required for
proper chip operation). For more information, refer to Section 5.2.
2.3 Clock and Phase Locked Loop Signals
Table 6. PLL and Clock
No. of
Pins
Signal
Name
Signal
Type
State
During Reset
1
EXTAL
Input
Input
External Crystal Oscillator Input—This input should be connected
to an 8MHz external crystal or ceramic resonator. For more
information, please refer to Section 3.5.
GPIOB2
Input/
Output
Input
Port B GPIO—This multiplexed pin is a General Purpose I/O (GPIO)
pin that can be programmed as an input or output pin. This I/O can be
utilized when using the on-chip relaxation oscillator so the EXTAL pin
is not needed.
Signal Description
7
Table 6. PLL and Clock (Continued)
No. of
Pins
Signal
Name
Signal
Type
State
During Reset
1
XTAL
Output
Chipdriven
Signal Description
Crystal Oscillator Output—This output should be connected to an
8MHz external crystal or ceramic resonator. For more information,
This pin can also be connected to an external clock source. For more
information, please refer to Section 3.5.3.
GPIOB3
Input/
Output
utilized when using the on-chip relaxation oscillator so the XTAL pin is
not needed.
Input
2.4 Interrupt and Program Control Signals
Table 7. Interrupt and Program Control Signals
State
During
Reset
No. of
Pins
Signal
Name
Signal
Type
1
IRQA
Input
(Schmitt)
Input
External Interrupt Request A—The IRQA input is a
synchronized external interrupt request that indicates that an
external device is requesting service. It can be programmed to be
level-sensitive or negative-edge- triggered.
1
RESET
Input
(Schmitt)
Input
Reset—This input is a direct hardware reset on the processor.
When RESET is asserted low, the hybrid controller is initialized
and placed in the Reset state. A Schmitt trigger input is used for
noise immunity. When the RESET pin is deasserted, the initial
chip operating mode is latched from the EXTBOOT pin. The
internal reset signal will be deasserted synchronous with the
internal clocks, after a fixed number of internal clocks.
Signal Description
To ensure complete hardware reset, RESET and TRST should be
asserted together. The only exception occurs in a debugging
environment when a hardware device reset is required and it is
necessary not to reset the OnCE/JTAG module. In this case,
assert RESET, but do not assert TRST.
2.5 Pulse Width Modulator (PWM) Signals
Table 8. Pulse Width Modulator (PWMA) Signals
8
No. of
Pins
Signal
Name
Signal
Type
State During
Reset
6
PWMA0-5
Output
Tri-stated
1
FAULTA0
Input
(Schmitt)
Input
Signal Description
PWMA0-5— These are six PWMA output pins.
FAULTA0— This fault input pin is used for disabling selected
PWMA outputs in cases where fault conditions originate offchip.
Serial Peripheral Interface (SPI) Signals
2.6 Serial Peripheral Interface (SPI) Signals
Table 9. Serial Peripheral Interface (SPI) Signals
State
During
Reset
No. of
Pins
Signal
Name
Signal
Type
1
MISO
Input/
Output
Input
SPI Master In/Slave Out (MISO)—This serial data pin is an
input to a master device and an output from a slave device.
The MISO line of a slave device is placed in the highimpedance state if the slave device is not selected.
GPIOB6
Input/
Output
Input
Port E GPIO—This pin is a General Purpose I/O (GPIO) pin
that can be individually programmed as input or output pin.
Signal Description
After reset, the default state is MISO.
1
MOSI
Input/
Output
Input
SPI Master Out/Slave In (MOSI)—This serial data pin is an
output from a master device and an input to a slave device.
The master device places data on the MOSI line a half-cycle
before the clock edge that the slave device uses to latch the
data.
GPIOB5
Input/
Output
Input
After reset, the default state is MOSI.
1
SCLK
Input/
Output
Input
SPI Serial Clock—In master mode, this pin serves as an
output, clocking slaved listeners. In slave mode, this pin
serves as the data clock input.
GPIOB4
Input/
Output
Input
that can be individually programmed as an input or output pin.
After reset, the default state is SCLK.
1
SS
Input
Input
SPI Slave Select—In master mode, this pin is used to
arbitrate multiple masters. In slave mode, this pin is used to
select the slave.
GPIOB7
Input/
Output
Input
After reset, the default state is SS.
9
2.7 Serial Communications Interface (SCI) Signals
Table 10. Serial Communications Interface (SCI0) Signals
No. of
Pins
Signal
Name
Signal
Type
State During
Reset
1
TXD0
Output
Input
Transmit Data (TXD0)—SCI0 transmit data output
GPIOB0
Input/
Output
Input
Port B GPIO—This pin is a General Purpose I/O (GPIO) pin
pin.
Signal Description
After reset, the default state is SCI output.
1
RXD0
Input
Input
Receive Data (RXD0)—SCI0 receive data input
GPIOB1
Input/
Output
Input
pin.
After reset, the default state is SCI input.
2.8 Analog-to-Digital Converter (ADC) Signals
Table 11. Analog to Digital Converter Signals
No. of
Pins
Signal
Name
Signal
Type
State During
Reset
4
ANA0-3
Input
Input
ANA0-3—Analog inputs to ADC, channel 1
4
ANA4-7
Input
Input
ANA4-7—Analog inputs to ADC, channel 2
1
VREF
Input
Input
VREF—Analog reference voltage for ADC. Must be set to
VDDA-0.3V for optimal performance.
Signal Description
2.9 Quad Timer Module Signals
Table 12. Quad Timer Module Signals
No. of
Pins
Signal
Name
Signal
Type
State During
Reset
3
TD0-2
Input/
Output
Input
TD0-2—Timer D Channel 0-2
GPIOA0-2
Input/
Output
Input
Port A GPIO—This pin is a General Purpose I/O (GPIO) pin
pin.
Signal Description
After reset, the default state is the quad timer input.
10
JTAG/OnCE
2.10 JTAG/OnCE
Table 13. JTAG/On-Chip Emulation (OnCE) Signals
No. of
Pins
Signal
Name
Signal
Type
1
TCK
Input
(Schmitt)
1
TMS
Input
Input, pulled Test Mode Select Input—This input pin is used to sequence the JTAG
(Schmitt) high internally TAP controller’s state machine. It is sampled on the rising edge of TCK
and has an on-chip pull-up resistor.
1
TDI
Input
Input, pulled Test Data Input—This input pin provides a serial input data stream to
(Schmitt) high internally the JTAG/OnCE port. It is sampled on the rising edge of TCK and has
1
TDO
1
TRST
1
DE
Output
State During
Reset
Signal Description
Input, pulled Test Clock Input—This input pin provides a gated clock to
low internally synchronize the test logic and shift serial data to the JTAG/OnCE port.
The pin is connected internally to a pull-down resistor.
Tri-stated
Test Data Output—This tri-statable output pin provides a serial output
data stream from the JTAG/OnCE port. It is driven in the Shift-IR and
Shift-DR controller states, and changes on the falling edge of TCK.
Input
Input, pulled Test Reset—As an input, a low signal on this pin provides a reset
(Schmitt) high internally signal to the JTAG TAP controller. To ensure complete hardware reset,
TRST should be asserted whenever RESET is asserted. The only
exception occurs in a debugging environment when a hardware device
reset is required and it is necessary not to reset the OnCE/JTAG
module. In this case, assert RESET, but do not assert TRST.
Output
Output
Debug Event—DE provides a low pulse on recognized debug events.
Part 3 Specifications
3.1 General Characteristics
The 56F801 is fabricated in high-density CMOS with 5-volt tolerant TTL-compatible digital inputs. The
term “5-volt tolerant” refers to the capability of an I/O pin, built on a 3.3V compatible process technology,
to withstand a voltage up to 5.5V without damaging the device. Many systems have a mixture of devices
designed for 3.3V and 5V power supplies. In such systems, a bus may carry both 3.3V and 5V- compatible
I/O voltage levels (a standard 3.3V I/O is designed to receive a maximum voltage of 3.3V ± 10% during
normal operation without causing damage). This 5V-tolerant capability therefore offers the power savings
of 3.3V I/O levels while being able to receive 5V levels without being damaged.
Absolute maximum ratings given in Table 14 are stress ratings only, and functional operation at the
maximum is not guaranteed. Stress beyond these ratings may affect device reliability or cause permanent
damage to the device.
The 56F801 DC and AC electrical specifications are preliminary and are from design simulations. These
specifications may not be fully tested or guaranteed at this early stage of the product life cycle. Finalized
specifications will be published after complete characterization and device qualifications have been
completed.
11
CAUTION
This device contains protective circuitry to guard against
damage due to high static voltage or electrical fields.
However, normal precautions are advised to avoid
application of any voltages higher than maximum rated
voltages to this high-impedance circuit. Reliability of
operation is enhanced if unused inputs are tied to an
appropriate voltage level.
Table 14. Absolute Maximum Ratings
Characteristic
Symbol
Min
Max
Unit
Supply voltage
VDD
VSS – 0.3
VSS + 4.0
V
All other input voltages, excluding Analog inputs
VIN
VSS – 0.3
VSS + 5.5V
V
Analog inputs ANA0-7 and VREF
VIN
VSSA– 0.3
VDDA+ 0.3
V
Analog inputs EXTAL, XTAL
VIN
VSSA– 0.3
VSSA+ 3.0
V
I
10
mA
Current drain per pin excluding VDD, VSS, & PWM ouputs
Table 15. Recommended Operating Conditions
Characteristic
Symbol
Min
Typ
Max
Unit
Supply voltage, digital
VDD
3.0
3.3
3.6
V
Supply Voltage, analog
VDDA
3.0
3.3
3.6
V
ADC reference voltage
VREF
2.7
VDDA
V
TA
–40
85
°C
Ambient operating temperature
12
Table 16. Thermal Characteristics6
Value
Characteristic
Comments
Symbol
Unit
Notes
48-pin LQFP
Junction to ambient
Natural convection
Junction to ambient (@1m/sec)
RθJA
50.6
°C/W
2
RθJMA
47.4
°C/W
2
Junction to ambient
Natural convection
Four layer board (2s2p)
RθJMA
(2s2p)
39.1
°C/W
1,2
RθJMA
37.9
°C/W
1,2
Junction to case
RθJC
17.3
°C/W
3
Junction to center of case
ΨJT
1.2
°C/W
4, 5
I/O pin power dissipation
P I/O
User Determined
W
Power dissipation
PD
P D = (IDD x VDD + P I/O)
W
PDMAX
(TJ - TA) /θJA
°C
Notes:
1.
Theta-JA determined on 2s2p test boards is frequently lower than would be observed in an application.
Determined on 2s2p thermal test board.
2.
Junction to ambient thermal resistance, Theta-JA (RθJA) was simulated to be equivalent to the
JEDEC specification JESD51-2 in a horizontal configuration in natural convection. Theta-JA was
also simulated on a thermal test board with two internal planes (2s2p where s is the number of signal
layers and p is the number of planes) per JESD51-6 and JESD51-7. The correct name for Theta-JA
for forced convection or with the non-single layer boards is Theta-JMA.
3.
Junction to case thermal resistance, Theta-JC (RθJC ), was simulated to be equivalent to the measured
values using the cold plate technique with the cold plate temperature used as the "case" temperature.
The basic cold plate measurement technique is described by MIL-STD 883D, Method 1012.1. This
is the correct thermal metric to use to calculate thermal performance when the package is being used
with a heat sink.
4.
Thermal Characterization Parameter, Psi-JT (ΨJT ), is the "resistance" from junction to reference
point thermocouple on top center of case as defined in JESD51-2. ΨJT is a useful value to use to
estimate junction temperature in steady state customer environments.
5.
Junction temperature is a function of on-chip power dissipation, package thermal resistance,
mounting site (board) temperature, ambient temperature, air flow, power dissipation of other
components on the board, and board thermal resistance.
6.
See Section 5.1 from more details on thermal design considerations.
13
3.2 DC Electrical Characteristics
Table 17. DC Electrical Characteristics
Operating Conditions: VSS = VSSA = 0 V, VDD = VDDA = 3.0–3.6V, TA = –40° to +85°C, CL ≤ 50pF
Characteristic
Symbol
Min
Typ
Max
Unit
Input high voltage (XTAL/EXTAL)
VIHC
2.25
2.75
V
Input low voltage (XTAL/EXTAL)
VILC
V
Input high voltage [GPIOB(2:3)]1
VIH[GPIOB(2:3)]
2.0
3.6
V
Input low voltage [GPIOB(2:3)]1
VIL[GPIOB(2:3)]
-0.3
0.8
V
Input high voltage (Schmitt trigger inputs)2
VIHS
2.2
5.5
V
Input low voltage (Schmitt trigger inputs)2
VILS
-0.3
0.8
V
Input high voltage (all other digital inputs)
VIH
2.0
5.5
V
Input low voltage (all other digital inputs)
VIL
-0.3
0.8
V
Input current high (pullup/pulldown resistors disabled, VIN=VDD)
IIH
-1
1
µA
Input current low (pullup/pulldown resistors disabled, VIN=VSS)
IIL
-1
1
µA
Input current high (with pullup resistor, VIN=VDD)
IIHPU
-1
1
µA
Input current low (with pullup resistor, VIN=VSS)
IILPU
-210
-50
µA
Input current high (with pulldown resistor, VIN=VDD)
IIHPD
µA
Input current low (with pulldown resistor, VIN=VSS)
IILPD
-1
1
µA
Nominal pullup or pulldown resistor value
RPU, RPD
30
KΩ
Output tri-state current low
IOZL
-10
10
µA
Output tri-state current high
IOZH
-10
10
µA
Input current high (analog inputs, VIN=VDDA)3
IIHA
-15
15
µA
Input current low (analog inputs, VIN=VSSA)3
IILA
-15
15
µA
Output High Voltage (at IOH)
VOH
VDD – 0.7
V
Output Low Voltage (at IOL)
VOL
0.4
V
Output source current
IOH
4
mA
Output sink current
IOL
4
mA
IOHP
10
mA
PWM pin output source current4
14
Table 17. DC Electrical Characteristics (Continued)
Characteristic
Symbol
Min
Typ
Max
Unit
PWM pin output sink current5
IOLP
16
mA
Input capacitance
CIN
8
pF
Output capacitance
COUT
12
pF
VDD supply current
IDDT6
Run7 (80MHz operation)
120
130
mA
Run7 (60MHz operation)
102
111
mA
Wait8
96
102
mA
Stop
62
70
mA
Low Voltage Interrupt, external power supply9
VEIO
2.4
2.7
3.0
V
Low Voltage Interrupt, internal power supply10
VEIC
2.0
2.2
2.4
V
Power on Reset11
VPOR
1.7
2.0
V
1. Since the GPIOB[2:3] signals are shared with the XTAL/EXTAL function, these inputs are not 5.5 volt tolerant.
2. Schmitt Trigger inputs are: FAULTA0, IRQA, RESET, TCS, TCK, TMS, TDI, and TRST.
3. Analog inputs are: ANA[0:7], XTAL and EXTAL. Specification assumes ADC is not sampling.
4. PWM pin output source current measured with 50% duty cycle.
5. PWM pin output sink current measured with 50% duty cycle.
6. IDDT = IDD + IDDA (Total supply current for VDD + VDDA)
7. Run (operating) IDD measured using 8MHz clock source. All inputs 0.2V from rail; outputs unloaded. All ports
configured as inputs; measured with all modules enabled.
8. Wait IDD measured using external square wave clock source (fosc = 8MHz) into XTAL; all inputs 0.2V from rail; no DC
loads; less than 50pF on all outputs. CL = 20pF on EXTAL; all ports configured as inputs; EXTAL capacitance linearly affects
wait IDD; measured with PLL enabled.
9. This low voltage interrupt monitors the VDDA external power supply. VDDA is generally connected to the same potential
as VDD via separate traces. If VDDA drops below VEIO, an interrupt is generated. Functionality of the device is guaranteed
under transient conditions when VDDA>VEIO (between the minimum specified VDD and the point when the VEIO interrupt is
generated).
10. This low voltage interrupt monitors the internally regulated core power supply. If the output from the internal voltage is
regulator drops below VEIC, an interrupt is generated. Since the core logic supply is internally regulated, this interrupt will not
be generated unless the external power supply drops below the minimum specified value (3.0V).
11. Power–on reset occurs whenever the internally regulated 2.5V digital supply drops below 1.5V typical. While power is
ramping up, this signal remains active for as long as the internal 2.5V is below 1.5V typical no matter how long the ramp up
rate is. The internally regulated voltage is typically 100 mV less than VDD during ramp up until 2.5V is reached, at which time
it self regulates.
15
160
IDD Digital
IDD Analog
IDD Total
IDD (mA)
120
80
40
40
60
50
70
80
Freq. (MHz)
Figure 3. Maximum Run IDD vs. Frequency (see Note 7. in Table 17)
3.3 AC Electrical Characteristics
Timing waveforms in Section 3.3 are tested using the VIL and VIH levels specified in the DC Characteristics
table. In Figure 4 the levels of VIH and VIL for an input signal are shown.
VIH
Input Signal
Low
High
90%
50%
10%
Midpoint1
Fall Time
VIL
Rise Time
Note: The midpoint is VIL + (VIH – VIL)/2.
Figure 4. Input Signal Measurement References
Figure 5 shows the definitions of the following signal states:
16
Active state, when a bus or signal is driven, and enters a low impedance state.
Tri-stated, when a bus or signal is placed in a high impedance state.
Data Valid state, when a signal level has reached VOL or VOH.
Data Invalid state, when a signal level is in transition between VOL and VOH.
Flash Memory Characteristics
Data2 Valid
Data1 Valid
Data1
Data3 Valid
Data2
Data3
Data
Tri-stated
Data Invalid State
Data Active
Data Active
Figure 5. Signal States
3.4 Flash Memory Characteristics
Table 18. Flash Memory Truth Table
Mode
XE1
YE2
SE3
OE4
PROG5
ERASE6
MAS17
NVSTR8
Standby
L
L
L
L
L
L
L
L
Read
H
H
H
H
L
L
L
L
Word Program
H
H
L
L
H
L
L
H
Page Erase
H
L
L
L
L
H
L
H
Mass Erase
H
L
L
L
L
H
H
H
1.
2.
3.
4.
5.
6.
7.
8.
X address enable, all rows are disabled when XE = 0
Y address enable, YMUX is disabled when YE = 0
Sense amplifier enable
Output enable, tri-state Flash data out bus when OE = 0
Defines program cycle
Defines erase cycle
Defines mass erase cycle, erase whole block
Defines non-volatile store cycle
Table 19. IFREN Truth Table
Mode
IFREN = 1
IFREN = 0
Read
Read information block
Read main memory block
Word program
Program information block
Program main memory block
Page erase
Erase information block
Erase main memory block
Mass erase
Erase both block
17
Table 20. Flash Timing Parameters
Characteristic
Symbol
Min
Typ
Max
Unit
Figure
Program time
Tprog*
us
Figure 6
Erase time
Terase*
ms
Figure 7
Mass erase time
Tme*
100
ms
Figure 8
Endurance1
ECYC
10,000
20,000
cycles
Data Retention1 @ 5000 cycles
DRET
10
30
years
The following parameters should only be used in the Manual Word Programming Mode
PROG/ERASE to NVSTR set
up time
Tnvs*
5
us
Figure 6,
Figure 7, Figure 8
NVSTR hold time
Tnvh*
5
us
Figure 6, Figure 7
NVSTR hold time (mass erase)
Tnvh1*
100
us
Figure 8
NVSTR to program set up time
Tpgs*
10
us
Figure 6
Recovery time
Trcv*
1
us
Figure 6,
Figure 7, Figure 8
Cumulative program
HV period2
Thv
3
ms
Figure 6
Program hold time3
Tpgh
Figure 6
Address/data set up time3
Tads
Figure 6
Address/data hold time3
Tadh
Figure 6
1. One cycle is equal to an erase program and read.
2. Thv is the cumulative high voltage programming time to the same row before next erase. The same address cannot
be programmed twice before next erase.
3. Parameters are guaranteed by design in smart programming mode and must be one cycle or greater.
*The Flash interface unit provides registers for the control of these parameters.
18
IFREN
XADR
XE
Tadh
YADR
YE
DIN
Tads
PROG
Tnvs
Tprog
Tpgh
NVSTR
Tpgs
Tnvh
Trcv
Thv
Figure 6. Flash Program Cycle
IFREN
XADR
XE
YE=SE=OE=MAS1=0
ERASE
Tnvs
NVSTR
Tnvh
Terase
Trcv
Figure 7. Flash Erase Cycle
19
IFREN
XADR
XE
MAS1
YE=SE=OE=0
ERASE
Tnvs
NVSTR
Tnvh1
Tme
Trcv
Figure 8. Flash Mass Erase Cycle
3.5 External Clock Operation
The 56F801 device clock is derived from either 1) an internal crystal oscillator circuit working in
conjunction with an external crystal, 2) an external frequency source, or 3) an on-chip relaxation oscillator.
To generate a reference frequency using the internal crystal oscillator circuit, a reference crystal external to
the chip must be connected between the EXTAL and XTAL pins. Paragrahs 3.5.1 and 3.5.4 describe these
methods of clocking. Whichever type of clock derivation is used provides a reference signal to a phaselocked loop (PLL) within the 56F801. In turn, the PLL generates a master reference frequency that
determines the speed at which chip operations occur.
Application code can be set to change the frequency source between the relaxation oscillator and crystal
oscillator or external source, and power down the relaxation oscillator if desired. Selection of which clock
is used is determined by setting the PRECS bit in the PLLCR (phase-locked loop control register) word (bit
2). If the bit is set to 1, the external crystal oscillator circuit is selected. If the bit is set to 0, the internal
relaxation oscillator is selected, and this is the default value of the bit when power is first applied.
3.5.1
Crystal Oscillator
The internal oscillator is also designed to interface with a parallel-resonant crystal resonator in the frequency
range specified for the external crystal in Table 23. Figure 9 shows a recommended crystal oscillator
circuit. Follow the crystal supplier’s recommendations when selecting a crystal, since crystal parameters
determine the component values required to provide maximum stability and reliable start-up. The crystal
and associated components should be mounted as close as possible to the EXTAL and XTAL pins to
minimize output distortion and start-up stabilization time. The internal 56F80x oscillator circuitry is
designed to have no external load capacitors present. As shown in Figure 10 no external load capacitors
should be used.
The 56F80x components internally are modeled as a parallel resonant oscillator circuit to provide a
capacitive load on each of the oscillator pins (XTAL and EXTAL) of 10pF to 13pF over temperature and
process variations. Using a typical value of internal capacitance on these pins of 12pF and a value of 3pF as
a typical circuit board trace capacitance the parallel load capacitance presented to the crystal is 9pF as
determined by the following equation:
CL1 * CL2
CL =
CL1 + CL2
12 * 12
+ Cs =
+ 3 = 6 + 3 = 9pF
12 + 12
This is the value load capacitance that should be used when selecting a crystal and determining the actual
frequency of operation of the crystal oscillator circuit.
EXTAL XTAL
Rz
Recommended External Crystal
Parameters:
Rz = 1 to 3 MΩ
fc = 8MHz (optimized for 8MHz)
fc
Figure 9. External Crystal Oscillator Circuit
3.5.2
Ceramic Resonator
It is also possible to drive the internal oscillator with a ceramic resonator, assuming the overall system
design can tolerate the reduced signal integrity. In Figure 10, a typical ceramic resonator circuit is shown.
Refer to supplier’s recommendations when selecting a ceramic resonator and associated components. The
resonator and components should be mounted as close as possible to the EXTAL and XTAL pins. The
internal 56F80x oscillator circuitry is designed to have no external load capacitors present. As shown in
Figure 9 no external load capacitors should be used.
EXTAL XTAL
Rz
Recommended Ceramic Resonator
Parameters:
Rz = 1 to 3 MΩ
fc
Figure 10. Connecting a Ceramic Resonator
Note: Motorola recommends only two terminal ceramic resonators vs. three terminal
resonators (which contain an internal bypass capacitor to ground).
3.5.3
External Clock Source
The recommended method of connecting an external clock is given in Figure 11. The external clock
source is connected to XTAL and the EXTAL pin is grounded.
21
56F801
XTAL
EXTAL
External Clock
VSS
Figure 11. Connecting an External Clock Signal
Table 21. External Clock Operation Timing Requirements3
Operating Conditions: VSS = VSSA = 0 V, VDD = VDDA = 3.0–3.6 V, TA = –40° to +85°C
Characteristic
Symbol
Min
Typ
Max
Unit
Frequency of operation (external clock driver)1
fosc
MHz
Clock Pulse Width3, 4
tPW
6.25
ns
1.
2.
3.
4.
See Figure 11 for details on using the recommended connection of an external clock driver.
May not exceed 60MHz for the DSP56F801FA60 device.
The high or low pulse width must be no smaller than 6.25ns or the chip will not function.
Parameters listed are guaranteed by design.
VIH
External
Clock
90%
50%
10%
90%
50%
10%
tPW
tPW
VIL
Figure 12. External Clock Timing
3.5.4
Use of On-Chip Relaxation Oscillator
An internal relaxation oscillator can supply the reference frequency when an external frequency source or
crystal are not used. During a 56F801 boot or reset sequence, the relaxation oscillator is enabled by default,
and the PRECS bit in the PLLCR word is set to 0 (Section 3.5). If an external oscillator is connected, the
relaxation oscillator can be deselected instead by setting the PRECS bit in the PLLCR to 1. When this
occurs, the PRECSS bit in the PLLSR (prescaler clock select status register) data word also sets to 1. If a
changeover between internal and external oscillators is required at startup, internal device circuits
compensate for any asynchronous transitions between the two clock signals so that no glitches occur in the
resulting master clock to the chip. When changing clocks, the user must ensure that the clock source is not
switched until the desired clock is enabled and stable.
To compensate for variances in the device manufacturing process, the accuracy of the relaxation oscillator
can be incrementally adjusted to within ±0.25% of 8MHz by trimming an internal capacitor. Bits 0-7 of the
IOSCTL (internal oscillator control) word allow the user to set in an additional offset (trim) to this preset
value to increase or decrease capacitance. The default value of this trim is 128 units, making the power-up
default capacitor size 432 units. Each unit added or deleted changes the output frequency by about 0.2%,
allowing incremental adjustment until the desired frequency accuracy is achieved.
22
Table 22. Relaxation Oscillator Characteristics
Characteristic
Symbol
Min
Typ
Max
Unit
∆f
+2
+5
Frequency Drift over Temp
∆f/∆t
+0.1
%/oC
Frequency Drift over Supply
∆f/∆V
0.1
%/V
∆fT
+0.25
Frequency Accuracy1
Trim Accuracy
1.
Over full temperature range.
8.2
Output Frequency
8.1
8.0
7.9
7.8
7.7
7.6
-40
-25
-5
15
35
55
75
85
Temperature (oC)
Figure 13. Typical Relaxation Oscillator Frequency vs. Temperature
(Trimmed to 8MHz @ 25oC)
23
11
10
9
8
7
6
5
10 20 30 40 50 60 70 80 90 A0 B0 C0 D0 E0 F0
Figure 14. Typical Relaxation Oscillator Frequency vs. Trim Value @ 25oC
3.5.5
Phase Locked Loop Timing
Table 23. PLL Timing
Characteristic
Symbol
Min
Typ
Max
Unit
fosc
4
8
10
MHz
fout/2
40
803
MHz
PLL stabilization time4 0o to +85oC
tplls
10
ms
PLL stabilization time4 -40o to 0oC
tplls
100
200
ms
External reference crystal frequency for the PLL1
PLL output frequency2
1. An externally supplied reference clock should be as free as possible from any phase jitter for the PLL to work
correctly. The PLL is optimized for 8MHz input crystal.
2. ZCLK may not exceed 80MHz. For additional information on ZCLK and fout/2, please refer to the OCCS chapter
in the User Manual. ZCLK = fop
3. Will not exceed 60MHz for the DSP56F801FA60 device.
4. This is the minimum time required after the PLL setup is changed to ensure reliable operation.
24
Reset, Stop, Wait, Mode Select, and Interrupt Timing
3.6 Reset, Stop, Wait, Mode Select, and Interrupt Timing
Table 24. Reset, Stop, Wait, Mode Select, and Interrupt Timing1, 5
Operating Conditions: VSS = VSSA = 0 V, VDD = VDDA = 3.0–3.6 V, TA = –40° to +85°C, CL ≤ 50pF
Characteristic
Symbol
Min
Max
Unit
See
RESET Assertion to Address, Data and Control
Signals High Impedance
tRAZ
21
ns
Figure 15
Minimum RESET Assertion Duration2
OMR Bit 6 = 0
OMR Bit 6 = 1
tRA
275,000T
128T
ns
ns
RESET De-assertion to First External Address
Output
tRDA
33T
34T
ns
Figure 15
Edge-sensitive Interrupt Request Width
tIRW
1.5T
ns
Figure 16
IRQA, IRQB Assertion to External Data Memory
Access Out Valid, caused by first instruction
execution in the interrupt service routine
tIDM
15T
ns
Figure 17
IRQA, IRQB Assertion to General Purpose Output
Valid, caused by first instruction execution in the
tIG
16T
ns
Figure 17
IRQA Low to First Valid Interrupt Vector Address
Out recovery from Wait State3
tIRI
13T
ns
Figure 18
IRQA Width Assertion to Recover from Stop State4
tIW
2T
ns
Figure 19
Delay from IRQA Assertion to Fetch of first
instruction (exiting Stop)
OMR Bit 6 = 0
OMR Bit 6 = 1
tIF
Figure 15
Figure 19
Duration for Level Sensitive IRQA Assertion to
Cause the Fetch of First IRQA Interrupt Instruction
(exiting Stop)
OMR Bit 6 = 0
OMR Bit 6 = 1
tIRQ
Delay from Level Sensitive IRQA Assertion to First
Interrupt Vector Address Out Valid (exiting Stop)
OMR Bit 6 = 0
OMR Bit 6 = 1
tII
275,000T
12T
ns
ns
Figure 20
275,000T
12T
ns
ns
Figure 20
275,000T
12T
ns
ns
1.
2.
In the formulas, T = clock cycle. For an operating frequency of 80MHz, T = 12.5ns.
Circuit stabilization delay is required during reset when using an external clock or crystal oscillator in two cases:
• After power-on reset
• When recovering from Stop state
3. The minimum is specified for the duration of an edge-sensitive IRQA interrupt required to recover from the Stop state.
This is not the minimum required so that the IRQA interrupt is accepted.
4. The interrupt instruction fetch is visible on the pins only in Mode 3.
5. Parameters listed are guaranteed by design.
25
RESET
tRA
tRAZ
tRDA
A0–A15,
D0–D15
First Fetch
PS, DS,
RD, WR
First Fetch
Figure 15. Asynchronous Reset Timing
IRQA,
IRQB
tIRW
Figure 16. External Interrupt Timing (Negative-Edge-Sensitive)
A0–A15,
PS, DS,
RD, WR
First Interrupt Instruction Execution
tIDM
IRQA,
IRQB
a) First Interrupt Instruction Execution
General
Purpose
I/O Pin
tIG
IRQA,
IRQB
b) General Purpose I/O
Figure 17. External Level-Sensitive Interrupt Timing
26
IRQA,
IRQB
tIRI
A0–A15,
PS, DS,
RD, WR
First Interrupt Vector
Instruction Fetch
Figure 18. Interrupt from Wait State Timing
tIW
IRQA
tIF
A0–A15,
PS, DS,
RD, WR
First Instruction Fetch
Not IRQA Interrupt Vector
Figure 19. Recovery from Stop State Using Asynchronous Interrupt Timing
tIRQ
IRQA
tII
A0–A15
PS, DS,
RD, WR
Instruction Fetch
Figure 20. Recovery from Stop State Using IRQA Interrupt Service
27
3.7 Serial Peripheral Interface (SPI) Timing
Table 25. SPI Timing1
Characteristic
Cycle time
Master
Slave
Symbol
tELD
Enable lag time
Master
Slave
tELG
Clock (SCK) high time
Master
Slave
tCH
Clock (SCK) low time
Master
Slave
tCL
Data setup time required for inputs
Master
Slave
tDS
Data hold time required for inputs
Master
Slave
tDH
Access time (time to data active from highimpedance state)
Slave
tA
Disable time (hold time to high-impedance state)
Slave
tD
Data Valid for outputs
Master
Slave (after enable edge)
tDV
Data invalid
Master
Slave
tDI
Rise time
Master
Slave
tR
Fall time
Master
Slave
tF
28
Max
Unit
50
25
ns
ns
25
ns
ns
100
ns
ns
17.6
12.5
ns
ns
24.1
25
ns
ns
ns
ns
ns
ns
4.8
15
ns
3.7
15.2
ns
4.5
20.4
ns
ns
ns
ns
11.5
10.0
ns
ns
9.7
9.0
ns
ns
tC
Enable lead time
Master
Slave
1.
Min
See Figure
Figures 21, 22,
23, 24
Figure 24
Figure 24
Figures 21, 22,
23, 24
Figures 21, 22,
23, 24
Figures 21, 22,
23, 24
Figures 21, 22,
23, 24
Figure 24
Figure 24
Figures 21, 22,
23, 24
Figures 21, 22,
23, 24
Figures 21, 22,
23, 24
Figures 21, 22,
23, 24
SS
SS is held High on master
(Input)
tC
tR
tF
tCL
SCLK (CPOL = 0)
(Output)
tF
tCH
tR
tCL
SCLK (CPOL = 1)
(Output)
tDH
tCH
tDS
MISO
(Input)
MSB in
Bits 14–1
tDI
MOSI
(Output)
LSB in
tDI(ref)
tDV
Master MSB out
Bits 14–1
Master LSB out
tF
tR
Figure 21. SPI Master Timing (CPHA = 0)
SS
(Input)
tF
tC
tR
tCL
SCLK (CPOL = 0)
(Output)
tCH
tF
tCL
SCLK (CPOL = 1)
(Output)
tCH
MISO
(Input)
MSB in
tDI
tDV(ref)
MOSI
(Output)
Master MSB out
tDS
tR
tDH
Bits 14–1
LSB in
tDV
Bits 14– 1
tF
Master LSB out
tR
Figure 22. SPI Master Timing (CPHA = 1)
29
SS
(Input)
tC
tF
tCL
SCLK (CPOL = 0)
(Input)
tELG
tR
tCH
tELD
tCL
SCLK (CPOL = 1)
(Input)
tCH
tA
MISO
(Output)
Slave MSB out
tDS
tR
tF
tD
Bits 14–1
Slave LSB out
tDV
tDI
tDI
tDH
MOSI
(Input)
MSB in
Bits 14–1
LSB in
Figure 23. SPI Slave Timing (CPHA = 0)
SS
(Input)
tC
tF
tCL
SCLK (CPOL = 0)
(Input)
tCH
tELG
tELD
SCLK (CPOL = 1)
(Input)
tR
tDV
tCL
tR
tCH
MISO
(Output)
Slave MSB out
Bits 14–1
tDV
tDS
tDH
MOSI
(Input)
MSB in
tD
tF
tA
Bits 14–1
Slave LSB out
tDI
LSB in
Figure 24. SPI Slave Timing (CPHA = 1)
30
Quad Timer Timing
3.8 Quad Timer Timing
Table 26. Timer Timing1, 2
Characteristic
Symbol
Min
Max
Unit
PIN
4T+6
ns
Timer input high/low period
PINHL
2T+3
ns
Timer output period
POUT
2T
ns
POUTHL
1T
ns
Timer input period
Timer output high/low period
1.
2.
In the formulas listed, T = clock cycle. For 80MHz operation, T = 12.5ns.
Timer Inputs
PIN
PINHL
PINHL
POUTHL
POUTHL
Timer Outputs
POUT
Figure 25. Timer Timing
3.9 Serial Communication Interface (SCI) Timing
Table 27. SCI Timing4
Characteristic
Symbol
Min
Max
Unit
BR
(fMAX*2.5)/(80)
Mbps
RXD2 Pulse Width
RXDPW
0.965/BR
1.04/BR
ns
TXD3 Pulse Width
TXDPW
0.965/BR
1.04/BR
ns
Baud Rate1
1.
2.
3.
4.
fMAX is the frequency of operation of the system clock in MHz.
The RXD pin in SCI0 is named RXD0 and the RXD pin in SCI1 is named RXD1.
The TXD pin in SCI0 is named TXD0 and the TXD pin in SCI1 is named TXD1.
31
RXD
SCI receive
data pin
(Input)
RXDPW
Figure 26. RXD Pulse Width
TXD
SCI receive
data pin
(Input)
TXDPW
Figure 27. TXD Pulse Width
3.10 Analog-to-Digital Converter (ADC) Characteristics
Table 28. ADC Characteristics
Operating Conditions: VSS = VSSA = 0 V, VDD = VDDA = 3.0–3.6 V, VREF = VDD-0.3V, ADCDIV = 4, 9, or 14 (for optimal
performance), ADC clock = 4MHz, 3.0–3.6 V, TA = –40° to +85°C, CL ≤ 50pF
Characteristic
Symbol
Min
Typ
Max
Unit
VADCIN
01
VREF2
V
Resolution
RES
12
12
Bits
Integral Non-Linearity3
INL
+/- 4
+/- 5
LSB4
Differential Non-Linearity
DNL
+/- 0.9
+/- 1
LSB4
ADC input voltages
Monotonicity
GUARANTEED
ADC internal clock5
fADIC
0.5
5
MHz
Conversion range
RAD
VSSA
VDDA
V
Conversion time
tADC
6
tAIC cycles6
Sample time
tADS
1
tAIC cycles6
Input capacitance
CADI
5
pF6
Gain Error (transfer gain)5
EGAIN
1.00
1.10
1.15
VOFFSET
+10
+230
+325
mV
THD
55
60
dB
Signal-to-Noise plus Distortion5
SINAD
54
56
dB
Effective Number of Bits5
ENOB
8.5
9.5
bit
Offset Voltage5
Total Harmonic Distortion5
32
Table 28. ADC Characteristics (Continued)
Characteristic
Symbol
Min
Typ
Max
Unit
SFDR
60
65
dB
Bandwidth
BW
100
KHz
ADC Quiescent Current (both ADCs)
IADC
50
mA
VREF Quiescent Current (both ADCs)
IVREF
12
16.5
mA
Spurious Free Dynamic Range5
1. For optimum ADC performance, keep the minimum VADCIN value > 250mV. Inputs less than 250mV volts may
convert to a digital output code of 0 or cause erroneous conversions.
2. VREF must be equal to or less than VDDA and must be greater than 2.7V. For optimal ADC performance, set VREF
to VDDA-0.3V.
3.
Measured in 10-90% range.
4.
5.
6.
LSB = Least Significant Bit.
Guaranteed by characterization.
tAIC = 1/fADIC
ADC analog input
1
3
2
4
Figure 28. Equivalent Analog Input Circuit
1.
2.
3.
Parasitic capacitance due to package, pin to pin, and pin to package base coupling. (1.8pf)
Parasitic capacitance due to the chip bond pad, ESD protection devices and signal routing. (2.04pf)
Equivalent resistance for the ESD isolation resistor and the channel select mux. (500 ohms)
4. Sampling capacitor at the sample and hold circuit. Capacitor 4 is normally disconnected from the input
and is only connected to it at sampling time. (1pf)
33
3.11 JTAG Timing
Table 29. JTAG Timing 1, 3
Characteristic
Symbol
Min
Max
Unit
TCK frequency of operation2
fOP
DC
10
MHz
TCK cycle time
tCY
100
ns
TCK clock pulse width
tPW
50
ns
TMS, TDI data setup time
tDS
0.4
ns
TMS, TDI data hold time
tDH
1.2
ns
TCK low to TDO data valid
tDV
26.6
ns
TCK low to TDO tri-state
tTS
23.5
ns
tTRST
50
ns
tDE
8T
ns
TRST assertion time
DE assertion time
1. Timing is both wait state and frequency dependent. For the values listed, T = clock cycle. For 80MHz
2. TCK frequency of operation must be less than 1/8 the processor rate.
3. Parameters listed are guaranteed by design.
tCY
tPW
tPW
VIH
VM
TCK
(Input)
VM = VIL + (VIH – VIL)/2
VM
VIL
Figure 29. Test Clock Input Timing Diagram
34
JTAG Timing
TCK
(Input)
tDS
TDI
TMS
(Input)
tDH
Input Data Valid
tDV
TDO
(Output)
Output Data Valid
tTS
TDO
(Output)
tDV
TDO
(Output)
Output Data Valid
Figure 30. Test Access Port Timing Diagram
TRST
(Input)
tTRST
Figure 31. TRST Timing Diagram
DE
tDE
Figure 32. OnCE—Debug Event
35
Part 4 Packaging
4.1 Package and Pin-Out Information 56F801
ANA5
ANA6
ANA7
ORIENTATION
MARK
TDO
ANA4
PIN 37
TD1
TD2
PWMA0
VCAPC1
VDD
VSS
PWMA1
PWMA2
PWMA3
PWMA4
PWMA5
This section contains package and pin-out information for the 48-pin LQFP configuration of the 56F801.
ANA3
VREF
PIN 1
/SS
ANA2
Motorola
MISO
ANA1
MOSI
ANA0
SCLK
FAULTA0
56F801
TXDO
VSS
VDD
VSS
VDD
VSSA
PIN 25
RXD0
VDDA
PIN 13
DE
TRST
TDO
XTAL
EXTAL
VDD
VSS
VCAPC2
TDI
IREQA
TMS
TCK
TCS
RESET
Figure 33. Top View, 56F801 48-pin LQFP Package
36
Table 30. 56F801 Pin Identification by Pin Number
Pin No.
Signal Name
Pin No.
Signal Name
Pin No.
Signal Name
Pin No.
Signal Name
1
TD0
13
TCS
25
RESET
37
ANA5
2
TD1
14
TCK
26
VDDA
38
ANA6
3
TD2
15
TMS
27
VSSA
39
ANA7
4
SS
16
IREQA
28
VDD
40
PWMA0
5
MISO
17
TDI
29
VSS
41
VCAPC1
6
MOSI
18
VCAPC2
30
FAULTA0
42
VDD
7
SCLK
19
VSS
31
ANA0
43
VSS
8
TXD0
VDD
32
ANA1
44
PWMA1
9
VSS
21
EXTAL
33
ANA2
45
PWMA2
10
VDD
22
XTAL
34
VREF
46
PWMA3
11
RXD0
23
TDO
35
ANA3
47
PWMA4
12
DE
24
TRST
36
ANA4
48
PWMA5
37
0.200 AB T-U Z
9
DETAIL Y
A
P
A1
48
37
1
36
T
U
B
V
AE
B1
12
25
13
AE
V1
24
NOTES:
1. DIMENSIONING AND TOLERANCING PER
ASME Y14.5M, 1994.
2. CONTROLLING DIMENSION: MILLIMETER.
3. DATUM PLANE AB IS LOCATED AT BOTTOM
OF LEAD AND IS COINCIDENT WITH THE
LEAD WHERE THE LEAD EXITS THE PLASTIC
BODY AT THE BOTTOM OF THE PARTING
LINE.
4. DATUMS T, U, AND Z TO BE DETERMINED AT
DATUM PLANE AB.
5. DIMENSIONS S AND V TO BE DETERMINED
AT SEATING PLANE AC.
6. DIMENSIONS A AND B DO NOT INCLUDE
MOLD PROTRUSION. ALLOWABLE
PROTRUSION IS 0.250 PER SIDE. DIMENSIONS
A AND B DO INCLUDE MOLD MISMATCH AND
ARE DETERMINED AT DATUM PLANE AB.
7. DIMENSION D DOES NOT INCLUDE DAMBAR
PROTRUSION. DAMBAR PROTRUSION
SHALL NOT CAUSE THE D DIMENSION TO
EXCEED 0.350.
8. MINIMUM SOLDER PLATE THICKNESS
SHALL BE 0.0076.
9. EXACT SHAPE OF EACH CORNER IS
OPTIONAL.
Z
S1
DIM
A
A1
B
B1
C
D
E
F
G
H
J
K
L
M
N
P
R
S
S1
V
V1
W
AA
T, U, Z
S
DETAIL Y
4X
0.200 AC T-U Z
0.080 AC
G
AB
AD
AC
M°
BASE METAL
TOP & BOTTOM
R
J
0.250
N
MILLIMETERS
MIN MAX
7.000 BSC
3.500 BSC
7.000 BSC
3.500 BSC
1.400 1.600
0.170 0.270
1.350 1.450
0.170 0.230
0.500 BSC
0.050 0.150
0.090 0.200
0.500 0.700
0 °
7°
12 ° REF
0.090 0.160
0.250 BSC
0.150 0.250
9.000 BSC
4.500 BSC
9.000 BSC
4.500 BSC
0.200 REF
1.000 REF
C
E
GAUGE PLANE
4X
F
D
0.080
M
AC T-U Z
SECTION AE-AE
H
CASE 932-03
ISSUE F
W
L°
K
DETAIL AD
AA
Figure 34. 48-pin LQFP Mechanical Information
38
Thermal Design Considerations
Part 5 Design Considerations
5.1 Thermal Design Considerations
An estimation of the chip junction temperature, TJ, in °C can be obtained from the equation:
Equation 1:
TJ = T A + ( P D × R θJA )
Where:
TA = ambient temperature °C
RθJA = package junction-to-ambient thermal resistance °C/W
PD = power dissipation in package
Historically, thermal resistance has been expressed as the sum of a junction-to-case thermal resistance and
a case-to-ambient thermal resistance:
Equation 2:
RθJA = RθJC + R θCA
Where:
RθJC = package junction-to-case thermal resistance °C/W
RθCA = package case-to-ambient thermal resistance °C/W
RθJC is device-related and cannot be influenced by the user. The user controls the thermal environment to
change the case-to-ambient thermal resistance, RθCA. For example, the user can change the air flow around
the device, add a heat sink, change the mounting arrangement on the Printed Circuit Board (PCB), or
otherwise change the thermal dissipation capability of the area surrounding the device on the PCB. This
model is most useful for ceramic packages with heat sinks; some 90% of the heat flow is dissipated through
the case to the heat sink and out to the ambient environment. For ceramic packages, in situations where the
heat flow is split between a path to the case and an alternate path through the PCB, analysis of the device
thermal performance may need the additional modeling capability of a system level thermal simulation tool.
The thermal performance of plastic packages is more dependent on the temperature of the PCB to which the
package is mounted. Again, if the estimations obtained from RθJA do not satisfactorily answer whether the
thermal performance is adequate, a system level model may be appropriate.
Definitions:
A complicating factor is the existence of three common definitions for determining the junction-to-case
thermal resistance in plastic packages:
Measure the thermal resistance from the junction to the outside surface of the package (case) closest
to the chip mounting area when that surface has a proper heat sink. This is done to minimize
temperature variation across the surface.
Measure the thermal resistance from the junction to where the leads are attached to the case. This
definition is approximately equal to a junction to board thermal resistance.
Use the value obtained by the equation (TJ – TT)/PD where TT is the temperature of the package
case determined by a thermocouple.
39
The thermal characterization parameter is measured per JESD51-2 specification using a 40-gauge type T
thermocouple epoxied to the top center of the package case. The thermocouple should be positioned so that
the thermocouple junction rests on the package. A small amount of epoxy is placed over the thermocouple
junction and over about 1mm of wire extending from the junction. The thermocouple wire is placed flat
against the package case to avoid measurement errors caused by cooling effects of the thermocouple wire.
When heat sink is used, the junction temperature is determined from a thermocouple inserted at the interface
between the case of the package and the interface material. A clearance slot or hole is normally required in
the heat sink. Minimizing the size of the clearance is important to minimize the change in thermal
performance caused by removing part of the thermal interface to the heat sink. Because of the experimental
difficulties with this technique, many engineers measure the heat sink temperature and then back-calculate
the case temperature using a separate measurement of the thermal resistance of the interface. From this case
temperature, the junction temperature is determined from the junction-to-case thermal resistance.
5.2 Electrical Design Considerations
CAUTION
Use the following list of considerations to assure correct operation:
40
Provide a low-impedance path from the board power supply to each VDD pin on the hybrid
controller, and from the board ground to each VSS (GND) pin.
The minimum bypass requirement is to place 0.1 µF capacitors positioned as close as possible to
the package supply pins. The recommended bypass configuration is to place one bypass capacitor
on each of the ten VDD/VSS pairs, including VDDA/VSSA. Ceramic and tantalum capacitors tend to
provide better performance tolerances.
Ensure that capacitor leads and associated printed circuit traces that connect to the chip VDD and
VSS (GND) pins are less than 0.5 inch per capacitor lead.
Bypass the VDD and VSS layers of the PCB with approximately 100 µF, preferably with a highgrade capacitor such as a tantalum capacitor.
Because the controller’s output signals have fast rise and fall times, PCB trace lengths should be
minimal.
Consider all device loads as well as parasitic capacitance due to PCB traces when calculating
capacitance. This is especially critical in systems with higher capacitive loads that could create
higher transient currents in the VDD and GND circuits.
Take special care to minimize noise levels on the VREF, VDDA and VSSA pins.
Designs that utilize the TRST pin for JTAG port or OnCE module functionality (such as
development or debugging systems) should allow a means to assert TRST whenever RESET is
asserted, as well as a means to assert TRST independently of RESET. TRST must be asserted at
power up for proper operation. Designs that do not require debugging functionality, such as
consumer products, TRST should be tied low.
Because the Flash memory is programmed through the JTAG/OnCE port, designers should provide
an interface to this port to allow in-circuit Flash programming.
41
Part 6 Ordering Information
Table 31 lists the pertinent information needed to place an order. Consult a Motorola Semiconductor sales
office or authorized distributor to determine availability and to order parts.
Table 31. DSP56F801 Ordering Information
42
Part
Supply
Voltage
56F801
3.0–3.6 V
56F801
3.0–3.6 V
Pin
Count
Frequency
(MHz)
Order Number
Low Profile Plastic Quad Flat Pack
(LQFP)
48
80
DSP56F801FA80
(LQFP)
48
60
DSP56F801FA60
Package Type
43
HOW TO REACH US:
USA/EUROPE/LOCATIONS NOT LISTED:
P.O. Box 5405, Denver, Colorado 80217
1-800-521-6274 or 480-768-2130
JAPAN:
Motorola Japan Ltd.
SPS, Technical Information Center
3-20-1, Minami-Azabu
Minato-ku
Tokyo 106-8573, Japan
81-3-3440-3569
ASIA/PACIFIC:
Motorola Semiconductors H.K. Ltd.
Silicon Harbour Centre
2 Dai King Street
Tai Po Industrial Estate
Tai Po, N.T. Hong Kong
852-26668334
HOME PAGE:
http://motorola.com/semiconductors
Information in this document is provided solely to enable system and software
implementers to use Motorola products. There are no express or implied copyright
licenses granted hereunder to design or fabricate any integrated circuits or
integrated circuits based on the information in this document.
Motorola reserves the right to make changes without further notice to any products
herein. Motorola makes no warranty, representation or guarantee regarding the
suitability of its products for any particular purpose, nor does Motorola assume any
liability arising out of the application or use of any product or circuit, and specifically
disclaims any and all liability, including without limitation consequential or incidental
damages. “Typical” parameters which may be provided in Motorola data sheets
and/or specifications can and do vary in different applications and actual
performance may vary over time. All operating parameters, including “Typicals”
must be validated for each customer application by customer’s technical experts.
Motorola does not convey any license under its patent rights nor the rights of
others. Motorola products are not designed, intended, or authorized for use as
components in systems intended for surgical implant into the body, or other
applications intended to support or sustain life, or for any other application in which
the failure of the Motorola product could create a situation where personal injury or
death may occur. Should Buyer purchase or use Motorola products for any such
unintended or unauthorized application, Buyer shall indemnify and hold Motorola
and its officers, employees, subsidiaries, affiliates, and distributors harmless
against all claims, costs, damages, and expenses, and reasonable attorney fees
arising out of, directly or indirectly, any claim of personal injury or death associated
with such unintended or unauthorized use, even if such claim alleges that Motorola
was negligent regarding the design or manufacture of the part.
Motorola and the Stylized M Logo are registered in the U.S. Patent and Trademark
Office. digital dna is a trademark of Motorola, Inc. All other product or service
names are the property of their respective owners. Motorola, Inc. is an Equal
Opportunity/Affirmative Action Employer.
© Motorola, Inc. 2004
DSP56F801/D
